Convert to mtd_device_register() and remove the CONFIG_MTD_PARTITIONS
preprocessor conditionals as partitioning is always available.
Signed-off-by: Jamie Iles <jamie@jamieiles.com>
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
As MTD_CONCAT is becoming a part of mtd core, it's now meaningless
to to check for it in ifdefs. Drop such references from MTD code.
Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
Commit f0b1e589 changed sa1100_mtd_probe from __init to __devinit,
but missed to correct sa1100_setup_mtd definition accordingly, which
causes following warning:
WARNING: vmlinux.o(.devinit.text+0xf4): Section mismatch in reference from
the function sa1100_mtd_probe() to the function .init.text:sa1100_setup_mtd()
The function __devinit sa1100_mtd_probe() references
a function __init sa1100_setup_mtd().
If sa1100_setup_mtd is only used by sa1100_mtd_probe then
annotate sa1100_setup_mtd with a matching annotation.
Signed-off-by: Dmitry Artamonow <mad_soft@inbox.ru>
drivers/mtd/maps/sa1100-flash.c: In function 'sa1100_probe_subdev':
drivers/mtd/maps/sa1100-flash.c:214: warning: format '%d' expects type 'int', but argument 3 has type 'uint64_t'
Due to problems at cam.org, my nico@cam.org email address is no longer
valid. FRom now on, nico@fluxnic.net should be used instead.
Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
Now the MTD core will do this for us, we don't need to hook it up from
the board drivers.
Shame we can't do shutdown from the class too...
* git://git.infradead.org/mtd-2.6: (53 commits)
[MTD] struct device - replace bus_id with dev_name(), dev_set_name()
[MTD] [NOR] Fixup for Numonyx M29W128 chips
[MTD] mtdpart: Make ecc_stats more realistic.
powerpc/85xx: TQM8548: Update DTS file for multi-chip support
powerpc: NAND: FSL UPM: document new bindings
[MTD] [NAND] FSL-UPM: Add wait flags to support board/chip specific delays
[MTD] [NAND] FSL-UPM: add multi chip support
[MTD] [NOR] Add device parent info to physmap_of
[MTD] [NAND] Add support for NAND on the Socrates board
[MTD] [NAND] Add support for 4KiB pages.
[MTD] sysfs support should not depend on CONFIG_PROC_FS
[MTD] [NAND] Add parent info for CAFÉ controller
[MTD] support driver model updates
[MTD] driver model updates (part 2)
[MTD] [NAND] move gen_nand's probe function to .devinit.text
[MTD] [MAPS] move sa1100 flash's probe function to .devinit.text
[MTD] fix use after free in register_mtd_blktrans
[MTD] [MAPS] Drop now unused sharpsl-flash map
[MTD] ofpart: Check name property to determine partition nodes.
Manually fix trivial conflict in drivers/mtd/maps/Makefile
A pointer to sa1100_mtd_probe is passed to the core via
platform_driver_register and so the function must not disappear when the
.init sections are discarded. Otherwise (if also having HOTPLUG=y)
unbinding and binding a device to the driver via sysfs will result in an
oops as does a device being registered late.
An alternative to this patch is using platform_driver_probe instead of
platform_driver_register plus removing the pointer to the probe function
from the struct platform_driver.
Cc: Nicolas Pitre <nico@marvell.com>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
"flash" is a very generic name for a platform_driver that is only
available on SA11x0.
This just leaves include/asm-arm/plat-* to deal with.
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h.
Then, since asm/hardware.h only exists to include asm/arch/hardware.h,
update everything to directly include asm/arch/hardware.h and remove
asm/hardware.h.
Once upon a time, the MTD repository was using CVS.
This patch therefore removes all usages of the no longer updated CVS
keywords from the MTD code.
This also includes code that printed them to the user.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is
prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable MTD mapping
platform drivers, to re-enable auto loading.
NOTE oddness with physmap ... it's a legacy driver in some configs, which
means it can't always support hotplugging. (Not that most of these mapping
drivers would often be used as modules...)
[dbrownell@users.sourceforge.net: bugfix, more drivers, registration fixes]
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Signed-off-by: Yan Burman <yan_952@hotmail.com>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
This allows us to eliminate the casts in the drivers, and eventually
remove the use of the device_driver function pointer methods for
platform device drivers.
Some manual fixups for clashing kfree() cleanups etc.
This is the drivers/mtd part of the big kfree cleanup patch.
Remove pointless checks for NULL prior to calling kfree() in drivers/mtd/.
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Acked-by: Joern Engel <joern@wohnheim.fh-wedel.de>
Manual #include fixups for clashes - there may be some unnecessary
Convert everyone who uses platform_bus_type to include
linux/platform_device.h.
Unfortunately, some devices forgot to reset the flash on reboot.
Arrange for the map driver to suspend & resume the flash to
ensure that it is in a sane state before rebooting.
Allow SA1100 devices to pass the name of the flash device to the
SA1100 map driver.
We should not delete MTD partitions when we registered a MTD
device.
In PM v1, all devices were called at SUSPEND_DISABLE level. Then
all devices were called at SUSPEND_SAVE_STATE level, and finally
SUSPEND_POWER_DOWN level. However, with PM v2, to maintain
compatibility for platform devices, I arranged for the PM v2
suspend/resume callbacks to call the old PM v1 suspend/resume
callbacks three times with each level in order so that existing
drivers continued to work.
Since this is obsolete infrastructure which is no longer necessary,
we can remove it. Here's an (untested) patch to do exactly that.
It's pointless to include mach-types.h if you're not going to use
anything from it. These references were removed as a result of:
grep -lr 'asm/mach-types\.h' . | xargs grep -L 'machine_is_\|MACH_TYPE_\|MACHINE_START\|machine_type'
This fixes u32 vs. pm_message_t in drivers/mmc, drivers/mtd and
drivers/scsi.
Signed-off-by: Pavel Machek <pavel@suse.cz>
infrastructure for it.
Let it rip!
