path: root/drivers/mtd/nand/socrates_nand.c
2013-11-14Merge tag 'for-linus-20131112' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull MTD changes from Brian Norris: - Unify some compile-time differences so that we have fewer uses of #ifdef CONFIG_OF in atmel_nand - Other general cleanups (removing unused functions, options, variables, fields; use correct interfaces) - Fix BUG() for new odd-sized NAND, which report non-power-of-2 dimensions via ONFI - Miscellaneous driver fixes (SPI NOR flash; BCM47xx NAND flash; etc.) - Improve differentiation between SLC and MLC NAND -- this clarifies an ABI issue regarding the MTD "type" (in sysfs and in the MEMGETINFO ioctl), where the MTD_MLCNANDFLASH type was present but inconsistently used - Extend GPMI NAND to support multi-chip-select NAND for some platforms - Many improvements to the OMAP2/3 NAND driver, including an expanded DT binding to bring us closer to mainline support for some OMAP systems - Fix a deadlock in the error path of the Atmel NAND driver probe - Correct the error codes from MTD mmap() to conform to POSIX and the Linux Programmer's Manual. This is an acknowledged change in the MTD ABI, but I can't imagine somebody relying on the non-standard -ENOSYS error code specifically. Am I just being unimaginative? :) - Fix a few important GPMI NAND bugs (one regression from 3.12 and one long-standing race condition) - More? Read the log! * tag 'for-linus-20131112' of git://git.infradead.org/linux-mtd: (98 commits) mtd: gpmi: fix the NULL pointer mtd: gpmi: fix kernel BUG due to racing DMA operations mtd: mtdchar: return expected errors on mmap() call mtd: gpmi: only scan two chips for imx6 mtd: gpmi: Use devm_kzalloc() mtd: atmel_nand: fix bug driver will in a dead lock if no nand detected mtd: nand: use a local variable to simplify the nand_scan_tail mtd: nand: remove deprecated IRQF_DISABLED mtd: dataflash: Say if we find a device we don't support mtd: nand: omap: fix error return code in omap_nand_probe() mtd: nand_bbt: kill NAND_BBT_SCANALLPAGES mtd: m25p80: fixup device removal failure path mtd: mxc_nand: Include linux/of.h header mtd: remove duplicated include from mtdcore.c mtd: m25p80: add support for Macronix mx25l3255e mtd: nand: omap: remove selection of BCH ecc-scheme via KConfig mtd: nand: omap: updated devm_xx for all resource allocation and free calls mtd: nand: omap: use drivers/mtd/nand/nand_bch.c wrapper for BCH ECC instead of lib/bch.c mtd: nand: omap: clean-up ecc layout for BCH ecc schemes mtd: nand: omap2: clean-up BCHx_HW and BCHx_SW ECC configurations in device_probe ...
2013-11-11powerpc: add missing explicit OF includes for ppcdevicetree-for-3.13Rob Herring
Commit b5b4bb3f6a11f9 (of: only include prom.h on sparc) removed implicit includes of of_*.h headers by powerpc's prom.h. Some components were missed in initial clean-up patch, so add the necessary includes to fix powerpc builds. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Tejun Heo <tj@kernel.org> Cc: Matt Mackall <mpm@selenic.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: "David S. Miller" <davem@davemloft.net> Cc: Vinod Koul <vinod.koul@intel.com> Cc: Dan Williams <dan.j.williams@intel.com> Cc: linuxppc-dev@lists.ozlabs.org Cc: linux-ide@vger.kernel.org Cc: linux-crypto@vger.kernel.org
2013-11-06mtd: socrates_nand: Use dev_err instead of printkSachin Kamat
dev_err is preferred to printk. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2013-11-06mtd: socrates_nand: Use devm_kzallocSachin Kamat
devm_kzalloc is device managed and makes code simpler. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2013-11-06mtd: socrates_nand: Remove redundant dev_set_drvdataSachin Kamat
Driver core will set the driver data to NULL upon detach or probe failure. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2012-11-22mtd: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-11-22mtd: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-11-22mtd: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-09-29mtd: kill MTD_NAND_VERIFY_WRITEHuang Shijie
Just as Artem suggested: "Both UBI and JFFS2 are able to read verify what they wrote already. There are also MTD tests which do this verification. So I think there is no reason to keep this in the NAND layer, let alone wasting RAM in the driver to support this feature. Besides, it does not work for sub-pages and many drivers have it broken. It hurts more than it provides benefits." So kill MTD_NAND_VERIFY_WRITE entirely. Signed-off-by: Huang Shijie <shijie8@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-01-09mtd: convert drivers/mtd/* to use module_platform_driver()Axel Lin
