arch/arm/mach-tegra/tegra3_usb_phy.c
arch/arm/mach-tegra/usb_phy.c
drivers/usb/gadget/tegra_udc.c
drivers/usb/otg/Makefile
drivers/video/tegra/fb.c
sound/soc/tegra/tegra_pcm.c
Merge with latest NVIDIA L4T R16.
Only real conflict concerning inverted VBUS gpio support.
Bug 1034241
Change-Id: I5607d53cf0bdd25c5e2b8447cd7e676b64cd32a2
Signed-off-by: Manoj Gangwal <mgangwal@nvidia.com>
Reviewed-on: http://git-master/r/125169
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
The regmap should be initialized before irq initialization
happen as register are accessed during irq init.
Change-Id: I301e8b84596a9075209901cbaff1dc42a944e163
Reviewed-on: http://git-master/r/121623
Reviewed-by: Venu Byravarasu <vbyravarasu@nvidia.com>
Maxim 77665 is Companion PMIC for Smartphones and Tablets.
This support Flash, Fuel Gauge, Haptic, MUIC and battery
charging.
This patch add the core driver for interface for accessing
resgister of the device.
Change-Id: I7d5dff8c222147b2ca1cd21a652f593cd7294601
Reviewed-on: http://git-master/r/121587
The mfd sub devices should get added through the
mfd_add_devices() not through legacy style of
adding sub devices.
Change-Id: If275d41629d799f1e22d95fd442ebe7d3ace448e
Reviewed-on: http://git-master/r/121137
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Register General Purpose ADC driver of TPS80031 as
mfd sub driver in place of adding it as a sub devices.
This is inline with the mfd driver policy.
Change-Id: Ib3f86f05716baef96ee534eec5ae262627c6a853
Reviewed-on: http://git-master/r/121136
Register battery charger driver of TPS80031 as mfd
Change-Id: I8cff39f5c9b22434f7c5b9d4ed9f3865ff4c0001
Reviewed-on: http://git-master/r/121135
Register battery gauge driver of TPS80031 as mfd
Change-Id: I15765be19fc138695de2d813e5fa025400747c86
Reviewed-on: http://git-master/r/121134
register RTC driver of TPS80031 as mfd sub
Change-Id: I2f9c13478a1e85c9670dd7bc576ec761f2e24733
Reviewed-on: http://git-master/r/121133
Prints error message when memory alloc failed for easing
debugging.
Change-Id: I6a8ae68702b01ec975f0130ee78aae3c9ac89c1b
Reviewed-on: http://git-master/r/120845
The structure tps65090 have member as "client", "lock", "id"
which is no more required.
Removing this member from structure.
Change-Id: I18e64c77caeaa0e9c4a23bbb3cd1a6b3419e36d4
Reviewed-on: http://git-master/r/120844
Fix compilation warning of -Wmaybe-uninitialized
Change-Id: I4e6cbe9f5768407b5212d7c3dcfa842560d62748
Reviewed-on: http://git-master/r/120842
Move the register access function to header and make
all register access apis to inline.
Change-Id: I78d23b73edd634145c6f9bee2f0ad08af2e51271
Reviewed-on: http://git-master/r/120841
TPS65090 add mfd sub device of "tps65090-pmic" and
"tps65090-regualtor" which is same.
Remove one of them.
Change-Id: Id02a432cbd240bd9deec9dce6865491afcec6303
Reviewed-on: http://git-master/r/120840
BUG 1026050
Change-Id: Ide19fd183ee172c84b0d5d2d0382e8ec944f2a87
Signed-off-by: Xin Xie <xxie@nvidia.com>
Reviewed-on: http://git-master/r/120580
GVS: Gerrit_Virtual_Submit
(Cherry-picked from mainline
1d88f7a01d9588b3298cfd6a2ec30538e96d166e)
Change-Id: I0613e268d6a9cd16a154d5dea00deb5b3eb528c4
Reviewed-on: http://git-master/r/120371
Return proper error instead of 0 if regmap_init_i2c fails.
Acked-by: Venu Byravarasu <vbyravarasu@nvidia.com>
(Cherrypicked from mainline
b683a0a675560307ebc458cf9044d98d27820b7c)
Change-Id: I2643a80e320664723d0fbb91b22120ec8d82a7df
Reviewed-on: http://git-master/r/120370
The legacy suspend operations have been deprecated and printing warnings
on boot for over a year now.
b6c9eeef4e775e1fff76f4395d11638dc198271d)
Change-Id: Ia8b79787c813327fe1d1ccb5a5ad19da57f2212f
Reviewed-on: http://git-master/r/120369
CONFIG_PM also covers runtime only PM.
