Some features can be configured by the companion I2C chips,
which may not be available at the probe time. Fix the issue
by returning -EPROBE_DEFER when the MMC controller slots
are not configured.
While at it, let's also add minimal device tree support so
omap24xx platforms can use this driver without legacy mode
since we claim to support device tree for mach-omap2 based
systems.
Although adding the minimal device tree support is not strictly
a fix, it does remove one of the last blockers for dropping a
bunch of legacy platform data for mach-omap2.
Cc: linux-mmc@vger.kernel.org
Acked-by: Chris Ball <cjb@laptop.org>
We are wrongly relying on device id for the DMA configuration
which can lead to wrong DMA channel being selected.
Fix the issue by using the standard resources like we should.
Suspend and resume of cards are handled by the protocol layer and
consequently the mmc_suspend|resume_host APIs are marked as deprecated.
While moving away from using the deprecated APIs, there are nothing
left to be done for the suspend and resume callbacks, so remove them.
Cc: Jarkko Lavinen <jarkko.lavinen@nokia.com>
Cc: linux-omap@vger.kernel.org
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
Signed-off-by: Chris Ball <cjb@laptop.org>
In commit 3451c067 (mmc: omap: add DMA engine support), some #if 0's
were used to comment out parts of the code. This has been in the code
for over a year and are not needed anymore (and the commented-out code
doesn't even compile). Remove them.
Signed-off-by: Luciano Coelho <coelho@ti.com>
The driver core clears the driver data to NULL after device_release
or on probe failure, since commit 0998d0631001288a5974afc0b2a5f568bcdecb4d
(device-core: Ensure drvdata = NULL when no driver is bound).
Thus, it is not needed to manually clear the device driver data to NULL.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Acked-by: Sonic Zhang <sonic.zhang@analog.com>
Acked-by: Seungwon Jeon <tgih.jun@samsung.com>
Acked-by: Shawn Guo <shawn.guo@linaro.org>
Acked-by: Adrian Hunter <adrian.hunter@intel.com>
Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com>
Acked-by: Jaehoon Chung <jh80.chung@samsung.com>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Acked-by: Tony Prisk <linux@prisktech.co.nz>
Pull ARM SoC Header cleanups from Olof Johansson:
"This is a collection of header file cleanups, mostly for OMAP and
AT91, that keeps moving the platforms in the direction of
multiplatform by removing the need for mach-dependent header files
used in drivers and other places."
Fix up mostly trivial conflicts as per Olof.
* tag 'headers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (106 commits)
ARM: OMAP2+: Move iommu/iovmm headers to platform_data
ARM: OMAP2+: Make some definitions local
ARM: OMAP2+: Move iommu2 to drivers/iommu/omap-iommu2.c
ARM: OMAP2+: Move plat/iovmm.h to include/linux/omap-iommu.h
ARM: OMAP2+: Move iopgtable header to drivers/iommu/
ARM: OMAP: Merge iommu2.h into iommu.h
atmel: move ATMEL_MAX_UART to platform_data/atmel.h
ARM: OMAP: Remove omap_init_consistent_dma_size()
arm: at91: move at91rm9200 rtc header in drivers/rtc
arm: at91: move reset controller header to arm/arm/mach-at91
arm: at91: move pit define to the driver
arm: at91: move at91_shdwc.h to arch/arm/mach-at91
arm: at91: move board header to arch/arm/mach-at91
arn: at91: move at91_tc.h to arch/arm/mach-at91
arm: at91 move at91_aic.h to arch/arm/mach-at91
arm: at91 move board.h to arch/arm/mach-at91
arm: at91: move platfarm_data to include/linux/platform_data/atmel.h
arm: at91: drop machine defconfig
ARM: OMAP: Remove NEED_MACH_GPIO_H
ARM: OMAP: Remove unnecessary mach and plat includes
CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Cc: Manuel Lauss <manuel.lauss@gmail.com>
Cc: Chris Ball <cjb@laptop.org>
Cc: "Michał Mirosław" <mirq-linux@rere.qmqm.pl>
Cc: Venkatraman S <svenkatr@ti.com>
Cc: Viresh Kumar <viresh.linux@gmail.com>
Cc: Ian Molton <ian@mnementh.co.uk>
Cc: Bruce Chang <brucechang@via.com.tw>
Cc: Harald Welte <HaraldWelte@viatech.com>
Cc: Pierre Ossman <pierre@ossman.eu>
Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
Acked-by: Ludovic Desroches <ludovic.desroches@atmel.com>
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer
needed.
