path: root/drivers/mmc/host/mmc_spi.c
2013-08-24mmc: mmc_spi: Remove platform data .get_cd() and .get_ro() callbacksLaurent Pinchart
All platforms now pass the CD and RO GPIOs to the MMC SPI driver, those callbacks are not used anymore. Remove them. Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Reviewed-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-08-24mmc: mmc_spi: Support CD/RO GPIOsLaurent Pinchart
Add support for passing CD/RO GPIO numbers directly to the mmc_spi driver instead of relying solely on board code callbacks to retrieve the CD/RO signals values. The driver will enable debouncing on the card detect GPIO if the cd_debounce field is set to a non-zero value. Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Reviewed-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-11-28mmc: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Manuel Lauss <manuel.lauss@gmail.com> Cc: Chris Ball <cjb@laptop.org> Cc: "Michał Mirosław" <mirq-linux@rere.qmqm.pl> Cc: Jarkko Lavinen <jarkko.lavinen@nokia.com> Cc: Venkatraman S <svenkatr@ti.com> Cc: Viresh Kumar <viresh.linux@gmail.com> Cc: Ian Molton <ian@mnementh.co.uk> Cc: Bruce Chang <brucechang@via.com.tw> Cc: Harald Welte <HaraldWelte@viatech.com> Cc: Pierre Ossman <pierre@ossman.eu> Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28mmc: remove use of __devinitdataBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinitdata is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Chris Ball <cjb@laptop.org> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Rob Herring <rob.herring@calxeda.com> Cc: linux-mmc@vger.kernel.org Cc: devicetree-discuss@lists.ozlabs.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28mmc: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Chris Ball <cjb@laptop.org> Cc: "Michał Mirosław" <mirq-linux@rere.qmqm.pl> Cc: Jarkko Lavinen <jarkko.lavinen@nokia.com> Cc: Venkatraman S <svenkatr@ti.com> Cc: Ian Molton <ian@mnementh.co.uk> Cc: Bruce Chang <brucechang@via.com.tw> Cc: Harald Welte <HaraldWelte@viatech.com> Cc: Pierre Ossman <pierre@ossman.eu> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-04mmc: mmc_spi: Use module_spi_driverSachin Kamat
module_spi_driver makes the code simpler by eliminating module_init and module_exit calls. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-01-11mmc: Remove redundant spi driver bus initializationLars-Peter Clausen
In ancient times it was necessary to manually initialize the bus field of an spi_driver to spi_bus_type. These days this is done in spi_driver_register(), so we can drop the manual assignment. The patch was generated using the following coccinelle semantic patch: // <smpl> @@ identifier _driver; @@ struct spi_driver _driver = { .driver = { - .bus = &spi_bus_type, }, }; // </smpl> Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-10-26mmc: Add module.h to drivers/mmc users assuming implicit presence.Paul Gortmaker
We are cleaning up the implicit presence of module.h; these guys are some of the people who just assume it will be there. Call it out explitly for those that really need it. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-21driver-core: remove conditionals around devicetree pointersGrant Likely
Having conditional around the of_match_table and the of_node pointers turns out to make driver code use ugly #ifdef blocks. Drop the conditionals and remove the #ifdef blocks from the affected drivers. Also tidy up minor whitespace issues within the same hunks. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-23mmc_spi: Recover from CRC errors for r/w operation over SPI.Sonic Zhang
The SPI bus is not reliable for large data transfers on all platforms. The current mmc_spi driver fails SD read/write commands immediately if occasional CRC errors are reported by the SD device. This patch makes the operation recover from CRC errors by repeating the last SD command. The retry count is set to 5 to ensure the driver passes stress tests. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2010-10-23mmc: Remove distinction between hw and phys segmentsMartin K. Petersen
We have deprecated the distinction between hardware and physical segments in the block layer. Consolidate the two limits into one in drivers/mmc/. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2010-08-14Merge branch 'next-spi' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'next-spi' of git://git.secretlab.ca/git/linux-2.6: spi/amba_pl022: Fix probe and remove hook section annotations. spi/mpc5121: change annotations for probe and remove functions spi/bitbang: reinitialize transfer parameters for every message spi/spi-gpio: add support for controllers without MISO or MOSI pin spi/bitbang: add support for SPI_MASTER_NO_{TX, RX} modes SPI100k: Fix 8-bit and RX-only transfers spi/mmc_spi: mmc_spi adaptations for SPI bus locking API spi/mmc_spi: SPI bus locking API, using mutex Fix trivial conflict in drivers/spi/mpc512x_psc_spi.c due to 'struct of_device' => 'struct platform_device' rename and __init/__exit to __devinit/__devexit fix.
