path: root/drivers/mtd/nftlcore.c
2010-08-08mtd: Update copyright noticesDavid Woodhouse
2010-02-26mtd: blktrans: Hotplug fixesMaxim Levitsky
* Add locking where it was missing. * Don't do a get_mtd_device in blktrans_open because it would lead to a deadlock; instead do that in add_mtd_blktrans_dev. * Only free the mtd_blktrans_dev structure when the last user exits. * Flush request queue on device removal. * Track users, and call tr->release in del_mtd_blktrans_dev Due to that ->open and release aren't called more that once. Now it is safe to call del_mtd_blktrans_dev while the device is still in use. Signed-off-by: Maxim Levitsky <maximlevitsky@gmail.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-09-03mtd: nftl: fix offset alignmentsDimitri Gorokhovik
Arithmetic conversion in the mask computation makes the upper word of the second argument passed down to mtd->read_oob(), be always 0 (assuming 'offs' being a 64-bit signed long long type, and 'mtd->writesize' being a 32-bit unsigned int type). This patch applies over the other one adding masking in nftl_write, "nftl: write support is broken". Signed-off-by: Dimitri Gorokhovik <dimitri.gorokhovik@free.fr> Cc: Tim Gardner <tim.gardner@canonical.com> Cc: Scott James Remnant <scott@canonical.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-09-03mtd: nftl: write support is brokenDimitri Gorokhovik
Write support is broken in NFTL. Fix it. Signed-off-by: <dimitri.gorokhovik@free.fr> Cc: Tim Gardner <tim.gardner@canonical.com> Cc: Scott James Remnant <scott@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-06-27mtd: Use BLOCK_NIL consistently in NFTL/INFTLJulia Lawall
Use BLOCK_NIL consistently rather than sometimes 0xffff and sometimes BLOCK_NIL. The semantic patch that finds this issue is below (http://www.emn.fr/x-info/coccinelle/). On the other hand, the changes were made by hand, in part because drivers/mtd/inftlcore.c contains dead code that causes spatch to ignore a relevant function. Specifically, the function INFTL_findwriteunit contains a do-while loop, but always takes a return that leaves the loop on the first iteration. // <smpl> @r exists@ identifier f,C; @@ f(...) { ... return C; } @s@ identifier r.C; expression E; @@ @@ identifier r.f,r.C,I; expression s.E; @@ f(...) { <... ( I | - E + C ) ...> } // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-03-20[MTD] Auto-load nftl module when device opened.Scott James Remnant
The nftl module is missing the block-major-93-* alias that would cause it to be auto-loaded when a nftl of that type is opened. This patch adds the alias. Signed-off-by: Scott James Remnant <scott@canonical.com> Signed-off-by: Tim Gardner <tim.gardner@canonical.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-03-20[MTD] we don't need no misc devicesDavid Brownell
Remove <linux/miscdevice.h> from various drivers which don't actually use any of its contents. There are still a number of these left in arch-specific bits of the tree. (Found by diffing results of "grep -rl" for linux/miscdevice.h and for misc_register, examining the differences, and verifying removals with a build test.) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-12-10[MTD] update internal API to support 64-bit device sizeAdrian Hunter
MTD internal API presently uses 32-bit values to represent device size. This patch updates them to 64-bits but leaves the external API unchanged. Extending the external API is a separate issue for several reasons. First, no one needs it at the moment. Secondly, whether the implementation is done with IOCTLs, sysfs or both is still debated. Thirdly external API changes require the internal API to be accepted first. Note that although the MTD API will be able to support 64-bit device sizes, existing drivers do not and are not required to do so, although NAND base has been updated. In general, changing from 32-bit to 64-bit values cause little or no changes to the majority of the code with the following exceptions: - printk message formats - division and modulus of 64-bit values - NAND base support - 32-bit local variables used by mtdpart and mtdconcat - naughtily assuming one structure maps to another in MEMERASE ioctl Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-06-04MTD/JFFS2: remove CVS keywordsAdrian Bunk
