Flash device drivers initialize 'ecc_strength' in struct mtd_info, which is the
maximum number of bit errors that can be corrected in one writesize region.
Drivers using the nand interface intitialize 'strength' in struct nand_ecc_ctrl,
which is the maximum number of bit errors that can be corrected in one ecc step.
Nand infrastructure code translates this to 'ecc_strength'.
Also for nand drivers, the nand infrastructure code sets ecc.strength for ecc
modes NAND_ECC_SOFT, NAND_ECC_SOFT_BCH, and NAND_ECC_NONE. It is set in the
driver for all other modes.
Signed-off-by: Mike Dunn <mikedunn@newsguy.com>
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
The first 3 arguments of 'mtd_device_parse_register()' are pointers,
but many callers pass '0' instead of 'NULL'. Fix this globally. Thanks
to coccinelle for making it easy to do with the following semantic patch:
expression mtd, types, parser_data, parts, nr_parts;
-mtd_device_parse_register(mtd, 0, parser_data, parts, nr_parts)
+mtd_device_parse_register(mtd, NULL, parser_data, parts, nr_parts)
-mtd_device_parse_register(mtd, types, 0, parts, nr_parts)
+mtd_device_parse_register(mtd, types, NULL, parts, nr_parts)
-mtd_device_parse_register(mtd, types, parser_data, 0, nr_parts)
+mtd_device_parse_register(mtd, types, parser_data, NULL, nr_parts)
module_param(bool) used to counter-intuitively take an int. In
fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy
trick.
It's time to remove the int/unsigned int option. For this version
it'll simply give a warning, but it'll break next kernel version.
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
This patch converts the drivers in drivers/mtd/* to use the
module_platform_driver() macro which makes the code smaller and a bit
simpler.
Acked by: Haojian Zhuang <haojian.zhuang@gmail.com>
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@linux.intel.com>
Current pxa3xx_nand controller has two chip select which
both be workable. This patch enable this feature.
Update platform driver to support this feature.
Another notice should be taken that:
When you want to use this feature, you should not enable the
keep configuration feature, for two chip select could be
attached with different nand chip. The different page size
and timing requirement make the keep configuration impossible.
Signed-off-by: Lei Wen <leiwen@marvell.com>
For support two chip select, we seperate chip specific info in this
patch.
Also add missed warning message.
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@intel.com>
This patch add protection on the suspend&resume path to prevent
some unexpected behavior, like interrupt occur at the very second
of resume back and it don't follow normal command path, which lead
to bug.
Replace custom invocations of parse_mtd_partitions and mtd_device_register
with common mtd_device_parse_register call. This would bring: standard
handling of all errors, fallback to default partitions, etc.
Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
This bug was introduced in f8155a40 ("mtd: pxa3xx_nand: rework irq
logic") and causes the PXA3xx NAND controller fail to operate with NAND
flash that has empty pages. According to the comment in this block, the
hardware controller will report a double-bit error for empty pages,
which can and must be ignored.
This patch restores the original behaviour of the driver.
Signed-off-by: Daniel Mack <zonque@gmail.com>
Acked-by: Lei Wen <leiwen@marvell.com>
Cc: Haojian Zhuang <haojian.zhuang@marvell.com>
Cc: David Woodhouse <David.Woodhouse@intel.com>
Cc: stable@kernel.org [2.6.38+]
When keep_config is set, the detection would goes different routine.
That the driver would read out the setting which is set previously
by bootloader. While most bootloader keep the irq mask as off, and
current driver need all irq default open, keep_config behavior would
lead to no irq at all.
Tested-by: Daniel Mack <zonque@gmail.com>
Since 'cmdline, NULL' is now a default for parse_mtd_partitions, don't specify
this in every driver, instead pass NULL to force parse_mtd_partitions
to use default.
Remove unused variable 'mtd' to eliminate below warning.
CC drivers/mtd/nand/pxa3xx_nand.o
drivers/mtd/nand/pxa3xx_nand.c: In function 'pxa3xx_nand_suspend':
drivers/mtd/nand/pxa3xx_nand.c:1167: warning: unused variable 'mtd'
drivers/mtd/nand/pxa3xx_nand.c: In function 'pxa3xx_nand_resume':
drivers/mtd/nand/pxa3xx_nand.c:1180: warning: unused variable 'mtd'
In pxa3xx_nand_remove, we should call nand_release instead of
mtd_device_unregister to properly free bad block table memory
and bad block descriptor memory.
Convert to mtd_device_register() and remove the CONFIG_MTD_PARTITIONS
preprocessor conditionals as partitioning is always available.
Cc: Cc: David Woodhouse <dwmw2@infradead.org>
Cc: Artem Bityutskiy <dedekind1@gmail.com>
Signed-off-by: Jamie Iles <jamie@jamieiles.com>
Use nand_scan_ident to unify the need of mtd member initilization
for both normal detection and keep configuration method.
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com>
Different NAND driver may require its unique detection. For pxa3xx_nand,
it use its self id database to get the necessary info.
Make the interface simpler which could make both debug
and enhancement easier.
Since we have rework the irq process, we don't need additional
delay in wait_for_event. Also write_cmd and __readid is also
discarded for the same reason.
Acked-by: Eric Miao <eric.y.miao@gmail.com>
Enable all irq when we start the nand controller, and
put all the transaction logic in the pxa3xx_nand_irq.
By doing this way, we could dramatically increase the
performance by avoid unnecessary delay.
The previous probe function is some kind of big part.
This patch seperate the resource allocation to keep the probe process
more clear than before.
"info->cmdset" gets dereferenced in __readid() so it needs to be
initialized earlier in the function. This bug was introduced in
18c81b1828f8 "mtd: pxa3xx_nand: remove the flash info in driver
structure".
