The older add_mtd_device()/add_mtd_partitions() and their removal
counterparts will soon be gone. Replace uses with mtd_device_register()
and mtd_device_unregister().
Signed-off-by: Jamie Iles <jamie@jamieiles.com>
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
This just leaves include/asm-arm/plat-* to deal with.
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h.
Then, since asm/hardware.h only exists to include asm/arch/hardware.h,
update everything to directly include asm/arch/hardware.h and remove
asm/hardware.h.
Once upon a time, the MTD repository was using CVS.
This patch therefore removes all usages of the no longer updated CVS
keywords from the MTD code.
This also includes code that printed them to the user.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
infrastructure for it.
Let it rip!
