path: root/drivers/mmc
2012-08-01Merge branch 'dmaengine' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull ARM DMA engine updates from Russell King: "This looks scary at first glance, but what it is is: - a rework of the sa11x0 DMA engine driver merged during the previous cycle, to extract a common set of helper functions for DMA engine implementations. - conversion of amba-pl08x.c to use these helper functions. - addition of OMAP DMA engine driver (using these helper functions), and conversion of some of the OMAP DMA users to use DMA engine. Nothing in the helper functions is ARM specific, so I hope that other implementations can consolidate some of their code by making use of these helpers. This has been sitting in linux-next most of the merge cycle, and has been tested by several OMAP folk. I've tested it on sa11x0 platforms, and given it my best shot on my broken platforms which have the amba-pl08x controller. The last point is the addition to feature-removal-schedule.txt, which will have a merge conflict. Between myself and TI, we're planning to remove the old TI DMA implementation next year." Fix up trivial add/add conflicts in Documentation/feature-removal-schedule.txt and drivers/dma/{Kconfig,Makefile} * 'dmaengine' of git://git.linaro.org/people/rmk/linux-arm: (53 commits) ARM: 7481/1: OMAP2+: omap2plus_defconfig: enable OMAP DMA engine ARM: 7464/1: mmc: omap_hsmmc: ensure probe returns error if DMA channel request fails Add feature removal of old OMAP private DMA implementation mtd: omap2: remove private DMA API implementation mtd: omap2: add DMA engine support spi: omap2-mcspi: remove private DMA API implementation spi: omap2-mcspi: add DMA engine support ARM: omap: remove mmc platform data dma_mask and initialization mmc: omap: remove private DMA API implementation mmc: omap: add DMA engine support mmc: omap_hsmmc: remove private DMA API implementation mmc: omap_hsmmc: add DMA engine support dmaengine: omap: add support for cyclic DMA dmaengine: omap: add support for setting fi dmaengine: omap: add support for returning residue in tx_state method dmaengine: add OMAP DMA engine driver dmaengine: sa11x0-dma: add cyclic DMA support dmaengine: sa11x0-dma: fix DMA residue support dmaengine: PL08x: ensure all descriptors are freed when channel is released dmaengine: PL08x: get rid of write only pool_ctr and free_txd locking ...
2012-07-31ARM: 7464/1: mmc: omap_hsmmc: ensure probe returns error if DMA channel ↵Kevin Hilman
request fails If dma_request_channel() fails (e.g. because DMA enine is not built into the kernel), the return value from probe is zero causing the driver to be bound to the device even though probe failed. To fix, ensure that probe returns an error value when a DMA channel request fail. Signed-off-by: Kevin Hilman <khilman@ti.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-07-31mmc: omap: remove private DMA API implementationRussell King
Remove the private DMA API implementation from omap, making it use entirely the DMA engine API. Tested-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-07-31mmc: omap: add DMA engine supportRussell King
Add DMA engine support to the OMAP driver. This supplements the private DMA API implementation contained within this driver, and the driver can be switched at build time between using DMA engine and the private DMA API. Tested-by: Tony Lindgren <tony@atomide.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-07-31mmc: omap_hsmmc: remove private DMA API implementationRussell King
Remove the private DMA API implementation from omap_hsmmc, making it use entirely the DMA engine API. Tested-by: Tony Lindgren <tony@atomide.com> Tested-by: Venkatraman S <svenkatr@ti.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-07-31mmc: omap_hsmmc: add DMA engine supportRussell King
Add DMA engine support to the OMAP HSMMC driver. This supplements the private DMA API implementation contained within this driver, and the driver can be switched at build time between using DMA engine and the private DMA API. Tested-by: Grazvydas Ignotas <notasas@gmail.com> Tested-by: Tony Lindgren <tony@atomide.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-07-26Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "A mixed bag of fixes, some for merge window fallout (tegra, MXS), and a short series of fixes for marvell platforms that didn't make it in before 3.5." * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: mxs: fix compile error caused by prom_update_property change ARM: dt: tegra trimslice: enable USB2 port ARM: dt: tegra trimslice: add vbus-gpio property ARM: vt8500: Add maintainer for VT8500 architecture ARM: Kirkwood: Replace mrvl with marvell ARM: Orion: fix driver probe error handling with respect to clk ARM: Dove: Fixup ge00 initialisation ARM: Kirkwood: Fix PHY disable clk problems ARM: Kirkwood: Ensure runit clock always ticks. ARM: versatile: Don't use platform clock for Integrator & VE ARM: tegra: harmony: add regulator supply name and its input supply