omap-for-v3.8/cleanup-headers
arch/arm/mach-omap1/devices.c
arch/arm/mach-omap2/omap_hwmod_33xx_data.c
arch/arm/mach-omap2/omap_hwmod_3xxx_data.c
drivers/mmc/host/omap.c
Move plat/dma.h to plat-omap/dma-omap.h as part of single
zImage work
Similar to omap1, some of the omap2+ dma channel definitions are
used by some drivers. For moving omap2+ dma channel definitions
to mach-omap2/, the used ones should be defined locally to driver.
Drivers can eliminate it using DT, platform data, or IORESOURCE_DMA
And moving omap2+ DMA channel definitions to mach-omap2
Some of the omap1 dma channel definitions are used by some drivers.
For moving omap1 dma channel definitions to mach-omap1/, the used
ones should be defined locally to driver. Driver can eliminate it
by using DT, platform data, or IORESOURCE_DMA.
And moving OMAP1 DMA channel definitions to mach-omap1
This is needed for the ARM common zImage support.
We can use the existing slot features to pass omap1
specific options to the driver. For omap2 we don't
want to pass anything new as that will be eventually
moved to use device tree based init.
Note that this patch depends on earlier patch that
moves plat/mmc.h into include/linux/platform_data.
We need to remove this from plat for ARM common zImage
support.
Also remove includes not needed by the omap_hsmmc.c driver.
Acked-by: Venkatraman S <svenkatr@ti.com>
[tony@atomide.com: fold in removal of unused driver includes]
The function mmc_omap_report_irq uses raw printks and the actual output
was disabled by a static variable. Make the function use dev_vdbg macro
and use it under the standard CONFIG_MMC_DEBUG flag.
Signed-off-by: Venkatraman S <svenkatr@ti.com>
Acked-by: Felipe Balbi <balbi@ti.com>
Get rid of some unnecessary includes in the driver and
a few unused variables.
After commit 26b88520b80695a6fa5fd95b5d97c03f4daf87e0 ("mmc:
omap_hsmmc: remove private DMA API implementation"), the Nokia N800
here stopped booting:
[ 2.086181] Waiting for root device /dev/mmcblk0p1...
[ 2.324066] Unhandled fault: imprecise external abort (0x406) at 0x00000000
[ 2.331451] Internal error: : 406 [#1] ARM
[ 2.335784] Modules linked in:
[ 2.339050] CPU: 0 Not tainted (3.6.0-rc3 #60)
[ 2.344146] PC is at default_idle+0x28/0x30
[ 2.348602] LR is at trace_hardirqs_on_caller+0x15c/0x1b0
This turned out to be due to memory corruption caused by long-broken
PIO code in drivers/mmc/host/omap.c. (Previously, this driver had
been using DMA; but the above commit caused the MMC driver to fall
back to PIO mode with an unmodified Kconfig.)
The PIO code, added with the rest of the driver in commit
730c9b7e6630f786fcec026fb11d2e6f2c90fdcb ("[MMC] Add OMAP MMC host
driver"), confused bytes with 16-bit words. This bug caused memory
located after the PIO transfer buffer to be corrupted with transfers
larger than 32 bytes. The driver also did not increment the buffer
pointer after the transfer occurred. This bug resulted in data
corruption during any transfer larger than 64 bytes.
Signed-off-by: Paul Walmsley <paul@pwsan.com>
Reviewed-by: Felipe Balbi <balbi@ti.com>
Tested-by: Tony Lindgren <tony@atomide.com>
Remove the private DMA API implementation from omap, making it use
entirely the DMA engine API.
Add DMA engine support to the OMAP driver. This supplements the
private DMA API implementation contained within this driver, and the
driver can be switched at build time between using DMA engine and the
private DMA API.
Commit fa550189 (mmc: core: Prevent eMMC VCC supply to be cut from late init)
slightly affected timings for how things are done for the omap MMC driver
causing the MMC cards not getting detected any longer.
