path: root/drivers/mtd/cmdlinepart.c
2010-08-08mtd: Update copyright noticesDavid Woodhouse
2009-06-25mtd: cmdlineparts: Use 64-bit format when printing a debug message.Thadeu Lima de Souza Cascardo
Commit 69423d99fc182a81f3c5db3eb5c140acc6fc64be ("[MTD] update internal API to support 64-bit device size") has changed some structure values to 64-bit and has not updated this debug message, since it's not built by default. Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-03-20[MTD] mtdpart: Make all partition parsers return allocated arrayAtsushi Nemoto
Currently redboot and afx parser return allocated mtd_partition array and cmdlinepart and ar7 return persistent array. This patch make cmdlinepart and ar7 also return allocated array, so that all users can free it regardless of parser type. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-10-18[MTD] cmdlineparts documentation change - explain where mtd-id comes fromPhilip Rakity
Signed-off-by: Philip Rakity <prakity@yahoo.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-07-11[MTD] Fix const assignment in the MTD command line partitioning driverDavid Howells
Fix const to non-const pointer assignment in the MTD command line partitioning driver. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-06-04MTD/JFFS2: remove CVS keywordsAdrian Bunk
Once upon a time, the MTD repository was using CVS. This patch therefore removes all usages of the no longer updated CVS keywords from the MTD code. This also includes code that printed them to the user. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-04-22[MTD] cmdlinepart: Missing partition info is not an errorPeter Korsgaard
Return 0 partitions instead of -EINVAL on no mtdpart= argument in kernel cmdline or missing partition info for device. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-04-22[MTD] cmdlinepart.c: don't compare pointers with 0Adrian Bunk
Sparse spotted that 0 was compared to pointers. While I was at it, I also moved the assignments out of the if's. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-02-03[MTD] Unlocking all Intel flash that is locked on power up.Justin Treon
Patch for unlocking all Intel flash that has instant locking on power up. The patch has been tested on Intel M18, P30 and J3D Strata Flash. 1. The automatic unlocking can be disabled for a particular partition in the map or the command line. a. For the bit mask in the map it should look like: .mask_flags = MTD_POWERUP_LOCK, b. For the command line parsing it should look like: mtdparts=0x80000(bootloader)lk 2. This will only unlock parts with instant individual block locking. Intel parts with legacy unlocking will not be unlocked. Signed-off-by: Justin Treon <justin_treon@yahoo.com> Signed-off-by: Jared Hulbert <jaredeh@gmail.com> Acked-by: Nicolas Pitre <nico@cam.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-11-28[MTD] replace kmalloc+memset with kzallocBurman Yan
Signed-off-by: Yan Burman <yan_952@hotmail.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-11-28[MTD] make drivers/mtd/cmdlinepart.c:mtdpart_setup() staticAdrian Bunk
This patch makes the needlessly global mtdpart_setup() static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-03-31[PATCH] mtd cmdlinepart: allow zero offset valueAtsushi Nemoto
Current cmdlinepart.c uses offset value 0 to specify a continuous partition. This prevents creating a second partition starting at 0. For example, I can split 4MB device using "mtdparts=id:2M,2M", but I can not do "mtdparts=id:2M@2M,2M@0" to swap mtd0 and mtd1. This patch introduces special OFFSET_CONTINUOUS value for a continuous partition and allows 0 for offset value. Also this patch replaces 0xffffffff with UINT_MAX for SIZE_REMAINING. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Thomas Gleixner <tglx@linutronix.de> Acked-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[MTD] core: Clean up trailing white spacesThomas Gleixner
2005-06-29[MTD] Fix commandline parser alignementJoern Engel
Add alignment to cmdline. From: "Timofei V. Bondarenko" <tim@ipi.ac.ru> Signed-off-by: Joern Engel <joern@wohnheim.fh-wedel.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
