[ Upstream commit 265984b36ce82fec67957d452dd2b22e010611e4 ]
The CMD19/CMD14 bus width test has been found to be unreliable in
some cases. It is not essential, so simply remove it.
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Cc: stable@vger.kernel.org
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
Since there no users of the struct sdhci_host, but the shdci host
drivers themselves, let's move the definition of it to the local sdhci
header.
The exported sdhci header then becomes empty, so let's remove it.
Just fix the comments, no functional changes.
Add ACPI HID INT344D for an Intel SDIO host controller.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core update from Greg KH:
"Here's the set of driver core patches for 3.19-rc1.
They are dominated by the removal of the .owner field in platform
drivers. They touch a lot of files, but they are "simple" changes,
just removing a line in a structure.
Other than that, a few minor driver core and debugfs changes. There
are some ath9k patches coming in through this tree that have been
acked by the wireless maintainers as they relied on the debugfs
changes.
Everything has been in linux-next for a while"
* tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits)
Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries"
fs: debugfs: add forward declaration for struct device type
firmware class: Deletion of an unnecessary check before the function call "vunmap"
firmware loader: fix hung task warning dump
devcoredump: provide a one-way disable function
device: Add dev_<level>_once variants
ath: use seq_file api for ath9k debugfs files
debugfs: add helper function to create device related seq_file
drivers/base: cacheinfo: remove noisy error boot message
Revert "core: platform: add warning if driver has no owner"
drivers: base: support cpu cache information interface to userspace via sysfs
drivers: base: add cpu_device_create to support per-cpu devices
topology: replace custom attribute macros with standard DEVICE_ATTR*
cpumask: factor out show_cpumap into separate helper function
driver core: Fix unbalanced device reference in drivers_probe
driver core: fix race with userland in device_add()
sysfs/kernfs: make read requests on pre-alloc files use the buffer.
sysfs/kernfs: allow attributes to request write buffer be pre-allocated.
fs: sysfs: return EGBIG on write if offset is larger than file size
Pull ACPI and power management updates from Rafael Wysocki:
"This time we have some more new material than we used to have during
the last couple of development cycles.
The most important part of it to me is the introduction of a unified
interface for accessing device properties provided by platform
firmware. It works with Device Trees and ACPI in a uniform way and
drivers using it need not worry about where the properties come from
as long as the platform firmware (either DT or ACPI) makes them
available. It covers both devices and "bare" device node objects
without struct device representation as that turns out to be necessary
in some cases. This has been in the works for quite a few months (and
development cycles) and has been approved by all of the relevant
maintainers.
On top of that, some drivers are switched over to the new interface
(at25, leds-gpio, gpio_keys_polled) and some additional changes are
made to the core GPIO subsystem to allow device drivers to manipulate
GPIOs in the "canonical" way on platforms that provide GPIO
information in their ACPI tables, but don't assign names to GPIO lines
(in which case the driver needs to do that on the basis of what it
knows about the device in question). That also has been approved by
the GPIO core maintainers and the rfkill driver is now going to use
it.
Second is support for hardware P-states in the intel_pstate driver.
It uses CPUID to detect whether or not the feature is supported by the
processor in which case it will be enabled by default. However, it
can be disabled entirely from the kernel command line if necessary.
Next is support for a platform firmware interface based on ACPI
operation regions used by the PMIC (Power Management Integrated
Circuit) chips on the Intel Baytrail-T and Baytrail-T-CR platforms.
That interface is used for manipulating power resources and for
thermal management: sensor temperature reporting, trip point setting
and so on.
Also the ACPI core is now going to support the _DEP configuration
information in a limited way. Basically, _DEP it supposed to reflect
off-the-hierarchy dependencies between devices which may be very
indirect, like when AML for one device accesses locations in an
operation region handled by another device's driver (usually, the
device depended on this way is a serial bus or GPIO controller). The
support added this time is sufficient to make the ACPI battery driver
work on Asus T100A, but it is general enough to be able to cover some
other use cases in the future.
Finally, we have a new cpufreq driver for the Loongson1B processor.
In addition to the above, there are fixes and cleanups all over the
place as usual and a traditional ACPICA update to a recent upstream
release.
As far as the fixes go, the ACPI LPSS (Low-power Subsystem) driver for
Intel platforms should be able to handle power management of the DMA
engine correctly, the cpufreq-dt driver should interact with the
thermal subsystem in a better way and the ACPI backlight driver should
handle some more corner cases, among other things.