Turns out this was caused by buggy reg_shift initialization in the omap
MMC driver that was happening after mmc_add_host() was being called.
Fix this by initializing reg_shift before mmc_add_host() is called.
Cc: <stable@vger.kernel.org>
Commit b01a4f1c (mmc: omap: convert to per instance workqueue) initializes
the workqueue too late causing the following:
Unable to handle kernel NULL pointer dereference at virtual address 00000000
pgd = c0004000
[00000000] *pgd=00000000
Internal error: Oops: 5 [#1] SMP ARM
Modules linked in:
CPU: 0 Not tainted (3.4.0-08218-gb48b2c3 #158)
PC is at __queue_work+0x8/0x46c
LR is at queue_work_on+0x38/0x40
pc : [<c005bb4c>] lr : [<c005c00c>] psr: 60000193
sp : c0691e1c ip : 00000000 fp : c07374ac
r10: c7aae400 r9 : c0395700 r8 : 00000100
r7 : c0691e70 r6 : 00000000 r5 : 00000000 r4 : c7aae440
r3 : 00000001 r2 : c7aae440 r1 : 00000000 r0 : 00000000
Flags: nZCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment kernel
Control: 00c5387d Table: 80004000 DAC: 00000017
Process swapper/0 (pid: 0, stack limit = 0xc06902f8)
Stack: (0xc0691e1c to 0xc0692000)
Fix this by initializing the workqueue before mmc_omap_remove_slot()
get called. Tested on n770, looks like n800 at least still has some
other issue with MMC.
Commit b6e0703b (mmc: omap: make it behave well as a module) made some
__devinit changes but missed one function causing a section warning:
WARNING: vmlinux.o(.devinit.text+0x8604): Section mismatch in reference
from the function mmc_omap_probe)
The function __devinit mmc_omap_probe() references a function
__init mmc_omap_new_slot().
Get rid of boilerplate code by using module_platform_driver macro,
no functional changes.
Acked-by: Balaji T K <balajitk@ti.com>
Use proper __devinit and __devexit annotation for driver functions.
Instantiate the probe function for driver_ops instead of a probe in
the register function.
Currently, a global mmc_omap_wq is created for all instances of omap
hosts, which can lead to races and doesn't lend itself to unload the
module cleanly. Instead, create per instance workqueue and remove
the common workqueue.
Either OMAP_MMC_STAT_CARD_ERR or OMAP_MMC_STAT_END_OF_CMD might fire
if there is no host->cmd pointer.
Check for a valid host->cmd pointer before calling mmc_omap_cmd_done().
Signed-off-by: Michael Buesch <mb@bu3sch.de>
Cc: Tony Lindgren <tony@atomide.com>
Cc: <linux-mmc@vger.kernel.org>
Workqueue creation API has been updated and flush_scheduled_work() is
deprecated and scheduled to be removed.
* core/core.c: Use alloc_ordered_workqueue() instead of
create_singlethread_workqueue(). This removes an unnecessary
rescuer.
* host/omap.c: Create, use and flush mmc_omap_wq instead of the
system_wq.
* Flush host->mmc_carddetect_work directly on removal instead of using
flush_scheduled_work().
We have deprecated the distinction between hardware and physical
segments in the block layer. Consolidate the two limits into one in
drivers/mmc/.
Remove a BUG_ON for when interrupts are disabled during an MMC request.
During boot, interrupts can be disabled when a request is made, causing
this bug to be triggered. In reality, there's no reason this should halt
the kernel, as the driver has proved reliable in spite of disabled
interrupts, and additionally, there's nothing in this code that would
require interrupts to be enabled.
The only setup I've managed to make it trigger on is on the HTC Herald
during bootup when the driver is built into the kernel (mostly because
that's all I have). I believe it's related to the fact that on bootup I
get many timeout errors on "CMD5" while initializing the card. Each CMD5
timeout triggers that bug (I changed it to a WARN_ON to get it to boot in)
due to the fact that part of the timeout code involves sending the request
again. With interrupts turned off, that BUG would be triggered.
