path: root/drivers/mfd/twl4030-power.c
2015-06-22mfd: twl4030-power: Fix pmic for boards that need AC charger disabledTony Lindgren
I noticed the PMIC configuration on 37xx-evm won't actually shut down the voltages during off-idle. Turns out 37xx-evm needs the AC charger state transitions disabled like we are doing for SDP and LDP in the legacy booting case. Let's fix this for device tree based booting by setting up the quirk flag based on the compatible flag. And let's also use the existing define for STARTON_CHG. Note that SDP and EVM do not have the PMIC clken wired to gate the the oscillator while LDP has. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2015-03-26mfd: Constify of_device_id arrayFabian Frederick
of_device_id is always used as const. (See driver.of_match_table and open firmware functions) Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-12-14Merge tag 'driver-core-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core update from Greg KH: "Here's the set of driver core patches for 3.19-rc1. They are dominated by the removal of the .owner field in platform drivers. They touch a lot of files, but they are "simple" changes, just removing a line in a structure. Other than that, a few minor driver core and debugfs changes. There are some ath9k patches coming in through this tree that have been acked by the wireless maintainers as they relied on the debugfs changes. Everything has been in linux-next for a while" * tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits) Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries" fs: debugfs: add forward declaration for struct device type firmware class: Deletion of an unnecessary check before the function call "vunmap" firmware loader: fix hung task warning dump devcoredump: provide a one-way disable function device: Add dev_<level>_once variants ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries ath: use seq_file api for ath9k debugfs files debugfs: add helper function to create device related seq_file drivers/base: cacheinfo: remove noisy error boot message Revert "core: platform: add warning if driver has no owner" drivers: base: support cpu cache information interface to userspace via sysfs drivers: base: add cpu_device_create to support per-cpu devices topology: replace custom attribute macros with standard DEVICE_ATTR* cpumask: factor out show_cpumap into separate helper function driver core: Fix unbalanced device reference in drivers_probe driver core: fix race with userland in device_add() sysfs/kernfs: make read requests on pre-alloc files use the buffer. sysfs/kernfs: allow attributes to request write buffer be pre-allocated. fs: sysfs: return EGBIG on write if offset is larger than file size ...
2014-12-08Merge tag 'mfd-for-linus-3.19' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd Pull MFD updates from Lee Jones: "Changes to the core: - Honour PLATFORM_DEVID_NONE and PLATFORM_DEVID_AUTO dev IDs Changes to existing drivers: - IRQ additions/fixes; axp20x, da9063-core - Code simplification; i2c-dln2 - Regmap additions/fixes; max77693 - Error checking/handling improvements; dln2, db8500-prcmu - Bug fixes; dln2, wm8350-core - DT support/documentation; max77693, max77686, tps65217, twl4030-power, gpio-tc3589x - Decouple syscon interface from platform devices - Use MFD hotplug registration; rtsx_usb, viperboard, hid-sensor-hub - Regulator fixups; sec-core - Power Management additions/fixes; rts5227, tc6393xb - Remove relic/redundant code; ab8500-sysctrl, lpc_sch, max77693-private - Clean-up/coding style changes; tps65090 - Clk additions/fixes; tc6393xb, tc6387xb, t7l66xb - Add USB-SPI support; dln2 - Trivial changes; max14577, arizona-spi, lpc_sch, wm8997-tables, wm5102-tables wm5110-tables, axp20x, atmel-hlcdc, rtsx_pci New drivers/supported devices: - axp288 PMIC support added to axp20x - s2mps13 support added to sec-core - New support for Diolan DLN-2 - New support for atmel-hlcdc" * tag 'mfd-for-linus-3.19' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (55 commits) mfd: rtsx: Add func to split u32 into register mfd: atmel-hlcdc: Add Kconfig option description and name mfd: da9063: Get irq base dynamically before registering device mfd: max14577: Fix obvious typo in company name in copyright mfd: axp20x: Constify axp20x_acpi_match and rid unused warning mfd: t7l66xb: prepare/unprepare clocks mfd: tc6387xb: prepare/unprepare clocks mfd: dln2: add support for USB-SPI module mfd: wm5110: Add missing registers for AIF2 channels 3-6 mfd: tc3589x: get rid of static base mfd: arizona: Document HP_CTRL_1L and HP_CTRL_1R registers mfd: wm8997: Mark INTERRUPT_STATUS_2_MASK as readable mfd: tc6393xb: Prepare/unprepare clocks mfd: tps65090: Fix bonkers indenting strategy mfd: tc6393xb: Fail ohci suspend if full state restore is required mfd: lpc_sch: Don't call mfd_remove_devices() mfd: wm8350-core: Fix probable mask then right shift defect mfd: ab8500-sysctrl: Drop ab8500_restart mfd: db8500-prcmu: Provide sane error path values mfd: db8500-prcmu: Check return of devm_ioremap for error ...
