path: root/drivers/misc/bh1770glc.c
2010-11-12drivers/misc/bh1770glc.c: error handling in bh1770_power_state_store()Dan Carpenter
There was a signedness bug so "ret" was never less than zero and that breaks the error handling. Also in the original code it would overwrite ret and the result is still negative but it's bogus number instead of the correct error code. Signed-off-by: Dan Carpenter <error27@gmail.com> Cc: Samu Onkalo <samu.p.onkalo@nokia.com> Cc: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26drivers/misc: driver for bh1770glc / sfh7770 ALS and proximity sensorSamu Onkalo
This is a driver for ROHM BH1770GLC and OSRAM SFH7770 combined ALS and proximity sensor. Interface is sysfs based. The driver uses interrupts to provide new data. The driver supports pm_runtime and regulator frameworks. See Documentation/misc-devices/bh1770glc.txt for details Signed-off-by: Samu Onkalo <samu.p.onkalo@nokia.com> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
