path: root/drivers/mmc/host/wbsd.c
2007-08-09wbsd: fix section mismatch warningsGabriel C
This patch fixes the following section mismatch warnings ... WARNING: vmlinux.o(.init.text+0x29d40): Section mismatch: reference to .exit.text:wbsd_release_resources (between 'wbsd_init' and 'wbsd_probe') WARNING: vmlinux.o(.init.text+0x29d49): Section mismatch: reference to .exit.text:wbsd_free_mmc (between 'wbsd_init' and 'wbsd_probe') WARNING: vmlinux.o(.init.text+0x29f28): Section mismatch: reference to .exit.text:wbsd_free_mmc (between 'wbsd_init' and 'wbsd_probe') ... Signed-off-by: Gabriel Craciunescu <nix.or.die@googlemail.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-07-26mmc: remove redundant debug information from sdhci and wbsdPierre Ossman
Remove the extra debugging output that now is properly printed by the core. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-07-26mmc: update header file pathsPierre Ossman
Make sure all headers in the files reflect their true position in the tree. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-05-01wbsd: check for data opcode earlierPierre Ossman
Move the check for supported data opcodes to the beginning of the request function to avoid wedging the card. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-05-01mmc: Move host and card drivers to subdirsPierre Ossman
Clean up the drivers/mmc directory by moving card and host drivers into subdirectories. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
