To prevent subsequent commands failing, ensure the cmd and data circuits
are reset after a tuning timeout.
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
In the busy response case (i.e. !host->data), an unexpected data interrupt
would result in clearing the data command as though it had completed but
without informing the upper layers and thus resulting in a hang. Fix by
only clearing the data command for data interrupts that are expected.
Cc: stable@vger.kernel.org # v4.8+
CMD line reset during an ongoing data transfer can cause the data transfer
to hang. Fix by delaying the reset until the data transfer is finished.
Add the "reset" as name of reset controller.
This is for preventing the wrong operation. Even if some SoC has reset
controller, doesn't define "resets" in device-tree.
Then it might be waiting for reset controller and it should be stuck.
Fixes: d6786fefe816 ("mmc: dw_mmc: add reset support to dwmmc host controller")
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
Acked-by: John Stultz <john.stultz@linaro.org>
Fix to return a negative error code from the platform_get_irq_byname()
error handling case instead of 0, as done elsewhere in this function.
Fixes: ad81d3871004 ("mmc: sdhci-msm: Add support for UHS cards")
Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com>
Acked-by: Adrian Hunter <adrian.hunter@intel.com>
Acked-by: Georgi Djakov <georgi.djakov@linaro.org>
platform_get_resource can be returned the NULL pointer.
Then regs->start should be referred to NULL Pointer.
devm_ioremap_resource() checks whether res is NULL or not.
Reviewed-by: Shawn Lin <shawn.lin@rock-chips.com>
Accesses of the rtsx sdmmc's parent device, which is the rtsx usb device,
must be done when it's runtime resumed. Currently this isn't case when
changing the led, so let's fix this by adding a pm_runtime_get_sync() and
a pm_runtime_put() around those operations.
Reported-by: Ritesh Raj Sarraf <rrs@researchut.com>
Tested-by: Ritesh Raj Sarraf <rrs@researchut.com>
Cc: <stable@vger.kernel.org>
Cc: Alan Stern <stern@rowland.harvard.edu>
The rtsx_usb_sdmmc driver may bail out in its ->set_ios() callback when no
SD card is inserted. This is wrong, as it could cause the device to remain
runtime resumed when it's unused. Fix this behaviour.
Potentially overflowing expression 1000000 * data->timeout_clks with
type unsigned int is evaluated using 32-bit arithmetic, and then used
in a context that expects an expression of type unsigned long long.
To avoid overflow, cast 1000000U to type unsigned long long.
Special thanks to Coverity.
Fixes: 7f05538af71c ("mmc: sdhci: fix data timeout (part 2)")
Signed-off-by: Haibo Chen <haibo.chen@nxp.com>
Cc: stable@vger.kernel.org # v3.15+
- The DMA error interrupt bit is in a different position as
compared to the sdhci standard. This is accounted for in
many cases, but not handled in the case of clearing the
INT_STATUS register by writing a 1 to that location.
- The HOST_CONTROL register is very different as compared to
the sdhci standard. This is accounted for in the write
case, but not when read back out (which it is in the sdhci
code).
Signed-off-by: Dave Russell <david.russell@datasoft.com>
Signed-off-by: Aaron Brice <aaron.brice@datasoft.com>
Acked-by: Dong Aisheng <aisheng.dong@nxp.com>
Some Intel controllers (e.g. BXT) might fail to set bus power after a
D3 -> D0 transition due to the present state not yet having propagated.
Retry for up to 2 milliseconds.
Let devices define their own sdhci_ops so that device-specific variations
can be implemented without adding quirks.
Unlike other cases, sdhci_set_power() does not reflect the default
implementation of the ->set_power() callback. Rename it and create
sdhci_set_power() that is the default implementation.
Cc: Jisheng Zhang <jszhang@marvell.com>
Multi-block data transfers can specify the number of blocks either using a
Set Block Count command (CMD23) or by sending a STOP command (CMD12) after
the required number of blocks has transferred. CMD23 is preferred, but some
cards don't support it. CMD12 with R1b response is used for writes, and
R1 response for reads.
Some SDHCI host controllers give a Transfer Complete (TC) interrupt for the
STOP command (CMD12) whether or not a R1b response has been specified. The
quirk SDHCI_QUIRK2_STOP_WITH_TC identifies those host controllers, but the
implementation only considers the case where the TC interrupt arrives at
the same time as the Command Complete (CC) interrupt. However,
occasionally TC arrives before CC. That is harmless, but does generate an
error message "Got data interrupt 0x00000002 even though no data operation
was in progress".
