path: root/drivers/misc/sgi-xp/xpc_channel.c
2008-05-13drivers/misc/sgi-xp: replace partid_t with a shortDean Nelson
In preparation for supporting greater than 64 partitions replace partid_t by short in drivers/misc/sgi-xp. Signed-off-by: Dean Nelson <dcn@sgi.com> Acked-by: Robin Holt <holt@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-13drivers/misc/sgi-xp: clean up return valuesDean Nelson
Make XP return values more generic to XP and not so tied to XPC by changing enum xpc_retval to xp_retval, along with changing return value prefixes from xpc to xp. Also, cleanup a comment block that referenced some of these return values as well as the handling of BTE related return values. Signed-off-by: Dean Nelson <dcn@sgi.com> Acked-by: Robin Holt <holt@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-22[IA64] run drivers/misc/sgi-xp through scripts/checkpatch.plDean Nelson
Addressed issues raised by scripts/checkpatch.pl. Removed unnecessary curly braces. Eliminated uses of volatiles and use of kernel_thread() and daemonize(). Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-22[IA64] run rest drivers/misc/sgi-xp through scripts/LindentDean Nelson
Ran patches through scripts/Lindent (part 2). Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-22[IA64] move XP and XPC to drivers/misc/sgi-xpDean Nelson
Move XPC and XPNET from arch/ia64/sn/kernel to drivers/misc/sgi-xp. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
