path: root/drivers/misc/sgi-xp
2011-06-19sgi-xp: fix a use after freeEric Dumazet
Its illegal to dereference skb after dev_kfree_skb(skb) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Robin Holt <holt@sgi.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-25sgi-xpc: XPC fails to discover partitions with all nasids above 128Robin@sgi.com
UV hardware defines 256 memory protection regions versus the baseline 64 with increasing size for the SN2 ia64. This was overlooked when XPC was modified to accomodate both UV and SN2. Without this patch, a user could reconfigure their existing system and suddenly disable cross-partition communications with no indication of what has gone wrong. It also prevents larger configurations from using cross-partition communication. Signed-off-by: Robin Holt <holt@sgi.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26sgi-xp: incoming XPC channel messages can come in after the channel's ↵Robin Holt
partition structures have been torn down Under some workloads, some channel messages have been observed being delayed on the sending side past the point where the receiving side has been able to tear down its partition structures. This condition is already detected in xpc_handle_activate_IRQ_uv(), but that information is not given to xpc_handle_activate_mq_msg_uv(). As a result, xpc_handle_activate_mq_msg_uv() assumes the structures still exist and references them, causing a NULL-pointer deref. Signed-off-by: Robin Holt <holt@sgi.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-06bitops: rename for_each_bit() to for_each_set_bit()Akinobu Mita
Rename for_each_bit to for_each_set_bit in the kernel source tree. To permit for_each_clear_bit(), should that ever be added. The patch includes a macro to map the old for_each_bit() onto the new for_each_set_bit(). This is a (very) temporary thing to ease the migration. [akpm@linux-foundation.org: add temporary for_each_bit()] Suggested-by: Alexey Dobriyan <adobriyan@gmail.com> Suggested-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Russell King <rmk@arm.linux.org.uk> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Artem Bityutskiy <dedekind@infradead.org> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16UV - XPC: pass nasid instead of nid to gru_create_message_queueRobin Holt
Currently, the UV xpc code is passing nid to the gru_create_message_queue instead of nasid as it expects. Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16x86: uv: XPC receive message reuse triggers invalid BUG_ON()Robin Holt
This was a difficult bug to trip. XPC was in the middle of sending an acknowledgement for a received message. In xpc_received_payload_uv(): . ret = xpc_send_gru_msg(ch->sn.uv.cached_notify_gru_mq_desc, msg, sizeof(struct xpc_notify_mq_msghdr_uv)); if (ret != xpSuccess) XPC_DEACTIVATE_PARTITION(&xpc_partitions[ch->partid], ret); msg->hdr.msg_slot_number += ch->remote_nentries; at the point in xpc_send_gru_msg() where the hardware has dispatched the acknowledgement, the remote side is able to reuse the message structure and send a message with a different slot number. This problem is made worse by interrupts. The adjustment of msg_slot_number and the BUG_ON in xpc_handle_notify_mq_msg_uv() which verifies the msg_slot_number is consistent are only used for debug purposes. Since a fix for this that preserves the debug functionality would either have to infringe upon the payload or allocate another structure just for debug, I decided to remove it entirely. Signed-off-by: Robin Holt <holt@sgi.com> Cc: Jack Steiner <steiner@sgi.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16X86: uv: xpc_make_first_contact hang due to not accepting ACTIVE stateRobin Holt
Many times while the initial connection is being made, the contacted partition will send back both the ACTIVATING and the ACTIVE remote_act_state changes in very close succescion. The 1/4 second delay in the make first contact loop is large enough to nearly always miss the ACTIVATING state change. Since either state indicates the remote partition has acknowledged our state change, accept either. Signed-off-by: Robin Holt <holt@sgi.com> Cc: Jack Steiner <steiner@sgi.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16x86: uv: xpc NULL deref when mesq becomes emptyRobin Holt
