Convert to mtd_device_register() and remove the CONFIG_MTD_PARTITIONS
preprocessor conditionals as partitioning is always available.
Signed-off-by: Jamie Iles <jamie@jamieiles.com>
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
Commit b826291c, "drivercore/dt: add a match table pointer to struct
device" added an of_match pointer to struct device to cache the
of_match_table entry discovered at driver match time. This was unsafe
because matching is not an atomic operation with probing a driver. If
two or more drivers are attempted to be matched to a driver at the
same time, then the cached matching entry pointer could get
overwritten.
This patch reverts the of_match cache pointer and reworks all users to
call of_match_device() directly instead.
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into for-linus-1
* 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6: (9356 commits)
[media] rc: update for bitop name changes
fs: simplify iget & friends
fs: pull inode->i_lock up out of writeback_single_inode
fs: rename inode_lock to inode_hash_lock
fs: move i_wb_list out from under inode_lock
fs: move i_sb_list out from under inode_lock
fs: remove inode_lock from iput_final and prune_icache
fs: Lock the inode LRU list separately
fs: factor inode disposal
fs: protect inode->i_state with inode->i_lock
lib, arch: add filter argument to show_mem and fix private implementations
SLUB: Write to per cpu data when allocating it
slub: Fix debugobjects with lockless fastpath
autofs4: Do not potentially dereference NULL pointer returned by fget() in autofs_dev_ioctl_setpipefd()
autofs4 - remove autofs4_lock
autofs4 - fix d_manage() return on rcu-walk
autofs4 - fix autofs4_expire_indirect() traversal
autofs4 - fix dentry leak in autofs4_expire_direct()
autofs4 - reinstate last used update on access
vfs - check non-mountpoint dentry might block in __follow_mount_rcu()
NOTE!
This merge commit was created to fix compilation error. The block
tree was merged upstream and removed the 'elv_queue_empty()'
function which the new 'mtdswap' driver is using. So a simple
merge of the mtd tree with upstream does not compile. And the
mtd tree has already be published, so re-basing it is not an option.
To fix this unfortunate situation, I had to merge upstream into the
mtd-2.6.git tree without committing, put the fixup patch on top of
this, and then commit this. The result is that we do not have commits
which do not compile.
In other words, this merge commit "merges" 3 things: the MTD tree, the
upstream tree, and the fixup patch.
As MTD_CONCAT is becoming a part of mtd core, it's now meaningless
to to check for it in ifdefs. Drop such references from MTD code.
Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
Final step to eliminate of_platform_bus_type. They're all just
platform drivers now.
v2: fix type in pasemi_nand.c (thanks to Stephen Rothwell)
Using %pR standardizes the struct resource output.
This patch changes the loop over the "reg" tuples to not exit
directly upon of_address_to_resource() failure but to continue
with the next "reg" tuple instead. This failure could be due to
size = 0, which might be passed via the device-tree.
This is needed for boards, where a "reg" tuple might have size 0
(of_address_to_resource() returns with EINVAL when size = 0).
Example:
Fully equipped board:
reg = <0 0x00000000 0x00400000
0 0x00400000 0x00400000>;
Partially equipped board:
0 0x00400000 0x00000000>;
This could be the case on boards with runtime detection of
multiple NOR flash configurations where the detected flash size
is inserted into the dtb in U-Boot.
This patch adds the appropriate conversions to correct the endianness
issues in the MTD driver whenever it accesses the device tree (which is
always big endian).
Signed-off-by: Ian Munsie <imunsie@au1.ibm.com>
The drivers for Xilinx' SystemACE and physically mapped MTDs were missing
prototypes for of_address_to_resource(). This patch adds the necessary
headers.
Signed-off-by: Graeme Smecher <graeme.smecher@mail.mcgill.ca>
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6:
mmc_spi: Fix unterminated of_match_table
of/sparc: fix build regression from of_device changes
of/device: Replace struct of_device with struct platform_device
* git://git.infradead.org/mtd-2.6: (79 commits)
mtd: Remove obsolete <mtd/compatmac.h> include
mtd: Update copyright notices
jffs2: Update copyright notices
mtd-physmap: add support users can assign the probe type in board files
mtd: remove redwood map driver
mxc_nand: Add v3 (i.MX51) Support
mxc_nand: support 8bit ecc
mxc_nand: fix correct_data function
mxc_nand: add V1_V2 namespace to registers
mxc_nand: factor out a check_int function
mxc_nand: make some internally used functions overwriteable
mxc_nand: rework get_dev_status
mxc_nand: remove 0xe00 offset from registers
mtd: denali: Add multi connected NAND support
mtd: denali: Remove set_ecc_config function
mtd: denali: Remove unuseful code in get_xx_nand_para functions
mtd: denali: Remove device_info_tag structure
mtd: m25p80: add support for the Winbond W25Q32 SPI flash chip
mtd: m25p80: add support for the Intel/Numonyx {16,32,64}0S33B SPI flash chips
mtd: m25p80: add support for the EON EN25P{32, 64} SPI flash chips
Fix up trivial conflicts in drivers/mtd/maps/{Kconfig,redwood.c} due to
redwood driver removal.
of_device is just an alias for platform_device, so remove it entirely. Also
replace to_of_device() with to_platform_device() and update comment blocks.
