Convert to mtd_device_register() and remove the CONFIG_MTD_PARTITIONS
preprocessor conditionals as partitioning is always available.
Signed-off-by: Jamie Iles <jamie@jamieiles.com>
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
The uClinux map driver doesn't even use partitions, so we shouldn't require
it in order to work properly.
Signed-off-by: Timofei Bondarenko <tim@ipi.ac.ru>
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
CC: Greg Ungerer <gerg@uclinux.org>
CC: uclinux-dev@uclinux.org
CC: linux-mtd@lists.infradead.org
The uclinux_ram_mtdinfo, uclinux_romfs, and uclinux_point symbols do not
need to be visible outside of this module, so mark them static.
Due to a processor anomaly (05000263 to be exact), most Blackfin parts
cannot keep the embedded filesystem image directly after the kernel in
RAM. Instead, the filesystem needs to be relocated to the end of memory.
As such, we need to tweak the map addr/size during boot for Blackfin
systems. This can be done in any early arch/board init code.
CC: Paul Mundt <lethal@linux-sh.org>
The functions uclinux_mtd_cleanup and uclinux_mtd_init do
not heed to be global. Add the needed keyword to the file
drivers/mtd/maps/uclinux.c to make these functions static.
Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@movial.fi>
* git://git.infradead.org/mtd-2.6: (57 commits)
[MTD] [NAND] subpage read feature as a way to increase performance.
CPUFREQ: S3C24XX NAND driver frequency scaling support.
[MTD][NAND] au1550nd: remove unused variable
[MTD] jedec_probe: Fix SST 16-bit chip detection
[MTD][MTDPART] Fix a division by zero bug
[MTD][MTDPART] Cleanup and document the erase region handling
[MTD][MTDPART] Handle most checkpatch findings
[MTD][MTDPART] Seperate main loop from per-partition code in add_mtd_partition
[MTD] physmap: resume already suspended chips on failure to suspend
[MTD] physmap: Fix suspend/resume/shutdown bugs.
[MTD] [NOR] Fix -ETIMEO errors in CFI driver
[MTD] [NAND] fsl_elbc_nand: fix section mismatch with CONFIG_MTD_OF_PARTS=y
[JFFS2] Use .unlocked_ioctl
[MTD] Fix const assignment in the MTD command line partitioning driver
[MTD] [NOR] gen_probe: No debug message when debugging is disabled
[MTD] [NAND] remove __PPC__ hardcoded address from DiskOnChip drivers
[MTD] [MAPS] Remove the bast-flash driver.
[MTD] [NAND] fsl_elbc_nand: ecclayout cleanups
[MTD] [NAND] fsl_elbc_nand: implement support for flash-based BBT
[MTD] [NAND] fsl_elbc_nand: fix OOB workability for large page NAND chips
On 32-bit architectures PAGE_ALIGN() truncates 64-bit values to the 32-bit
boundary. For example:
u64 val = PAGE_ALIGN(size);
always returns a value < 4GB even if size is greater than 4GB.
The problem resides in PAGE_MASK definition (from include/asm-x86/page.h for
example):
#define PAGE_SHIFT 12
#define PAGE_SIZE (_AC(1,UL) << PAGE_SHIFT)
#define PAGE_MASK (~(PAGE_SIZE-1))
#define PAGE_ALIGN(addr) (((addr)+PAGE_SIZE-1)&PAGE_MASK)
The "~" is performed on a 32-bit value, so everything in "and" with
PAGE_MASK greater than 4GB will be truncated to the 32-bit boundary.
Using the ALIGN() macro seems to be the right way, because it uses
typeof(addr) for the mask.
Also move the PAGE_ALIGN() definitions out of include/asm-*/page.h in
include/linux/mm.h.
See also lkml discussion: http://lkml.org/lkml/2008/6/11/237
[akpm@linux-foundation.org: fix drivers/media/video/uvc/uvc_queue.c]
[akpm@linux-foundation.org: fix v850]
[akpm@linux-foundation.org: fix powerpc]
[akpm@linux-foundation.org: fix arm]
[akpm@linux-foundation.org: fix mips]
[akpm@linux-foundation.org: fix drivers/media/video/pvrusb2/pvrusb2-dvb.c]
[akpm@linux-foundation.org: fix drivers/mtd/maps/uclinux.c]
Signed-off-by: Andrea Righi <righi.andrea@gmail.com>
Cc: <linux-arch@vger.kernel.org>
Once upon a time, the MTD repository was using CVS.
This patch therefore removes all usages of the no longer updated CVS
keywords from the MTD code.
This also includes code that printed them to the user.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Adding the ability to get a physical address from point() in addition
to virtual address. This physical address is required for XIP of
userspace code from flash.
Signed-off-by: Jared Hulbert <jaredeh@gmail.com>
Reviewed-by: Jörn Engel <joern@logfs.org>
Acked-by: Nicolas Pitre <nico@cam.org>
Acked-by: Greg Ungerer <gerg@uclinux.org>
The cheesy uclinux mtd maps can be used for more than just the root device, so
I think we should drop the forcing.
Also, I feel like this is a policy decision that shouldnt be in the kernel in
the first place. People who have been lazy and boot with uclinux mtd maps and
dont put root= into their commandline can simply add the appropriate root=
line either into their bootloader or into the compiled in bootargs.
Acked-by: Christoph Hellwig <hch@lst.de>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove
duplicates of the macro.
Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch>
Acked-by: David Woodhouse <dwmw2@infradead.org>
We should not call mtd_put_device() in the uclinux MTD map driver.
Also consistently use phys/virt fields of maps map_info struct,
instead of mixing it with map_priv_1.
Signed-off-by: Greg Ungerer <gerg@uclinux.com>
infrastructure for it.
Let it rip!