Once upon a time, the MTD repository was using CVS. This patch therefore removes all usages of the no longer updated CVS keywords from the MTD code. This also includes code that printed them to the user. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-05-02PCI: Cleanup the includes of <linux/pci.h>Jean Delvare
I noticed that many source files include <linux/pci.h> while they do not appear to need it. Here is an attempt to clean it all up. In order to find all possibly affected files, I searched for all files including <linux/pci.h> but without any other occurence of "pci" or "PCI". I removed the include statement from all of these, then I compiled an allmodconfig kernel on both i386 and x86_64 and fixed the false positives manually. My tests covered 66% of the affected files, so there could be false positives remaining. Untested files are: arch/alpha/kernel/err_common.c arch/alpha/kernel/err_ev6.c arch/alpha/kernel/err_ev7.c arch/ia64/sn/kernel/huberror.c arch/ia64/sn/kernel/xpnet.c arch/m68knommu/kernel/dma.c arch/mips/lib/iomap.c arch/powerpc/platforms/pseries/ras.c arch/ppc/8260_io/enet.c arch/ppc/8260_io/fcc_enet.c arch/ppc/8xx_io/enet.c arch/ppc/syslib/ppc4xx_sgdma.c arch/sh64/mach-cayman/iomap.c arch/xtensa/kernel/xtensa_ksyms.c arch/xtensa/platform-iss/setup.c drivers/i2c/busses/i2c-at91.c drivers/i2c/busses/i2c-mpc.c drivers/media/video/saa711x.c drivers/misc/hdpuftrs/hdpu_cpustate.c drivers/misc/hdpuftrs/hdpu_nexus.c drivers/net/au1000_eth.c drivers/net/fec_8xx/fec_main.c drivers/net/fec_8xx/fec_mii.c drivers/net/fs_enet/fs_enet-main.c drivers/net/fs_enet/mac-fcc.c drivers/net/fs_enet/mac-fec.c drivers/net/fs_enet/mac-scc.c drivers/net/fs_enet/mii-bitbang.c drivers/net/fs_enet/mii-fec.c drivers/net/ibm_emac/ibm_emac_core.c drivers/net/lasi_82596.c drivers/parisc/hppb.c drivers/sbus/sbus.c drivers/video/g364fb.c drivers/video/platinumfb.c drivers/video/stifb.c drivers/video/valkyriefb.c include/asm-arm/arch-ixp4xx/dma.h sound/oss/au1550_ac97.c I would welcome test reports for these files. I am fine with removing the untested files from the patch if the general opinion is that these changes aren't safe. The tested part would still be nice to have. Note that this patch depends on another header fixup patch I submitted to LKML yesterday: [PATCH] scatterlist.h needs types.h http://lkml.org/lkml/2007/3/01/141 Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-11-28[MTD] replace kmalloc+memset with kzallocBurman Yan
Signed-off-by: Yan Burman <yan_952@hotmail.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-11-28[MTD] [NAND] remove len/ooblen confusion.Vitaly Wool
As was discussed between Ricard Wanderlöf, David Woodhouse, Artem Bityutskiy and me, the current API for reading/writing OOB is confusing. The thing that introduces confusion is the need to specify ops.len together with ops.ooblen for reads/writes that concern only OOB not data area. So, ops.len is overloaded: when ops.datbuf != NULL it serves to specify the length of the data read, and when ops.datbuf == NULL, it serves to specify the full OOB read length. The patch inlined below is the slightly updated version of the previous patch serving the same purpose, but with the new Artem's comments taken into account. Artem, BTW, thanks a lot for your valuable input! Signed-off-by: Vitaly Wool <vwool@ru.mvista.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-11-28[MTD] Allow variable block sizes in mtd_blkdevsRichard Purdie
Currently, mtd_blkdevs enforces a block size of 512, even if the drivers can seemingly request a different size. This patch fixes mtd_blkdevs so block sizes other than 512 work correctly. Signed-off-by: Richard Purdie <rpurdie@openedhand.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-10-02[MTD] fix nftl_write warningFrederik Deweerdt