1ca5513af77307eccea7efd4d12ef5c14f1b12ab)
Change-Id: I5d8d35f72f46dec28d62e6b01fbc915049185ec3
Reviewed-on: http://git-master/r/120368
Align the driver with mainline.
This is vbased on commit
3c33be06f9aa0949ad24e67dfcae1f2a3006f4e1
mfd: Add support for TPS65090
TPS65090 is a Texas Instrument PMIC. It contains 3 Step-Down converters, 2
always on LDO's and 7 current limited load switches.
Signed-off-by: Venu Byravarasu <vbyravarasu@nvidia.com>
Change-Id: I26545520f2cc72100a927cb60b38693153a4afce
Reviewed-on: http://git-master/r/119320
Add provision to register sub devices through mfd sub
devices. This will help to move all sub devices as
mfd subdevices.
Change-Id: Ibc9f56a210d852749cdc3be7da92d54aad298a21
Reviewed-on: http://git-master/r/118957
Rewrite exit path in case of failure in registration in
probe.
Change-Id: I6c2a8ce3d4fcc01dff97eeea63124d2da419da27
Reviewed-on: http://git-master/r/118956
Use regmap for register access of device in place of
direct i2c calls.
This helps to have the debug FS support through regmap and
also help to caching register with minimum configuration.
Change-Id: I2a1285ab750639babcda40ba53001e7d1bd10a71
Reviewed-on: http://git-master/r/117332
Allocate memory for device state using devm_kzalloc()
to simplify accounting and letting the kernel do the
garbage-collection.
Change-Id: I8dcde205556c43f4fdfe5e335507df206f204177
Reviewed-on: http://git-master/r/117331
Make the tps80031 driver define its PM callbacks through a
struct dev_pm_ops object rather than by using legacy PM hooks
in struct i2c_driver
Change-Id: I3963426c26eb7609794c6fe761d69f31ee630cb2
Reviewed-on: http://git-master/r/117330
Fixing compilation warning:
kernel/drivers/mfd/tps80031.c: In function 'tps80031_init_ext_control.isra.4':
kernel/drivers/mfd/tps80031.c:594:6: warning: 'ret' is used uninitialized in this
function [-Wuninitialized]
Change-Id: I7d9cfab7b03ffe085ef4db7c9b08b0f2cb4e6fec
Reviewed-on: http://git-master/r/117329
From a regulator point of view those PMICs differentiate in their SM2 voltage tables. While the older tps658621a and tps658621d as utilised on Harmony resp. Ventana have a range from 3000 to 4550 mV the tps658623 goes from 1700 to 2475 mV and the tps658643 just from 1025 to 1800 mV. Using its VERSIONCRC register the type of PMIC is queried and the right ranges applied.
Add the new palmas MFD to Kconfig and Makefile
Signed-off-by: Graeme Gregory <gg@slimlogic.co.uk>
(cherry picked from commit c948ef3ae71c18c1079333b65d6887ceb4577618)
Change-Id: I779faf7f0e110ba80761136eebeb7193b1826b4f
Reviewed-on: http://git-master/r/111486
Tested-by: Pradeep Goudagunta <pgoudagunta@nvidia.com>
Palmas is a PMIC from Texas Instruments and this is the MFD part of the
driver for this chip. The PMIC has SMPS and LDO regulators, a general
purpose ADC, GPIO, USB OTG mode detection, watchdog and RTC features.
Acked-by: Samuel Ortiz <sameo@linux.intel.com>
(cherry picked from commit 2945fbc2fcd83df03165342c1bc3ab83d0fe9c04)
Change-Id: I0bdebbef55d91d2293806355dced43b4c2decad8
Reviewed-on: http://git-master/r/111485
The tps65910_parse_dt() prototype for !CONFIG_OF was not correct, leading to:
drivers/mfd/tps65910.c: In function ‘tps65910_i2c_probe’:
drivers/mfd/tps65910.c:218:3: error: too many arguments to function ‘tps65910_parse_dt’
(cherry picked from commit 7f65f74ccee15f6eb0009921a428e3c5d5d06ae0)
Change-Id: I1592020268c408effc331069b7ae241c6da248bb
Reviewed-on: http://git-master/r/105927
As gpio support for tps65910 is on gpio driver, registering
gpio support as the mfd sub devices instead of calling gpio_init()
from the core probe.