2012-07-25Merge branch 'v3.5-rc7-fixes' of git://github.com/lunn/linux into fixesArnd Bergmann
From Andrew Lunn <andrew@lunn.ch>: * 'v3.5-rc7-fixes' of git://github.com/lunn/linux: ARM: Kirkwood: Replace mrvl with marvell ARM: Orion: fix driver probe error handling with respect to clk ARM: Dove: Fixup ge00 initialisation ARM: Kirkwood: Fix PHY disable clk problems ARM: Kirkwood: Ensure runit clock always ticks. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-07-25ARM: Orion: fix driver probe error handling with respect to clkSimon Baatz
The clk patches added code to get and enable clocks in the respective driver probe functions. If the probe function failed for some reason after enabling the clock, the clock was not disabled again in many cases. Signed-off-by: Simon Baatz <gmbnomis@gmail.com> Signed-off-by: Andrew Lumm <andrew@lunn.ch>
2012-07-24Merge branch 'next' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dmaengine update from Vinod Koul: "This time we have a new dmaengine driver from the tegra folks. Also we have Guennadi's cleanup of sh drivers which incudes a library for sh drivers. And the usual odd fixes in bunch of drivers and some nice cleanup of dw_dmac from Andy." Fix up conflicts in drivers/mmc/host/sh_mmcif.c * 'next' of git://git.infradead.org/users/vkoul/slave-dma: (46 commits) dmaengine: Cleanup logging messages mmc: sh_mmcif: switch to the new DMA channel allocation and configuration dma: sh: provide a migration path for slave drivers to stop using .private dma: sh: use an integer slave ID to improve API compatibility dmaengine: shdma: prepare to stop using struct dma_chan::private sh: remove unused DMA device pointer from SIU platform data ASoC: siu: don't use DMA device for channel filtering dmaengine: shdma: (cosmetic) simplify a static function dmaengine: at_hdmac: add a few const qualifiers dw_dmac: use 'u32' for LLI structure members, not dma_addr_t dw_dmac: mark dwc_dump_lli inline dma: mxs-dma: Export missing symbols from mxs-dma.c dma: shdma: convert to the shdma base library ASoC: fsi: prepare for conversion to the shdma base library usb: renesas_usbhs: prepare for conversion to the shdma base library ASoC: siu: prepare for conversion to the shdma base library serial: sh-sci: prepare for conversion to the shdma base library mmc: sh_mobile_sdhi: prepare for conversion to the shdma base library mmc: sh_mmcif: remove unneeded struct sh_mmcif_dma, prepare to shdma conversion dma: shdma: prepare for conversion to the shdma base library ...
2012-07-23Merge tag 'clk' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm-soc clk changes from Arnd Bergmann: "Clock support is moving to the clk subsystem. These tegra, omap and imx changes are for code that is still platform specific and not (yet) part of that subsystem." Fix up conflicts in arch/arm/mach-{imx/clk-imx51-imx53.c,omap2/Makefile} * tag 'clk' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (23 commits) ARM: imx: clk-imx31: Fix clock id for rnga driver ARM: imx: add missing item to the list of clock event modes ARM: i.MX5x CSPI: Fixed clock name for CSPI ARM: i.MX5x clocks: Fix GPT clocks ARM: i.MX5x clocks: Fix parent for PWM clocks ARM: i.MX5x clocks: Add EPIT support ARM: mx27: Reenable silicon version print ARM: clk-imx27: Fix rtc clock id ARM: tegra: Provide clock for only one PWM controller ARM: tegra: Fix PWM clock programming ARM: OMAP3+: clock33xx: Add AM33XX clock tree data ARM: OMAP3+: clock: Move common clksel_rate & clock data to common file ARM: tegra: dma: rename driver name for clock to "tegra-apbdma" ARM: tegra: Remove second instance of uart clk crypto: add clk_prepare/clk_unprepare ASoC: tegra: add clk_prepare/clk_unprepare staging: nvec: add clk_prepare/clk_unprepare spi/tegra: add clk_prepare/clk_unprepare Input: tegra-kbc - add clk_prepare/clk_unprepare USB: ehci-tegra: add clk_prepare/clk_unprepare ...