A simpler approach is to force R1b response onto all STOP commands, because
SDHCI will handle TC before CC in the general case, so do that.
Cc: Giuseppe Cavallaro <peppe.cavallaro@st.com>
Commit f68381a70bb2 (mmc: block: fix packed command header endianness)
correctly fixed endianness handling of packed_cmd_hdr in
mmc_blk_packed_hdr_wrq_prep.
But now, sparse complains about incorrect types:
drivers/mmc/card/block.c:1613:27: sparse: incorrect type in assignment (different base types)
drivers/mmc/card/block.c:1613:27: expected unsigned int [unsigned] [usertype] <noident>
drivers/mmc/card/block.c:1613:27: got restricted __le32 [usertype] <noident>
So annotate cmd_hdr properly using __le32 to make everyone happy.
Fixes: f68381a70bb2 (mmc: block: fix packed command header endianness)
Per the vendor's requirement, we shouldn't do any setting for
1.8V Signaling Enable, otherwise the interaction/behaviour between
phy and controller will be undefined. Mostly it works fine if we do
that, but we still see failures. Anyway, let's fix it to meet the
vendor's requirement. The error log looks like:
[ 93.405085] mmc1: unexpected status 0x800900 after switch
[ 93.408474] mmc1: switch to bus width 1 failed
[ 93.408482] mmc1: mmc_select_hs200 failed, error -110
[ 93.408492] mmc1: error -110 during resume (card was removed?)
[ 93.408705] PM: resume of devices complete after 213.453 msecs
Signed-off-by: Shawn Lin <shawn.lin@rock-chips.com>
Reviewed-by: Douglas Anderson <dianders@chromium.org>
Per JESD84-B51 P49, Host need to change frequency to <=52MHz
after setting HS_TIMING to 0x1, and host may changes frequency
to <= 200MHz after setting HS_TIMING to 0x3. That means the card
expects the clock rate to increase from the current used f_init
(which is less than 400KHz, but still being less than 52MHz) to
52MHz, otherwise we find some eMMC devices significantly report
failure when sending status.
Reported-by: Xiao Yao <xiaoyao@rock-chips.com>
When introducing hs400es, I didn't notice that we haven't
switched voltage to 1V2 or 1V8 for it. That happens to work
as the first controller claiming to support hs400es, arasan(5.1),
which is designed to only support 1V8. So the voltage is fixed to 1V8.
But it actually is wrong, and will not fit for other host controllers.
Let's fix it.
Fixes: commit 81ac2af65793ecf ("mmc: core: implement enhanced strobe support")
We get 1 warning when building kernel with W=1:
drivers/mmc/card/block.c:2147:5: warning: no previous prototype for
'mmc_blk_issue_rq' [-Wmissing-prototypes]
In fact, this function is declared in drivers/mmc/card/block.h, so this
patch adds missing header dependencies.
Signed-off-by: Baoyou Xie <baoyou.xie@linaro.org>
Fixes the following sparse warning:
drivers/mmc/host/sdhci-of-arasan.c:253:6: warning:
symbol 'sdhci_arasan_reset' was not declared. Should it be static?
Acked-by: Sören Brinkmann <soren.brinkmann@xilinx.com>
Remvoe the deprecated "supports-highspeed" property.
DWMMC controller will not use this property anymore.
msize and rx_wmark are properly initialized, we dont't
need to assign them again.
It's very prone to make mistake as we might forget
to replace all PAGE_SIZEs with new values if we try
to modify the ring buffer size for whatever reasons.
Let's use a macro to define it.
The original log didn't figure out that we could still
finish this transfer by PIO mode even if failing to use
DMA. And it should be kept for debug level instead of
error one.
We could see an obvious race condition by test that
the former write operation by IDMAC aiming to clear
OWN bit reach right after the later configuration of
the same desc, which makes the IDMAC be in SUSPEND
state as the OWN bit was cleared by the asynchronous
write operation of IDMAC. The bug can be very easy
reproduced on RK3288 or similar when we reduce the
running rate of system buses and keep the CPU running
faster. So as two separate masters, IDMAC and cpu
write the same descriptor stored on the same address,
and this should be protected by adding check of OWN
bit before preparing new descriptors.
