path: root/drivers/mmc/host/sdhci-of-esdhc.c
2013-09-27mmc: sdhci-esdhc-imx: set actual_clock in clock settingDong Aisheng
This enables access the actual_clock via sys. root@imx6qsabreauto:~# cat /sys/kernel/debug/mmc0/ios clock: 198000000 Hz actual clock: 198000000 Hz vdd: 17 (2.9 ~ 3.0 V) bus mode: 2 (push-pull) chip select: 0 (don't care) power mode: 2 (on) bus width: 2 (4 bits) timing spec: 6 (sd uhs SDR104) signal voltage: 0 (1.80 V) Signed-off-by: Dong Aisheng <b29396@freescale.com> Acked-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-09-26mmc: sdhci-esdhc: move common esdhc_set_clock to platform driverDong Aisheng
We need a lot of imx6 specific things into common esdhc_set_clock for support SD3.0 and eMMC DDR mode which is not needed for power pc platforms, so esdhc_set_clock seems not so common anymore. Instead of keeping add platform specfics things into this common API, we choose to move that code into platform driver itself to handle. This can also exclude the dependency between imx and power pc on this headfile and is easy for maintain in the future. Signed-off-by: Dong Aisheng <b29396@freescale.com> Acked-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-08-26mmc: esdhc: add support to get voltage from device-treeHaijun Zhang
Add suppport to get voltage from device-tree node for esdhc host, if voltage-ranges was specified in device-tree node we can get ocr_mask instead of read from host capacity register. If not voltages still can be get from host capacity register. Signed-off-by: Haijun Zhang <haijun.zhang@freescale.com> Acked-by: Anton Vorontsov <anton@enomsg.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-07-05mmc: esdhc: Fix bug when writing to SDHCI_HOST_CONTROL registerOded Gabbay
The P2020 has a non-standard implementation of the SDHCI_HOST_CONTROL register. This patch adds a QUIRK in the SDHCI header to signal that a host controller has a non-standard SDHCI_HOST_CONTROL register. The patch adds a check to the function esdhc_writeb in file sdhci-of-esdhc.c, where it checks if the write is done to the SDHCI_HOST_CONTROL register and th host has the above mentioned QUIRK, then the function simply returns instead of writing to the register. The patch also detects if the processor is P2020 (by looking in dev tree) and if so, adds the QUIRK to the host->quirk2 Signed-off-by: Oded Gabbay <ogabbay@advaoptical.com> Reviewed-by: Anton Vorontsov <anton@enomsg.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-07-05mmc: esdhc: Add support for 8-bit bus width and non-removable cardOded Gabbay
This patch adds support of connecting an MMC media using an 8-bit bus width connection to Freescale's P2020 H/W SDHC controller. During the probe function, the generic function mmc_of_parse is called to detect whether the controller is configured with 8-bit bus width. Also, the generic function detects if the non-removable property is set in the device tree. The function esdhc_pltfm_bus_width was added because the bus width configuration is platform specific. Signed-off-by: Oded Gabbay <ogabbay@advaoptical.com> Reviewed-by: Anton Vorontsov <anton@enomsg.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-06-27mmc: sdhci-esdhc: calculate sdclk divider from controller clockLucas Stach
The SDCLK is divided down from the host controller clock. Host controller clock may be different from the maximum SDCLK, so get it from the platform, instead of just using the max SDCLK. Signed-off-by: Lucas Stach <l.stach@pengutronix.de> Acked-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-05-31mmc: sdhci: Add size for caller in init+registerChristian Daudt
Add a param to allow users of sdhci_pltfm to allocate private space in calls to sdhci_pltfm_init+sdhci_pltfm_register. This is implemented in the same way as sdhci does for its users. None of the users have been migrated yet and are passing in zero to retain their private allocation. - todo: migrate clients to using allocation this way - todo: remove priv variable once migration is complete Also removed unused variable in sdhci_pltfm_init fn Signed-off-by: Christian Daudt <csd@broadcom.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-03-22mmc: sdhci: Constify sdhci_ops structs where possibleLars-Peter Clausen
Basically all drivers can have sdhci_ops struct const, but almost none do. This patch constifies all sdhci_ops struct declarations where possible. The patch was auto-generated with the following coccinelle semantic patch: // <smpl> @r1@ identifier ops; identifier fld; @@ ops.fld = ...; @disable optional_qualifier@ identifier ops != r1.ops; @@ static +const struct sdhci_ops ops = { ... }; // </smpl> Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-03-22mmc: sdhci_pltfm: Constify sdhci_pltfm_dataLars-Peter Clausen