2010-08-08mmc_spi: Fix unterminated of_match_tableAnton Vorontsov
commit 2ffe8c5f323c3b9749bf7bc2375d909d20bdbb15 ("of: refactor of_modalias_node() and remove explicit match table"), introduced an unterminated of_match_table, which may cause kernel to oops. This patch fixes the issue by adding an empty device ID. Signed-off-by: Anton Vorontsov <avorontsov@mvista.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-07-05of: refactor of_modalias_node() and remove explicit match table.Grant Likely
This patch tightens up the behaviour of of_modalias_node() to be more predicatable and to eliminate the explicit of_modalias_tablep[] that is currently used to override the first entry in the compatible list of a device. The override table was needed originally because spi and i2c drivers had no way to do of-style matching. Now that all devices can have an of_node pointer, and all drivers can have an of_match_table, the explicit override table is no longer needed because each driver can specify its own OF-style match data. The mpc8349emitx-mcu driver is modified to explicitly specify the correct device to bind against. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-07-03spi/mmc_spi: mmc_spi adaptations for SPI bus locking APIErnst Schwab
Modification of the mmc_spi driver to use the SPI bus locking API. With this, the mmc_spi driver can be used together with other SPI devices on the same SPI bus. The exclusive access to the SPI bus is now managed in the SPI layer. The counting of chip selects in the probe function is no longer needed. Signed-off-by: Ernst Schwab <eschwab@online.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Tested-by: Matt Fleming <matt@console-pimps.org> Tested-by: Antonio Ospite <ospite@studenti.unina.it>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-09-23spi: prefix modalias with "spi:"Anton Vorontsov
This makes it consistent with other buses (platform, i2c, vio, ...). I'm not sure why we use the prefixes, but there must be a reason. This was easy enough to do it, and I did it. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Jean Delvare <khali@linux-fr.org> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Samuel Ortiz <sameo@openedhand.com> Cc: "John W. Linville" <linville@tuxdriver.com> Acked-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-30spi: add spi_master flag wordDavid Brownell
Add a new spi_master.flags word listing constraints relevant to that controller. Define the first constraint bit: a half duplex restriction. Include that constraint in the OMAP1 MicroWire controller driver. Have the mmc_spi host be the first customer of this flag. Its coding relies heavily on full duplex transfers, so it must fail when the underlying controller driver won't perform them. (The spi_write_then_read routine could use it too: use the temporarily-withdrawn full-duplex speedup unless this flag is set, in which case the existing code applies. Similarly, any spi_master implementing only SPI_3WIRE should set the flag.) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-13mmc_spi: don't use EINVAL for possible transmission errorsWolfgang Muees
This patch changes the reported error code for the responses to a command from EINVAL to EFAULT/ENOSYS, as EINVAL is reserved for non-recoverable host errors, and the responses from the SD/MMC card may be because of recoverable transmission errors in the command or in the response. Response codes in SPI mode are NOT protected by a checksum, so don't trust them. Signed-off-by: Wolfgang Muees <wolfgang.mues@auerswald.de> Acked-by: Matt Fleming <matt@console-pimps.org> Signed-off-by: Pierre Ossman <pierre@ossman.eu>
2009-06-13mmc_spi: speedup for slow cards, less wear-outWolfgang Muees
Speedup for slow cards by transfering more data at once. This patch also reduces the amount of wear-out of the flash blocks because fewer partial blocks are written. Signed-off-by: Wolfgang Muees <wolfgang.mues@auerswald.de> Signed-off-by: Pierre Ossman <pierre@ossman.eu>
2009-04-08mmc_spi: support for non-byte-aligned cardsWolfgang Muees
A very large subset of SD cards in the market send their responses and data non-byte-aligned. So add logic to the mmc spi driver to handle this mess. Signed-off-by: Wolfgang Muees <wolfgang.mues@auerswald.de> Signed-off-by: Pierre Ossman <pierre@ossman.eu>
2009-04-08mmc_spi: convert timeout handling to jiffies and avoid busy waitingWolfgang Muees
SD/MMC card timeouts can be very high. So avoid busy-waiting, using the scheduler. Calculate all timeouts in jiffies units, because this will give us the correct sign when to involve the scheduler. Signed-off-by: Wolfgang Muees <wolfgang.mues@auerswald.de> Signed-off-by: Pierre Ossman <pierre@ossman.eu>
2009-03-24mmc_spi: adjust for delayed data token responseWolfgang Muees
Some cards are not able to send the data token in time, but miss the time frame for some bits(!). So synchronize to the start of the token. Signed-off-by: Wolfgang Muees <wolfgang.mues@auerswald.de> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2009-03-24mmc_spi: wait more bytes for card responseWolfgang Muees
Some cards are slower than the standard allows and need more time to respond to a command. Max. observed number of bytes was 12. Signed-off-by: Wolfgang Muees <wolfgang.mues@auerswald.de> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2009-03-24mmc_spi: allow setting of spi mode 3Wolfgang Muees
Allow the platform data structures to specify spi mode 3 (if there is a pullup on the clock line or the spi hardware is not able to serve spi mode 0). Signed-off-by: Wolfgang Muees <wolfgang.mues@auerswald.de> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-12-31mmc_spi: Add support for OpenFirmware bindingsAnton Vorontsov