2014-11-25mfd: twl4030-power: Fix regression with missing compatible flagTony Lindgren
Commit e7cd1d1eb16f ("mfd: twl4030-power: Add generic reset configuration") accidentally removed the compatible flag for "ti,twl4030-power" that should be there as documented in the binding. If "ti,twl4030-power" only the poweroff configuration is done by the driver. Fixes: e7cd1d1eb16f ("mfd: twl4030-power: Add generic reset configuration") Cc: stable@vger.kernel.org # v3.16+ Reported-by: "Dr. H. Nikolaus Schaller" <hns@goldelico.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-11-10mfd: twl4030-power: Fix poweroff with PM configuration enabledTony Lindgren
Commit e7cd1d1eb16f ("mfd: twl4030-power: Add generic reset configuration") enabled configuring the PM features for twl4030. This caused poweroff command to fail on devices that have the BCI charger on twl4030 wired, or have power wired for VBUS. Instead of powering off, the device reboots. This is because voltage is detected on charger or VBUS with the default bits enabled for the power transition registers. To fix the issue, let's just clear VBUS and CHG bits as we want poweroff command to keep the system powered off. Fixes: e7cd1d1eb16f ("mfd: twl4030-power: Add generic reset configuration") Cc: stable@vger.kernel.org # v3.16+ Reported-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-10-20mfd: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-10-15Merge tag 'mfd-for-linus-3.18' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd Pull MFD updates from Lee Jones: "Changes to existing drivers: - DT clean-ups in da9055-core, max14577, rn5t618, arizona, hi6421, stmpe, twl4030 - Export symbols for use in modules in max14577 - Plenty of static code analysis/Coccinelle fixes throughout the SS - Regmap clean-ups in arizona, wm5102, wm5110, da9052, tps65217, rk808 - Remove unused/duplicate code in da9052, 88pm860x, ti_ssp, lpc_sch, arizona - Bug fixes in ti_am335x_tscadc, da9052, ti_am335x_tscadc, rtsx_pcr - IRQ fixups in arizona, stmpe, max14577 - Regulator related changes in axp20x - Pass DMA coherency information from parent => child in MFD core - Rename DT document files for consistency - Add ACPI support to the MFD core - Add Andreas Werner to MAINTAINERS for MEN F21BMC New drivers/supported devices: - New driver for MEN 14F021P00 Board Management Controller - New driver for Ricoh RN5T618 PMIC - New driver for Rockchip RK808 - New driver for HiSilicon Hi6421 PMIC - New driver for Qualcomm SPMI PMICs - Add support for Intel Braswell in lpc_ich - Add support for Intel 9 Series PCH in lpc_ich - Add support for Intel Quark ILB in lpc_sch" [ Delayed to after the poweer/reset pull due to Kconfig problems with recursive Kconfig select/depends-on chains. - Linus ] * tag 'mfd-for-linus-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (79 commits) mfd: cros_ec: wait for completion of commands that return IN_PROGRESS i2c: i2c-cros-ec-tunnel: Set retries to 3 mfd: cros_ec: move locking into cros_ec_cmd_xfer mfd: cros_ec: stop calling ->cmd_xfer() directly mfd: cros_ec: Delay for 50ms when we see EC_CMD_REBOOT_EC MAINTAINERS: Adds Andreas Werner to maintainers list for MEN F21BMC mfd: arizona: Correct mask to allow setting micbias external cap mfd: Add ACPI support Revert "mfd: wm5102: Manually apply register patch" mfd: ti_am335x_tscadc: Update logic in CTRL register for 5-wire TS mfd: dt-bindings: atmel-gpbr: Rename doc file to conform to naming convention mfd: dt-bindings: qcom-pm8xxx: Rename doc file to conform to naming convention mfd: Inherit coherent_dma_mask from parent device mfd: Document DT bindings for Qualcomm SPMI PMICs mfd: Add support for Qualcomm SPMI PMICs mfd: dt-bindings: pm8xxx: Add new compatible string mfd: axp209x: Drop the parent supplies field mfd: twl4030-power: Use 'ti,system-power-controller' as alternative way to support system power off mfd: dt-bindings: twl4030-power: Use the standard property to mark power control mfd: syscon: Add Atmel GPBR DT bindings documention ...
