path: root/drivers/mfd/ucb1x00-ts.c
2011-03-23mfd: Add BTN_TOUCH event to ucb1x00-tsJochen Friedrich
Add BTN_TOUCH event reporting to ucb1x00_ts touchscreen driver. This will make this touchscreen driver behave consistently wrt. BTN_TOUCH. Signed-off-by: Jochen Friedrich <jochen@scram.de> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-03-02mfd: Fix NULL pointer due to non-initialized ucb1x00-ts absinfoJochen Friedrich
Call input_set_abs_params instead of manually setting absbit only. This fixes this oops: Unable to handle kernel NULL pointer dereference at virtual address 00000024 Internal error: Oops: 41b67017 [#1] CPU: 0 Not tainted (2.6.37 #4) pc : [<c016d1fc>] lr : [<00000000>] psr: 20000093 sp : c19e5f30 ip : c19e5e6c fp : c19e5f58 r10: 00000000 r9 : c19e4000 r8 : 00000003 r7 : 000001e4 r6 : 00000001 r5 : c1854400 r4 : 00000003 r3 : 00000018 r2 : 00000018 r1 : 00000018 r0 : c185447c Flags: nzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment kernel Control: c1b6717f Table: c1b6717f DAC: 00000017 Stack: (0xc19e5f30 to 0xc19e6000) 5f20: 00000003 00000003 c1854400 00000013 5f40: 00000001 000001e4 000001c5 c19e5f80 c19e5f5c c016d5e8 c016cf5c 000001e4 5f60: c1854400 c18b5860 00000000 00000171 000001e4 c19e5fc4 c19e5f84 c01559a4 5f80: c016d584 c18b5868 00000000 c1bb5c40 c0035afc c18b5868 c18b5868 c1a55d54 5fa0: c18b5860 c0155750 00000013 00000000 00000000 00000000 c19e5ff4 c19e5fc8 5fc0: c0050174 c015575c 00000000 c18b5860 00000000 c19e5fd4 c19e5fd4 c1a55d54 5fe0: c00500f0 c003b464 00000000 c19e5ff8 c003b464 c00500fc 04000400 04000400 Backtrace: Function entered at [<c016cf50>] from [<c016d5e8>] Function entered at [<c016d578>] from [<c01559a4>] r8:000001e4 r7:00000171 r6:00000000 r5:c18b5860 r4:c1854400 Function entered at [<c0155750>] from [<c0050174>] Function entered at [<c00500f0>] from [<c003b464>] r6:c003b464 r5:c00500f0 r4:c1a55d54 Code: e59520fc e1a03286 e0433186 e0822003 (e592000c) >>PC; c016d1fc <input_handle_event+2ac/5a0> <===== Trace; c016cf50 <input_handle_event+0/5a0> Trace; c016d5e8 <input_event+70/88> Trace; c016d578 <input_event+0/88> Trace; c01559a4 <ucb1x00_thread+254/2dc> Trace; c0155750 <ucb1x00_thread+0/2dc> Trace; c0050174 <kthread+84/8c> Trace; c00500f0 <kthread+0/8c> Trace; c003b464 <do_exit+0/624> Signed-off-by: Jochen Friedrich <jochen@scram.de> CC: stable@kernel.org Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-11-27move drivers/mfd/*.h to include/linux/mfdThomas Kunze
So drivers like collie_battery driver can use those files easier.