The sdhci_pltfm_data struct is never modified within the sdhci_pltfm module. So make the pdata parameter to sdhci_pltfm_init and sdhci_pltfm_register const. This allows drivers to declare their sdhci_pltfm_data struct as const. This patch also makes the sdhci_pltfm_data declarations const where possible. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-12-11Merge tag 'driver-core-3.8-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core updates from Greg Kroah-Hartman: "Here's the large driver core updates for 3.8-rc1. The biggest thing here is the various __dev* marking removals. This is going to be a pain for the merge with different subsystem trees, I know, but all of the patches included here have been ACKed by their various subsystem maintainers, as they wanted them to go through here. If this is too much of a pain, I can pull all of them out of this tree and just send you one with the other fixes/updates and then, after 3.8-rc1 is out, do the rest of the removals to ensure we catch them all, it's up to you. The merges should all be trivial, and Stephen has been doing them all in linux-next for a few weeks now quite easily. Other than the __dev* marking removals, there's nothing major here, some firmware loading updates and other minor things in the driver core. All of these have (much to Stephen's annoyance), been in linux-next for a while. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" Fixed up trivial conflicts in drivers/gpio/gpio-{em,stmpe}.c due to gpio update. * tag 'driver-core-3.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (93 commits) modpost.c: Stop checking __dev* section mismatches init.h: Remove __dev* sections from the kernel acpi: remove use of __devinit PCI: Remove __dev* markings PCI: Always build setup-bus when PCI is enabled PCI: Move pci_uevent into pci-driver.c PCI: Remove CONFIG_HOTPLUG ifdefs unicore32/PCI: Remove CONFIG_HOTPLUG ifdefs sh/PCI: Remove CONFIG_HOTPLUG ifdefs powerpc/PCI: Remove CONFIG_HOTPLUG ifdefs mips/PCI: Remove CONFIG_HOTPLUG ifdefs microblaze/PCI: Remove CONFIG_HOTPLUG ifdefs dma: remove use of __devinit dma: remove use of __devexit_p firewire: remove use of __devinitdata firewire: remove use of __devinit leds: remove use of __devexit leds: remove use of __devinit leds: remove use of __devexit_p mmc: remove use of __devexit ...
2012-12-06mmc: eSDHC: Recover from ADMA errorsHaijun Zhang
A-003500: False ADMA Error might be reported when ADMA is used for multiple block read command with Stop at Block Gap. If PROCTL[SABGREQ] is set when the particular block's data is received by the System side logic before entire block (with CRC) data is received by the SD side logic, and also if ADMA descriptor line is fetched at the same time, then DMA engine might report false ADMA error. eSDHC might not be able to Continue (PROCTL[CREQ]=1) after Stop at Block Gap. This issue will impact the eSDHC IP VVN2.3. Signed-off-by: Haijun Zhang <Haijun.Zhang@freescale.com> Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com> Acked-by: Anton Vorontsov <cbouatmailru@gmail.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-12-06mmc: sdhci-of-esdhc: support commands with busy response expecting TCJerry Huang
The IP versions older than 2.3 didn't support commands with busy response which expect the TC bit set. But after the VVN2.3, eSDHC IP has supported it. Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-11-28mmc: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Manuel Lauss <manuel.lauss@gmail.com> Cc: Chris Ball <cjb@laptop.org> Cc: "Michał Mirosław" <mirq-linux@rere.qmqm.pl> Cc: Jarkko Lavinen <jarkko.lavinen@nokia.com> Cc: Venkatraman S <svenkatr@ti.com> Cc: Viresh Kumar <viresh.linux@gmail.com> Cc: Ian Molton <ian@mnementh.co.uk> Cc: Bruce Chang <brucechang@via.com.tw> Cc: Harald Welte <HaraldWelte@viatech.com> Cc: Pierre Ossman <pierre@ossman.eu> Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28mmc: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Chris Ball <cjb@laptop.org> Cc: Manuel Lauss <manuel.lauss@gmail.com> Cc: "Michał Mirosław" <mirq-linux@rere.qmqm.pl> Cc: Jarkko Lavinen <jarkko.lavinen@nokia.com> Cc: Venkatraman S <svenkatr@ti.com> Cc: Ian Molton <ian@mnementh.co.uk> Cc: Bruce Chang <brucechang@via.com.tw> Cc: Harald Welte <HaraldWelte@viatech.com> Cc: Pierre Ossman <pierre@ossman.eu> Acked-by: Ludovic Desroches <ludovic.desroches@atmel.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28mmc: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Chris Ball <cjb@laptop.org> Cc: "Michał Mirosław" <mirq-linux@rere.qmqm.pl> Cc: Jarkko Lavinen <jarkko.lavinen@nokia.com> Cc: Venkatraman S <svenkatr@ti.com> Cc: Ian Molton <ian@mnementh.co.uk> Cc: Bruce Chang <brucechang@via.com.tw> Cc: Harald Welte <HaraldWelte@viatech.com> Cc: Pierre Ossman <pierre@ossman.eu> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-07mmc: sdhci-of-esdhc: disable CMD23 for some Freescale SoCsJerry Huang