2014-09-26mfd: twl4030-power: Use 'ti,system-power-controller' as alternative way to ↵Nishanth Menon
support system power off ti,system-power-controller is more or less the standard way of indicating that the PMIC is the system wide power controller and hence may be used to switch off the system. Almost ALL TI PMIC drivers and many Maxim PMIC drivers follow the same style. So support 'ti,system-power-controller' in addition to the usual 'ti,use_poweroff' to indicate that the PMIC instance has control for switching off the system. Signed-off-by: Nishanth Menon <nm@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-08-28mfd: twl4030-power: Fix PM idle pin configuration to not conflict with ↵Tony Lindgren
regulators Commit 43fef47f94a1 (mfd: twl4030-power: Add a configuration to turn off oscillator during off-idle) added support for configuring the PMIC to cut off resources during deeper idle states to save power. This however caused regression for n900 display power that needed the PMIC configuration to be disabled with commit d937678ab625 (ARM: dts: Revert enabling of twl configuration for n900). Turns out the root cause of the problem is that we must use TWL4030_RESCONFIG_UNDEF instead of DEV_GRP_NULL to avoid disabling regulators that may have been enabled before the init function for twl4030-power.c runs. With TWL4030_RESCONFIG_UNDEF we let the regulator framework control the regulators like it should. Here we need to only configure the sys_clken and sys_off_mode triggers for the regulators that cannot be done by the regulator framework as it's not running at that point. This allows us to enable the PMIC configuration for n900. Fixes: 43fef47f94a1 (mfd: twl4030-power: Add a configuration to turn off oscillator during off-idle) Cc: stable@vger.kernel.org # v3.16 Signed-off-by: Tony Lindgren <tony@atomide.com> Tested-by: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-05-28mfd: twl4030-power: Add a configuration to turn off oscillator during off-idleTony Lindgren
Some oscillators can be turned off during off-idle saving few a little bit power at the cost of the oscillator start up latency. If you board can do this, you can now enable it by using the ti,twl4030-power-idle-osc-off compatible flag. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-05-28mfd: twl4030-power: Add support for board specific configurationTony Lindgren
With the recommended twl4030 configuration added, we can now add board specific changes as modifications to the recommended configuration. Note that the data is private to this driver, and the data must always have a NULL resource in the sentinel. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-05-28mfd: twl4030-power: Add recommended idle configurationTony Lindgren
These settings are based on the "Recommended Sleep Sequences for the Zoom Platform". The settings assume most of the regulators are under control of Linux, and twl4030 only cuts off VDD1 and VDD2 during off-idle as Linux cannot do it. For any board specific changes to these, let's patch them in as changes to the generic data in the follow-up patches. This keeps the board specific changes small. Note that this does not consider the twl5030 errata 27 and 28. That can be added later on after it has been tested. For more information about errata 27 and 28. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-05-28mfd: twl4030-power: Add generic reset configurationTony Lindgren
The twl4030 PMIC needs to be configured properly for things like warm reset and deeper idle states so the PMIC manages the regulators properly based on the hardware triggers from the SoC. Earlier we have configured twl4030 using platform data, but we want to do it for device tree based booting also. In some cases configuring twl4030 is needed for things to work. For example, when rebooting an OMAP3530 at 125 MHz, it hangs. With this patch, TWL4030 will be reset when a warm reset occures, and OMAP3530 does not hang on reboot. Let's add device tree support and configure things for warm reset as the default when compatible = "ti,twl4030-power". More complicated configurations can be added to the driver based on other compatible flags. Note we now also make the pdata const like it should be. This allows use it for match->data with the device tree related functions. Based on earlier patch by Matthias Brugger <matthias.bgg@gmail.com> and Lesly A M <leslyam@ti.com>. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-05-28mfd: twl4030-power: Fix some defines for SW_EVENTSTony Lindgren
We have these bits partially defined in two different places, so let's fix them up and add defines for the missing bits. These bits are the same for P1_SW_EVENTS, P2_SW_EVENTS and P3_SW_EVENTS. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-05-28mfd: twl4030-power: Fix hang on reboot if sleep configuration was loaded earlierTony Lindgren
Looks like we can still hit the issue of wrong load order of twl4030 configuration. If we have a sleep configuration loaded, and do a warm reset, the device can hang while initializing the wakeup12 sequence. We do have a warning message about wrong order of twl4030 configuration, but in this case it does not help as the sleep configuration was loaded during the previous boot and the state of twl4030 is maintained throughout the warm reset. Fix the issue by clearing any existing sleep configuration before we load the warm reset configuration. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2013-08-01mfd: twl4030-power: Staticize local functionsJingoo Han