This patch was initially generated from the following semantic patch, and then
edited by hand to pick up the bits that coccinelle didn't catch.
-struct of_device
+struct platform_device
Reviewed-by: David S. Miller <davem@davemloft.net>
Error handling code following a kmalloc should free the allocated data.
The semantic match that finds the problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
@r exists@
local idexpression x;
statement S;
expression E;
identifier f,f1,l;
position p1,p2;
expression *ptr != NULL;
x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
when != if (...) { <+...x...+> }
x->f1 = E
(x->f1 == NULL || ...)
f(...,x->f1,...)
return \(0\|<+...x...+>\|ptr\);
return@p2 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line)
// </smpl>
Merging in current state of Linus' tree to deal with merge conflicts and
build failures in vio.c after merge.
drivers/i2c/busses/i2c-cpm.c
drivers/i2c/busses/i2c-mpc.c
drivers/net/gianfar.c
Also fixed up one line in arch/powerpc/kernel/vio.c to use the
correct node pointer.
.name, .match_table and .owner are duplicated in both of_platform_driver
and device_driver. This patch is a removes the extra copies from struct
of_platform_driver and converts all users to the device_driver members.
This patch is a pretty mechanical change. The usage model doesn't change
and if any drivers have been missed, or if anything has been fixed up
incorrectly, then it will fail with a compile time error, and the fixup
will be trivial. This patch looks big and scary because it touches so
many files, but it should be pretty safe.
Acked-by: Sean MacLennan <smaclennan@pikatech.com>
The following structure elements duplicate the information in
'struct device.of_node' and so are being eliminated. This patch
makes all readers of these elements use device.of_node instead.
(struct of_device *)->node
(struct dev_archdata *)->prom_node (sparc)
(struct dev_archdata *)->of_node (powerpc & microblaze)
This is to support custom partitioning schemes for embedded PPC. To use
define your own mtd_part_parser and then add something like:
linux,part-probe = "my_probe", "cmdlinepart";
To the board's dts file.
If linux,part-probe is not specified then this behaves the same as before.
Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
drivers/mtd/mtdcore.c
Pull in the bdi fixes and ARM platform changes that other outstanding
patches depend on.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
mtd_list has type struct mtd_info **, not struct mtd_info *, so the
elements of the array should have pointer type, not structure type.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@disable sizeof_type_expr@
type T;
T **x;
x =
<+...sizeof(
- T
+ *x
// </smpl>
Use physmap_of to access RAMs as mtd and add documenation for it. This approach
is a lot less intrusive as adding an of-wrapper around plat-ram.c. As most
extensions of plat-ram.c (e.g. custom map-functions) can't be mapped to the
device tree anyhow, extending physmap_of seems to be the cleanest approach.
Tested with a phyCORE-MPC5121e.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Cc: Vitaly Wool <vwool@ru.mvista.com>
Cc: Artem Bityutskiy <dedekind@infradead.org>
Cc: Ken MacLeod <ken@bitsko.slc.ut.us>
Cc: Albrecht Dreß <albrecht.dress@arcor.de>
This patch fixes a spelling error that has resulted from copy and
pasting. The location of the error was found using a semantic patch
but the semantic patch was not trying to find these errors. After
looking things over it seemed logical that this change was needed.
The patch also makes sure mtd_list is not being freed if it has not
been allocated
Signed-off-by: Stoyan Gaydarov <sgayda2@uiuc.edu>
Signed-off-by: Vimal Singh <vimalsingh@ti.com>
This patch adds support to handle multiple non-identical chips in one
flash device tree node. It also adds concat support to physmap_of. This
makes it possible to support e.g. the Intel P30 48F4400 chips which
internally consists of 2 non-identical NOR chips on one die. Additionally
partitions now can span over multiple chips.
To describe such a chip's, multiple "reg" tuples are now supported in one
flash device tree node. Here an dts example:
flash@f0000000,0 {
#address-cells = <1>;
#size-cells = <1>;
compatible = "cfi-flash";
reg = <0 0x00000000 0x02000000
0 0x02000000 0x02000000>;
bank-width = <2>;
partition@0 {
label = "test-part1";
reg = <0 0x04000000>;
Reviewed-by: Grant Likely <grant.likely@secretlab.ca>
CC: David Woodhouse <dwmw2@infradead.org>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Use of_get_next_child for proper ref counting as suggested by Stephen Rothwell
and remove add_mtd_partitions from parse_partitions to avoid duplicate
mtd device registration for RedBoot partitions.