Under heavy load conditions, our set of xpc messages may become exhausted. The code handles this correctly with the exception of the management code which hits a NULL pointer dereference. Signed-off-by: Robin Holt <holt@sgi.com> Cc: Jack Steiner <steiner@sgi.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16x86: uv: update XPC to handle updated BIOS interfaceRobin Holt
The UV BIOS has moved the location of some of their pointers to the "partition reserved page" from memory into a uv hub MMR. The GRU does not support bcopy operations from MMR space so we need to special case the MMR addresses using VLOAD operations. Additionally, the BIOS call for registering a message queue watchlist has removed the 'blade' value and eliminated the structure that was being passed in. This is also reflected in this patch. Signed-off-by: Robin Holt <holt@sgi.com> Cc: Jack Steiner <steiner@sgi.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16x86: uv: xpc needs to provide an abstraction for uv_gpaRobin Holt
Provide an SGI SN2/UV agnositic method for converting a global physical address into a socket physical address. Signed-off-by: Robin Holt <holt@sgi.com> Cc: Jack Steiner <steiner@sgi.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/sysctl-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/sysctl-2.6: (43 commits) security/tomoyo: Remove now unnecessary handling of security_sysctl. security/tomoyo: Add a special case to handle accesses through the internal proc mount. sysctl: Drop & in front of every proc_handler. sysctl: Remove CTL_NONE and CTL_UNNUMBERED sysctl: kill dead ctl_handler definitions. sysctl: Remove the last of the generic binary sysctl support sysctl net: Remove unused binary sysctl code sysctl security/tomoyo: Don't look at ctl_name sysctl arm: Remove binary sysctl support sysctl x86: Remove dead binary sysctl support sysctl sh: Remove dead binary sysctl support sysctl powerpc: Remove dead binary sysctl support sysctl ia64: Remove dead binary sysctl support sysctl s390: Remove dead sysctl binary support sysctl frv: Remove dead binary sysctl support sysctl mips/lasat: Remove dead binary sysctl support sysctl drivers: Remove dead binary sysctl support sysctl crypto: Remove dead binary sysctl support sysctl security/keys: Remove dead binary sysctl support sysctl kernel: Remove binary sysctl logic ...
2009-11-18sysctl: Drop & in front of every proc_handler.Eric W. Biederman
For consistency drop & in front of every proc_handler. Explicity taking the address is unnecessary and it prevents optimizations like stubbing the proc_handlers to NULL. Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Joe Perches <joe@perches.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-11-12sysctl ia64: Remove dead binary sysctl supportEric W. Biederman
Now that sys_sysctl is a generic wrapper around /proc/sys .ctl_name and .strategy members of sysctl tables are dead code. Remove them. Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-10-14x86: SGI UV: Fix irq affinity for hub based interruptsDimitri Sivanich
This patch fixes handling of uv hub irq affinity. IRQs with ALL or NODE affinity can be routed to cpus other than their originally assigned cpu. Those with CPU affinity cannot be rerouted. Signed-off-by: Dimitri Sivanich <sivanich@sgi.com> LKML-Reference: <20090930160259.GA7822@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-18Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] Clean up linker script using standard macros. [IA64] Use standard macros for page-aligned data. [IA64] Use .ref.text, not .text.init for start_ap. [IA64] sgi-xp: fix printk format warnings [IA64] ioc4_serial: fix printk format warnings [IA64] mbcs: fix printk format warnings [IA64] pci_br, fix infinite loop in find_free_ate() [IA64] kdump: Short path to freeze CPUs [IA64] kdump: Try INIT regardless of [IA64] kdump: Mask INIT first in panic-kdump path [IA64] kdump: Don't return APs to SAL from kdump [IA64] kexec: Unregister MCA handler before kexec [IA64] kexec: Make INIT safe while transition to [IA64] kdump: Mask MCA/INIT on frozen cpus Fix up conflict in arch/ia64/kernel/vmlinux.lds.S as per Tony's suggestion.