twl4030_power_configure_scripts(), twl4030_power_configure_resources(), twl4030_power_probe() are used only in this file. Fix the following sparse warnings: drivers/mfd/twl4030-power.c:496:5: warning: symbol 'twl4030_power_configure_scripts' was not declared. Should it be static? drivers/mfd/twl4030-power.c:512:5: warning: symbol 'twl4030_power_configure_resources' was not declared. Should it be static? drivers/mfd/twl4030-power.c:556:5: warning: symbol 'twl4030_power_probe' was not declared. Should it be static? Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2013-07-31mfd: Use dev_get_platdata()Jingoo Han
Use the wrapper function for retrieving the platform data instead of accessing dev->platform_data directly. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2013-06-19mfd: twl4030-power: Fix relocking on errorFlorian Vaussard
If an error occurs when loading power scripts or resources, the registers are not correctly relocked. Fix it. Signed-off-by: Florian Vaussard <florian.vaussard@epfl.ch> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-06-19mfd: twl4030-power: Simplify error pathFlorian Vaussard
Remove unnecessary goto statements, causing duplicated if conditions. Signed-off-by: Florian Vaussard <florian.vaussard@epfl.ch> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-06-19mfd: twl4030-power: Start transition to DTFlorian Vaussard
Support for loading twl4030-power module via devicetree. For now, when booting with a DT, only the poweroff callback feature is supported through the ti,use_poweroff property. Signed-off-by: Florian Vaussard <florian.vaussard@epfl.ch> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-06-19mfd: twl4030-power: Simplify probing of power scripts and resourcesFlorian Vaussard
Increase lisibility when probing power scripts and resources by creating dedicated functions. Signed-off-by: Florian Vaussard <florian.vaussard@epfl.ch> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-06-19mfd: twl4030-power: Split from twl-core into a dedicated moduleFlorian Vaussard
For now, the call to twl4030-power is hard-wired inside twl-core. To ease the future transition to DT, make twl4030-power as a separate module, like what is already done for twl4030-audio and others. Signed-off-by: Florian Vaussard <florian.vaussard@epfl.ch> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-01-27mfd: twl4030: Don't warn about uninitialized return codeArnd Bergmann
If the twl4030_write_script function gets called with a zero length argument, its return value does not get set. We know that all scripts have a nonzero length, but returning an error in case they ever do is probably appropriate. Without this patch, building omap2plus_defconfig results in: drivers/mfd/twl4030-power.c: In function 'load_twl4030_script': drivers/mfd/twl4030-power.c:414:5: error: 'err' may be used uninitialized in this function Signed-off-by: Arnd Bergmann <arnd@arndb.de> Reviewed-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Reviewed-by: Amit Kucheria <amit.kucheria@linaro.org> Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: "Kristo, Tero" <t-kristo@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-12-16Merge tag 'mfd-3.8-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 Pull MFS update from Samuel Ortiz: "This is the MFD patch set for the 3.8 merge window. We have several new drivers, most of the time coming with their sub devices drivers: - Austria Microsystem's AS3711 - Nano River's viperboard - TI's TPS80031, AM335x TS/ADC, - Realtek's MMC/memstick card reader - Nokia's retu We also got some notable cleanups and improvements: - tps6586x got converted to IRQ domains. - tps65910 and tps65090 moved to the regmap IRQ API. - STMPE is now Device Tree aware. - A general twl6040 and twl-core cleanup, with moves to the regmap I/O and IRQ APIs and a conversion to the recently added PWM framework. - sta2x11 gained regmap support. Then the rest is mostly tiny cleanups and fixes, among which we have Mark's wm5xxx and wm8xxx patchset." Far amount of annoying but largely trivial conflicts. Many due to __devinit/exit removal, others due to one or two of the new drivers also having come in through another tree. * tag 'mfd-3.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (119 commits) mfd: tps6507x: Convert to devm_kzalloc mfd: stmpe: Update DT support for stmpe driver mfd: wm5102: Add readback of DSP status 3 register mfd: arizona: Log if we fail to create the primary IRQ domain mfd: tps80031: MFD_TPS80031 needs to select REGMAP_IRQ mfd: tps80031: Add terminating entry for tps80031_id_table mfd: sta2x11: Fix potential NULL pointer dereference in __sta2x11_mfd_mask() mfd: wm5102: Add tuning for revision B mfd: arizona: Defer patch initialistation until after first device boot mfd: tps65910: Fix wrong ack_base register mfd: tps65910: Remove unused data mfd: stmpe: Get rid of irq_invert_polarity mfd: ab8500-core: Fix invalid free of devm_ allocated data mfd: wm5102: Mark DSP memory regions as volatile mfd: wm5102: Correct default for LDO1_CONTROL_2 mfd: arizona: Register haptics devices mfd: wm8994: Make current device behaviour the default mfd: tps65090: MFD_TPS65090 needs to select REGMAP_IRQ mfd: Fix stmpe.c build when OF is not enabled mfd: jz4740-adc: Use devm_kzalloc ...