This patch converts the drivers in drivers/mtd/* to use the module_platform_driver() macro which makes the code smaller and a bit simpler. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked by: Haojian Zhuang <haojian.zhuang@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-09-11mtd: socrates_nand.c: use mtd_device_parse_registerDmitry Eremin-Solenikov
Replace custom invocations of parse_mtd_partitions and mtd_device_register with common mtd_device_parse_register call. This would bring: standard handling of all errors, fallback to default partitions, etc. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Artem Bityutskiy <dedekind1@gmail.com>
2011-09-11mtd: socrates_nand: use ofpart through generic parsingDmitry Eremin-Solenikov
Convert the driver to use ofpart partitions parsing through the generic parse_mtd_partitions(). Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Artem Bityutskiy <dedekind1@gmail.com>
2011-09-11mtd: socrates_nand don't specify default parsing optionsDmitry Eremin-Solenikov
Since 'cmdline, NULL' is now a default for parse_mtd_partitions, don't specify this in every driver, instead pass NULL to force parse_mtd_partitions to use default. Artem: tweaked the patch Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-05-25mtd: socrates_nand: convert to mtd_device_register()Jamie Iles
Convert to mtd_device_register() and remove the CONFIG_MTD_PARTITIONS preprocessor conditionals as partitioning is always available. Signed-off-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-02-28dt: Eliminate of_platform_{,un}register_driverGrant Likely
Final step to eliminate of_platform_bus_type. They're all just platform drivers now. v2: fix type in pasemi_nand.c (thanks to Stephen Rothwell) Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-08-06of/device: Replace struct of_device with struct platform_deviceGrant Likely
of_device is just an alias for platform_device, so remove it entirely. Also replace to_of_device() with to_platform_device() and update comment blocks. This patch was initially generated from the following semantic patch, and then edited by hand to pick up the bits that coccinelle didn't catch. @@ @@ -struct of_device +struct platform_device Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Reviewed-by: David S. Miller <davem@davemloft.net>
2010-06-02of/mtd: nand: fix build breakage in driversAnatolij Gustschin
Fixes build errors in drivers caused by the OF device_node pointer being moved into struct device Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-22Merge remote branch 'origin' into secretlab/next-devicetreeGrant Likely
Merging in current state of Linus' tree to deal with merge conflicts and build failures in vio.c after merge. Conflicts: drivers/i2c/busses/i2c-cpm.c drivers/i2c/busses/i2c-mpc.c drivers/net/gianfar.c Also fixed up one line in arch/powerpc/kernel/vio.c to use the correct node pointer. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-22of: Remove duplicate fields from of_platform_driverGrant Likely
.name, .match_table and .owner are duplicated in both of_platform_driver and device_driver. This patch is a removes the extra copies from struct of_platform_driver and converts all users to the device_driver members. This patch is a pretty mechanical change. The usage model doesn't change and if any drivers have been missed, or if anything has been fixed up incorrectly, then it will fail with a compile time error, and the fixup will be trivial. This patch looks big and scary because it touches so many files, but it should be pretty safe. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Sean MacLennan <smaclennan@pikatech.com>
2010-02-26mtd: nand: Allow caller to pass alternative ID table to nand_scan_ident()David Woodhouse
2010-02-25mtd: nand: make Open Firmware device id constantMárton Németh
The match_table field of the struct of_device_id is constant in <linux/of_platform.h> so it is worth to make xps2_of_match also constant. The semantic match that finds this kind of pattern is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r@ disable decl_init,const_decl_init; identifier I1, I2, x; @@ struct I1 { ... const struct I2 *x; ... }; @s@ identifier r.I1, y; identifier r.x, E; @@ struct I1 y = { .x = E, }; @c@ identifier r.I2; identifier s.E; @@ const struct I2 E[] = ... ; @depends on !c@ identifier r.I2; identifier s.E; @@ + const struct I2 E[] = ...; // </smpl> Signed-off-by: Márton Németh <nm127@freemail.hu> Cc: Julia Lawall <julia@diku.dk> Cc: cocci@diku.dk Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-04-06[MTD] [NAND] Add support for NAND on the Socrates boardWolfgang Grandegger
Signed-off-by: Ilya Yanok <yanok@emcraft.com> Acked-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
