path: root/drivers/misc
2006-03-09[PATCH] ibmasm: use after free fixMax Asbock
The kobject_put() can free the memory at *cmd, but cmd->lock points to a persistent lock that is not freed with cmd. Signed-off-by: Max Asbock <masbock@us.ibm.com> Cc: Vernon Mauery <vernux@us.ibm.com> Cc: Srihari Vijayaraghavan <sriharivijayaraghavan@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-21[SERIAL] Remove UPF_AUTOPROBE and UPF_BOOT_ONLYMCARussell King
The functionality UPF_BOOT_ONLYMCA provided has been replaced by the 8250_mca module, which only registers MCA ports if MCA is present. UPF_AUTOPROBE has no functional effect - in fact, it's never tested. Only ibmasm set the flag. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-10Input: ibmasm - fix input initialization error pathDmitry Torokhov
Do not try to free device that has already been unregistered, input_unregister_device() frees it automatically. Spotted by Vernon Mauery <vernux@us.ibm.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-01-07Input: ibmasm - convert to dynamic input_dev allocationVernon Mauery
Update the ibmasm driver to use the dynamic allocation of input_dev structs to work with the sysfs subsystem. Vojtech: Fixed some problems/bugs in the patch. Dmitry: Fixed some more. Signed-off-by: Vernon Mauery <vernux@us.ibm.com> Signed-off-by: Vojtech Pavlik <vojtech@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2005-11-11Merge master.kernel.org:/home/rmk/linux-2.6-drvmodelLinus Torvalds
2005-11-09[DRIVER MODEL] Convert platform drivers to use struct platform_driverRussell King
This allows us to eliminate the casts in the drivers, and eventually remove the use of the device_driver function pointer methods for platform device drivers. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-09[PATCH] changing CONFIG_LOCALVERSION rebuilds too much, for no good reasonOlaf Hering
This patch removes almost all inclusions of linux/version.h. The 3 #defines are unused in most of the touched files. A few drivers use the simple KERNEL_VERSION(a,b,c) macro, which is unfortunatly in linux/version.h. There are also lots of #ifdef for long obsolete kernels, this was not touched. In a few places, the linux/version.h include was move to where the LINUX_VERSION_CODE was used. quilt vi `find * -type f -name "*.[ch]"|xargs grep -El '(UTS_RELEASE|LINUX_VERSION_CODE|KERNEL_VERSION|linux/version.h)'|grep -Ev '(/(boot|coda|drm)/|~$)'` search pattern: /UTS_RELEASE\|LINUX_VERSION_CODE\|KERNEL_VERSION\|linux\/\(utsname\|version\).h Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-10[PATCH] hdpu_cpustate.c: misc_register() can failChristophe Lucas
Signed-off-by: Christophe Lucas <clucas@rotomalug.org> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[SERIAL] Update ibmasm driver for death of register_serial&coMax Asbock
Signed-off-by: Max Asbock <masbock@us.ibm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-08-31[ARM] 2866/1: add i.MX set_mctrl / get_mctrl functionsSascha Hauer
Patch from Sascha Hauer This patch adds support for setting and getting RTS / CTS via set_mtctrl / get_mctrl functions. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-12[PATCH] IBM_ASM Kconfig correctionsAdrian Bunk
This patch contains the following fixes: - IBM_ASM must depend on PCI - remove useless "default n" - correct the URL to further information Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] ibmasm driver: fix race in command refcount logicMax Asbock
This patch fixes a race in the command reference counting logic by putting spinlocks around kobject_put() in the command_put function. - Also added debug messages. - Changed a memcpy to memcpy_fromio since we are reading from io space. Signed-off-by: Max Asbock <masbock@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] ibmasm driver: redesign handling of remote control eventsMax Asbock
This patch rewrites the handling of remote control events. Rather than making them available from a special file in the ibmasmfs, now the events from the RSA card get translated into kernel input events and injected into the input subsystem. The driver now will generate two /dev/input/eventX nodes -- one for the keyboard and one for the mouse. The mouse node generates absolute events more like a touch pad than a mouse. Signed-off-by: Vernon Mauery <vernux@us.ibm.com> Signed-off-by: Max Asbock <masbock@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] ibmasm driver: correctly wake up sleeping threadsMax Asbock
Due to my incomplete understanding of the wait_event_interruptible() function threads waiting for service processor events were not woken up. This patch fixes that problem. Signed-off-by: Max Asbock <masbock@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] ibmasm driver: fix command buffer sizeMax Asbock
First of a series of patches for the ibmasm driver. (that is the driver for the IBM xSeries RSA service processor) To summarize what they do: [1] change a #define for the buffer size for commands [2] Fix a bug where threads in the event handling code calling wait_event_interruptible() weren't woken up as expected. [3] Redesigned how remote mouse and keyboard events received by the driver are handled. [4] Fixed a race in the command reference counting logic. This patch: - change a #define for the buffer size for commands Signed-off-by: Max Asbock <masbock@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