CMD23 causes lots of errors in kernel on some freescale SoCs (P1020, P1021, P1022, P1024, P1025 and P4080) when MMC card used, which is because these controllers does not support CMD23, even on the SoCs which declares CMD23 is supported. Therefore, we'll not use CMD23. Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com> Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Acked-by: Anton Vorontsov <cbouatmailru@gmail.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-09-04mmc: eSDHC: Add ADMA mode supportJerry Huang
The register of eSDHC Host Controller Capabilities is not compatible with standard SDHC register, and eSDHC cannot support End Attribute in NOP ADMA descriptor. With this patch eSDHC can works in ADMA mode and performance can be improved. Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com> Signed-off-by: Pan Jiafei <Jiafei.Pan@freescale.com> Signed-off-by: Jason Jin <Jason.jin@freescale.com> Acked-by: Anton Vorontsov <cbouatmailru@gmail.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-03-25mmc: esdhc: Workaround for data crc error on p1010rdbJerry Huang
SD card read was failing (data crc error) on some cards at maximum possible frequency on P1010 (CCB frequency set to 400MHz). Some clock deviations are also observed at this frequency. Hence reduced the mmc clock freq. Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Singed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com> Acked-by: Anton Vorontsov <cbouatmailru@gmail.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-03-25mmc: esdhc: Implement power management for ESDHCJerry Huang
For FSL ESDHC controllers, when entering sleep the controller will power off, therefore the registers will lose their values, and the driver should save the value of registers during suspend and write them back during resume. Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com> Signed-off-by: Jiang Yutang <b14898@freescale.com> Acked-by: Anton Vorontsov <cbouatmailru@gmail.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-02-12mmc: esdhc: fix errors when booting kernel on Freescale eSDHC version 2.3Roy Zang
When eSDHC module is enabled on P5020/P3041/P2041/P1010 with eSDHC version 2.3, there is following errors: mmc0: Timeout waiting for hardware interrupt. mmc0: error -110 whilst initialising SD card mmc0: Unexpected interrupt 0x02000000. mmc0: Timeout waiting for hardware interrupt. mmc0: error -110 whilst initialising SD card mmc0: Unexpected interrupt 0x02000000. It is because eSDHC controller has different bit setting for PROCTL register at 0x28 comparing SD specification. This patch sets DMAS bits correctly for byte operation and does not change the default value of other field of PROCTL register. For other FSL chips, such as MPC8536/P2020, PROCTL[DMAS] bits are reserved and even if they are set to wrong bits, it will not take effective. Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Acked-by: Anton Vorontsov <cbouatmailru@gmail.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-01-11mmc: convert drivers/mmc/host/* to use module_platform_driver()Axel Lin
This patch converts the drivers in drivers/mmc/host/* to use the module_platform_driver() macro which makes the code smaller and a bit simpler. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: "Michał Mirosław" <mirq-linux@rere.qmqm.pl> Acked-by: David Brown <davidb@codeaurora.org> Acked-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Anton Vorontsov <cbouatmailru@gmail.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-12-19mmc: sdhci: remove "state" argument from sdhci_suspend_hostManuel Lauss
Drop the "state" argument from sdhci_suspend_host. Its only user is the PCI glue; this allows to move all SDHCI glues to use dev_pm_ops instead. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> Acked-by: Adrian Hunter <adrian.hunter@intel.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-10-26mmc: Add module.h to drivers/mmc users assuming implicit presence.Paul Gortmaker
We are cleaning up the implicit presence of module.h; these guys are some of the people who just assume it will be there. Call it out explitly for those that really need it. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-10-26mmc: sdhci-of-esdhc: Access Freescale eSDHC registers as 32-bitXu lei
