commit 3d6271f92e98094584fd1e609a9969cd33e61122 upstream.
Without turning the MADC clock on, no MADC conversions occur.
$ cat /sys/class/hwmon/hwmon0/device/in8_input
[ 53.428436] twl4030_madc twl4030_madc: conversion timeout!
cat: read error: Resource temporarily unavailable
Signed-off-by: Kyle Manna <kyle@kylemanna.com>
commit 8653be1afd60d6e8c36139b487e375b70357d9ef upstream.
Check inuse variable before trying to access twl_map to prevent
dereferencing of uninitialized variable.
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
commit f09ee0451a44a4e913a7c3cec3805508f7de6c54 upstream.
The codec for Devkit8000 (TWL4030) was not detected except
when build with CONFIG_SND_SOC_ALL_CODECS.
twl-core.c still uses the CONFIG_TWL4030_CODEC for
twl_has_codec().
In commit 57fe7251f5bfc4332f24479376de48a1e8ca6211
the CONFIG_TWL4030_CODEC was renamed
into CONFIG_MFD_TWL4030_AUDIO, thatswhy the codec
was not detected.
This patch renames the CONFIG_ TWL4030_CODEC into
CONFIG_MFD_TWL4030_AUDIO in twl-core.c.
Signed-off-by: Thomas Weber <weber@corscience.de>
Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Cc: Jarkko Nikula <jarkko.nikula@bitmer.com>
In commit 659fb32d1b6("genirq: replace irq_gc_ack() with {set,clr}_bit
variants"), irq_gc_ack was renamed to irq_gc_ack_set_bit. The jz4740-adc
driver still uses the old name which results in a compile error.
The patch fixes the build failure:
drivers/mfd/omap-usb-host.c:1034:1: warning: data definition has no type
or storage class
drivers/mfd/omap-usb-host.c:1034:1: warning: type defaults to 'int' in
declaration of 'EXPORT_SYMBOL_GPL'
drivers/mfd/omap-usb-host.c:1034:1: warning: parameter names (without
types) in function declaration
drivers/mfd/omap-usb-host.c:1040:1: warning: data definition has no type
or storage class
drivers/mfd/omap-usb-host.c:1040:1: warning: type defaults to 'int' in
drivers/mfd/omap-usb-host.c:1040:1: warning: parameter names (without
drivers/mfd/omap-usb-host.c:1045:13: error: 'THIS_MODULE' undeclared
here (not in a function)
drivers/mfd/omap-usb-host.c:1050:15: error: expected declaration
specifiers or '...' before string constant
drivers/mfd/omap-usb-host.c:1050:1: warning: data definition has no type
or storage class
drivers/mfd/omap-usb-host.c:1050:1: warning: type defaults to 'int' in
declaration of 'MODULE_AUTHOR'
drivers/mfd/omap-usb-host.c:1050:15: warning: function declaration isn't
a prototype
drivers/mfd/omap-usb-host.c:1051:14: error: expected declaration
drivers/mfd/omap-usb-host.c:1051:1: warning: data definition has no type
or storage class
drivers/mfd/omap-usb-host.c:1051:1: warning: type defaults to 'int' in
declaration of 'MODULE_ALIAS'
drivers/mfd/omap-usb-host.c:1051:14: warning: function declaration isn't
a prototype
drivers/mfd/omap-usb-host.c:1052:16: error: expected declaration
drivers/mfd/omap-usb-host.c:1052:1: warning: data definition has no type
or storage class
drivers/mfd/omap-usb-host.c:1052:1: warning: type defaults to 'int' in
declaration of 'MODULE_LICENSE'
drivers/mfd/omap-usb-host.c:1052:16: warning: function declaration isn't
a prototype
drivers/mfd/omap-usb-host.c:1053:20: error: expected declaration
drivers/mfd/omap-usb-host.c:1053:1: warning: data definition has no type
or storage class
drivers/mfd/omap-usb-host.c:1053:1: warning: type defaults to 'int' in
declaration of 'MODULE_DESCRIPTION'
drivers/mfd/omap-usb-host.c:1053:20: warning: function declaration isn't
a prototype
make[2]: *** [drivers/mfd/omap-usb-host.o] Error 1
CC fs/proc/namespaces.o
make[1]: *** [drivers/mfd] Error 2
make: *** [drivers] Error 2
make: *** Waiting for unfinished jobs....