The support is implemented via platform data accessors, new module (of_mmc_spi) will be created automatically when the driver compiles on OpenFirmware platforms. Link-time dependency will load the module automatically. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-11-08mmc: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-Off-By: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-10-12MMC: Use timeout values from CSRMatthew Fleming
Hard-coded timeout values of 250ms for writes and 100ms for reads are currently used for MMC transactions over SPI. The spec states that the timeout values from the card should be used. Signed-off-by: Matthew Fleming <matthew.fleming@imgtec.com> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-07-24mmc_spi: put signals to low power off fixJan Nikitenko
The original intention was to write a zero byte to mmc to force spi signals to low when doing power off. Somehow the spi_w8r8 call got there so a read followed the write of single zero byte. This patch changes that to simple write of zero byte without the following read. This way the power off is more reliable and completely sufficient. Signed-off-by: Jan Nikitenko <jan.nikitenko@gmail.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-07-15mmc: remove multiwrite capabilityPierre Ossman
Relax requirements on host controllers and only require that they do not report a transfer count than is larger than the actual one (i.e. a lower value is okay). This is how many other parts of the kernel behaves so upper layers should already be prepared to handle that scenario. This gives us a performance boost on MMC cards. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-07-15mmc: change .get_ro() callback semanticsAnton Vorontsov
Now get_ro() callback must return 0/1 values for its logical states, and negative errno values in case of error. If particular host instance doesn't support RO/WP switch, it should return -ENOSYS. This patch changes some hosts in two ways: 1. Now functions should be smart to not return negative values in "RO asserted" case (particularly gpio_ calls could return negative values for the outermost GPIOs). Also, board code usually passes get_ro() callbacks that directly return gpioreg & bit result, so at91_mci, imxmmc, pxamci and mmc_spi's get_ro() handlers need take special care when returning platform's values to the mmc core. 2. In case of host instance didn't implement get_ro() callback, it should really return -ENOSYS and let the mmc core decide what to do about it (mmc core thinks the same way as the hosts, so it isn't functional change). Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-07-15mmc_spi: add support for card-detection pollingAnton Vorontsov
This patch adds new platform data variable "caps", so platforms could pass theirs capabilities into MMC core (for example, platforms without interrupt on the CD line will most probably want to pass MMC_CAP_NEEDS_POLL). New platform get_cd() callback provided to optimize polling. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-04-29mmc: use get/put_unaligned_* helpersHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Tony Jones <tonyj@suse.de> Cc: Pierre Ossman <drzeus@drzeus.cx> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-05spi: use simplified spi_sync() calling conventionMarc Pignat
Given the patch which simplifies the spi_sync calling convention, this one updates the callers of that routine which tried using it according to the previous specification. (Most didn't.) Signed-off-by: Marc Pignat <marc.pignat@hevs.ch> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-27mmc_spi: Fix mmc-over-spi regressionDavid Brownell
Patch 49dce689ad4ef0fd1f970ef762168e4bd46f69a3 changed the sysfs data structures for SPI in a way which broke the MMC-over-SPI host driver. This patch fixes that regression by changing the scheme used to keep from knowingly trying to use a shared bus segment, and updates the adjacent comments slightly to better explain the issue. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-10-22[SG] Update drivers to use sg helpersJens Axboe
2007-10-16missing include in mmcAl Viro
AFAICS, fallout from repacing include of blkdev.h with include of bio.h. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16spi doesn't need class_deviceTony Jones
Make the SPI framework and drivers stop using class_device. Update docs accordingly ... highlighting just which sysfs paths should be "safe"/stable. Signed-off-by: Tony Jones <tonyj@suse.de> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-14Fix compile while compiling drivers/mmc/host/mmc_spi.o with !BLOCKDavid Brownell
Make sure the mmc_spi driver can build without CONFIG_BLOCK. Issue noted by "Avuton Olrich" <avuton@gmail.com> and randconfig. While that won't be a common configuration, sometimes embedded boards use SDIO to interface WLAN or Bluetooth chips (vs some parallel interface), and don't provide an MMC/SD socket for use with flash memory cards. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-23mmc_spi host driverDavid Brownell
This is the latest version of the MMC-over-SPI support. It works on 2.6.23-rc2 plus git-mmc (from rc1-mm2), along with the preceding patches which teach the rest of the MMC stack about SPI. The main issue of note is that sometimes cards need to be power cycled to recover after certain faults. Also, it may sometimes be necessary to disable CRCs. ("modprobe mmc_core use_spi_crc=n") Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: mikael.starvik@axis.com, Cc: Hans-Peter Nilsson <hp@axis.com> Cc: Jan Nikitenko <jan.nikitenko@gmail.com> Cc: Mike Lavender <mike@steroidmicros.com> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