Freescale eSDHC registers only support 32-bit accesses, this patch ensures that all Freescale eSDHC register accesses are 32-bit. Signed-off-by: Xu lei <B33228@freescale.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Anton Vorontsov <cbouatmailru@gmail.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-07-20mmc: sdhci: change sdhci-pltfm into a moduleShawn Guo
There are a couple of problems left from the sdhci pltfm and OF consolidation changes. * When building more than one sdhci-pltfm based drivers in the same image, linker will give multiple definition error on the sdhci-pltfm helper functions. For example right now, building sdhci-of-esdhc and sdhci-of-hlwd together is a valid combination from Kconfig view. * With the current build method, there is error with building the drivers as module, but module installation fails with modprobe. The patch fixes above problems by changing sdhci-pltfm into a module. To avoid EXPORT_SYMBOL on so many big endian IO accessors, it moves these accessors into sdhci-pltfm.h as the 'static inline' functions. As a result, sdhci.h needs to be included in sdhci-pltfm.h, and in turn can be removed from individual drivers which already include sdhci-pltfm.h. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-07-20mmc: sdhci: make sdhci-of device drivers self registeredShawn Guo
The patch turns the sdhci-of-core common stuff into helper functions added into sdhci-pltfm.c, and makes sdhci-of device drviers self registered using the same pair of .probe and .remove used by sdhci-pltfm device drivers. As a result, sdhci-of-core.c and sdhci-of.h can be eliminated with those common things merged into sdhci-pltfm.c and sdhci-pltfm.h respectively. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Anton Vorontsov <cbouatmailru@gmail.com> Reviewed-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-07-20mmc: sdhci: eliminate sdhci_of_host and sdhci_of_dataShawn Guo
The patch migrates the use of sdhci_of_host and sdhci_of_data to sdhci_pltfm_host and sdhci_pltfm_data, so that the former pair can be eliminated. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Reviewed-by: Grant Likely <grant.likely@secretlab.ca> Reviewed-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Anton Vorontsov <cbouatmailru@gmail.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-03-25mmc: sdhci-esdhc: remove SDHCI_QUIRK_NO_CARD_NO_RESET from esdhcRichard Zhu
sdhci-esdhc-imx does not need SDHCI_QUIRK_NO_CARD_NO_RESET. Make it OF-specific. Signed-off-by: Richard Zhu <Hong-Xing.Zhu@freescale.com> Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-03-17mmc: sdhci-esdhc: broken card detection is not a default quirkWolfram Sang
It can be worked around using a GPIO which will be done for i.MX later. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Anton Vorontsov <cbouatmailru@gmail.com> Tested-by: Marc Reilly <marc@cpdesign.com.au> Tested-by: Eric Benard <eric@eukrea.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2010-10-23mmc: sdhci-of-esdhc: factor out common stuffWolfram Sang
Put everything which can be shared between the OF and platform version of this driver into a local .h file. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Tested-by: Eric Bénard <eric@eukrea.com> [cjb: fix compile error: sdhci-esdhc.c->sdhci-esdhc.h] Signed-off-by: Chris Ball <cjb@laptop.org>
2010-05-27sdhci: build fix: rename SDHCI I/O accessor functionsMatt Fleming
Unfortunately some architectures #define their read{b,w,l} and write{b,w,l} I/O accessors which makes the SDHCI I/O accessor functions of the same names subject to preprocessing. This leads to the following compiler error, In file included from drivers/mmc/host/sdhci.c:26: drivers/mmc/host/sdhci.h:318:35: error: macro "writel" passed 3 arguments, but takes just 2 Rename the SDHCI I/O functions so that CONFIG_MMC_SDHCI_IO_ACCESSORS can be enabled for architectures that implement their read{b,w,l} and write{b,w,l} functions with macros. Signed-off-by: Matt Fleming <matt@console-pimps.org> Cc: Zhangfei Gao <zgao6@marvell.com> Acked-by: Anton Vorontsov <cbouatmailru@gmail.com> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Ben Dooks <ben-linux@fluff.org> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-17sdhci-of: reorganize driver to support additional hardwareAlbert Herranz
This patch breaks down sdhci-of into a core portion and a eSDHC portion, clearing the path to easily support additional hardware using the same OF driver. Signed-off-by: Albert Herranz <albert_herranz@yahoo.es> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