Signed-off-by: Ming Lei <ming.lei@canonical.com>
This code section seems to have been accidentally copy pasted.
It causes incorrect bits to be set up in the TLL_CHANNEL_CONF
register and prevents the TLL mode from working correctly.
Cc: stable@kernel.org
Signed-off-by: Anand Gadiyar <gadiyar@ti.com>
Cc: Keshava Munegowda <keshava_mgowda@ti.com>
Acked-by: Felipe Balbi <balbi@ti.com>
Required platform information is not handed to max8997-irq.c properly.
This patch enables to hand over such information to max8997-irq.c so
that max8997-irq functions properly.
Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com>
Fix regression introduced by commit
a2974732ca7614aaf0baf9d6dd3ad893d50ce1c5 (TPS65911: Add new irq
definitions) which caused irq_num to be incorrectly set for tps65910.
Signed-off-by: Johan Hovold <jhovold@gmail.com>
Acked-by: Graeme Gregory <gg@slimlogic.co.uk>
If the twl4030-madc device wasn't registered, and another device, such
as twl4030-madc-hwmon, calls twl4030_madc_conversion() a NULL pointer is
dereferenced.
Worst case this fixes the following error:
[ 72.086212] (NULL device *): conversion timeout!
Best case it prevents a crash
The kernel already has a function with this name declared
in asm-generic/gpio.h. So if this header leaks into wm8350/gpio.c
we get
drivers/mfd/wm8350-gpio.c:40:12: error: conflicting types for 'gpio_set_debounce'
include/asm-generic/gpio.h:156:12: note: previous declaration of 'gpio_set_debounce' was here
Fix this by adding a wm8350_ prefix to the function.
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
A mutex is locked on entry into twl4030_madc_conversion().
Immediate return on some error conditions leaves the
mutex locked.
This patch ensures that mutex is always unlocked before
leaving the function.
Signed-off-by: Sanjeev Premi <premi@ti.com>
Cc: Keerthy <j-keerthy@ti.com>
twl6030_pwm: module license 'unspecified' taints kernel.
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Acked-by: Hemanth V <hemanthv@ti.com>
usbhs_disable function was invoking clk_enable() instead of
clk_disable(), thus only increasing the clock usage counter and
preventing this particular clock from being ever turned off.
Because of this, the power domain of omap4 the USB Host subsystem
would never reach lower power states.This patch calls clk_disable()
in usbhs_disable function
Signed-off-by: Keshava Munegowda <keshava_mgowda@ti.com>
This ensures we never have a window where we've handled an interrupt but
not told the hardware about it.
Ensure that we never have a window where we've handled an interrupt (and
therefore need to be notified of new events) but haven't yet told the
interrupt controller that this is the case (so any new events will be
discarded).
In drivers/mfd/tps65910.c:tps65910_i2c_probe() there's potential for a
tiny optimization.
We assign to init_data->irq and init_data->irq_base long before we
need them, and there are two potential exits from the function before
they are needed.
Moving the assignments below these two potential exits means we
completely avoid doing them in these two (failure) cases.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
There are a couple of situations where we leak init_data in
drivers/mfd/tps65910.c:tps65910_i2c_probe() - this patch should take
care of them.
Add mfd core driver for AnalogicTech AAT2870.
The AAT2870 is communication through I2C and contains backlight and
regulator components.
Signed-off-by: Jin Park <jinyoungp@nvidia.com>
We either hit one of the case's or the default in the switch statement
in get_i2c(), so the 'return ERR_PTR(-EINVAL);' at the end of the
function is just dead code - remove it.
Acked-by: MyungJoo Ham <myungjoo.ham@samsung.com>
Having another TPS chip at the end of the Kconfig when all it's
relatives are grouped together in their own section seems totally
counter-intuitive. Move it, also in the Makefile.
Generating kerneldoc for STMPE result in warnings, so fix this by
adding missing documentation.
Signed-off-by: Om Prakash <omprakash.pal@stericsson.com>
Reviewed-by: Rabin Vincent <rabin.vincent@stericsson.com>
Reviewed-by: Jonas Aberg <jonas.aberg@stericsson.com>
Reviewed-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
If bytes == (TPS6591X_MAX_REGISTER + 1), we have a buffer overflow when
doing memcpy(&msg[1], src, bytes).
With the new generic clk API that should appear at some point we should be
able to support the clocking sensibly in Linux.
The user has to select the I2C and SPI drivers individually and they select
the core driver for the device so there's no point in presenting the user
with an option for the core driver.