2008-11-29[ARM] Hide ISA DMA API when ISA_DMA_API is unsetRussell King
When ISA_DMA_API is unset, we're not implementing the ISA DMA API, so there's no point in publishing the prototypes via asm/dma.h, nor including the machine dependent parts of that API. This allows us to remove a lot of mach/dma.h files which don't contain any useful code. Unfortunately though, some platforms put their own private non-ISA definitions into mach/dma.h, so we leave these behind and fix the appropriate #include statments. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-28mfd: use shorter set_current_state()Robert P. J. Day
Since this routine declares a separate "tsk" pointer for no other reason than to call set_task_state(), get rid of it and just invoke set_current_state(). Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Nicolas Pitre <nico@cam.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-18drivers: Remove unnecessary inclusions of asm/semaphore.hMatthew Wilcox
None of these files use any of the functionality promised by asm/semaphore.h. It's possible that they rely on it dragging in some unrelated header file, but I can't build all these files, so we'll have fix any build failures as they come up. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2007-07-17Freezer: make kernel threads nonfreezable by defaultRafael J. Wysocki
Currently, the freezer treats all tasks as freezable, except for the kernel threads that explicitly set the PF_NOFREEZE flag for themselves. This approach is problematic, since it requires every kernel thread to either set PF_NOFREEZE explicitly, or call try_to_freeze(), even if it doesn't care for the freezing of tasks at all. It seems better to only require the kernel threads that want to or need to be frozen to use some freezer-related code and to remove any freezer-related code from the other (nonfreezable) kernel threads, which is done in this patch. The patch causes all kernel threads to be nonfreezable by default (ie. to have PF_NOFREEZE set by default) and introduces the set_freezable() function that should be called by the freezable kernel threads in order to unset PF_NOFREEZE. It also makes all of the currently freezable kernel threads call set_freezable(), so it shouldn't cause any (intentional) change of behaviour to appear. Additionally, it updates documentation to describe the freezing of tasks more accurately. [akpm@linux-foundation.org: build fixes] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Nigel Cunningham <nigel@nigel.suspend2.net> Cc: Pavel Machek <pavel@ucw.cz> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Gautham R Shenoy <ego@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: reduce raciness when input handlers disconnect Input: ucb1x00 - do not access input_dev->private directly Input: logips2pp - fix typo in Kconfig Input: db9 - do not ignore dev2 module parameter
2007-06-03Input: ucb1x00 - do not access input_dev->private directlyDmitry Torokhov
Use input_get_drvdata() and input_set_drvdata() helpers to do that. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Acked-by: Pavel Machek <pavel@ucw.cz>
2007-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: ads7846 - SPI_CPHA mode bugfix Input: ads7846 - document that it handles tsc2046 too Input: input-polldev - add module info Input: ucb1x00-ts - remove commented out code Input: ucb1400_ts - use sched_setscheduler() Input: ALPS - force stream mode Input: iforce - minor clean-ups Input: iforce - fix force feedback not working Input: adbhid - do not access input_dev->private directly Input: logips2pp - add type 72 (PS/2 TrackMan Marble)
2007-05-22Input: ucb1x00-ts - remove commented out codeDmitry Torokhov
2006-12-07[PATCH] Add include/linux/freezer.h and move definitions from sched.hNigel Cunningham
Move process freezing functions from include/linux/sched.h to freezer.h, so that modifications to the freezer or the kernel configuration don't require recompiling just about everything. [akpm@osdl.org: fix ueagle driver] Signed-off-by: Nigel Cunningham <nigel@suspend2.net> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] ucb1x00-ts: handle errors from input_register_device()Dmitry Torokhov
ucb1x00-ts: handle errors from input_register_device() Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] drivers/mfd: header included twiceNicolas Kaiser
linux/delay.h included twice Signed-off-by: Nicolas Kaiser <nikai@nikai.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-12[PATCH] input: fix ucb1x00-ts breakage after conversion to dynamic input_dev ↵Nicolas Pitre
allocation The bd622663192e8ebebb27dc1d9397f352a82d2495 commit broke the UCB1x00 touchscreen driver since the idev structure was assumed to be into the ts structure, simply casting the former to the later in a couple places. This patch fixes those, and also cache the idev pointer between multiple calls to input_report_abs() to avoid growing the compiled code needlessly. Signed-off-by: Nicolas Pitre <nico@cam.org> Cc: Dmitry Torokhov <dtor_core@ameritech.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[ARM] Sharp sl-5500 touchscreen supportPavel Machek
This adds support for sharp zaurus sl-5500 touchscreen. It introduces some not-too-nice ifs, but I guess copying whole ucb1x00-ts.c would be bad idea... Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-28[PATCH] Input: convert ucb1x00-ts to dynamic input_dev allocationDmitry Torokhov
Input: convert ucb1x00-ts to dynamic input_dev allocation This is required for input_dev sysfs integration Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-24[MFD] Fix "bious one-bit signed bitfield" errorsRussell King
ucb1x00-ts declared a couple of one-bit 'int' bitfields. Make them unsigned. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-11[MFD] Cleanups suggested by Dmitri, Vojtech and lists.Pavel Machek
These are small ucb1x00-ts cleanups, as suggested by Vojtech, Dmitri and the lists. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-11[MFD] Add code UCB1200/UCB1300 touchscreen supportRussell King
Add support for Philips UCB1200 and UCB1300 touchscreen interfaces found on ARM devices. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