Signed-off-by: Cory Maccarrone <darkstar6262@gmail.com>
Even though many mmc host drivers pass a pm_message_t argument to
mmc_suspend_host() that argument isn't used the by MMC core. As host
drivers are converted to dev_pm_ops they'll have to construct
pm_message_t's (as they won't be passed by the PM subsystem any more) just
to appease the mmc suspend interface.
We might as well just delete the unused paramter.
Signed-off-by: Matt Fleming <matt@console-pimps.org>
Acked-by: Anton Vorontsov <cbouatmailru@gmail.com>
Acked-by: Michal Miroslaw <mirq-linux@rere.qmqm.pl>ZZ
Acked-by: Sascha Sommer <saschasommer@freenet.de>
The omap850 and omap730 use 16-bit registers instead of 32-bit, requiring
a modification of the register addresses in the mmc-omap driver. To
resolve this, a bit shift is performed on base register addresses, either
by 1 or 2 bits depending on the CPU in use. This yields the correct
registers for each CPU.
Signed-off-by: Marek Belisko <marek.belisko@open-nandra.com>
Cc: Ladislav Michl <ladis@linux-mips.org>
Cc: Ben Dooks <ben@fluff.org>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Remove check for host->iclk being NULL from error path since we already
know it is non-null and use return value from clk_get.
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
Merge branch '7xx-iosplit-plat-merge' into omap-for-linus
Free IRQ on remove.
Move the remaining headers under plat-omap/include/mach
to plat-omap/include/plat. Also search and replace the
files using these headers to include using the right path.
This was done with:
#!/bin/bash
mach_dir_old="arch/arm/plat-omap/include/mach"
plat_dir_new="arch/arm/plat-omap/include/plat"
headers=$(cd $mach_dir_old && ls *.h)
omap_dirs="arch/arm/*omap*/ \
drivers/video/omap \
sound/soc/omap"
other_files="drivers/leds/leds-ams-delta.c \
drivers/mfd/menelaus.c \
drivers/mfd/twl4030-core.c \
drivers/mtd/nand/ams-delta.c"
for header in $headers; do
old="#include <mach\/$header"
new="#include <plat\/$header"
for dir in $omap_dirs; do
find $dir -type f -name \*.[chS] | \
xargs sed -i "s/$old/$new/"
done
find drivers/ -type f -name \*omap*.[chS] | \
for file in $other_files; do
sed -i "s/$old/$new/" $file
done
done
for header in $(ls $mach_dir_old/*.h); do
git mv $header $plat_dir_new/
done
A pointer to mmc_omap_probe which lives in .init.text is passed to the
core via platform_driver_register and so the kernel might oops if probe
is called after the init code is discarded.
As requested by David Brownell platform_driver_probe is used instead of
moving the probe function to .devinit.text. This saves some memory, but
might have the downside that a device being registered after the call to
mmc_omap_init but before the init sections are discarded will not be
bound anymore to the driver.
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
Signed-off-by: Pierre Ossman <pierre@ossman.eu>
disable_irq() should wait for all running handlers to complete
before returning. As such, if it's used to disable an interrupt
from that interrupt's handler it will deadlock. This replaces
the dangerous instances with the _nosync() variant which doesn't
have this problem.
Signed-off-by: Ben Nizette <bn@niasdigital.com>
Remove unused power_pin
Eliminate the OMAP1 vs OMAP2 clock knowledge in the MMC driver.
Convert OMAP MMC driver to match clocks using the device ID and a
connection ID rather than a clock name. This allows us to eliminate
the OMAP1/OMAP2 differences for the function clock.
Add low-level initialization for hsmmc controller. Merged into
this patch patch are various improvments and board support by
Grazvydas Ignotas and David Brownell.
Also change wire4 to be wires, as some newer controllers support
8 data lines.
Cc: Pierre Ossman <drzeus-mmc@drzeus.cx>
Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
This will simplify the MMC low-level init, and make it more
flexible to add support for a newer MMC controller in the
following patches.
The patch rearranges platform data and gets rid of slot vs
controller confusion in the old data structures. Also fix
device id numbering in the clock code.
Some code snippets are based on an earlier patch by
Russell King <linux@arm.linux.org.uk>.
be static?"
This just leaves include/asm-arm/plat-* to deal with.