On top of the ACPICA update there are fixes for race conditions in the
ACPICA's interrupt handling code which might lead to some random and
strange looking failures on some systems.
In the cleanups department the most visible part is the series of
commits targeted at getting rid of the CONFIG_PM_RUNTIME configuration
option. That was triggered by a discussion regarding the generic
power domains code during which we realized that trying to support
certain combinations of PM config options was painful and not really
worth it, because nobody would use them in production anyway. For
this reason, we decided to make CONFIG_PM_SLEEP select
CONFIG_PM_RUNTIME and that lead to the conclusion that the latter
became redundant and CONFIG_PM could be used instead of it. The
material here makes that replacement in a major part of the tree, but
there will be at least one more batch of that in the second part of
the merge window.
Specifics:
- Support for retrieving device properties information from ACPI _DSD
device configuration objects and a unified device properties
interface for device drivers (and subsystems) on top of that. As
stated above, this works with Device Trees and ACPI and allows
device drivers to be written in a platform firmware (DT or ACPI)
agnostic way. The at25, leds-gpio and gpio_keys_polled drivers are
now going to use this new interface and the GPIO subsystem is
additionally modified to allow device drivers to assign names to
GPIO resources returned by ACPI _CRS objects (in case _DSD is not
present or does not provide the expected data). The changes in
this set are mostly from Mika Westerberg, Rafael J Wysocki, Aaron
Lu, and Darren Hart with some fixes from others (Fabio Estevam,
Geert Uytterhoeven).
- Support for Hardware Managed Performance States (HWP) as described
in Volume 3, section 14.4, of the Intel SDM in the intel_pstate
driver. CPUID is used to detect whether or not the feature is
supported by the processor. If supported, it will be enabled
automatically unless the intel_pstate=no_hwp switch is present in
the kernel command line. From Dirk Brandewie.
- New Intel Broadwell-H ID for intel_pstate (Dirk Brandewie).
- Support for firmware interface based on ACPI operation regions used
by the PMIC chips on the Intel Baytrail-T and Baytrail-T-CR
platforms for power resource control and thermal management (Aaron
Lu).
- Limited support for retrieving off-the-hierarchy dependencies
between devices from ACPI _DEP device configuration objects and
deferred probing support for the ACPI battery driver based on the
_DEP information to make that driver work on Asus T100A (Lan
Tianyu).
- New cpufreq driver for the Loongson1B processor (Kelvin Cheung).
- ACPICA update to upstream revision 20141107 which only affects
tools (Bob Moore).
- Fixes for race conditions in the ACPICA's interrupt handling code
and in the ACPI code related to system suspend and resume (Lv Zheng
and Rafael J Wysocki).
- ACPI core fix for an RCU-related issue in the ioremap() regions
management code that slowed down significantly after CPUs had been
allowed to enter idle states even if they'd had RCU callbakcs
queued and triggered some problems in certain proprietary graphics
driver (and elsewhere). The fix replaces synchronize_rcu() in that
code with synchronize_rcu_expedited() which makes the issue go
away. From Konstantin Khlebnikov.
- ACPI LPSS (Low-Power Subsystem) driver fix to handle power
management of the DMA engine included into the LPSS correctly. The
problem is that the DMA engine doesn't have ACPI PM support of its
own and it simply is turned off when the last LPSS device having
ACPI PM support goes into D3cold. To work around that, the PM
domain used by the ACPI LPSS driver is redesigned so at least one
device with ACPI PM support will be on as long as the DMA engine is
in use. From Andy Shevchenko.
- ACPI backlight driver fix to avoid using it on "Win8-compatible"
systems where it doesn't work and where it was used by default by
mistake (Aaron Lu).
- Assorted minor ACPI core fixes and cleanups from Tomasz Nowicki,
Sudeep Holla, Huang Rui, Hanjun Guo, Fabian Frederick, and Ashwin
Chaugule (mostly related to the upcoming ARM64 support).
- Intel RAPL (Running Average Power Limit) power capping driver fixes
and improvements including new processor IDs (Jacob Pan).
- Generic power domains modification to power up domains after
attaching devices to them to meet the expectations of device
drivers and bus types assuming devices to be accessible at probe
time (Ulf Hansson).
- Preliminary support for controlling device clocks from the generic
power domains core code and modifications of the ARM/shmobile
platform to use that feature (Ulf Hansson).
