path: root/drivers/mfd/wm831x-auxadc.c
2011-07-31mfd: Support multiple active WM831x AUXADC conversionsMark Brown
The WM831x AUXADC hardware can schedule multiple conversions at once, allowing higher performance when more than one source is in use as we can have the hardware start new conversions without having to wait for a register write. Take advantage of this in the interrupt driven case, maintaining a list of callers that are waiting for AUXADC conversions and completing them all simultaneously. The external interface of the AUXADC is not changed so there will be limited use of the feature immediately. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-07-31mfd: Refactor wm831x AUXADC handling into a separate fileMark Brown
In preparation for some additional work on the wm831x AUXADC code move the support into a separate file. This is a simple code motion patch, there should be no functional changes. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
