Source files should not be with executable permission.
Original-Change-Id: I70b6be4cf88fea4be9b092ca2f5dd08e40ee7cbd
Reviewed-on: http://git-master/r/12081
Reviewed-by: Chao Jiang <chaoj@nvidia.com>
Tested-by: Chao Jiang <chaoj@nvidia.com>
Rebase-Id: R735406da6ad586ca43d65d1c1abc3844761f0378
SDIO specification allows RAW (Read after Write) operation using
IO_RW_DIRECT command (CMD52) by setting the RAW bit. This operation is
similar to ordinary read/write commands, except that both write and read
are performed using single command/response pair. The Linux SDIO layer
already supports this internaly, only external function is missing for
drivers to make use, which is added by this patch.
This type of command is required to implement proper power save mode
support in wl1251 wifi driver.
Android has similar patch for G1 in it's tree for the same reason:
http://android.git.kernel.org/?p=kernel/common.git;a=commitdiff;h=74a47786f6ecbe6c1cf9fb15efe6a968451deb52
Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
Acked-by: Kalle Valo <kalle.valo@iki.fi>
Cc: Dmitry Shmidt <dimitrysh@google.com>
Cc: <linux-mmc@vger.kernel.org>
This patch series provides the core changes needed to allow SDIO cards to
remain powered and active while the host system is suspended, and let them
wake up the host system when needed. This is used to implement
wake-on-lan with SDIO wireless cards at the moment. Patches to add that
support to the libertas driver will be posted separately.
This patch:
Some SDIO cards have the ability to keep on running autonomously when the
host system is suspended, and wake it up when needed. This however
requires that the host controller preserve power to the card, and
configure itself appropriately for wake-up.
There is however 4 layers of abstractions involved: the host controller
driver, the MMC core code, the SDIO card management code, and the actual
SDIO function driver. To make things simple and manageable, host drivers
must advertise their PM capabilities with a feature bitmask, then function
drivers can query and set those features from their suspend method. Then
each layer in the suspend call chain is expected to act upon those bits
accordingly.
[akpm@linux-foundation.org: fix typo in comment]
Signed-off-by: Nicolas Pitre <nico@marvell.com>
Some SDIO cards expect byte transfers not to exceed the configured block
transfer size. Add a quirk to that effect.
Patches to make use of this quirk will be sent separately.
Signed-off-by: Bing Zhao <bzhao@marvell.com>
Normally writes to SDIO function 0 outside the vendor specific CCCR
registers are prohibited.
To support embedded devices that require writes to SDIO function 0 outside
this range (e.g. TI WL127x embedded sdio wifi device),
MMC_QUIRK_LENIENT_FN0 is introduced.
A card quirks field is added to `struct mmc_card' to support non-standard
devices (e.g. embedded sdio devices).
[akpm@linux-foundation.org: code in C, not cpp!]
Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com>
git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc: (68 commits)
sdio_uart: Fix SDIO break control to now return success or an error
mmc: host driver for Ricoh Bay1Controllers
sdio: sdio_io.c Fix sparse warnings
sdio: fix the use of hard coded timeout value.
mmc: OLPC: update vdd/powerup quirk comment
mmc: fix spares errors of sdhci.c
mmc: remove multiwrite capability
wbsd: fix bad dma_addr_t conversion
atmel-mci: Driver for Atmel on-chip MMC controllers
mmc: fix sdio_io sparse errors
mmc: wbsd.c fix shadowing of 'dma' variable
MMC: S3C24XX: Refuse incorrectly aligned transfers
MMC: S3C24XX: Add maintainer entry
MMC: S3C24XX: Update error debugging.
MMC: S3C24XX: Add media presence test to request handling.
MMC: S3C24XX: Fix use of msecs where jiffies are needed
MMC: S3C24XX: Add MODULE_ALIAS() entries for the platform devices
MMC: S3C24XX: Fix s3c2410_dma_request() return code check.
MMC: S3C24XX: Allow card-detect on non-IRQ capable pin
MMC: S3C24XX: Ensure host->mrq->data is valid
Manually fixed up bogus executable bits on drivers/mmc/core/sdio_io.c
and include/linux/mmc/sdio_func.h when merging.
Unfold nested macros it creates not readable code and
sparse warnings
sdio_io.c:190:9: warning: symbol '_min1' shadows an earlier one
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
This adds reading and using of enable_timeout from the CIS
Signed-off-by: Benzi Zbit <benzi.zbit@intel.com>
This patch fixes sdio_io sparse errors.
This fix changes signature of API functions,
changing
unsigned char -> u8
unsigned short -> u16
unsigned long -> u32 - this was probably a bug in 64 bit platforms
Make sure that the maximum size for a byte mode transfer is identical
in all places. Also tweak the transfer helper so that a single byte
mode transfer is preferred over (possibly multiple) block mode
request(s).
There are a lot of crappy controllers out there that cannot handle
all the request sizes that the MMC/SD/SDIO specifications require.
In case the card driver can pad the data to overcome the problems,
this commit adds a helper that calculates how much that padding
should be.
A corresponding helper is also added for SDIO, but it can also deal
with all the complexities of splitting up a large transfer efficiently.
Add sdio_f0_readb() and sdio_f0_writeb() functions to reading and
writing function 0 registers. Writes outside the vendor specific CCCR
registers (0xF0 - 0xFF) are not permitted.
Signed-off-by: David Vrabel <david.vrabel@csr.com>
Extend sdio_readsb(), sdio_writesb(), sdio_memcpy_fromio(), and
sdio_memcpy_toio() to handle any length of buffer by splitting the transfer
into several IO_RW_EXTENDED commands. Typically, a transfer would be split
into a single block mode transfer followed by a byte mode transfer for the
remainder but we also handle lack of block mode support and the block size
being greater than 512 (the maximum byte mode transfer size).
host->max_seg_size <= host->max_req_size so there's no need to check both
when determining the maximum data size for a single command.
Before a driver is probed, set the function's block size to the default so the
driver is sure the block size is something sensible and it needn't explicitly
set it.
The default block size is the largest that's supported by both the card and
the host, with a maximum of 512 to ensure aribitrarily sized transfer use the
optimal (least) number of commands.
See http://lkml.org/lkml/2007/8/7/150 for reasons for the block size choice.
Support the multi-byte transfer operation, including handlers for
common operations like writel()/readl().
Like many other buses, the devices (functions) on the SDIO bus
must be enabled before they can be used. Add functions that allow
drivers to do so.
Add command wrappers that simplify register access from SDIO
function drivers.
