arch/arm/mach-tegra/tegra3_usb_phy.c
arch/arm/mach-tegra/usb_phy.c
drivers/usb/gadget/tegra_udc.c
drivers/usb/otg/Makefile
drivers/video/tegra/fb.c
sound/soc/tegra/tegra_pcm.c
Hack to avoid extensive warning messages from Redpine Signals LiteFi
driver due to unaligned DMA accesses.
The gpio mode of pin is configured when setting
direction and hence this call is no more required.
Change-Id: I2c9bce83a283f6ef45754075cf3b7b1bc5c1d9ac
Reviewed-on: http://git-master/r/119612
Reviewed-by: Simone Willett <swillett@nvidia.com>
- Add compilation flag to treat warning as error
- Modified sdhci-tegra.c to remove compile warning
bug 949219
Change-Id: I704ea95e3b8ca8862482b6793b71ca4e5114f832
Signed-off-by: schowdary <schowdary@nvidia.com>
Reviewed-on: http://git-master/r/118036
Without card clock, inband interrupt is not working on
some wifi chips.
Bug 981683
This reverts commit b31946b34507209f26c6d709e23fd1c0cedd25f8.
Change-Id: I2dd86edb2445bd6db7917adf509b7a018d31aaed
Reviewed-on: http://git-master/r/110839
Signed-off-by: Pavan Kunapuli <pkunapuli@nvidia.com>
Change-Id: I6f2266ac5b6bd9585272958b4b8a89af1b3cdffb
Reviewed-on: http://git-master/r/119009
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
Tested-by: Lokesh Pathak <lpathak@nvidia.com>
Modified the mmc_poweroff to resume before sending the poweroff
notification command. In sleep mode only AWAKE and RESET commands are
allowed, so before sending the poweroff notification command resume from
sleep mode and then send the notification command.
PowerOff Notify is tested on a Synopsis Designware Host Controller
(eMMC 4.5). The suspend to RAM and resume works fine.
Change-Id: Ib4642a29e423aee6041a92cc72a388d677674ae3
Signed-off-by: Girish K S <girish.shivananjappa@linaro.org>
Tested-by: Girish K S <girish.shivananjappa@linaro.org>
Reviewed-by: Saugata Das <saugata.das@linaro.org>
Signed-off-by: Chris Ball <cjb@laptop.org>
Bug 1007644
Bug 936069
Change-Id: I2e3d421c82eb765cb640876691ffe4818d7e146b
Reviewed-on: http://git-master/r/118918
Reviewed-by: Min-wuk Lee <mlee@nvidia.com>
Reviewed-by: Naveen Kumar Arepalli <naveenk@nvidia.com>
Host may now use MMC_CAP2_NO_SLEEP_CMD to disable the use
of eMMC sleep/awake command.
This option can be used when your platform has a buggy
kernel crash dump software, which is supposed to store
the dump on the eMMC, but is not able to wake up the eMMC
from sleep state.
In particular, failures have been seen with u-boot; even if
it is fixed there, platforms will be slow to update their
bootloader binaries.
Change-Id: I403f4b2a231dde087095a660189dc2f4e79edfd5
Signed-off-by: Ulf Hansson <ulf.hansson@stericsson.com>
Reviewed-by: Hanumath Prasad <hanumath.prasad@stericsson.com>
Reviewed-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
Acked-by: Subhash Jadavani <subhashj@codeaurora.org>
Bug 1007644
Bug 936069
Change-Id: I8b2834e154e338a97bd6d82f177809d47d318ff0
Reviewed-on: http://git-master/r/118914
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
If eMMC sleep support is enabled, set MMC_PM_KEEP_POWER
to avoid host power off and power on. Instead, restore
the host context in resume.
Bug 1007644
Bug 936069
Change-Id: I74578bb1f9e297b3af6bd79b9215364334984836
Reviewed-on: http://git-master/r/118913
For SDIO devices, MMC_PM_KEEP_POWER would be set
by wifi driver during suspend. It need not be set
by default.