- Assorted minor fixes and cleanups of the generic power domains core
code (Ulf Hansson, Geert Uytterhoeven).
- Assorted minor fixes and cleanups of the device clocks control code
in the PM core (Geert Uytterhoeven, Grygorii Strashko).
- Consolidation of device power management Kconfig options by making
CONFIG_PM_SLEEP select CONFIG_PM_RUNTIME and removing the latter
which is now redundant (Rafael J Wysocki and Kevin Hilman). That
is the first batch of the changes needed for this purpose.
- Core device runtime power management support code cleanup related
to the execution of callbacks (Andrzej Hajda).
- cpuidle ARM support improvements (Lorenzo Pieralisi).
- cpuidle cleanup related to the CPUIDLE_FLAG_TIME_VALID flag and a
new MAINTAINERS entry for ARM Exynos cpuidle (Daniel Lezcano and
Bartlomiej Zolnierkiewicz).
- New cpufreq driver callback (->ready) to be executed when the
cpufreq core is ready to use a given policy object and cpufreq-dt
driver modification to use that callback for cooling device
registration (Viresh Kumar).
- cpufreq core fixes and cleanups (Viresh Kumar, Vince Hsu, James
Geboski, Tomeu Vizoso).
- Assorted fixes and cleanups in the cpufreq-pcc, intel_pstate,
cpufreq-dt, pxa2xx cpufreq drivers (Lenny Szubowicz, Ethan Zhao,
Stefan Wahren, Petr Cvek).
- OPP (Operating Performance Points) framework modification to allow
OPPs to be removed too and update of a few cpufreq drivers
(cpufreq-dt, exynos5440, imx6q, cpufreq) to remove OPPs (added
during initialization) on driver removal (Viresh Kumar).
- Hibernation core fixes and cleanups (Tina Ruchandani and Markus
Elfring).
- PM Kconfig fix related to CPU power management (Pankaj Dubey).
- cpupower tool fix (Prarit Bhargava)"
* tag 'pm+acpi-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (120 commits)
i2c-omap / PM: Drop CONFIG_PM_RUNTIME from i2c-omap.c
dmaengine / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
tools: cpupower: fix return checks for sysfs_get_idlestate_count()
drivers: sh / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
e1000e / igb / PM: Eliminate CONFIG_PM_RUNTIME
MMC / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
MFD / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
misc / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
media / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
input / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
leds: leds-gpio: Fix multiple instances registration without 'label' property
iio / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
hsi / OMAP / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
i2c-hid / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
drm / exynos / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
gpio / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
hwrandom / exynos / PM: Use CONFIG_PM in #ifdef
block / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
USB / PM: Drop CONFIG_PM_RUNTIME from the USB core
PM: Merge the SET*_RUNTIME_PM_OPS() macros
After commit b2b49ccbdd54 (PM: Kconfig: Set PM_RUNTIME if PM_SLEEP is
selected) PM_RUNTIME is always set if PM is set, so #ifdef blocks
depending on CONFIG_PM_RUNTIME may now be changed to depend on
CONFIG_PM.
Replace CONFIG_PM_RUNTIME with CONFIG_PM everywhere under
drivers/mmc/.
Acked-by: Ulf Hansson <ulf.hansson@linaro.org>
Intel host controllers are capable of doing the bus
width test and of waiting while busy, so add the
capability flags.
SDHCI_QUIRK_NO_ENDATTR_IN_NOPDESC actually causes
standard-compliant behaviour by causing the flagging
of the last DMA transfer descriptor as the end
instead of there being an additional nop descriptor
which is flagged as the end. Consequently, it is
better to have the quirk.
Set the DMA mask during the first call to ->enable_dma() to
make use of the SDHCI_USE_64_BIT_DMA flag.
This patch is dependent on
commit 8a2f38ddfeb526c30b3ec209468172a30a38d996 ("ACPI / platform: provide default DMA mask")
which provides the dev->dma_mask pointer without
which dma_set_mask_and_coherent() will always fail.
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Braswell eMMC host controller specifies an incorrect
timeout clock frequncy in the capabilities registers.
The correct value is 1 MHz. A similar fix was done
for sdhci-pci, however in the sdhci-acpi case the
HID/UID is not unique so the capabilities register
values are matched also.
Pass HID and UID to probe_slot so extra setup
can be done for specific ids.
UID was made available on acpi_device since
commit ccf78040265b ("ACPI: Add _UID support for ACPI devices.")
