path: root/drivers/mtd/sm_ftl.c
2011-03-25Merge branch 'master' of ↵Artem Bityutskiy
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into for-linus-1 * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6: (9356 commits) [media] rc: update for bitop name changes fs: simplify iget & friends fs: pull inode->i_lock up out of writeback_single_inode fs: rename inode_lock to inode_hash_lock fs: move i_wb_list out from under inode_lock fs: move i_sb_list out from under inode_lock fs: remove inode_lock from iput_final and prune_icache fs: Lock the inode LRU list separately fs: factor inode disposal fs: protect inode->i_state with inode->i_lock lib, arch: add filter argument to show_mem and fix private implementations SLUB: Write to per cpu data when allocating it slub: Fix debugobjects with lockless fastpath autofs4: Do not potentially dereference NULL pointer returned by fget() in autofs_dev_ioctl_setpipefd() autofs4 - remove autofs4_lock autofs4 - fix d_manage() return on rcu-walk autofs4 - fix autofs4_expire_indirect() traversal autofs4 - fix dentry leak in autofs4_expire_direct() autofs4 - reinstate last used update on access vfs - check non-mountpoint dentry might block in __follow_mount_rcu() ... NOTE! This merge commit was created to fix compilation error. The block tree was merged upstream and removed the 'elv_queue_empty()' function which the new 'mtdswap' driver is using. So a simple merge of the mtd tree with upstream does not compile. And the mtd tree has already be published, so re-basing it is not an option. To fix this unfortunate situation, I had to merge upstream into the mtd-2.6.git tree without committing, put the fixup patch on top of this, and then commit this. The result is that we do not have commits which do not compile. In other words, this merge commit "merges" 3 things: the MTD tree, the upstream tree, and the fixup patch.
2011-03-11mtd: sm_rtl: check kmalloc return valueXiaochen Wang
Because malloc/kzalloc may fail, we should check kmalloc/kzalloc return value in sm_create_sysfs_attributes(), mtd/sm_rtl.c and do error handling. Meanwhile, we should check sm_create_sysfs_attributes return value. Signed-off-by: Xiaochen Wang <wangxiaochen0@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-02-16workqueue, freezer: unify spelling of 'freeze' + 'able' to 'freezable'Tejun Heo
There are two spellings in use for 'freeze' + 'able' - 'freezable' and 'freezeable'. The former is the more prominent one. The latter is mostly used by workqueue and in a few other odd places. Unify the spelling to 'freezable'. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Alex Dubov <oakad@yahoo.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Steven Whitehouse <swhiteho@redhat.com>
2010-04-08bitops: rename for_each_bit() to for_each_set_bit(): mtdAkinobu Mita
Rename for_each_bit() to for_each_set_bit in the kernel source tree. To permit for_each_clear_bit(), should that ever be added. I'll be sending a patch to Linus this week which removes the temporary for_each_bit() macro, so this patch will be needed to avoid build breakage. Suggested-by: Alexey Dobriyan <adobriyan@gmail.com> Suggested-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Russell King <rmk@arm.linux.org.uk> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Artem Bityutskiy <dedekind@infradead.org> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2010-03-29mtd: SmartMedia/xD FTL: use of kmalloc/kfree requires the include of slab.hStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2010-03-26mtd: sm_ftl: remove CONFIG_SM_FTL_MUSEUM and make it always onMaxim Levitsky
The sole purpose of this setting was to avoid a dependency on MTD_NAND. Now that we can depend on MTD_NAND_ECC without pulling in all the rest of the NAND code, we might as well do so unconditionally. Signed-off-by: Maxim Levitsky <maximlevitsky@gmail.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2010-03-26mtd: sm_ftl: initialize sysfs attributesMaxim Levitsky
This is new requirement in 2.6.34 Signed-off-by: Maxim Levitsky <maximlevitsky@gmail.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2010-02-26mtd: Few follow up cleanups for Smartmedia/xD supportMaxim Levitsky
* Test results of few functions that were declared with __must_check * Fix bogus gcc warning about uinitialized variable 'ret' * Remove unused variable from mtdblock_remove_dev * Don't use deprecated DMA_32BIT_MASK Signed-off-by: Maxim Levitsky <maximlevitsky@gmail.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2010-02-26mtd: Add new SmartMedia/xD FTLMaxim Levitsky
This implements new readwrite SmartMedia/xd FTL. mtd driver must have support proper ECC and badblock verification based on oob parts for 512 bytes nand. Also mtd driver must define read_oob and write_oob, which are used to read and write both data and oob together. Signed-off-by: Maxim Levitsky <maximlevitsky@gmail.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