Bug 1011349
Change-Id: I779a438b45afed2cc0fd7283d89c24e9049cfe39
Reviewed-on: http://git-master/r/118954
GVS: Gerrit_Virtual_Submit
Unlike SDSC and SDHC, for SDXC cards CMD20 needs to be
issued to meet the class performance for speed class
recording. Adding mmc_speed_class_control() which should
be used by an AV recording app/utility before starting
recording on an SDXC card.
Bug 969360
Reviewed-on: http://git-master/r/39394
Reviewed-on: http://git-master/r/115685
(cherry picked from commit 04b8d1287a95e1882d956cdf7997015350408a3c)
Change-Id: Id567effb476ee580de3d49b70201ebae5a13360a
Reviewed-on: http://git-master/r/118038
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Without the card clock, inband interrupt is not working on
some wifi chips.
Bug 981683
This reverts commit 0467657691ba046b492504272baf7c626d9a3713.
Reviewed-on: http://git-master/r/110826
(cherry picked from commit 33c8e504328387097ed0160082cce6b36b994bd8)
Change-Id: I6683720a9bda1f779a63133d8ca64a024c5d8a08
Reviewed-on: http://git-master/r/116707
Disable the normal interrupts signalling before
tuning and enable it only after the entire tuning
process is done.
Bug 860102
Reviewed-on: http://git-master/r/111589
(cherry picked from commit 15a97f33f6cf1fc1c25441142f69f62ce5f7029b)
Change-Id: I9eba9af65a50928dc4bb475e06cbf401963751bc
Reviewed-on: http://git-master/r/116433
The host clock configuration in SDR50 mode is
incorrectly grouped with DDR50 mode due to which
DDR50 mode clock limits are wrongly applied even
in SDR50 mode.
Bug 965298
Reviewed-on: http://git-master/r/111566
(cherry picked from commit 2ad290d477e8198bace22d2623856555f07b9bf9)
Change-Id: I5d3a446e39a349209e5842d385c1b728bfb7012e
Reviewed-on: http://git-master/r/116428
Reviewed-by: Pavan Kunapuli <pkunapuli@nvidia.com>
Tested-by: Pavan Kunapuli <pkunapuli@nvidia.com>
This is a WAR solution that allows for the turning on
SD DPD feature.
The original issue is that enabling SD DPD immediately after device comes
out of LP0 causes ULPI disconnect. The root cause of that is
not known.
The WAR is to delay the enabling of SD DPD for 100ms after
device comes out of LP0.
Bug 929628
Change-Id: I946771a8e92459464ce571295f96f197db25c061
Signed-off-by: Bitan Biswas <bbiswas@nvidia.com>
(cherry picked from commit beba2b34af7ff9313aed074342b9bb86b12620a8)
Reviewed-on: http://git-master/r/113391
Reviewed-by: Wen Yi <wyi@nvidia.com>
Tested-by: Wen Yi <wyi@nvidia.com>
If there are errors happened in sdhci_suspend_host, handle it so that
when the function returns with an error, the host's behaviour is the
same before this function call, e.g. card detection is enabled and
tuning timer is active, etc.
Signed-off-by: Philip Rakity <prakity@marvell.com>
Signed-off-by: Aaron Lu <aaron.lu@amd.com>
Cc: Adrian Hunter <adrian.hunter@intel.com>
(cherry picked from commit 38a60ea2e7b33ab33ee11d6ef527f259edb102cf)
Bug 984811
Change-Id: I532c3914cecf63291a23baa669c650b4ac5448e4
Signed-off-by: Sang-Hun Lee <sanlee@nvidia.com>
Reviewed-on: http://git-master/r/106351
Reviewed-by: Thomas Cherry <tcherry@nvidia.com>
Adding new sysfs entry for product revision which is needed by
mNAND health and status user space tool.
Bug 974823.
Change-Id: I4a07a5e6c1c81e2b7a4c1ed024e987e06f9f87c8
Signed-off-by: Vishal Singh <vissingh@nvidia.com>
Reviewed-on: http://git-master/r/103366
Reviewed-by: Sandeep Trasi <strasi@nvidia.com>
Reviewed-by: Luis Dib <ldib@nvidia.com>
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Adding CMD56 implementation.