Use it from there instead of reprocessing the
ACPI object info.
Add a HID (INT33BB) and UID (3) for a SD Card host controller.
Add quirk SDHCI_QUIRK2_STOP_WITH_TC for Intel host controllers.
commit 98e90de99a0c43bd434da814c882c4332441871e
"mmc: host: switch OF parser to use gpio descriptors"
switched the semantic behaviour of card detect and read
only flags such that the inversion capability flag would
only be set if inversion was explicitly specified in the
device tree, in the hopes that no-one was using double
inversion.
It turns out that the XOR:ing between the explicit
inversion was indeed in use, so we need to restore the
old semantics where both ways of inversion are checked
and the end result XOR:ed.
Reported-by: Javier Martinez Canillas <javier@dowhile0.org>
Tested-by: Javier Martinez Canillas <javier@dowhile0.org>
Similar to sdhci-pci controller, also add probe_slot
and remove_slot method in the sdhci-acpi driver.
Signed-off-by: Yunpeng Gao <yunpeng.gao@intel.com>
Signed-off-by: Chuanxiao Dong <chuanxiao.dong@intel.com>
This allows us to get rid of the #else condition, as the macro compiles
away to nothing if not enabled.
Signed-off-by: Peter Griffin <peter.griffin@linaro.org>
This is to enable DDR50 bus speed mode with 1.8V signaling capability
for BayTrail ACPI and PCI mode eMMC Controller.
Signed-off-by: Maurice Petallo <mauricex.r.petallo@intel.com>
Acked-by: Adrian Hunter <adrian.hunter@intel.com>
"SDHCI_QUIRK2_PRESET_VALUE_BROKEN" quirk is added to prohibit
preset value enabling for Baytrail eMMC controller.
Add sdhci_set_uhs_signaling() and always call the set_uhs_signaling
method. This avoids quirks being added into sdhci_set_uhs_signaling().
Tested-by: Markus Pargmann <mpa@pengutronix.de>
[Ulf Hansson] Resolved conflict
Signed-off-by: Chris Ball <chris@printf.net>
Rather than having platform_reset_enter/platform_reset_exit methods,
turn the core of the reset handling into a library function which
platforms can call at the appropriate moment in their (new) reset
method.
Intel SDIO has broken card detect so add a quirk to reflect that.
Add ACPI HID 80860F16 as a host controller for a SD card.
Some 80860F14 devices do not support card detect and must rely
completely on GPIO. Presently the card detect GPIO is used
only to wake-up from runtime suspend. Change to using
mmc_gpioid_request_cd() which will cause the SDHCI driver to
prefer the GPIO to the host controller's native card detect.
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc
Pull MMC updates from Chris Ball:
"MMC highlights for 3.14:
Core:
- Avoid get_cd() on cards marked nonremovable
Drivers:
- arasan: New driver for controllers found in e.g. Xilinx Zynq SoC
- dwmmc: Support Hisilicon K3 SoC controllers
- esdhc-imx: Support for HS200 mode, DDR modes on MX6, runtime PM
- sdhci-pci: Support O2Micro/BayHubTech controllers used in laptops
like Lenovo ThinkPad W540, Dell Latitude E5440, Dell Latitude E6540
- tegra: Support Tegra124 SoCs"
* tag 'mmc-updates-for-3.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (55 commits)
mmc: sdhci-pci: Fix possibility of chip->fixes being null
mmc: sdhci-pci: Fix BYT sd card getting stuck in runtime suspend
mmc: sdhci: Allow for long command timeouts
mmc: sdio: add a quirk for broken SDIO_CCCR_INTx polling
mmc: sdhci: fix lockdep error in tuning routine
mmc: dw_mmc: k3: remove clk_table
mmc: dw_mmc: fix dw_mci_get_cd
mmc: dw_mmc: fix sparse non static symbol warning
mmc: sdhci-esdhc-imx: fix warning during module remove function
mmc: sdhci-esdhc-imx: fix access hardirq-unsafe lock in atomic context
mmc: core: sd: implement proper support for sd3.0 au sizes
mmc: atmel-mci: add vmmc-supply support
mmc: sdhci-pci: add broken HS200 quirk for Intel Merrifield
mmc: sdhci: add quirk for broken HS200 support
mmc: arasan: Add driver for Arasan SDHCI
mmc: dw_mmc: add dw_mmc-k3 for k3 platform
mmc: dw_mmc: use slot-gpio to handle cd pin
mmc: sdhci-pci: add support of O2Micro/BayHubTech SD hosts
mmc: sdhci-pci: break out definitions to header file
mmc: tmio: fixup compile error
MAINTAINERS
Newer Intel PCHs with LPSS have the same SDHCI controller than Haswell but
ACPI ID is different. Add this ID to the driver list.
