path: root/drivers/mtd/maps/dbox2-flash.c
2011-05-25mtd: convert remaining users to mtd_device_register()Jamie Iles
The older add_mtd_device()/add_mtd_partitions() and their removal counterparts will soon be gone. Replace uses with mtd_device_register() and mtd_device_unregister(). Signed-off-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-12-10[MTD] Make init_dbox2_flash staticDmitri Vorobiev
The symbol init_dbox2_flash is not used outside of the file drivers/mtd/maps/dbox2-flash.c, so make it static. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@movial.fi> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-06-04MTD/JFFS2: remove CVS keywordsAdrian Bunk
Once upon a time, the MTD repository was using CVS. This patch therefore removes all usages of the no longer updated CVS keywords from the MTD code. This also includes code that printed them to the user. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-14[MTD] Fix legacy character sets throughout drivers/mtd, include/linux/mtdDavid Woodhouse
2006-03-31[PATCH] drivers/mtd: Use ARRAY_SIZE macroTobias Klauser
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove duplicates of the macro. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Cc: Thomas Gleixner <tglx@linutronix.de> Acked-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[MTD] maps: Clean up trailing white spacesThomas Gleixner