Doing the following for manfid 0x90 and FW revisions 0x73 and
0x7b (both are non-standard custom FW):
1. Adding change to issue BKOPS_START whenever 20 seconds have gone
by without any slow write operations.
2. Adding change to issue CMD56 to refresh (custom feature) 1 block
whenever 60 seconds have gone by without any slow write operations.
Corresponding changes are already there in embedded branches:
http://git-master/r/#change,93247
http://git-master/r/#change,97555
Bug 847037.
Bug 874256.
Bug 963737.
Change-Id: Ie36b52620a75320abfedc36d1408647b36eddb46
Reviewed-on: http://git-master/r/102259
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
check for platform limits before setting the voltage
Bug 979504
Change-Id: Iea78be15d6a0eea0f4344c9b78ff9366f4759af8
Signed-off-by: naveen kumar arepalli <naveenk@nvidia.com>
Reviewed-on: http://git-master/r/104711
mmc_test currently shows test case number as 0 for all test cases.
Correcting this to depict the correct test case number.
Bug 976137.
Change-Id: Ifa7bdd08d537ef20a3303594938a771e823d4e3b
Reviewed-on: http://git-master/r/103368
Reviewed-by: Shridhar Rasal <srasal@nvidia.com>
Tested-by: Shridhar Rasal <srasal@nvidia.com>
Merges of dma changes from mainline reported conflict and
it was not got resolved properly.
Fix the resolution issue.
Change-Id: I7edc5effc0b9a61363e77e6cc39eb62e315396d0
Reviewed-on: http://git-master/r/102590
Adding a new config option and enabling background ops in driver.
Correcting the EXT_CSD byte that needs to be written in order to
trigger background ops in the MMC firmware.
Bug 847037.
Change-Id: Ibc517540cab43fa5070b142a416f6b67f2f7e7be
Reviewed-on: http://git-master/r/99117
Set the eMMC ddr mode clock dynamically based on emc
clock rate. If ddr clock limit is specified and the emc
clock is less than max emc freq, then limit emmc ddr
clk. If not, set the max eMMC ddr clock.
Bug 967719
Change-Id: I9f70077c4ac4bb1f3e6d894fcb8420b1aba284dd
Reviewed-on: http://git-master/r/100579
In SDR50 mode, set the controller clock to double
the requested clock to ensure that the core voltage
is maintained at a min of 1.2V.
Bug 965298
Change-Id: I557a07de97efd6b44f812a11da657e03d3ddefd0
Reviewed-on: http://git-master/r/101522
Retries should be done only after abort command
is issued for the current failed transfer. The block
layer already has an implementation for retrying.
No need for the extra retries.
Bug 961761
Bug 922239
Change-Id: I07f60e85e093b725007727833739013f8fd66d43
Reviewed-on: http://git-master/r/100563
Some boards don't have a vddio regulator for few rails hence not getting
the regulator handle. And we assume that those rails are always powered.
Hence rephrased the error message and lowered the loglevel to KERN_INFO.
Bug 976177
Change-Id: I92b82f75934eaf7137584a625065e3389b6ae1b7
Signed-off-by: Ramalingam C <ramalingamc@nvidia.com>
Reviewed-on: http://git-master/r/100490
The CL disables SDIO card clock when idle for Tegra 3 only.
Bonus: conditional build for some tegra 3 functionalities.
Bug 975541
Change-Id: I097c4771f3565bf9137d7854ada10c1fe8535056
Signed-off-by: Mursalin Akon <makon@nvidia.com>
Reviewed-on: http://git-master/r/99707
Reviewed-by: Allen Martin <amartin@nvidia.com>
Reviewed-by: Peer Chen <pchen@nvidia.com>
enable MMC_PM_IGNORE_PM_NOTIFY for all sd instances
Bug 956238
Bug 932086
Change-Id: I4d455e480eabace403719f1813d97abfa4d01924
Reviewed-on: http://git-master/r/96071
Reviewed-by: Rakesh Kumar <krakesh@nvidia.com>
Disable card clock before disabling internal clock to
ensure that there are no abnormal clock waveforms.