2012-07-23Merge tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull general arm-soc cleanups from Arnd Bergmann: "These are all boring changes, moving stuff around or renaming things mostly, and also getting rid of stuff that is duplicate or should not be there to start with. Platform-wise this is all over the place, mainly omap, samsung, at91, imx and tegra." Resolve trivial conflict in arch/arm/mach-omap2/clockdomains3xxx_data.c * tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (67 commits) ARM: clps711x: Remove the setting of the time ARM: clps711x: Removed superfluous transform virt_to_bus and related functions ARM: clps711x/p720t: Replace __initcall by .init_early call ARM: S3C24XX: Remove unused GPIO definitions for Openmoko GTA02 board ARM: S3C24XX: Remove unused GPIO definitions for port J ARM: S3C24XX: Remove unused GPA, GPE, GPH bank GPIO aliases ARM: S3C24XX: Convert the touchscreen setup code to common GPIO API ARM: S3C24XX: Convert the PM code to gpiolib API ARM: S3C24XX: Convert QT2410 board file to the gpiolib API ARM: S3C24XX: Convert SMDK board file to the gpiolib API ARM: S3C24XX: Free the backlight gpio requested in Mini2440 board code ARM: imx: remove unused pdata from device macros ARM: imx: Kconfig: Remove IMX_HAVE_PLATFORM_IMX_SSI from MACH_MX25_3DS ARM: at91: fix new build errors ARM: at91: add AIC5 support ARM: at91: remove mach/irqs.h ARM: at91: sparse irq support ARM: at91: at91 based machines specify their own irq handler at run time ARM: at91: remove static irq priorities for sam9x5 ARM: at91: add of irq priorities support ...
2012-07-22mmc: sdhci-dove: Prepare for common clock frameworkSebastian Hesselbarth
As mach-dove is moving towards common clock framework prepare the sdhci driver to grab its clock. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@googlemail.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-22mmc: sdhci-dove: Add SDHCI_QUIRK_NO_HISPD_BITSebastian Hesselbarth
The sdio controller on dove doesn't have a bit to indicate high-speed. With the quirk set it fixes accessing high-speed sdcards. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@googlemail.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-22mmc: omap_hsmmc: ensure probe returns error upon resource failureKevin Hilman
If platform_get_resource_by_name() fails, driver probe is aborted an should return an error so the driver is not bound to the device. However, in the current error path of platform_get_resource_by_name(), probe returns zero since the return value (ret) is not properly set. With a zero return value, the driver core assumes probe was successful and will bind the driver to the device. Fix this by ensuring that probe returns an error code in this failure path. Signed-off-by: Kevin Hilman <khilman@ti.com> Acked-by: Venkatraman S <svenkatr@ti.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-22mmc: mxs-mmc: Add wp-inverted propertyMarek Vasut
The write-protect GPIO is inverted on some boards. Handle such case. Signed-off-by: Marek Vasut <marex@denx.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-22mmc: esdhc: Fix DMA_MASK to not break mx25 DMA accessWilson Callan
Patch to not set reserved bits in i.MX25 PROCTL register. DMA stops working if those bits get set. Signed-off-by: Wilson Callan <wilson.callan@savantsystems.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-22mmc: core: reset signal voltage on power upAaron Lu
Add a call to mmc_set_signal_voltage() to set signal voltage to 3.3v in mmc_power_up so that we do not need to touch signal voltage setting in mmc/sd/sdio init functions and rescan function. For mmc/sd cards, when doing a suspend/resume cycle, consider the unsafe resume case, the card will lose its power and when powered on again, we will set signal voltage to 3.3v in mmc_power_up before its resume function gets called, which will re-init the card. And for sdio cards, when doing a suspend/resume cycle, consider the unsafe resume case, the card will either lose its power or not depending on if it wants to wakeup the host. If power is not maintained, it is the same case as mmc/sd cards. If power is maintained, mmc_power_up will not be called and the card's signal voltage will remain at the last setting. Signed-off-by: Aaron Lu <aaron.lu@amd.com> Tested-by: Venkatraman S <svenkatr@ti.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-22mmc: sd: Fix sd current limit settingAaron Lu
