commit c804c733846572ca85c2bba60c7fe6fa024dff18 upstream.
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf (platform: prefix MODALIAS
with "platform:"), the platform modalias is prefixed with "platform:".
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
commit 93b352fce679945845664b56b0c3afbd655a7a12 upstream.
Test on a PXA310 platform with Samsung K9F2G08X0B NAND flash,
with tCH=5 and clk is 156MHz, ns2cycle(5, 156000000) returns -1.
ns2cycle returns negtive value will break NDTR0_tXX macros.
After checking the commit log, I found the problem is introduced by
commit 5b0d4d7c8a67c5ba3d35e6ceb0c5530cc6846db7
"[MTD] [NAND] pxa3xx: convert from ns to clock ticks more accurately"
To get num of clock cycles, we use below equation:
num of clock cycles = time (ns) / one clock cycle (ns) + 1
We need to add 1 cycle here because integer division will truncate the result.
It is possible the developers set the Min values in SPEC for timing settings.
Thus the truncate may cause problem, and it is safe to add an extra cycle here.
The various fields in NDTR{01} are in units of clock ticks minus one,
thus we should subtract 1 cycle then.
Thus the correct equation should be:
num of clock cycles = time (ns) / one clock cycle (ns) + 1 - 1
Signed-off-by: Lei Wen <leiwen@marvell.com>
Acked-by: Eric Miao <eric.y.miao@gmail.com>
Fixed following htmldocs warnings:
DOCPROC Documentation/DocBook/mtdnand.xml
Warning(drivers/mtd/nand/nand_base.c:769): No description found for parameter 'page'
Warning(drivers/mtd/nand/nand_base.c:785): No description found for parameter 'page'
Warning(drivers/mtd/nand/nand_base.c:824): No description found for parameter 'page'
Warning(drivers/mtd/nand/nand_base.c:947): No description found for parameter 'page'
Warning(drivers/mtd/nand/nand_base.c:996): No description found for parameter 'page'
Warning(drivers/mtd/nand/nand_base.c:1040): No description found for parameter 'page'
Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
* git://git.infradead.org/mtd-2.6: (58 commits)
mtd: jedec_probe: add PSD4256G6V id
mtd: OneNand support for Nomadik 8815 SoC (on NHK8815 board)
mtd: nand: driver for Nomadik 8815 SoC (on NHK8815 board)
m25p80: Add Spansion S25FL129P serial flashes
jffs2: Use SLAB_HWCACHE_ALIGN for jffs2_raw_{dirent,inode} slabs
mtd: sh_flctl: register sh_flctl using platform_driver_probe()
mtd: nand: txx9ndfmc: transfer 512 byte at a time if possible
mtd: nand: fix tmio_nand ecc correction
mtd: nand: add __nand_correct_data helper function
mtd: cfi_cmdset_0002: add 0xFF intolerance for M29W128G
mtd: inftl: fix fold chain block number
mtd: jedec: fix compilation problem with I28F640C3B definition
mtd: nand: fix ECC Correction bug for SMC ordering for NDFC driver
mtd: ofpart: Check availability of reg property instead of name property
driver/Makefile: Initialize "mtd" and "spi" before "net"
mtd: omap: adding DMA mode support in nand prefetch/post-write
mtd: omap: add support for nand prefetch-read and post-write
mtd: add nand support for w90p910 (v2)
mtd: maps: add mtd-ram support to physmap_of
mtd: pxa3xx_nand: add single-bit error corrections reporting
Trivial patch which adds the __init and __exit macros to the module_init /
module_exit functions to the following modules from drivers/mtd/
devices/m25p80.c
devices/slram.c
linux version 2.6.30
ftl.c
nand/cafe_nand.c
nand/cmx270_nand.c
Signed-off-by: Peter Huewe <peterhuewe@gmx.de>
Signed-off-by: Alessandro Rubini <rubini@unipv.it>
Acked-by: Andrea Gallo <andrea.gallo@stericsson.com>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
drivers/mtd/mtdcore.c
Merged in order that I can apply the Nomadik nand/onenand support patches.
As with orion_nand in commit f33dabbe79fdf7a8568c65faa1db7794c87ac4d3
("register orion_nand using platform_driver_probe()"), avoid .init.text
problems by using platform_device_probe(). This isn't going to be
hotplugged anyway.
