[ Upstream commit ef0de747f7ad179c7698a5b0e28db05f18ecbf57 ]
During probe, if there was an error the memory region and the memory
map were not properly released.This can lead a system unusable if
deferred probe is in use.
Replace mem_request and map with devm_ioremap_resource
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com>
Signed-off-by: Boris Brezillon <boris.brezillon@bootlin.com>
If 'of_flash_probe_gemini()' or 'of_flash_probe_versatile()' fail, we must
reslease some resources, as already done in all error handling paths in
this function.
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Now that we have a custom printf format specifier, convert users of
full_name to use %pOF instead. This is preparation to remove storing
of the full path string for each node.
Signed-off-by: Rob Herring <robh@kernel.org>
Cc: Brian Norris <computersforpeace@gmail.com>
Cc: Boris Brezillon <boris.brezillon@free-electrons.com>
Cc: Marek Vasut <marek.vasut@gmail.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Cyrille Pitchen <cyrille.pitchen@wedev4u.fr>
Cc: linux-mtd@lists.infradead.org
OF core code provides helpers for counting strings and reading them so
use them instead of doing this manually. This simplifies the code a bit.
Signed-off-by: Rafał Miłecki <rafal@milecki.pl>
Reviewed-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
The current way of building the of_physmap add-ons result in just
the add-on being in the object code, and not the actual core
implementation and regress the Gemini and Versatile.
Bake the physmap_of.o object by baking physmap_of_core.o and
adding the Versatile and/or Gemini add-ons to the final object.
Rename the source file physmap_of_core.c to get the desired
build components.
Suggested-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Fixes: 4f04f68e1598 ("mtd: physmap_of: fixup gemini/versatile dependencies")
Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com>
