A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Use the much more common pr_warn instead of pr_warning.
Other miscellanea:
o Coalesce formats
o Realign arguments
o Remove extra spaces when coalescing formats
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
The commit "mmc: wbsd: Move away from using deprecated APIs" introduced
a compiler warning, let's silence it.
Cc: Pierre Ossman <pierre@ossman.eu>
Signed-off-by: Chris Ball <cjb@laptop.org>
Suspend and resume of cards are being handled from the protocol layer
and consequently the mmc_suspend|resume_host APIs are deprecated.
This means we can simplify the suspend|resume callbacks by removing the
use of the deprecated APIs.
CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Cc: Manuel Lauss <manuel.lauss@gmail.com>
Cc: Chris Ball <cjb@laptop.org>
Cc: "Michał Mirosław" <mirq-linux@rere.qmqm.pl>
Cc: Jarkko Lavinen <jarkko.lavinen@nokia.com>
Cc: Venkatraman S <svenkatr@ti.com>
Cc: Viresh Kumar <viresh.linux@gmail.com>
Cc: Ian Molton <ian@mnementh.co.uk>
Cc: Bruce Chang <brucechang@via.com.tw>
Cc: Harald Welte <HaraldWelte@viatech.com>
Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
Acked-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer
needed.
All the files using printk function for displaying kernel messages
in the mmc driver have been replaced with corresponding macro.
Signed-off-by: Girish K S <girish.shivananjappa@linaro.org>
We have deprecated the distinction between hardware and physical
segments in the block layer. Consolidate the two limits into one in
drivers/mmc/.
Even though many mmc host drivers pass a pm_message_t argument to
mmc_suspend_host() that argument isn't used the by MMC core. As host
drivers are converted to dev_pm_ops they'll have to construct
pm_message_t's (as they won't be passed by the PM subsystem any more) just
to appease the mmc suspend interface.
We might as well just delete the unused paramter.
Signed-off-by: Matt Fleming <matt@console-pimps.org>
Acked-by: Anton Vorontsov <cbouatmailru@gmail.com>
Acked-by: Michal Miroslaw <mirq-linux@rere.qmqm.pl>ZZ
Acked-by: Sascha Sommer <saschasommer@freenet.de>
Cc: <linux-mmc@vger.kernel.org>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Signed-off-by: Pierre Ossman <pierre@ossman.eu>
Relax requirements on host controllers and only require that they do not
report a transfer count than is larger than the actual one (i.e. a lower
value is okay). This is how many other parts of the kernel behaves so
upper layers should already be prepared to handle that scenario. This
gives us a performance boost on MMC cards.
Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
DMA addresses are not pointers, so don't treat them as such. Avoids
compiler warnings when using 64-bit DMA addresses on a 32-bit system.
This patch fix warning :shadowing dma variable
and made use of module_param_named instead of module_param
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Now get_ro() callback must return 0/1 values for its logical states, and
negative errno values in case of error. If particular host instance doesn't
support RO/WP switch, it should return -ENOSYS.
This patch changes some hosts in two ways:
1. Now functions should be smart to not return negative values in
"RO asserted" case (particularly gpio_ calls could return negative
values for the outermost GPIOs).
Also, board code usually passes get_ro() callbacks that directly return
gpioreg & bit result, so at91_mci, imxmmc, pxamci and mmc_spi's get_ro()
handlers need take special care when returning platform's values to the
mmc core.
2. In case of host instance didn't implement get_ro() callback, it should
really return -ENOSYS and let the mmc core decide what to do about it
(mmc core thinks the same way as the hosts, so it isn't functional
change).
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
With CONFIG_DEBUG_SHIRQ set we will get an interrupt as soon as we
allocate one. Tasklets may be scheduled in the interrupt handler but they
will be initialized after the handler returns, causing a BUG() in
kernel/softirq.c when they run.
Should fix this Fedora bug report:
https://bugzilla.redhat.com/show_bug.cgi?id=449817
Signed-off-by: Chuck Ebbert <cebbert@redhat.com>
Acked-by: Pierre Ossman <drzeus@drzeus.cx>
Cc: <stable@kernel.org>
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is
prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable MMC host
platform drivers, to re-enable auto loading.
Also, add missing owner declarations in driver init.
[dbrownell@users.sourceforge.net: registration fixes]
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Do a full scan of the directory to try and be a bit more proactive,
instead of waiting for things to break.
Remove the BYTEBLOCK capability and let the broken hosts fail the
requests with -EINVAL instead.
Convert the MMC layer to use standard error codes and not its own,
incompatible values.
This patch fixes the following section mismatch warnings
WARNING: vmlinux.o(.init.text+0x29d40): Section mismatch: reference to .exit.text:wbsd_release_resources (between 'wbsd_init' and 'wbsd_probe')
WARNING: vmlinux.o(.init.text+0x29d49): Section mismatch: reference to .exit.text:wbsd_free_mmc (between 'wbsd_init' and 'wbsd_probe')
WARNING: vmlinux.o(.init.text+0x29f28): Section mismatch: reference to .exit.text:wbsd_free_mmc (between 'wbsd_init' and 'wbsd_probe')
Signed-off-by: Gabriel Craciunescu <nix.or.die@googlemail.com>
Acked-by: Sam Ravnborg <sam@ravnborg.org>
Remove the extra debugging output that now is properly printed
by the core.
Make sure all headers in the files reflect their true position
in the tree.
Move the check for supported data opcodes to the beginning of the
request function to avoid wedging the card.
Clean up the drivers/mmc directory by moving card and host drivers
into subdirectories.