Host has different current capabilities at different voltages, we need to record these settings seperately. The defined voltages are 1.8/3.0/3.3. For other voltages, we do not touch current limit setting. Before we set the current limit for the sd card, find out the host's operating voltage first and then find out the current capabilities of the host at that voltage to set the current limit. Signed-off-by: Aaron Lu <aaron.lu@amd.com> Reviewed-by: Philip Rakity <prakity@marvell.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-22mmc: omap_hsmmc: add clk_prepare and clk_unprepareRajendra Nayak
In preparation for OMAP moving to the Common Clock Framework (CCF) add clk_prepare() and clk_unprepare() for the hsmmc clocks. Signed-off-by: Rajendra Nayak <rnayak@ti.com> Acked-by: Venkatraman S <svenkatr@ti.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-22mmc: sdhci: When a UHS switch fails, cycle power if regulator is usedPhilip Rakity
Power needs to be removed from the card when switching to 1.8v fails. If a regulator is used to control vmmc we need to turn the regulator off and then back on otherwise power will not be removed from the card. Signed-off-by: Philip Rakity <prakity@marvell.com> Reviewed-by: Aaron Lu <aaron.lu@amd.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-22mmc: atmel-mci: modify CLKDIV displaying in debugfsNicolas Ferre
Modify clock division displaying in debugfs for matching the new CLKDIV,CLKODD user interface arrangement. Is using the has_odd_clk_div property to choose the proper format. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Ludovic Desroches <ludovic.desroches@atmel.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-22mmc: atmel-mci: fix incorrect setting of host->data to NULLNicolas Ferre
Setting host->data to NULL is incorrect sequence in STATE_SENDING_STOP state of FSM: This early setting leads to the skip of dma_unmap_sg() in atmci_dma_cleanup() which is a bug. Idea taken from dw_mmc by Seungwon Jeon. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Seungwon Jeon <tgih.jun@samsung.com> Acked-by: Ludovic Desroches <ludovic.desroches@atmel.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-22mmc: sdhci: poll for card even when card is logically unremovableDaniel Drake
The Marvell CaFe is now marked as having bad card detection to fix a problem during system resume. Now on the OLPC XO-1 we are facing the issue that the card is marked as logically unremovable (via MMC_UNSAFE_RESUME), which means that mmc_card_is_removable considers the card non-removable. The existing code logic decides not to poll for card presence in this case, and card detection is also disabled because of the quirk being set. This means that no SD cards are detected when inserted after boot. Refine the logic to enable card presence polling in the case when a card is logically unremovable, only avoiding the poll in the case when the card is physically non-removable (denoted with MMC_CAP_NONREMOVABLE). Signed-off-by: Daniel Drake <dsd@laptop.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-22mmc: sdhci: Introduce new flag SDHCI_USING_RETUNING_TIMERAaron Lu
Add a new flag of SDHCI_USING_RETUNING_TIMER to represent if the host is using a retuning timer for the card inserted. This flag is set when the host does tuning the first time for the card and the host's retuning mode is 1. This flag is used afterwards whenever needs to decide if the host is currently using a retuning timer. This flag is cleared when the card is removed in sdhci_reinit. The set/clear of the flag and the start/stop of the retuning timer is associated with the card's init/remove time, so there is no need to touch it when the host is to be removed as at that time the card should have already been removed. Signed-off-by: Aaron Lu <aaron.lu@amd.com> Reviewed-by: Girish K S <girish.shivananjappa@linaro.org> Reviewed-by: Philip Rakity <prakity@marvell.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-22mmc: sdio: Change pr_warning to pr_warn_ratelimitedLiu Chuansheng
When debugging one bad issue, got lots of pr_warning messages "queuing unknown CIS tuple" which caused a printk storm and flooded the console. This patch changes the pr_warning to use pr_warn_ratelimited. Signed-off-by: Liu Chuansheng <chuansheng.liu@intel.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-22mmc: core: Simplify and fix for SD switch processingAaron Lu
In mmc_read_switch, just do a one time mode 0 switch command to get the support bits information, no need to do multiple times as the support bits do not change with different arguments. And no need to check current limit support bits, as these bits are fixed according to the signal voltage. If the signal voltage is 1.8V, the support bits would be 0xf and if the signal voltage is 3.3V, the support bits would be 0x01. We will check host's ability to set the current limit. Signed-off-by: Aaron Lu <aaron.lu@amd.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-22mmc: sdhci: restore host settings when card is removedAaron Lu