Reported-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Using __nand_correct_data() helper function, this driver can read 512
byte (with 6 byte ECC) at a time. This results minor performance
improvement.
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
This driver may be reading 512 bytes at a times, but still calculates
256-byte sector ECC. So the nand_correct_data() is not appropriate
for this driver. Implement its ecc.correct function calling
__nand_correct_data() twice.
Acked-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
Acked-by: Vimal Singh <vimalsingh@ti.com>
Split nand_correct_data() into two part, a pure calculation function
and a wrapper for mtd interface.
The tmio_nand driver can implement its ecc.correct function easily
using this __nand_correct_data helper.
Fix ECC Correction bug where the byte offset location were double
fliped causing correction routine to toggle the wrong byte location
in the ECC segment. The ndfc_calculate_ecc routine change the order
of getting the ECC code.
/* The NDFC uses Smart Media (SMC) bytes order */
ecc_code[0] = p[2];
ecc_code[1] = p[1];
ecc_code[2] = p[3];
But in the Correction algorithm when calculating the byte offset
location, the b1 is used as the upper part of the address. Which
again reverse the order making the final byte offset address
location incorrect.
byte_addr = (addressbits[b1] << 4) + addressbits[b0];
The order is change to read it in straight and let the correction
function to revert it to SMC order.
Cc: stable@kernel.org
Signed-off-by: Feng Kan <fkan@amcc.com>
Acked-by: Victor Gallardo <vgallardo@amcc.com>
Acked-by: Prodyut Hazarika <phazarika@amcc.com>
This patch adds DMA mode support for nand prefetch/post-write engine.
Signed-off-by: Vimal Singh <vimalsingh@ti.com>
This patch adds prefetch support to access nand flash in mpu mode.
This patch also adds 8-bit nand support (omap_read/write_buf8).
Prefetch can be used for both 8- and 16-bit devices.
Add w90p910 NAND driver for w90p910 evaluation board
based on w90p910,there is a K8F1G08 NAND on my board.
[dwmw2: depend on MTD_PARTITIONS]
Signed-off-by: Wan ZongShun <mcuos.com@gmail.com>
Signed-off-by: Yeasah Pell <yeasah@comrex.com>
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
This patch allows i.MX27 to support 2KiB pagesize NAND flash.
We are using a 1.8V NAND flash which datasheet (unfortunately only
available under NDA) says :
Page size: x8: 2,112 bytes (2,048 + 64 bytes).
Without this patch, all sectors are marked as bad eraseblock.
Signed-off-by: Eric Benard <ebenard@eukrea.com>
Acked-by : Sascha Hauer <s.hauer@pengutronix.de>
This patch adds 4-bit ECC support for large page NAND chips using the new
ECC mode NAND_ECC_HW_OOB_FIRST. The platform data from board-dm355-evm
has been adjusted to use this mode.
The patches have been verified on DM355 device with 2KiB-page Micron
devices using mtd-tests and JFFS2. Error correction up to 4 bits has
also been verified using nandwrite/nanddump utilities.
Reviewed-by: David Brownell <dbrownell@users.sourceforge.net>
Signed-off-by: Sneha Narnakaje <nsnehaprabha@ti.com>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
Cc: Troy Kisky <troy.kisky@boundarydevices.com>
This patch adds the new mode NAND_ECC_HW_OOB_FIRST in the nand code to
support 4-bit ECC on TI DaVinci devices with large page (up to 2KiB) NAND
chips. This ECC mode is similar to NAND_ECC_HW, with the exception of
read_page API that first reads the OOB area, reads the data in chunks,
feeds the ECC from OOB area to the ECC hw engine and perform any
correction on the data as per the ECC status reported by the engine.
"ECC_HW_OOB_FIRST" name suggested by Thomas Gleixner
This patch adds a new "page" parameter to all NAND read_page/read_page_raw
APIs. The read_page API for the new mode ECC_HW_OOB_FIRST requires the
page information to send the READOOB command and read the OOB area before
the data area.
orion_nand_probe lives in .init.text, so using platform_driver_register to
register it is wrong because binding a device after the init memory is
discarded (e.g. via sysfs) results in an oops.