We intend to add more check for descriptors when
preparing desc. Let's spilt out the separate body
to make the dw_mci_translate_sglist not so lengthy.
After spliting out these two functions, we could
remove dw_mci_translate_sglist and call both of them
when staring idmac.
Per spec, block size should always be 512 bytes for dual rate mode,
so any attempts to switch the block size under dual rate mode should
be neglected.
Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com>
The sdhci controller on xilinx zynq devices will not function unless
the CD bit is provided. http://www.xilinx.com/support/answers/61064.html
In cases where it is impossible to provide the CD bit in hardware,
setting the controller to test mode and then setting inserted to true
will get the controller to function without the CD bit.
When the device has the property xlnx,fails-without-test-cd the driver
changes the controller to test mode and sets test inserted to true to
make the controller function.
Signed-off-by: Zach Brown <zach.brown@ni.com>
We need to add R1 without CRC support, refactor the bus width routine a
little and extend a quirk check. To support "non-removable;" we need a
workaround which will be hopefully removed when reworking PM soon.
Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
We have enough vtables in the kernel as it is, we don't need
this one to create even more artificial separation of concerns.
As is proved by the Makefile:
obj-$(CONFIG_MMC_BLOCK) += mmc_block.o
mmc_block-objs := block.o queue.o
block.c and queue.c are baked into the same mmc_block.o object.
So why would one of these objects access a function in the
other object by dereferencing a pointer?
Create a new block.h header file for the single shared function
from block to queue and remove the function pointer and just
call the queue request function.
Apart from making the code more readable, this also makes link
optimizations possible and probably speeds up the call as well.
Set MMC_CAP_CMD_DURING_TFR for Intel BYT and related eMMC host controllers.
Now SDHCI supports commands during transfer, enable support for the core
API.
There are 3 small changes needed:
First, auto-CMD12 cannot be used with a cap_cmd_during_tfr request because
the host controller cannot expect the command line to be available.
Secondly, a cap_cmd_during_tfr request must not send a stop command, again
because the host controller cannot expect the command line to be available.
Thirdly, when a cap_cmd_during_tfr command completes, use
mmc_command_complete() to notify the upper layers that the command line is
now available for further commands.
Add 6 tests for sending commands during transfer. The tests are:
* Commands during read - no Set Block Count (CMD23).
* Commands during write - no Set Block Count (CMD23).
* Commands during read - use Set Block Count (CMD23).
* Commands during write - use Set Block Count (CMD23).
* Commands during non-blocking read - use Set Block Count (CMD23).
* Commands during non-blocking write - use Set Block Count (CMD23).
For a range of transfer sizes, the tests start an ongoing data transfer and
then repeatedly send the status command (CMD13) while the transfer
continues. The tests pass if all requests complete with no errors. The host
controller driver must support MMC_CAP_CMD_DURING_TFR.
A host controller driver exposes its capability using caps flag
MMC_CAP_CMD_DURING_TFR. A driver with that capability can accept requests
that are marked mrq->cap_cmd_during_tfr = true. Then the driver informs the
upper layers when the command line is available for further commands by
calling mmc_command_done(). Because of that, the driver will not then
automatically send STOP commands, and it is the responsibility of the upper
layer to send a STOP command if it is required.
For requests submitted through the mmc_wait_for_req() interface, the caller
sets mrq->cap_cmd_during_tfr = true which causes mmc_wait_for_req() in fact
not to wait. The caller can then send commands that do not use the data
lines. Finally the caller can wait for the transfer to complete by calling
mmc_wait_for_req_done() which is now exported.
For requests submitted through the mmc_start_req() interface, the caller
again sets mrq->cap_cmd_during_tfr = true, but mmc_start_req() anyway does
not wait. The caller can then send commands that do not use the data
lines. Finally the caller can wait for the transfer to complete in the
normal way i.e. calling mmc_start_req() again.
Irrespective of how a cap_cmd_during_tfr request is started,
mmc_is_req_done() can be called if the upper layer needs to determine if
the request is done. However the appropriate waiting function (either
mmc_wait_for_req_done() or mmc_start_req()) must still be called.
The implementation consists primarily of a new completion
mrq->cmd_completion which notifies when the command line is available for
further commands. That completion is completed by mmc_command_done().
When there is an ongoing data transfer, calls to mmc_wait_for_req() will
automatically wait on that completion, so the caller does not have to do
anything special.