(cherry picked from commit 32df986e985921386b75b4bd1117102bf65fe095)
Change-Id: I631596313528ab192d7d8c2f376965ccc989c313
Reviewed-on: http://git-master/r/105926
Convert memory allocation and regmap initialization to
use devm_* functions.
Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
(cherry picked from commit 63fe7dee9183118716078a9f2503f5f805d37c12)
Change-Id: I9b21c63031afffd1d9d1a37abf80895824f7fc7b
Reviewed-on: http://git-master/r/105925
During regmap initialization, we do not provide the default value and
hence in place of caching register during regmap_init(), cache it
when actually we need it i.e. after reading of that register.
(cherry picked from commit 3bf6bf9be51a0195c6b1604454fdd28ed1cc1770)
Change-Id: I151f52436162a328b8d683fc06beba0587d6bda3
Reviewed-on: http://git-master/r/105924
Add device tree based initialization support for TI's tps65910 pmic.
Signed-off-by: Rhyland Klein <rklein@nvidia.com>
(cherry picked from commit cd4209ced4d3936cfe51b7b8833260457e2d9995)
Change-Id: I6f211ebcee135fd0c52662f296eee9f47f801e7a
Reviewed-on: http://git-master/r/105923
This change removes the read/write callback functions in favor of common
regmap accessors inside the header file. This change also makes use of
regmap_read/write for single register access which maps better onto what this
driver actually needs.
(Cherry-pick from mainline
3f7e82759c692df473675ed06fb90b20f1f225c3)
Change-Id: Ida79b196acf65ed14ff9fd2cc1f7c0048f99ba2b
Reviewed-on: http://git-master/r/105922
Reviewed-by: Rhyland Klein <rklein@nvidia.com>
A warning was being generated by the reference from tps65910_i2c_probe()
to tps65910_sleepinit() since the latter was annotated as __init but the
former was unannotated. Since these functions can only be called during
device init make them both __devinit, and while we're at it also annotate
tps65910_i2c_remove() __devexit for symmetry.
(cherry picked from commit 63745d4068de8ccea3580214c6dbfdca0ec37859)
Change-Id: I9e85e31e770c7ea68524d046b87036d6d0264523
Reviewed-on: http://git-master/r/105921
Adding support for device sleep through the external input control
signal "SLEEP".
Changing the SLEEP signal state can switch the device into SLEEP and
ACTIVE state.
Also adding sleep configuration for different resources so that they
should be keep on during sleep state of device.
201cf052810d20814a77ca0e0045a2c1a3508a1f)
Change-Id: Iec18bfcc7a1df6442e833dccaa1d39407918f710
Reviewed-on: http://git-master/r/105920
This was the copy-paste issue in reg cache support code where
variable name for regmap config was not really starting from
the device name, it was starting from some other device name.
Fixing this so that variable name contains actual device name.
(cherry picked from commit 39ecb0376508b5cd20a951388d10aed2d719a77f)
Change-Id: Ife11f77952d847ae7918f11cf1e936bf5008feb4
Reviewed-on: http://git-master/r/105918
Acked-by: Laxman Dewangan <ldewangan@nvidia.com>
(cherry picked from commit f8dddc0cfe9f56ed74fd5efde8d0754f5fb73a3f)
Change-Id: I72d44f59c79abbbdac95398a5d4da2bedf19d8f1
Reviewed-on: http://git-master/r/105880
Adding the gpio of RC583 in the list of rc583 mfd devices
to register the gpio driver of RC5T583.
(cherry picked from commit e1277f45d8748ff59608b140780f75390cb5400c)
Change-Id: Iea2ccf7831c331d1ad08f96100d4222cce31224f
Reviewed-on: http://git-master/r/105879
The combination of commit 1b1247dd75aa5cf5fae54a3bec7280046e9c7957
"mfd: Add support for RICOH PMIC RC5T583"
and commit 6ffc3270210efa2bea526953a142ffc908f5bd86
"regulator: Add support for RICOH PMIC RC5T583 regulator"
are causing the i386 allmodconfig builds to fail with this:
ERROR: "rc5t583_update" [drivers/regulator/rc5t583-regulator.ko] undefined!
ERROR: "rc5t583_set_bits" [drivers/regulator/rc5t583-regulator.ko] undefined!