Building 2.6.18-mm2 issues the following warning if CONFIG_NFTL_RW is not set: CC [M] drivers/mtd/nftlcore.o drivers/mtd/nftlcore.c:183: warning: 'nftl_write' defined but not used The following patch only compiles nftl_write if CONFIG_NFTL_RW is set. Signed-off-by: Frederik Deweerdt <frederik.deweerdt@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-29[MTD] NAND Signal that a bitflip was corrected by ECCThomas Gleixner
Return -EUCLEAN on read when a bitflip was detected and corrected, so the clients can react and eventually copy the affected block to a spare one. Make all in kernel users aware of the change. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-29[MTD] Rework the out of band handling completelyThomas Gleixner
Hopefully the last iteration on this! The handling of out of band data on NAND was accompanied by tons of fruitless discussions and halfarsed patches to make it work for a particular problem. Sufficiently annoyed by I all those "I know it better" mails and the resonable amount of discarded "it solves my problem" patches, I finally decided to go for the big rework. After removing the _ecc variants of mtd read/write functions the solution to satisfy the various requirements was to refactor the read/write _oob functions in mtd. The major change is that read/write_oob now takes a pointer to an operation descriptor structure "struct mtd_oob_ops".instead of having a function with at least seven arguments. read/write_oob which should probably renamed to a more descriptive name, can do the following tasks: - read/write out of band data - read/write data content and out of band data - read/write raw data content and out of band data (ecc disabled) struct mtd_oob_ops has a mode field, which determines the oob handling mode. Aside of the MTD_OOB_RAW mode, which is intended to be especially for diagnostic purposes and some internal functions e.g. bad block table creation, the other two modes are for mtd clients: MTD_OOB_PLACE puts/gets the given oob data exactly to/from the place which is described by the ooboffs and ooblen fields of the mtd_oob_ops strcuture. It's up to the caller to make sure that the byte positions are not used by the ECC placement algorithms. MTD_OOB_AUTO puts/gets the given oob data automaticaly to/from the places in the out of band area which are described by the oobfree tuples in the ecclayout data structre which is associated to the devicee. The decision whether data plus oob or oob only handling is done depends on the setting of the datbuf member of the data structure. When datbuf == NULL then the internal read/write_oob functions are selected, otherwise the read/write data routines are invoked. Tested on a few platforms with all variants. Please be aware of possible regressions for your particular device / application scenario Disclaimer: Any whining will be ignored from those who just contributed "hot air blurb" and never sat down to tackle the underlying problem of the mess in the NAND driver grown over time and the big chunk of work to fix up the existing users. The problem was not the holiness of the existing MTD interfaces. The problems was the lack of time to go for the big overhaul. It's easy to add more mess to the existing one, but it takes alot of effort to go for a real solution. Improvements and bugfixes are welcome! Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-29[MTD] Remove silly MTD_WRITE/READ macrosThomas Gleixner
Most of those macros are unused and the used ones just obfuscate the code. Remove them and fixup all users. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-23[MTD] Remove read/write _ecc variantsThomas Gleixner
MTD clients are agnostic of FLASH which needs ECC suppport. Remove the functions and fixup the callers. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-11-07Merge master.kernel.org:/pub/scm/linux/kernel/git/tglx/mtd-2.6Linus Torvalds
Some manual fixups for clashing kfree() cleanups etc.
2005-11-07[PATCH] kfree cleanup: drivers/mtdJesper Juhl
This is the drivers/mtd part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in drivers/mtd/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Cc: David Woodhouse <dwmw2@infradead.org> Acked-by: Joern Engel <joern@wohnheim.fh-wedel.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[MTD] core: Clean up trailing white spacesThomas Gleixner