The GPIO IRQs aren't the first IRQs defined, we need to subtract the base
for the GPIOs as well to use them for array indexes.
Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com>
Very similar to TPS65920
List of differences: http://www.ti.com/litv/pdf/swcu066b
Signed-off-by: Oleg Drokin <green@linuxhacker.ru>
Purely for defensiveness.
The tps65910_irq_exit() cleanup function was generating a warning from
sparse due to the lack of a prototype. This wasn't causing GCC warnings
as the driver wasn't cleaning up its IRQs on exit at all so there was no
use of an unprototyped function.
Tunnel Creek has an additional watchdog core.
Signed-off-by: Alexander Stein <alexander.stein@systec-electronic.com>
This synchronize the subdevice entries for the AB8500 MFD driver
with the latest development of subdrivers for things like battery
charging and temperature monitoring.
Internal MFD device structs are marked as __devinitdata since the kernel
will allocate memory for the same when calling mfd_add_devices.
Signed-off-by: Robert Rosengren <robert.rosengren@stericsson.com>
Reviewed-by: Mattias Wallin <mattias.wallin@stericsson.com>
Reviewed-by: Johan Palsson <johan.palsson@stericsson.com>
This module controls the interrupt handling for the tps65912.
The interrupt sources can be the following:
- GPIO
- PWRON signal
- PWRHOLD signal
- Temperature detection
Signed-off-by: Margarita Olaya Cabrera <magi@slimlogic.co.uk>
Acked-by: Samuel Ortiz <sameo@linux.intel.com>
Acked-by: Liam Girdwood <lrg@ti.com>
The tps65912 chip is a power management IC. It contains the following
components:
- Regulators
- GPIO controller
The core driver is registered as a platform driver, it provides communication
through I2C and SPI interfaces.
This patch replaces the code for getting an unsigned long from a
userspace buffer by a simple call to kstroul_from_user.
This makes it easier to read and less error prone.
Signed-off-by: Peter Huewe <peterhuewe@gmx.de>
Use the generic irq chip framework for implementing the irq chip for
the jz4740-adc driver.
Even if we would've BUG()ed we should still tidy up after ourselves if that
isn't enabled in the kernel config.
When the byte swap was factored out into the per-register I/O functions
the register restore for the IRQ mask cache (which we use and store in
CPU native format for the interrupt handler) was not updated to do a byte
swap when it uses the bulk I/O. Fix this by writing the cache out one
register at a time.
The WM831x AUXADC hardware can schedule multiple conversions at once,
allowing higher performance when more than one source is in use as we
can have the hardware start new conversions without having to wait for
a register write.
Take advantage of this in the interrupt driven case, maintaining a list of
callers that are waiting for AUXADC conversions and completing them all
simultaneously. The external interface of the AUXADC is not changed so
there will be limited use of the feature immediately.
Switch on the device type before revision since anything we do here will
be device as well as revision specific.
This allows boards to leave the irq_base field unitialized and
prevents them having to reserve irqs in the platform.
pdata can be optional for irq support now. Without pdata the
driver allocates some free irq range. With pdata and irq_base > 0
the driver allocates exactly the specified irq.
Without pdata the irq defaults to IRQF_TRIGGER_LOW.
In preparation for some additional work on the wm831x AUXADC code move the
support into a separate file. This is a simple code motion patch, there
should be no functional changes.
Ensure that there's no possibility of loosing an AUXADC interrupt by reading
the conversion result in the IRQ handler when using interrupts. Otherwise
it's possible that under very heavy load a new conversion could be initiated
before the acknowledgement for a previous interrupt has happened.
Use irq_allocate_desc() to get the IRQ range, which turns into a noop on
non-sparse systems. Since all existing users are non-sparse there should
be no compatibility issues.
The RTC uses the 32.768kHz crystal so if it's not enabled (and it can only
be enabled via OTP or InstantConfig, not runtime software) the RTC can't
function.
Allow platform data to flag the touchscreen as disabled so that if the
touch driver is built in we don't end up causing lots of work by spuriously
detecting touchscreen activity on systems where it isn't in use.
Systems using this functionality will be uncommon.
The WM831x IRQ set_type() operation is doing a direct register write when
called but since set_type() is called with the bus lock held this isn't
legal and could cause deadlocks in the IRQ core.
Fix this by posting the updates into an array and syncing in the
bus_sync_unlock() callback.