Cc: stable@kernel.org [2.6.37+]
Reported-and-tested-by: Sven Neumann <s.neumann@raumfeld.com>
For different command need different oob requirement, set the proper
oob length by different cmd.
After probe, all info already transfer to driver structure.
There is no need to keep the original flash info.
So that we could safely free the flash info in memory, which may grows
larger when more flash is suported.
We certainly don't need to send read id command times by times, since
we already know what the id is after the first read id...
So create a default timing which could ensure it would successfully read
id out all supported chip. Then follow the build-in table to reconfigure
the timing.
Adding a new flash definition would need less code.
Keep the platform passing flash definition method.
If one flash is both defined in platform data and builtin table,
driver would select the one from platform data first.
By this way, platform could select the timing most suit for itself,
not need to follow the common settings.
Signed-off-by: Mark F. Brown <mark.brown314@gmail.com>
Test on a PXA310 platform with Samsung K9F2G08X0B NAND flash,
with tCH=5 and clk is 156MHz, ns2cycle(5, 156000000) returns -1.
ns2cycle returns negtive value will break NDTR0_tXX macros.
After checking the commit log, I found the problem is introduced by
commit 5b0d4d7c8a67c5ba3d35e6ceb0c5530cc6846db7
"[MTD] [NAND] pxa3xx: convert from ns to clock ticks more accurately"
To get num of clock cycles, we use below equation:
num of clock cycles = time (ns) / one clock cycle (ns) + 1
We need to add 1 cycle here because integer division will truncate the result.
It is possible the developers set the Min values in SPEC for timing settings.
Thus the truncate may cause problem, and it is safe to add an extra cycle here.
The various fields in NDTR{01} are in units of clock ticks minus one,
thus we should subtract 1 cycle then.
Thus the correct equation should be:
num of clock cycles = time (ns) / one clock cycle (ns) + 1 - 1
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
drivers/mtd/mtdcore.c
Pull in the bdi fixes and ARM platform changes that other outstanding
patches depend on.
The pxa32xx_nand driver doesn't support partition tables from the
command line. This patch adds support for it.
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Since the same nand controller is shared between ARCH_PXA and ARCH_MMP. Move
the pxa3xx_nand.h from mach directory to plat directoy.
Cc: David Woodhouse <david.woodhouse@intel.com>
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
Support samsung 2GbX8 and 32GbX8 nand flash.
Support micron 4GbX8 and 4GbX16 nand flash.
In some bootloader, IRQ is enabled. Writing nand triggers unexpected
interrupts. So disable nand irq in initialization. After nand
initialized and in working state, irq is controlled by nand driver.
Nand driver uses IRQ_NAND as hardcode irq number. In ARCH_MMP, the irq
number is different. So get irq resource from platform device structure
and use it in initialization and deinitialization code.
Although nand controller is same between PXA3xx and MMP, the register space
is different. Remove the hardcode register address setting in pxa3xx_nand.h.
Slow down the tRp of Micron NAND flash timing.
Initialize the read buffer content to 0xFF.
When fetch nand data with non-DMA mode, we should align info->data_size to
32bit, not 8bit.
Signed-off-by: Yeasah Pell <yeasah@comrex.com>
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
* git://git.infradead.org/mtd-2.6: (53 commits)
[MTD] struct device - replace bus_id with dev_name(), dev_set_name()
[MTD] [NOR] Fixup for Numonyx M29W128 chips
[MTD] mtdpart: Make ecc_stats more realistic.
powerpc/85xx: TQM8548: Update DTS file for multi-chip support
powerpc: NAND: FSL UPM: document new bindings
[MTD] [NAND] FSL-UPM: Add wait flags to support board/chip specific delays
[MTD] [NAND] FSL-UPM: add multi chip support
[MTD] [NOR] Add device parent info to physmap_of
[MTD] [NAND] Add support for NAND on the Socrates board
[MTD] [NAND] Add support for 4KiB pages.
[MTD] sysfs support should not depend on CONFIG_PROC_FS
[MTD] [NAND] Add parent info for CAFÉ controller
[MTD] support driver model updates
[MTD] driver model updates (part 2)
[MTD] [NAND] move gen_nand's probe function to .devinit.text
[MTD] [MAPS] move sa1100 flash's probe function to .devinit.text
[MTD] fix use after free in register_mtd_blktrans
[MTD] [MAPS] Drop now unused sharpsl-flash map
[MTD] ofpart: Check name property to determine partition nodes.
Manually fix trivial conflict in drivers/mtd/maps/Makefile
OBM/bootloader
Acked-by: Eric Miao <eric.miao@marvell.com>
1. Driver code where pxa_request_dma() is called will most likely
reference DMA registers as well, and it is really unnecessary
to include pxa-regs.h just for this. Move the definitions into
<mach/dma.h> and make relevant drivers include it instead of
<mach/pxa-regs.h>.
2. Introduce DMAC_REGS_VIRT as the virtual address base for these
DMA registers. This allows later processors to re-use the same
IP while registers may start at different I/O address.
Signed-off-by: Eric Miao <eric.miao@marvell.com>
The various fields in NDTR{01} are in units of clock ticks minus one, but the
ns2cycle macro mistakenly adds one, inflating the number of clock ticks and
making it impossible to set any of these fields to zero.
Signed-off-by: Matt Reimer <mreimer@vpop.net>
Reads from non-page-aligned addresses were broken because while the
address to read from was correctly written to NDCB*, a full page was
always read. Fix this by ignoring the column and only using the page
address.
I suspect this whole-page behavior is due to the controller's need to
read the entire page in order to generate correct ECC. In the non-ECC
case this could be optimized to use the column address, and to set the
read length to what is being requested rather than the length of an
entire page.