2012-11-28mfd: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Daniel Walker <dwalker@fifo99.com> Cc: Bryan Huntsman <bryanh@codeaurora.org> Acked-by: David Brown <davidb@codeaurora.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21mfd: twl4030-power: Change TWL4030_MODULE_* ids to TWL_MODULE_*Peter Ujfalusi
To facilitate upcoming cleanup in twl stack. No functional changes. Acked-by: Tero Kristo <t-kristo@ti.com> Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-02-13ARM: omap: fix section mismatch errors in TWL PMIC driverRussell King
WARNING: drivers/mfd/built-in.o(.devinit.text+0x258): Section mismatch in reference from the function twl_probe() to the function .init.text:twl4030_power_init() The function __devinit twl_probe() references a function __init twl4030_power_init(). If twl4030_power_init is only used by twl_probe then annotate twl4030_power_init with a matching annotation. twl4030_power_init() references other __init marked functions, so these too must become __devinit. Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-01-09mfd: Add power off functionality to TWLIgor Grinberg
TWL family of PMICs, used in master mode, have a power off functionality. The resulting power off sequence shuts down all the SoC supplies, LDOs, etc. The sequence is described in the datasheets chapter "Power-Off Sequence". Note, that board must be wired correctly for the power off to work as expected. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-26mfd: Check twl4030-power remove script error condition after i2cwriteLesly A M
Fixing the error condition check in twl4030 remove script function. Due to some typo in commit ID: 11a441ce82d6ffecfd39b324024de0cd630b36c1 Signed-off-by: Lesly A M <leslyam@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-26mfd: Modifying the twl4030-power macro name Main_Ref to all capsLesly A M
Modifying the macro name Main_Ref to all caps(MAIN_REF). Suggested by Nishanth Menon <nm@ti.com> Signed-off-by: Lesly A M <leslyam@ti.com> Cc: Nishanth Menon <nm@ti.com> Cc: David Derrick <dderrick@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-26mfd: Correct the twl4030-power warning print during script loadingLesly A M
Correcting the if condition check for printing the warning, if wakeup script is not updated before updating the sleep script. Since the flag 'order' is set to '1' while updating the wakeup script for P1P2, the condition checking for printing the warning should be if(!order) (ie: print the warning if wakeup script is not updated before updating the sleep script) Signed-off-by: Lesly A M <leslyam@ti.com> Cc: Nishanth Menon <nm@ti.com> Cc: David Derrick <dderrick@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-11mfd: Fix for the TWL4030 PM sleep/wakeup sequenceLesly A M
Only configure sleep script when the flag is TWL4030_SLEEP_SCRIPT. Adding the missing brackets for fixing the issue. Signed-off-by: Lesly A M <leslyam@ti.com> Cc: Nishanth Menon <nm@ti.com> Cc: David Derrick <dderrick@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Switch twl4030-power over to defines in twl.hFelipe Balbi
use the new definitions on twl header for code consistency. Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-03-07mfd: Introduce remove_script function for twl4030Mike Turquette
New function twl4030_remove_script(u8 flags) takes a script type as defined in twl.h and prevents any script already loaded in that position from running. This is accomplished by programming SEQ_ADD_* to 0x3f, the END_OF_SCRIPT value, where SEQ_ADD_* is determined by flags. (Future) users of this function include OMAP board files for machines facing a race condition between sleep and warm reset. Signed-off-by: Mike Turquette <mturquette@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-03-07mfd: Program twl4030 remap_sleep correctlyMike Turquette
Variable remap was incorrectly referencing remap_off for the remap_sleep case when configuring TWL4030 power scripts. Signed-off-by: Mike Turquette <mturquette@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-12-13mfd: Rename all twl4030_i2c*Balaji T K
This patch renames function names like twl4030_i2c_write_u8, twl4030_i2c_read_u8 to twl_i2c_write_u8, twl_i2c_read_u8 and also common variable in twl-core.c Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Balaji T K <balajitk@ti.com> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Acked-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-12-13mfd: Rename twl4030* driver files to enable re-useSantosh Shilimkar
