Using regmap apis for accessing the device registers and
using RBTREE caching mechanims for caching registers.
Enabling caching of the registers which is used for voltage
controls. By doing this, the modify_bits operation is faster as
it does not involve the i2c register read from device, just read
from cache. This results faster set voltage operation.
Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
cherry picked from mainline commit
0e7018c7b161dc5544f7af862dc59e0b9a0dbd20
Change-Id: Ie0bc1fd32f1c7f7b80004b30ec9ba615d4c29360
Reviewed-on: http://git-master/r/86349
irq_base of the tps65910 irq platform data should be
initialized with the board provided irq_base data.
commit e2aaed2403078ce919d9cf8091ec0ece8e3f12ad
Change-Id: I9861b612feb85d9b53095d221f09e3059b3b1371
Reviewed-on: http://git-master/r/85125
TPS65910 can be used without interrupts.
Hence let probe succeed in case interrupt can't be
configured and let Kernel only to complain about it
Signed-off-by: Afzal Mohammed <afzal@ti.com>
cherry picked from mainline's commit
1e351a95b6fda20e16b64a698bae505765080308
Change-Id: Ib619d906f0cc9668c08e156d85eb940f29945771
Reviewed-on: http://git-master/r/77529
The function is not actually cleaing the bitmask.
Signed-off-by: Marcus Folkesson <marcus.folkesson@gmail.com>
cherry picked from mainline's commit:
8f6a459a9daa6ce76d7c192f2cb3047fffb45ec8
Change-Id: I53d59ba72ecca513ef4b1ad265d578e493007660
Reviewed-on: http://git-master/r/77528
In drivers/mfd/tps65910.c:tps65910_i2c_probe() there's potential for a
tiny optimization.
We assign to init_data->irq and init_data->irq_base long before we
need them, and there are two potential exits from the function before
they are needed.
Moving the assignments below these two potential exits means we
completely avoid doing them in these two (failure) cases.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
Acked-by: Graeme Gregory <gg@slimlogic.co.uk>
There are a couple of situations where we leak init_data in
drivers/mfd/tps65910.c:tps65910_i2c_probe() - this patch should take
care of them.
The tps65910_irq_exit() cleanup function was generating a warning from
sparse due to the lack of a prototype. This wasn't causing GCC warnings
as the driver wasn't cleaning up its IRQs on exit at all so there was no
use of an unprototyped function.
The TPS65911 is the next generation of the TPS65910 family of
PMIC chips. It adds a few features:
- Watchdog Timer
- PWM & LED generators
- Comparators for system control status
It also adds a set of Interrupts and GPIOs, among other things.
The driver exports a function to identify between different
versions of the tps65910 family, allowing other modules to
identify the capabilities of the current chip.
Signed-off-by: Jorge Eduardo Candelaria <jedu@slimlogic.co.uk>
Acked-by: Samuel Ortiz <sameo@linux.intel.com>
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
If bytes == (TPS65910_MAX_REGISTER + 1), we have a buffer overflow when
doing memcpy(&msg[1], src, bytes).
This module controls the interrupt handling for the tps chip. The
interrupt sources are the following:
- GPIO falling/rising edge detection
- Battery voltage below/above threshold
- PWRON signal
- PWRHOLD signal
- Temperature detection
- RTC alarm and periodic event
Signed-off-by: Graeme Gregory <gg@slimlogic.co.uk>
TPS65910 has one configurable GPIO that can be used for several
purposes. Subsequent versions of the TPS chip support more than
one GPIO.
The TPS65910 chip is a power management IC for multimedia and handheld
devices. It contains the following components:
- Regulators
- GPIO controller
- RTC
The tps65910 core driver is registered as a platform driver and provides
communication through I2C with the host device for the different
components.