Signed-off-by: Valentine Barshak <vbarshak@ru.mvista.com>
Acked-by: David Gibson <david@gibson.dropbear.id.au>
Heckled-for-on-IRC-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
This patch includes a whole batch of smallish cleanups for
drivers/mtd/physmap_of.c.
- A bunch of uneeded #includes are removed
- We switch to the modern linux/of.h etc. in place of
asm/prom.h
- Use some helper macros to avoid some ugly inline #ifdefs
- A few lines of unreachable code are removed
- A number of indentation / line-wrapping fixes
- More consistent use of kernel idioms such as if (!p) instead
of if (p == NULL)
- Clarify some printk()s and other informative strings.
- parse_obsolete_partitions() now returns 0 if no partition
information is found, instead of returning -ENOENT which the caller
had to handle specially.
- (the big one) Despite the name, this driver really has
nothing to do with drivers/mtd/physmap.c. The fact that the flash
chips must be physically direct mapped is a constrant, but doesn't
really say anything about the actual purpose of this driver, which is
to instantiate MTD devices based on information from the device tree.
Therefore the physmap name is replaced everywhere within the file with
"of_flash". The file itself and the Kconfig option is not renamed for
now (so that the diff is actually a diff). That can come later.
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
The latest physmap_of driver has a small error where it will fail the probe
with:
physmap-flash: probe of fff00000.small-flas failed with error -2
if there are no partition subnodes in the device tree and the old style binding
is not used. Since partition definitions are optional, the probe should still
succeed.
This replaces the binding for flash chips in booting-without-of.txt
with an clarified and improved version. It also makes
drivers/mtd/maps/physmap_of.c recognize this new binding. Finally it
revises the Ebony device tree source to use the new binding as an
example.
Acked-by: Segher Boessenkool <segher@kernel.crashing.org>
This patch removes redundant memset() and dead return line from
of_physmap_probe(). No functional change.
Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl>
* git://git.infradead.org/mtd-2.6: (21 commits)
[MTD] [CHIPS] Remove MTD_OBSOLETE_CHIPS (jedec, amd_flash, sharp)
[MTD] Delete allegedly obsolete "bank_size" field of mtd_info.
[MTD] Remove unnecessary user space check from mtd.h.
[MTD] [MAPS] Remove flash maps for no longer supported 405LP boards
[MTD] [MAPS] Fix missing printk() parameter in physmap_of.c MTD driver
[MTD] [NAND] platform NAND driver: add driver
[MTD] [NAND] platform NAND driver: update header
[JFFS2] Simplify and clean up jffs2_add_tn_to_tree() some more.
[JFFS2] Remove another bogus optimisation in jffs2_add_tn_to_tree()
[JFFS2] Remove broken insert_point optimisation in jffs2_add_tn_to_tree()
[JFFS2] Remember to calculate overlap on nodes which replace older nodes
[JFFS2] Don't advance c->wbuf_ofs to next eraseblock after wbuf flush
[MTD] [NAND] at91_nand.c: CMDLINE_PARTS support
[MTD] [NAND] Tidy up handling of page number in nand_block_bad()
[MTD] block2mtd_paramline[] mustn't be __initdata
[MTD] [NAND] Support multiple chips in CAFÉ driver
[MTD] [NAND] Rename cafe.c to cafe_nand.c and remove the multi-obj magic
[MTD] [NAND] Use rslib for CAFÉ ECC
[RSLIB] Support non-canonical GF representations
[JFFS2] Remove dead file histo_mips.h
Squashes a compiler warning, and provides more useful information in
the case messed up device tree information.
These are all the remaining instances of get_property. Simple rename of
get_property to of_get_property.
inlined below is the patch that adds physmap driver for of_device.
It's an MTD part of the two-part support for flash/ROM devices based
on Open Firmware descriptions. The arch part (currently only PowerPC
which is no surprise) was introduced to powerpc folks earlier and
recently the older version of the powerpc part has been included into
the powerpc.git tree
(see http://www.kernel.org/git/?p=linux/kernel/git/paulus/powerpc.git;a=commitdiff;h=28f9ec349ae47c91768b7bc5607db4442c818e11).
drivers/mtd/maps/Kconfig | 9 +
drivers/mtd/maps/Makefile | 1
drivers/mtd/maps/physmap_of.c | 255 ++++++++++++++++++++++++++++++++++++++++++
3 files changed, 265 insertions(+)
Signed-off-by: Vitaly Wool <vwool@ru.mvista.com>
Signed-off-by: Sergey Shtylyov <sshtylyov@ru.mvista.com>