2009-09-15[IA64] sgi-xp: fix printk format warningsRandy Dunlap
Fix warnings in SGI XPC sn2 driver: lots of printk format warnings and: drivers/misc/sgi-xp/xpc_sn2.c: In function 'xpc_get_partition_rsvd_page_pa_sn2': drivers/misc/sgi-xp/xpc_sn2.c:618: warning: passing argument 3 of 'sn_partition_reserved_page_pa' from incompatible pointer type drivers/misc/sgi-xp/xpc_sn2.c:618: warning: passing argument 4 of 'sn_partition_reserved_page_pa' from incompatible pointer type (likely due to generic u64 / long long changes) Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Robin Holt <holt@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2009-09-02drivers: Kill now superfluous ->last_rx storesEric Dumazet
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Neil Horman <nhorman@txudriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-12Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: arch/microblaze/include/asm/socket.h
2009-07-08Remove multiple KERN_ prefixes from printk formatsJoe Perches
Commit 5fd29d6ccbc98884569d6f3105aeca70858b3e0f ("printk: clean up handling of log-levels and newlines") changed printk semantics. printk lines with multiple KERN_<level> prefixes are no longer emitted as before the patch. <level> is now included in the output on each additional use. Remove all uses of multiple KERN_<level>s in formats. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-05net: use NETDEV_TX_OK instead of 0 in ndo_start_xmit() functionsPatrick McHardy
This patch is the result of an automatic spatch transformation to convert all ndo_start_xmit() return values of 0 to NETDEV_TX_OK. Some occurences are missed by the automatic conversion, those will be handled in a seperate patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-16page allocator: do not check NUMA node ID when the caller knows the node is ↵Mel Gorman
valid Callers of alloc_pages_node() can optionally specify -1 as a node to mean "allocate from the current node". However, a number of the callers in fast paths know for a fact their node is valid. To avoid a comparison and branch, this patch adds alloc_pages_exact_node() that only checks the nid with VM_BUG_ON(). Callers that know their node is valid are then converted. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Paul Mundt <lethal@linux-sh.org> [for the SLOB NUMA bits] Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-13net: fix network driver ndo_start_xmit() return values (part 1)Patrick McHardy
Fix up drivers that return an errno value to qdisc_restart(), causing qdisc_restart() to print a warning and requeue/retransmit the skb. - xpnet: memory allocation error, intention is to drop - ethoc: oversized packet, packet must be dropped - ibmlana: skb freed: use after free - rrunner: skb freed: use after free Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-21sgi-xp/sgi-gru: allow modules to load on non-uv systemsRobin Holt
For an upcoming distro release, we need to have the xp kernel module loadable even when not on UV equipment. The xpc module will not load. This will allow one set of modules dependent upon xp to work on either UV or non-UV equipment. Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Jack Steiner <steiner@sgi.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13sgi-xpc: clean up numerous globalsRobin Holt
Introduce xpc_arch_ops and eliminate numerous individual global definitions. Signed-off-by: Robin Holt <holt@sgi.com> Cc: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13sgi-xpc: implement opencomplete messagingRobin Holt
sgi-xpc has a window of failure where an open message can be sent and a subsequent data message can get lost. We have added a new message (opencomplete) which closes that window. Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13sgi-xpc: prevent false heartbeat failuresRobin Holt
The heartbeat timeout functionality in sgi-xpc is currently not trained to the connection time. If a connection is made and the code is in the last polling window prior to doing a timeout, the next polling window will see the heartbeat as unchanged and initiate a no-heartbeat disconnect. Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02xpc_sn2: fix max() warning about pointers of different typesRobin Holt
Fix a minor compile warning when building on ia64. drivers/misc/sgi-xp/xpc_sn2.c: In function `xpc_clear_remote_msgqueue_flags_sn2': drivers/misc/sgi-xp/xpc_sn2.c:1746: warning: comparison of distinct pointer types lacks a cast Signed-off-by: Robin Holt <holt@sgi.com> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02sgi-gru: add support to the GRU driver for message queue interruptsJack Steiner
Add support to the GRU driver for message queue interrupts. Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-11SGI IA64 UV: fix ia64 build error in the linux-next treeDean Nelson
Fix the ia64 build error that occurs in the linux-next tree by introducing an ia64 version of uv.h. Additionally, clean up the usage of is_uv_system(). Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-09Merge commit 'v2.6.29-rc4' into core/percpuIngo Molnar
Conflicts: arch/x86/mach-voyager/voyager_smp.c arch/x86/mm/fault.c
2009-02-05sgi-xp: fix writing past the end of kzalloc()'d spaceDean Nelson
A missing type cast results in writing way beyond the end of a kzalloc()'d memory segment resulting in slab corruption. But it seems like the better solution is to define ->recv_msg_slots as a 'void *' rather than a 'struct xpc_notify_mq_msg_uv *' and add the type cast. Signed-off-by: Dean Nelson <dcn@sgi.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-03sgi-xp: link XPNET's net_device_ops to its net_device structureDean Nelson