Some of the host settings are affected by different cards inserted, e.g. when an UHS-I card is inserted, the SDHCI_NEEDS_RETUING flag might be set when the tuning timer expired and host's max_blk_count will be reduced to make sure the data transfer for a command does not exceed 4MiB to meet the retuning mode 1's requirement. When the card is removed, we should restore the original setting of the host since we can't be sure the next card being inserted will still be an UHS-I card that needs tuning. The original setting include its max_blk_count and no set of the flag of SDHCI_NEEDS_RETUNING. Signed-off-by: Aaron Lu <aaron.lu@amd.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-22mmc: sdhci: fix incorrect command used in tuningAaron Lu
For SD hosts using retuning mode 1, when retuning timer expired, it will need to do retuning in sdhci_request before processing the actual request. But the retuning command is fixed: cmd19 for SD card and cmd21 for eMMC card, so we can't use the original request's command to do the tuning. And since the tuning command depends on the card type attached to the host, we will need to know the card type to use the correct tuning command. Signed-off-by: Aaron Lu <aaron.lu@amd.com> Reviewed-by: Philip Rakity <prakity@marvell.com> Cc: stable <stable@vger.kernel.org> [3.3+] Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-22mmc: sdhci-pci: CaFe has broken card detectionDaniel Drake
At http://dev.laptop.org/ticket/11980 we have determined that the Marvell CaFe SDHCI controller reports bad card presence during resume. It reports that no card is present even when it is. This is a regression -- resume worked back around 2.6.37. Around 400ms after resuming, a "card inserted" interrupt is generated, at which point it starts reporting presence. Work around this hardware oddity by setting the SDHCI_QUIRK_BROKEN_CARD_DETECTION flag. Thanks to Chris Ball for helping with diagnosis. Signed-off-by: Daniel Drake <dsd@laptop.org> [stable@: please apply to 3.0+] Cc: <stable@vger.kernel.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-22mmc: sdhci: Report failure reasons for all cases in sdhci_add_host()Mark Brown
For most error conditions sdhci_add_host() will print a diagnostic message indicating why it failed but there are a few cases where this does not happen. Add error messages in these cases to aid diagnosis. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-22mmc: s3cmci: Convert s3cmci driver to gpiolib APISylwester Nawrocki
The s3c2410_gpio* calls are obsolete and have been scheduled for removal since several kernel releases. Remove them and use common gpiolib API. This patch is a prerequisite for removal of the S3C24XX SoC specific arch/arm/plat-samsung/include/gpio-fns.h header. Tested on Micro2440-SDK. Signed-off-by: Sylwester Nawrocki <sylvester.nawrocki@gmail.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-22mmc: sdhci: Allow caps[1] to be set via SDHCI_QUIRK_MISSING_CAPSPhilip Rakity
Currently only the capability_0 register can be set if SDHCI_QUIRK_MISSING_CAPS is defined. This is a problem when the capability_1 register also needs changing. Use the quirk SDHCI_QUIRK_MISSING_CAPS to allow both registers to be set. Redefining caps[1] is useful when the board design does not support 1.8v vccq so UHS modes are not available. The code that calls sdhci_add_host can then detect this condition and adjust the caps so the UHS mode will not be attempted on UHS cards. Signed-off-by: Philip Rakity <prakity@marvell.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-22mmc: mxs-mmc: enable regulator for mmc slotShawn Guo
If bootloader or platform initialization code does not enable the power supply to mmc slot, we need to do it in mmc driver. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-21mmc: core: correct invalid error checkingAlan Cox
The effect of the existing code is that we continue blindly when we should warn about an invalid allocation unit. Reported-by: dcb314@hotmail.com Resolves-bug: https://bugzilla.kernel.org/show_bug.cgi?id=44061 Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-21mmc: only support voltage (vdd) that regulator agrees withPhilip Rakity
If we are using a regulator the SD Host Controller and the regulator should agree about the voltages supported. Use the common subset that is supported. Signed-off-by: Philip Rakity <prakity@marvell.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-21mmc: sdhci: only set 200mA support for 1.8v if 200mA is availablePhilip Rakity