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Signed-off-by: Chris Ball <cjb@laptop.org>
The new descriptor based GPIO interface is now the recommended and safer
way of using GPIOs from device drivers. Convert the ACPI SDHCI driver to
use that interface.
Acked-by: Alexandre Courbot <acourbot@nvidia.com>
The code sequence:
dev->dma_mask = &dev->coherent_dma_mask;
dev->coherent_dma_mask = dma_mask;
bypasses the architectures check on the DMA mask. It can be replaced
with dma_coerce_mask_and_coherent(), avoiding the direct initialization
of this mask.
Add support for eMMC hardware reset for HID 80860F14.
Fix to return a negative error code in the gpio_to_irq() error
handling case instead of 0, as done elsewhere in this function.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Reviewed-by: Jingoo Han <jg1.han@samsung.com>
Enable runtime PM for ACPI HID 80860F14 SD cards, adding support for
card detect GPIO.
The driver core clears the driver data to NULL after device_release
or on probe failure, since commit 0998d0631001288a5974afc0b2a5f568bcdecb4d
(device-core: Ensure drvdata = NULL when no driver is bound).
Thus, it is not needed to manually clear the device driver data to NULL.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Acked-by: Sonic Zhang <sonic.zhang@analog.com>
Acked-by: Seungwon Jeon <tgih.jun@samsung.com>
Acked-by: Shawn Guo <shawn.guo@linaro.org>
Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com>
Acked-by: Jaehoon Chung <jh80.chung@samsung.com>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Acked-by: Tony Prisk <linux@prisktech.co.nz>
Add three more ACPI HIDs. Also, as some devices must be
further distinguished by ACPI UID, slot information is now
associated with HID and UID.
Initial runtime pm status is active.
Commit fa5501890d8974301042e0202d342a6cbe8609f4 introduced a performance
regression by adding mmc_power_up() to mmc_start_host(). mmc_power_up()
is not necessary to host controller initialization, it is part of card
initialization and is performed anyway asynchronously.
This patch allows a driver to leave the power up in asynchronous code
(as it was before).
On my current target platform this reduces driver initialization from:
[ 1.313220] initcall sdhci_acpi_driver_init+0x0/0x12 returned 0 after 102008 usecs
to this:
[ 1.217209] initcall sdhci_acpi_driver_init+0x0/0x12 returned 0 after 8331 usecs
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, and __devexit
from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Cc: Chris Ball <cjb@laptop.org>
Cc: Tony Prisk <linux@prisktech.co.nz>
Cc: Will Newton <will.newton@imgtec.com>
Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Cc: Thomas Abraham <thomas.abraham@linaro.org>
Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: "Rafael J. Wysocki" <rafael.j.wysocki@intel.com>
Cc: Mika Westerberg <mika.westerberg@linux.intel.com>
sdhci-acpi supports ACPI devices which have compatibility ID
PNP0D40, however it is not possible to know if those devices
will all work correctly with runtime-pm, so that must be configured
per hardware ID.
For INT33C6, several related quirks, capabilities and flags are set:
MMC_CAP_NONREMOVABLE
The SDIO card will never be removable
SDHCI_ACPI_RUNTIME_PM
Enable runtime-pm of the host controller
MMC_CAP_POWER_OFF_CARD
Enable runtime-pm of the SDIO card
MMC_PM_KEEP_POWER
SDIO card has the capability to remain powered up
during system suspend
SDHCI_QUIRK2_HOST_OFF_CARD_ON
Always do a full reset during system resume
because the card may be already initialized having
not been powered off.
Wake-ups from the INT33C6 host controller are not supported, so the
following capability must *not* be set:
MMC_PM_WAKE_SDIO_IRQ
Enable wake on card interrupt
Acked-by: Chris Ball <cjb@laptop.org>
Add a driver for SDHCI controllers enumerated via ACPI and identified
by the ACPI Compatibility ID PNP0D40 (or other SDHCI-specific ACPI
hardware IDs in the future).
[rjw: Added the changelog.]
Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com>