As requested by Nicolas Pitre platform_driver_probe is used instead of
moving the probe function to .devinit.text as proposed initially. This
saves some memory, but devices registered after the driver is probed are
not bound (probably there are none) and binding via sysfs isn't possible.
Cc: Lennert Buytenhek <buytenh@marvell.com>
Cc: Saeed Bishara <saeed@marvell.com>
Cc: Joern Engel <joern@logfs.org>
Acked-by: Nicolas Pitre <nico@marvell.com>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6
* 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (47 commits)
OMAP clock: use debugfs_remove_recursive() for rewinding
OMAP2/3/4 core: create omap_device layer
OMAP: omap_hwmod: call omap_hwmod init at boot; create interconnects
OMAP2/3/4: create omap_hwmod layer
OMAP2/3 board-*.c files: read bootloader configuration earlier
OMAP2/3/4 PRCM: add module IDLEST wait code
OMAP2/3 PM: create the OMAP PM interface and add a default OMAP PM no-op layer
OMAP3 clock: remove superfluous calls to omap2_init_clk_clkdm
OMAP clock: associate MPU clocks with the mpu_clkdm
OMAP3 clock: Fixed processing of bootarg 'mpurate'
OMAP: SDRC: Add several new register definitions
OMAP: powerdomain: Fix overflow when doing powerdomain deps lookups.
OMAP: PM: Added suspend target state control to debugfs for OMAP3
OMAP: PM debug: Add PRCM register dump support
OMAP: PM debug: make powerdomains use PM-debug counters
OMAP: PM: Add pm-debug counters
OMAP: PM: Add closures to clkdm_for_each and pwrdm_for_each.
OMAP: PM: Hook into PM counters
OMAP: PM counter infrastructure.
OMAP3: PM: fix lockdep warning caused by omap3_pm_init
'w90x900' into devel
This patch allows core driver to choose ECC block size in
sw ecc case.
1. <linux/io.h> should be included not <asm/io.h>
2. add platform specific header <mach/ts72xx.h>
Cc: Lennert Buytenhek <buytenh@wantstofly.org>
Correcting debug prints by removing function names from print messages
and using '__func__' macro instead.
Function names were wrong in few places.
Singed-off-by: Vimal Singh <vimalsingh@ti.com>
Rename OMAP_MPUIO_BASE to OMAP1_MPUIO_BASE
GCC 4.3.3 and 4.4.1 happily moves the dword load instruction out of the
loop in orion_nand_read_buf. This patch makes the instruction volatile
to avoid the issue. I've discussed this at gcc-help, refer to the thread
at
http://gcc.gnu.org/ml/gcc-help/2009-08/msg00187.html
The early clobber is added to avoid the destination registers and the
source register overlapping.
Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net>
Signed-off-by: Nicolas Pitre <nico@marvell.com>
arch/arm/mach-ep93xx/include/mach/hardware.h
1. Properly name the include files so that they are loaded
from the <mach/*> directory and not the local directory.
2. Remove including the ts72xx.h header. This header is not
generic to the ep93xx platform. It should only be included
by the ts72xx specific files that require it. The only
two users in the tree are arch/arm/mach-ep93xx/ts72xx.c
and drivers/mtd/nand/ts7250.c.
arch/arm/mach-ep93xx/include/mach/ts72xx.h
1. <linux/io.h> should already be included by any user of this
header. Doing the include here hides it from being needed
by the calling source file.
arch/arm/mach-ep93xx/core.c
1. Remove unnecessary headers. They were probably included
originally due to cut-and-paste from other files.
2. <linux/io.h> should be included not <mach/gpio.h>
arch/arm/mach-ep93xx/adsphere.c
arch/arm/mach-ep93xx/edb93xx.c
arch/arm/mach-ep93xx/gesbc9312.c
arch/arm/mach-ep93xx/micro9.c
2. Add platform specific header <mach/ts72xx.h>.
1. <linux/io.h> should be included not <asm/io.h>.
Cc: Ryan Mallon <ryan@bluewatersys.com>
We need to include jiffies.h manually in some cases, and the status
returned from omap_wait() was broken in two separate ways.
Also add cond_resched() to the loop.