A recent patch by Stephen Hemminger to convert XPNET to use net_device_ops and internal net_device_stats failed to link the net_device_ops structure to the net_device structure. See commit e8ac9c55f28482f5b2f497a8e7eb90985db237c2 ("xpnet: convert devices to new API"). Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-30Merge branch 'linus' into core/percpuIngo Molnar
Conflicts: kernel/irq/handle.c
2009-01-29sgi-xpc: fix up stale DBUG_ON statementsRobin Holt
Clean up the stale DBUG_ON checks and add a couple new ones. Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-29sgi-xpc: Remove NULL pointer dereference.Robin Holt
If the bte copy fails, the attempt to retrieve payloads merely returns a null pointer deref and not NULL as was expected. Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Dean Nelson <dcn@sgi.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-29sgi-xpc: ensure flags are updated before bte_copyRobin Holt
The clearing of the msg->flags needs a barrier between it and the notify of the channel threads that the messages are cleaned and ready for use. Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Dean Nelson <dcn@sgi.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-21x86: uv cleanup, build fix #2Ingo Molnar
Fix more build-failure fallout from the UV cleanup - the UV drivers were not updated to include <asm/uv/uv.h>. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-21Merge branch 'x86/mm' into core/percpuIngo Molnar
Conflicts: arch/x86/mm/fault.c
2009-01-15sgi-xp: eliminate false detection of no heartbeatDean Nelson
After XPC has been up and running on multiple partitions for any length of time, if XPC on one of the partitions is stopped and restarted (either by a rmmod/insmod or a system restart), it is possible for the XPCs running on the other partitions to falsely detect a lack of heartbeat from the XPC that was just restarted. This false detection will occur if the restarted XPC comes up within the five-seconds preceding one of the other XPC's heartbeat check (which occurs once every twenty seconds). The detection of no heartbeat results in the detecting XPC deactivating from the just restarted XPC. The only remedy is to restart one of the XPCs and hope that one doesn't hit this five-second window on any of the other partitions. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Robin Holt <holt@sgi.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-11cpumask: convert misc driver functionsRusty Russell
Impact: use new cpumask API. Convert misc driver functions to use struct cpumask. To Do: - Convert iucv_buffer_cpumask to cpumask_var_t. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Mike Travis <travis@sgi.com> Acked-by: Dean Nelson <dcn@sgi.com> Cc: Robert Richter <robert.richter@amd.com> Cc: oprofile-list@lists.sf.net Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Chris Wright <chrisw@sous-sol.org> Cc: virtualization@lists.osdl.org Cc: xen-devel@lists.xensource.com Cc: Ursula Braun <ursula.braun@de.ibm.com> Cc: linux390@de.ibm.com Cc: linux-s390@vger.kernel.org
2009-01-08Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
2009-01-07xpnet: convert devices to new APIStephen Hemminger
Convert to net_device_ops and internal net_device_stats Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-06SGI: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
CC: Jack Steiner <steiner@sgi.com> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1429 commits) net: Allow dependancies of FDDI & Tokenring to be modular. igb: Fix build warning when DCA is disabled. net: Fix warning fallout from recent NAPI interface changes. gro: Fix potential use after free sfc: If AN is enabled, always read speed/duplex from the AN advertising bits sfc: When disabling the NIC, close the device rather than unregistering it sfc: SFT9001: Add cable diagnostics sfc: Add support for multiple PHY self-tests sfc: Merge top-level functions for self-tests sfc: Clean up PHY mode management in loopback self-test sfc: Fix unreliable link detection in some loopback modes sfc: Generate unique names for per-NIC workqueues 802.3ad: use standard ethhdr instead of ad_header 802.3ad: generalize out mac address initializer 802.3ad: initialize ports LACPDU from const initializer 802.3ad: remove typedef around ad_system 802.3ad: turn ports is_individual into a bool 802.3ad: turn ports is_enabled into a bool 802.3ad: make ntt bool ixgbe: Fix set_ringparam in ixgbe to use the same memory pools. ... Fixed trivial IPv4/6 address printing conflicts in fs/cifs/connect.c due to the conversion to %pI (in this networking merge) and the addition of doing IPv6 addresses (from the earlier merge of CIFS).
2008-12-16sgi-xp: xpc needs to pass the physical address, not virtualRuss Anderson
Impact: fix crash xpc needs to pass the physical address, not virtual. Testing uncovered this problem. The virtual address happens to work most of the time due to the way bios was masking off the node bits. Passing the physical address makes it work all of the time. Signed-off-by: Russ Anderson <rja@sgi.com> Acked-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-04sgi-xp: Kill directly reference of netdev->privWang Chen
Simply replace netdev->priv with netdev_priv(). [ Kill unnecessary casts, noticed by Ilpo -DaveM ] Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-20Merge branch 'linus' into x86/uvIngo Molnar
2008-11-05sgi-xp: support getting the address of a partition's reserved pageDean Nelson
Add support for getting the address of a partition's reserved page. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-11-05sgi-xp: define xp_partition_id and xp_region_sizeDean Nelson
Define xp_partition_id and xp_region_size to their correct values. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