Bug 947058
Change-Id: I98a3f7f63b4380b62bead05f1018d3cddc0ac217
Reviewed-on: http://git-master/r/95396
Disable SDIO card clock when there are no commands/
data transfers on the SD bus.
Bug 958954
Bug 955742
Bug 952344
Change-Id: I7390be0406f7e46c0eb88ede2ae6f904b2181306
Reviewed-on: http://git-master/r/95390
bug 949219
Change-Id: I5942ba86bd1cbe1f1bd06a7c9f51a10d83e6cabb
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/92819
Enable embedded sdio code, iff MMC_EMBEDDED_SDIO
Kconfig is on.
Bug 956238
Change-Id: I16539f5cad5fc66082af2f569ea36a54c12457e3
Reviewed-on: http://git-master/r/90655
Add inline wrappers for device_prep_slave_sg() and device_prep_dma_cyclic()
interfaces to hide new parameter from current users of affected interfaces.
Convert current users to use new wrappers instead of direct calls.
Suggested by Russell King [https://lkml.org/lkml/2012/2/3/269].
Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com>
Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
cherry-picked from mainline commit
16052827d98fbc13c31ebad560af4bd53e2b4dd5
Change-Id: I929a49556539621a0546829e88b3caa498c94be2
Reviewed-on: http://git-master/r/94463
Initialize pm_caps and pm_flags through platform
data.
Bug 956238
Change-Id: I400f6e92541fa2e63ccc7f829e204d5eef4697fc
Reviewed-on: http://git-master/r/90790
Tested-by: Gerrit_Virtual_Submit
Enable quirk SDHCI_QUIRK_BROKEN_CARD_DETECTION.
Also, implemented tegra_sdhci_get_cd() to return
the card presence status.
Bug 948943
Change-Id: I42eed23f951304e331a235f5a9199b70ba5e96b5
Reviewed-on: http://git-master/r/87766
Add get_cd callback in the host ops to get the
card presence status incase SDHCI_QUIRK_BROKEN_
CARD_DETECTION is enabled.
Bug 948943
Change-Id: I788d9e907920a0aeb79784751ec0df25bc2a72d6
Reviewed-on: http://git-master/r/87765
if SDHCI_QUIRK_NO_HISPD_BIT is set in host->quirks,
don't set SDHCI_CTRL_HISPD in sdhci_host_control register.
bug 929985
Signed-off-by: Harry Hong <hhong@nvidia.com>
Reviewed-on: http://git-master/r/79933
(cherry picked from commit 194670660af90b2bb7bc0efea920332459296141)
Change-Id: I7b5f58f5078886309610e9e4cc2bad83f0788168
Reviewed-on: http://git-master/r/87704
Bug 930113
Change-Id: I15fede503217152263905d8f7f56d3392e460e8a
Signed-off-by: Sachin Nikam <snikam@nvidia.com>
Reviewed-on: http://git-master/r/87241
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
Bug 942826
Change-Id: Ie782f17c51e78994e0fc96da3fbbe2e6592f58dc
Signed-off-by: Rakesh Kumar <krakesh@nvidia.com>
Reviewed-on: http://git-master/r/84697
Reviewed-by: Rakesh Goyal <rgoyal@nvidia.com>
Tested-by: Rakesh Goyal <rgoyal@nvidia.com>
support to change *ios* parameteres
bug 930113
Change-Id: I469db49ec9e4ca533ba3be654455ae6b4b052d1c
Signed-off-by: Shridhar Rasal <srasal@nvidia.com>
Reviewed-on: http://git-master/r/79238
This bit should always be 0 according to TRM.