max_current_caps can return 0 if not available from the sd controller. If no regulator is present or the regulator specifies a current less then 200ma, we no longer still set the 200mA caps bit anyway. Signed-off-by: Philip Rakity <prakity@marvell.com> Reviewed-by: Aaron Lu <aaron_lu@amd.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-21mmc: sdhci: if MAX_CURRENT is 0, try getting current from regulatorPhilip Rakity
The sd host controller spec indicates the the MAX_CURRENT value may be returned as 0. In this case other methods need to be used to return the current. If 0 is returned and there is a regulator, ask the regulator for how much current is available. Signed-off-by: Philip Rakity <prakity@marvell.com> Signed-off-by: Mark F. Brown <mark.brown314@gmail.com> Reviewed-by: Aaron Lu <aaron.lu@amd.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-21mmc: sh_mmcif: support generic card-detectionGuennadi Liakhovetski
Extend the sh_mmcif driver to support GPIO card detection, provided by the slot function module. The original .get_cd() platform callback is also preserved for now. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-21mmc: prohibit card detection when host is not readyGuennadi Liakhovetski
Currently mmc host drivers have to decide whether to enable card detection before calling mmc_add_host() -- in which case a card insertion event can arrive before the host has been completely initialised -- or after mmc_add_host(), in which case the initial card detection can be problematic. This patch adds an explicit indication of when card detection should not be carried out. With it in place enabling card detection before calling mmc_add_host() should be safe. Similarly, disabling it again after calling mmc_remove_host() will avoid any races. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-21mmc: sh-mmcif: add OF support, make platform data optionalGuennadi Liakhovetski
Add primitive OF support to the sh-mmcif driver, which also makes it necessary to be able to run without platform data. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-21mmc: sdhi: add OF support, make platform data optionalGuennadi Liakhovetski
Add primitive support for OF to the SDHI TMIO glue, which also makes it necessary to be able to run without platform data. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-21mmc: tmio: use generic GPIO CD and WP handlersGuennadi Liakhovetski
The tmio-mmc driver is already using the generic GPIO CD handler in IRQ mode. This patch adds support for CD polling mode and also checks for availability of a WP GPIO. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-21mmc: sh_mobile_sdhi: support caps2 flagsGuennadi Liakhovetski
Let SDHI platforms specify mmc_host::caps2 flags in their platform data. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-21mmc: tmio: support caps2 flagsGuennadi Liakhovetski
Allow tmio mmc glue drivers to pass mmc_host::caps2 flags down to the mmc layer. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-21mmc: core: add WP pin handler to slot functionsGuennadi Liakhovetski
Card Write-Protect pin is often implemented, using a GPIO, which makes it simple to provide a generic handler for it. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-21mmc: core: convert slot functions to managed allocationGuennadi Liakhovetski
This prepares for the addition of further slot functions. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-21mmc: add CD GPIO polling support to slot functionsGuennadi Liakhovetski
A simple extension of mmc slot functions add support for CD GPIO polling for cases where the GPIO cannot produce interrupts, or where this is not desired for some reason. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-21mmc: core: use a more generic name for slot function types and fieldsGuennadi Liakhovetski
struct mmc_host::hotplug is becoming a generic hook for slot functions. Rename it accordingly. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-21mmc: sh_mmcif: add regulator supportGuennadi Liakhovetski
Add regulator support to the sh_mmcif driver, but also preserve the current power-callback. Also note, that the card power is not switched off during clock gating periods, hence there's no need to power it on every time the card is re-activated. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Reviwed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Reviewed-by: Simon Horman <horms@verge.net.au> Signed-off-by: Chris Ball <cjb@laptop.org>