ERROR: "rc5t583_clear_bits" [drivers/regulator/rc5t583-regulator.ko] undefined!
ERROR: "rc5t583_read" [drivers/regulator/rc5t583-regulator.ko] undefined!
and this:
ERROR: "rc5t583_ext_power_req_config" [drivers/regulator/rc5t583-regulator.ko] undefined!
For the 1st four, make the simple ops static inline, instead of
polluting the namespace with trivial exports. For the last one,
add an EXPORT_SYMBOL.
(cherry picked from commit 82ea267f7dc853a5e6a724916a70a10656efdfc2)
Change-Id: I7f03cc5c0005883eb8355170cdc7996a9c392091
Reviewed-on: http://git-master/r/105878
The backup battery for the RTC circuit needs to be manually turned
on. This change turns it on when the driver is first probed, off
during LP0 to prevent excess power draw, and back on again upon
resume.
Bug 986402
Change-Id: Id4768929d6a73546662806f04d98d714997174b0
Signed-off-by: Tom Cherry <tcherry@nvidia.com>
Reviewed-on: http://git-master/r/103425
Add gpio irq masking in irq_sync_unlock.
Change-Id: I008caf58ae82d9ed888f4720f54675e9106f027d
Signed-off-by: Jinyoung Park <jinyoungp@nvidia.com>
Reviewed-on: http://git-master/r/98664
Reviewed-by: Simone Willett <swillett@nvidia.com>
Unmasked EN0 rising interrupt to generate fast PMU_INT by
EN0(POWER_KEY).
Bug 930883
Change-Id: I9a3d8c4f564e83deea86fbd3d05f14933a0b0f65
Reviewed-on: http://git-master/r/98665
We found missed irq could be happened if clear all INT_STS_x register in one time.
Shadow register pushes the irq status after the first byte of INT_STS_x was cleared
The proposed way to clear interrupt is to write only one INT_STS_x register.
It will also clear the other two ones.
Bug 952476
Reviewed-on: http://git-master/r/93453
Signed-off-by: Steve Kuo <stevek@nvidia.com>
(cherry picked from commit 0c92f32e9e03defaeac991518b26134e59ef4db6)
Change-Id: I76179be4847f59a1687926b9b0dde6ebd3f58aa4
Reviewed-on: http://git-master/r/100306
Disable Hard Reset on long press of power key.
Bug 893517
Change-Id: Ic328a04e917aa1bed6780e6f9a2f1c575f84fb68
Signed-off-by: Ashwini Ghuge <aghuge@nvidia.com>
Reviewed-on: http://git-master/r/96687
Bug 958089
(cherry-picked from commit 7f4c6d6b9dd2b06984b59dcd60d92026cab4c87c)
Reviewed-on: http://git-master/r/92053
Change-Id: I0f2bdb5482fdcb508808d2d58771d74a05b5597f
Reviewed-on: http://git-master/r/94117
It is not recommended to use the flag I2C_M_NOSTART in first
message.
The documentation kernel/Documentation/i2c/i2c-proocol says:
Flag I2C_M_NOSTART:
In a combined transaction, no 'S Addr Wr/Rd [A]' is generated at some
point. For example, setting I2C_M_NOSTART on the second partial message
generates something like:
S Addr Rd [A] [Data] NA Data [A] P
If you set the I2C_M_NOSTART variable for the first partial message,
we do not generate Addr, but we do generate the startbit S. This will
probably confuse all other clients on your bus, so don't try this.
Change-Id: I8a8a4f6f91a1b53b6d443588ab18704cf100fd50
Reviewed-on: http://git-master/r/93187
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Tested-by: Bandi Krishna Chaitanya <bandik@nvidia.com>
Fixing build error reported by Stephen Rothwell:
drivers/built-in.o: In function `rc5t583_i2c_init':
rc5t583.c:(.init.text+0xb3db): undefined reference to `i2c_register_driver'
drivers/built-in.o: In function `rc5t583_i2c_probe':
rc5t583.c:(.devinit.text+0x8fa0): undefined reference to `regmap_init_i2c'
drivers/built-in.o: In function `rc5t583_i2c_exit':
rc5t583.c:(.exit.text+0x708): undefined reference to `i2c_del_driver'
(cherry picked from commit 5364d0b8640dd15e5c0b3ba40d0e874764b1bc88)
Change-Id: If1cfde6c6e0e52b4e55b07401afcd91a895b8905
Reviewed-on: http://git-master/r/91799
