path: root/drivers/mfd/twl4030-power.c
2011-05-26mfd: Check twl4030-power remove script error condition after i2cwriteLesly A M
Fixing the error condition check in twl4030 remove script function. Due to some typo in commit ID: 11a441ce82d6ffecfd39b324024de0cd630b36c1 Signed-off-by: Lesly A M <leslyam@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-26mfd: Modifying the twl4030-power macro name Main_Ref to all capsLesly A M
Modifying the macro name Main_Ref to all caps(MAIN_REF). Suggested by Nishanth Menon <nm@ti.com> Signed-off-by: Lesly A M <leslyam@ti.com> Cc: Nishanth Menon <nm@ti.com> Cc: David Derrick <dderrick@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-26mfd: Correct the twl4030-power warning print during script loadingLesly A M
Correcting the if condition check for printing the warning, if wakeup script is not updated before updating the sleep script. Since the flag 'order' is set to '1' while updating the wakeup script for P1P2, the condition checking for printing the warning should be if(!order) (ie: print the warning if wakeup script is not updated before updating the sleep script) Signed-off-by: Lesly A M <leslyam@ti.com> Cc: Nishanth Menon <nm@ti.com> Cc: David Derrick <dderrick@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-11mfd: Fix for the TWL4030 PM sleep/wakeup sequenceLesly A M
Only configure sleep script when the flag is TWL4030_SLEEP_SCRIPT. Adding the missing brackets for fixing the issue. Signed-off-by: Lesly A M <leslyam@ti.com> Cc: Nishanth Menon <nm@ti.com> Cc: David Derrick <dderrick@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Switch twl4030-power over to defines in twl.hFelipe Balbi
use the new definitions on twl header for code consistency. Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-03-07mfd: Introduce remove_script function for twl4030Mike Turquette
New function twl4030_remove_script(u8 flags) takes a script type as defined in twl.h and prevents any script already loaded in that position from running. This is accomplished by programming SEQ_ADD_* to 0x3f, the END_OF_SCRIPT value, where SEQ_ADD_* is determined by flags. (Future) users of this function include OMAP board files for machines facing a race condition between sleep and warm reset. Signed-off-by: Mike Turquette <mturquette@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-03-07mfd: Program twl4030 remap_sleep correctlyMike Turquette
Variable remap was incorrectly referencing remap_off for the remap_sleep case when configuring TWL4030 power scripts. Signed-off-by: Mike Turquette <mturquette@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-12-13mfd: Rename all twl4030_i2c*Balaji T K
This patch renames function names like twl4030_i2c_write_u8, twl4030_i2c_read_u8 to twl_i2c_write_u8, twl_i2c_read_u8 and also common variable in twl-core.c Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Balaji T K <balajitk@ti.com> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Acked-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-12-13mfd: Rename twl4030* driver files to enable re-useSantosh Shilimkar
The upcoming TWL6030 is companion chip for OMAP4 like the current TWL4030 for OMAP3. The common modules like RTC, Regulator creates opportunity to re-use the most of the code from twl4030. This patch renames few common drivers twl4030* files to twl* to enable the code re-use. Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Balaji T K <balajitk@ti.com> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Acked-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-12-13mfd: Fix more undefined twl4030-power resconfig value checksAmit Kucheria
Based on Aaro's previous fix, this needs to be fixed for the newly added remap_off and remap_sleep resources as well. The code tries to skip values initialized with -1, but since the values are unsigned the comparison is always true. The patch eliminates the following compiler warnings: drivers/mfd/twl4030-power.c: In function 'twl4030_configure_resource': drivers/mfd/twl4030-power.c:338: warning: comparison is always true due to limited range of data type Signed-off-by: Amit Kucheria <amit.kucheria@verdurent.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-12-13mfd: fix undefined twl4030-power resconfig value checksAaro Koskinen
The code tries to skip values initialized with -1, but since the values are unsigned the comparison is always true. The patch eliminates the following compiler warnings: drivers/mfd/twl4030-power.c: In function 'twl4030_configure_resource': drivers/mfd/twl4030-power.c:338: warning: comparison is always true due to limited range of data type drivers/mfd/twl4030-power.c:358: warning: comparison is always true due to limited range of data type drivers/mfd/twl4030-power.c:363: warning: comparison is always true due to limited range of data type Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-12-13mfd: Add support for remapping twl4030-power power statesAmit Kucheria
The <RESOURCE>_REMAP register allows configuration of the <RESOURCE> in case of a sleep or off transition. Allow this property of resources to be configured (through twl4030_resconfig) and add code to parse these values to program the registers accordingly. Signed-off-by: Amit Kucheria <amit.kucheria@verdurent.com> Cc: linux-omap@vger.kernel.org Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-12-13mfd: Add comments for the twl4030-power register and bit layoutAmit Kucheria
Describe how the resource registers are laid out and the various bit-fields in them. Signed-off-by: Amit Kucheria <amit.kucheria@verdurent.com> Cc: linux-omap@vger.kernel.org Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-12-13mfd: twl4030-power: Rename DEVGROUP to DEV_GRPAmit Kucheria
Stick to the names used in the reference manual Signed-off-by: Amit Kucheria <amit.kucheria@verdurent.com> Cc: linux-omap@vger.kernel.org Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-09-17mfd: Fix twl4030-power warningsSamuel Ortiz
KEY_1 and KEY_2 definitions conflicts with include/linux/input.h Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-09-17mfd: Print warning for twl4030 out-of-order script loadingAmit Kucheria
When the sleep script is loaded before the wakeup script, there is a chance that the system might go to sleep before the wakeup script loading is completed. This will lead to a system that does not wakeup and has been observed to cause non-booting boards. Various options were considered to solve this problem, including modification of the core twl4030 power code to be smart enough to reorder the loading of the scripts. But it felt too over-engineered. Hence this patch just warns the DPS script developer so that they may be reordered in the board-code itself. Signed-off-by: Amit Kucheria <amit.kucheria@verdurent.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-09-17mfd: Add support for TWL4030/5030 dynamic power switchingAmit Kucheria
The TWL4030/5030 family of multifunction devices allows board-specific control of the the various regulators, clock and reset lines through 'scripts' that are loaded into its memory. This allows for Dynamic Power Switching (DPS). Implement board-independent core support for DPS that is then used by board-specific code to load custom DPS scripts. Signed-off-by: Amit Kucheria <amit.kucheria@verdurent.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