Bug 929985
Reviewed-on: http://git-master/r/79975
(cherry picked from commit 9371d04b4f9d79f1e03e60120bf1bba28af77d4b)
Change-Id: I225d6b5442f63809a77ce92d9cbd152dc4112ac4
Reviewed-on: http://git-master/r/87640
Tested-by: Harry Hong <hhong@nvidia.com>
MMC_PM_KEEP_POWER was used on the wrong structure member, which might
cause card interrupt lost during suspend/resume
Bug 936503
Change-Id: Ib42d7a5ba27c0175e944223967c416a3c80802dd
Signed-off-by: David Schalig <dschalig@nvidia.com>
Reviewed-on: http://git-master/r/83011
Reviewed-on: http://git-master/r/86020
This reverts commit caa6566d4fb8539d09276c1bcb818444af675624.
MMC_PM_KEEP_POWER should be used only for sdio as power-on/off code is
implemented only for sdio.
This may also create regression in power.
Bug 938011
Bug 943131
Change-Id: I41a29acb3dd6f3396c97ab78f9704f9b39359675
Signed-off-by: Bharat Nihalani <bnihalani@nvidia.com>
Reviewed-on: http://git-master/r/85213
Reviewed-by: Om Prakash Singh <omp@nvidia.com>
Tested-by: Om Prakash Singh <omp@nvidia.com>
In case of non standard clock, preset value
should not be enabled from sdhci driver as
it would make clock divider programming in-
effective.
Bug 937318
Change-Id: I5eaeab538a4978dd8c03501c3dcba2e8a92eea59
Reviewed-on: http://git-master/r/84807
Tegra sdmmc controllers support fixed sampling
frequency tuning. Also, frequency tuning is used
to find the ideal tap delay value which ensures
reliable high speed data transfers. Added support
for the same. In SDR50 mode, setting controller clk
rate to 208MHz as lower clk rates result in CRC
errors.
Bug 919232
Originally reviewed on: http://git-master/r/72596
Change-Id: I8825b4bdbc8533005bc76c54f5d1660f18304e4d
Reviewed-on: http://git-master/r/77798
During resume mmc_power_up is not necessary for eMMC
Bug 932606
Change-Id: I6dd6e7c4f5582ecca8b9c459e3537b05cce69e69
Signed-off-by: naveen kumar arepalli<naveenk@nvidia.com>
Reviewed-on: http://git-master/r/83709
Enable the regulator with out any dependency on slot
regulator
Bug 932739
Signed-off-by: vjagadish <vjagadish@nvidia.com>
Reviewed-on: http://git-master/r/78745
(cherry picked from commit 83d256fe3c269f59436a7cc08e46235ab5c067c8)
Change-Id: I80fbaef6b76fd4bb7990c29499a62abfe46e5150
Signed-off-by: Pritesh Raithatha <praithatha@nvidia.com>
Reviewed-on: http://git-master/r/82711
Issue BKOPS when the request queue is empty.
Before handling any new request, issue HPI
if bkops is being performed.
bug 919232
Originally reviewed on http://git-master/r/69779
Change-Id: Ic9258ebfea7f9cde96525371a5ef9d6d003ebf2f
Reviewed-on: http://git-master/r/77335
Added support for starting BKOPS and issuing HPI
commands which are supported by eMMC v4.41 and eMMC
v4.5 cards.
Enable BKOPS and HPI interrupt if the host and card
support it.
Originally reviewed on: http://git-master/r/69778
Bug 919232
Change-Id: I09b33ddc18013e2eeb505fdb28dd8357fa75b569
Reviewed-on: http://git-master/r/77319
enabling quirk *SDHCI_QUIRK_NO_CALC_MAX_DISCARD_TO* for not to
calculate max discard timeout.
bug 930767
Change-Id: Id2ca4fd202961d1997c9269eb0d437a6fca241cf
Reviewed-on: http://git-master/r/79840
Adding SDHCI_QUIRK_NO_CALC_MAX_DISCARD_TO for not to calculate
max_discard_to which is deviation in setting max_discard.
For some host controllers, combination of
1) calculated non-zero value of max_discard_to and
2) erase_group_def not set
can result into setting max_discard value to pref_erase in
sectors which is very less, so it takes long time for erase.
With this change host controller can specify to calculate
max_discard_to and based on that max_discard value will be set.
bug 930767
Change-Id: I2c64ef8a6821620f2a65c06e25d2af68e3554a75
Reviewed-on: http://git-master/r/79839
