path: root/drivers/mtd/ofpart.c
2009-09-19mtd: ofpart: Check availability of reg property instead of name propertyBenjamin Krill
The previous implementation breaks the dts binding "mtd-physmap.txt". This implementation fixes the issue by checking the availability of the reg property instead of the name property. Cc: stable@kernel.org Signed-off-by: Benjamin Krill <ben@codiert.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-03-24[MTD] ofpart: Check name property to determine partition nodes.Benjamin Krill
SLOF has a further node which could not be evaluated by the current routine. The current routine returns because the node hasn't the required reg property. As fix this patch adds a check to determine the partition child nodes. If the node is not a partition the number of total partitions will be decreased and loop continues with the next nodes. Signed-off-by: Benjamin Krill <ben@codiert.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-10-13[MTD] remove unused mtd parameter in of_mtd_parse_partitions()Sebastian Andrzej Siewior
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-04-22[MTD] mtd/ofpart.c: add MODULE_LICENSEAdrian Bunk
This patch adds the missing MODULE_LICENSE("GPL"). Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-02-03[MTD] Factor out OF partition support from the NOR driver.Scott Wood
Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
