path: root/drivers/mtd/maps/latch-addr-flash.c
2011-05-25mtd: latch-addr-flash: convert to mtd_device_register()Jamie Iles
Convert to mtd_device_register() and remove the CONFIG_MTD_PARTITIONS preprocessor conditionals as partitioning is always available. Signed-off-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-03-11mtd: NOR flash driver for OMAP-L137/AM17xDavid Griego
OMAP-L137/AM17x has limited number of dedicated EMIFA address pins, enough to interface directly to an SDRAM. If a device such as an asynchronous flash needs to be attached to the EMIFA, then either GPIO pins or a chip select may be used to control the flash device's upper address lines. This patch adds support for the NOR flash on the OMAP-L137/ AM17x user interface daughter board using the latch-addr-flash MTD mapping driver which allows flashes to be partially physically addressed. The upper address lines are set by a board specific code which is a separate patch. Signed-off-by: David Griego <dgriego@mvista.com> Signed-off-by: Aleksey Makarov <amakarov@ru.mvista.com> Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Savinay Dharmappa <savinay.dharmappa@ti.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