Note, in the case of errors, the driver may call mmc_request_done() without
calling mmc_command_done() because mmc_request_done() always calls
mmc_command_done().
Clear incorrect SDHCI_CAN_64BIT capability on Broadcom MIPS based SoCs.
The MIPS based SoCs are using ADMA only, but the several SoCs have the
incorrect capability bit about ADMA 64-bit. The "brcm,bcm7425-sdhci" is
compatible string for MIPS based SoC.
Signed-off-by: Jaedon Shin <jaedon.shin@gmail.com>
A64 SoC features a MMC controller which need only the mod clock, and can
calibrate delay by itself. This patch adds support for the new MMC
controller IP core.
Signed-off-by: Icenowy Zheng <icenowy@aosc.xyz>
In most cases the 'card->erase_size' is power of 2, then the round_up/down()
function is more efficient than '%' operation when the 'card->erase_size' is
power of 2.
Signed-off-by: Baolin Wang <baolin.wang@linaro.org>
Tested-by: Shawn Lin <shawn.lin@rock-chips.com>
In order to clean up the mmc_erase() function and do some optimization
for erase size alignment, factor out the guts of erase size alignment
into mmc_align_erase_size() function.
platform_get_irq() returns an error value on failure, not NO_IRQ,
so the error handling here could never work.
This changes the code to propagate the error value instead.
Add support for r8a7796 SoC.
Signed-off-by: Ai Kyuse <ai.kyuse.uw@renesas.com>
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be>
In cases when the host->max_busy_timeout isn't specified, the calculated
number of maximum discard sectors defaults to UINT_MAX. This may cause a
too long timeout for a discard request.
Avoid this by using a default maximum erase timeout of 60s, used when we
calculate the maximum number of sectors that are allowed to be discarded
per request.
Do note that the minimum number of sectors to be discarded is still at
least one "preferred erase size".
According to the TRM, the SD/MMC controller on Tegra124 supports 34-bit
addressing, but testing shows that this doesn't work. On a device which
has more than 2 GiB of RAM and LPAE enabled, buffer allocations can use
addresses above the 32-bit boundary.
One way to work around this would be to enable IOMMU physical to virtual
address translations for the SD/MMC controllers, but that's not easy to
implement without breaking existing use-cases. It's also not obvious why
34-bit addressing doesn't work as advertised. In order to fix this for
existing users, add the SDHCI_QUIRK2_BROKEN_64_BIT_DMA quirk for now.
Reported-by: Paul Kocialkowski <contact@paulk.fr>
Signed-off-by: Thierry Reding <treding@nvidia.com>
corecfg_clockmultiplier indicates clock multiplier value of
programmable clock generator which should be the same value
of SDHCI_CAPABILITIES_1. The default value of the register,
corecfg_clockmultiplier, is 0x10. But actually it is a mistake
by designer as our intention was to set it to be zero which
means we don't support programmable clock generator. So we have
to make it to be zero on bootloader which seems work fine until
now. But now we find an issue that when deploying genpd support
for it, the remove callback will trigger the genpd to poweroff the
power domain for sdhci-of-arasan which manage the controller, phy
and corecfg_* stuff.
So when we do bind/unbind the driver, we have already reinit
the controller and phy, but without doing that for corecfg_*.
Regarding to only the corecfg_clockmultipler is wrong, let's
fix it by explicitly marking it to be zero when probing. With
this change, we could do bind/unbind successfully.
Reported-by: Ziyuan Xu <xzy.xu@rock-chips.com>
Cc: Douglas Anderson <dianders@chromium.org>
Reviewed-by: Ziyuan Xu <xzy.xu@rock-chips.com>
Tested-by: Ziyuan Xu <xzy.xu@rock-chips.com>
Intel Merrifield provides an interface to an external SD card.
Enable it here.
Intel Merrifield is known to have an SDIO interface and on Intel Edison board a
WiFi card is wired to it.
Enable the interface here to allow WiFi card enumeration.
Refactor intel_mrfld_mmc_probe_slot() to use switch case. The change allows to
add a support for SD and SDIO interfaces without any pain.
Hisilicon Hikey have no tuning function in dw_mmc-k3.c,
so we must do the tuning function stub when we init UHS card.
Signed-off-by: Jin Guojun <kid.jin@hisilicon.com>
