path: root/drivers/misc/bh1780gli.c
2011-04-26treewide: cleanup continuations and remove logging message whitespaceJoe Perches
Using C line continuation inside format strings is error prone. Clean up the unintended whitespace introduced by misuse of \. Neaten correctly used line continations as well for consistency. drivers/scsi/arcmsr/arcmsr_hba.c has these errors as well, but arcmsr needs a lot more work and the driver should likely be moved to staging instead. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-03-22bh1780gli: convert to dev pm opsShubhrajyoti Datta
Signed-off-by: Shubhrajyoti Datta <shubhrajyoti@ti.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-30i2c: Remove obsolete cleanup for clientdataWolfram Sang
A few new i2c-drivers came into the kernel which clear the clientdata-pointer on exit. This is obsolete meanwhile, so fix it and hope the word will spread. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-08-09drivers/misc: ROHM BH1780GLI ambient light sensor driverHemanth V
Add support for ROHM BH1780GLI Ambient light sensor. BH1780 supports I2C interface. Driver supports read/update of power state and read of lux value (through SYSFS). Writing value 3 to power_state enables the sensor and current lux value could be read. Currently this driver follows the same sysfs convention as supported by drivers/misc/isl29003.c. Signed-off-by: Hemanth V <hemanthv@ti.com> Reviewed-by: Daniel Mack <daniel@caiaq.de> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Cc: Jean Delvare <khali@linux-fr.org> Cc: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