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com>
* git://git.infradead.org/mtd-2.6: (63 commits)
mtd: OneNAND: Allow setting of boundary information when built as module
jffs2: leaking jffs2_summary in function jffs2_scan_medium
mtd: nand: Fix memory leak on txx9ndfmc probe failure.
mtd: orion_nand: use burst reads with double word accesses
mtd/nand: s3c6400 support for s3c2410 driver
[MTD] [NAND] S3C2410: Use DIV_ROUND_UP
[MTD] [NAND] S3C2410: Deal with unaligned lengths in S3C2440 buffer read/write
[MTD] [NAND] S3C2410: Allow the machine code to get the BBT table from NAND
[MTD] [NAND] S3C2410: Added a kerneldoc for s3c2410_nand_set
mtd: physmap_of: Add multiple regions and concatenation support
mtd: nand: max_retries off by one in mxc_nand
mtd: nand: s3c2410_nand_setrate(): use correct macros for 2412/2440
mtd: onenand: add bbt_wait & unlock_all as replaceable for some platform
mtd: Flex-OneNAND support
mtd: nand: add OMAP2/OMAP3 NAND driver
mtd: maps: Blackfin async: fix memory leaks in probe/remove funcs
mtd: uclinux: mark local stuff static
mtd: uclinux: do not allow to be built as a module
mtd: uclinux: allow systems to override map addr/size
mtd: blackfin NFC: fix hang when using NAND on BF527-EZKITs
.ko is normally not included in Kconfig help, make it consistent.
Signed-off-by: Pavel Machek <pavel@ucw.cz>
Commit 81933046ef2a615031c46171013bde2c5225ee69 ('mtd: Fix handling of
mtdname in txx9ndfmc.c') introduced a potential memory leak. The
'mtdname' member of the private data structure is now allocated
separately, but was not freed on certain error paths.
Fix that, and make things simpler by _always_ allocating it separately
so that we don't need 'if (mtdname != dev_name()) kfree(mtdname);'...
which gets ugly now that we're doing it more than once, and more likely
that we'll get it wrong some time.
This is not 8 times faster than byte access, but still around 60% faster.
Add s3c6400 support to the s3c2410 driver. The nand controller in
the s3c64xx devices is compatible with the one in the s3c2412, so
simply reuse that code.
Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
Acked-by: Ben Dooks <ben-linux@fluff.org>
Change to using DIV_ROUND_UP() in the timing calculation
instead of blindly doing result++
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
Add code to deal with fractional lengths, as reported by
Werner Almesberger. Re-work of his original patch.
Added a flag to allow the machine code to tell the NAND
subsystem that it should try to pickup a BBT from the flash,
and also skip the NAND full scan at startup.
Signed-off-by: Michel Pollet <buserror@gmail.com>
with `while (max_retries-- > 0)' max_retries reaches -1 after the loop.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Use the correct S3C2440_NFCONF_* macros for the mask for the 2412/2440
variants instead of the 2410 ones which use wrong bit positions.
DaVinci clock support has been updated in mainline.
Update clock names accordingly.
Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
This driver is present in the OMAP tree, now pushing it to MTD.
Original author(s):
Jian Zhang <jzhang@ti.com>
Cc: Jian Zhang <jzhang@ti.com>
Cc: Artem Bityutskiy <dedekind@infradead.org>
The DMAs have different bit sizes on BF52x and BF54x. From the PHRM:
"The 16-bit DMA Access Bus (DAB) connects the DMA controller to the
on-chip peripherals, PPI, SPI, Ethernet MAC, the SPORTs, NFC,
HOSTDP and the UARTs."
32-bit DMA won't work for BF52x.
Signed-off-by: Cliff Cai <cliff.cai@analog.com>
Signed-off-by: Bryan Wu <cooloney@kernel.org>
Just add a new on-flash-bbt module parameter.
Signed-off-by: Simon Polette <spolette@adetelgroup.com>
- Add support for 2KiB page size flashes
- Fix page address access for large pages
- Detect oob layout at runtime
- handle pagesize_2k variable
- Fix oob16 layout: reserve location 5 of oob area since it's used for bbt
Signed-off-by: Vladimir Barinov <vova.barinov@gmail.com>