The upcoming TWL6030 is companion chip for OMAP4 like the current TWL4030 for OMAP3. The common modules like RTC, Regulator creates opportunity to re-use the most of the code from twl4030. This patch renames few common drivers twl4030* files to twl* to enable the code re-use. Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Balaji T K <balajitk@ti.com> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Acked-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-12-13mfd: Fix more undefined twl4030-power resconfig value checksAmit Kucheria
Based on Aaro's previous fix, this needs to be fixed for the newly added remap_off and remap_sleep resources as well. The code tries to skip values initialized with -1, but since the values are unsigned the comparison is always true. The patch eliminates the following compiler warnings: drivers/mfd/twl4030-power.c: In function 'twl4030_configure_resource': drivers/mfd/twl4030-power.c:338: warning: comparison is always true due to limited range of data type Signed-off-by: Amit Kucheria <amit.kucheria@verdurent.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-12-13mfd: fix undefined twl4030-power resconfig value checksAaro Koskinen
The code tries to skip values initialized with -1, but since the values are unsigned the comparison is always true. The patch eliminates the following compiler warnings: drivers/mfd/twl4030-power.c: In function 'twl4030_configure_resource': drivers/mfd/twl4030-power.c:338: warning: comparison is always true due to limited range of data type drivers/mfd/twl4030-power.c:358: warning: comparison is always true due to limited range of data type drivers/mfd/twl4030-power.c:363: warning: comparison is always true due to limited range of data type Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-12-13mfd: Add support for remapping twl4030-power power statesAmit Kucheria
The <RESOURCE>_REMAP register allows configuration of the <RESOURCE> in case of a sleep or off transition. Allow this property of resources to be configured (through twl4030_resconfig) and add code to parse these values to program the registers accordingly. Signed-off-by: Amit Kucheria <amit.kucheria@verdurent.com> Cc: linux-omap@vger.kernel.org Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-12-13mfd: Add comments for the twl4030-power register and bit layoutAmit Kucheria
Describe how the resource registers are laid out and the various bit-fields in them. Signed-off-by: Amit Kucheria <amit.kucheria@verdurent.com> Cc: linux-omap@vger.kernel.org Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-12-13mfd: twl4030-power: Rename DEVGROUP to DEV_GRPAmit Kucheria
Stick to the names used in the reference manual Signed-off-by: Amit Kucheria <amit.kucheria@verdurent.com> Cc: linux-omap@vger.kernel.org Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-09-17mfd: Fix twl4030-power warningsSamuel Ortiz
KEY_1 and KEY_2 definitions conflicts with include/linux/input.h Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-09-17mfd: Print warning for twl4030 out-of-order script loadingAmit Kucheria
When the sleep script is loaded before the wakeup script, there is a chance that the system might go to sleep before the wakeup script loading is completed. This will lead to a system that does not wakeup and has been observed to cause non-booting boards. Various options were considered to solve this problem, including modification of the core twl4030 power code to be smart enough to reorder the loading of the scripts. But it felt too over-engineered. Hence this patch just warns the DPS script developer so that they may be reordered in the board-code itself. Signed-off-by: Amit Kucheria <amit.kucheria@verdurent.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-09-17mfd: Add support for TWL4030/5030 dynamic power switchingAmit Kucheria
The TWL4030/5030 family of multifunction devices allows board-specific control of the the various regulators, clock and reset lines through 'scripts' that are loaded into its memory. This allows for Dynamic Power Switching (DPS). Implement board-independent core support for DPS that is then used by board-specific code to load custom DPS scripts. Signed-off-by: Amit Kucheria <amit.kucheria@verdurent.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
