path: root/drivers/mtd
2011-05-23Merge branches 'consolidate-clksrc', 'consolidate-flash', ↵Russell King
'consolidate-generic', 'consolidate-smp', 'consolidate-stmp' and 'consolidate-zones' into consolidate
2011-05-20ARM: 6910/1: MTD: physmap: let set_vpp() pass a platform_device instead of a ↵Marc Zyngier
map_info The set_vpp() method provided by physmap passes a map_info back to the platform code, which has little relevance as far as the platform is concerned (this parameter is completely unused). Instead, pass the platform_device, which can be used in the pismo driver to retrieve some important information in a nicer way, instead of the hack that was in place. The empty set_vpp function in board-at572d940hf_ek.c is left untouched, as the board/SoC is scheduled for removal. Cc: Andrew Victor <linux@maxim.org.za> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Philipp Zabel <philipp.zabel@gmail.com> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Ben Dooks <ben-linux@fluff.org> Acked-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Acked-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-20ARM: 6906/1: MTD: Remove integrator-flashMarc Zyngier
As there is now no in-tree user of integrator-flash, remove it completely. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Acked-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-20ARM: 6904/1: MTD: Add integrator-flash feature to physmapMarc Zyngier
In the process of moving platforms away from integrator-flash (aka armflash), add to physmap the few features that make armflash unique: - optionnal probing for the AFS partition type - init() and exit() methods, used by Integrator to control write access to the various onboard programmable components Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Acked-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-19MIPS: Alchemy: Clean up GPIO registers and accessorsManuel Lauss
remove au_readl/au_writel, remove the predefined GPIO1/2 KSEG1 register addresses and fix the fallout in all boards and drivers. This also fixes a bug in the mtx-1_wdt driver which was introduced by commit 6ea8115bb6f359df4f45152f2b40e1d4d1891392 ("Convert mtx1 wdt to be a platform device and use generic GPIO API") before this patch mtx-1_wdt only modified GPIO215, the patch then used the gpio resource information as bit index into the GPIO2 register but the conversion to the GPIO API didn't realize that. With this patch the drivers original behaviour is restored and GPIO15 is left alone. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> Cc: Florian Fainelli <florian@openwrt.org> To: Linux-MIPS <linux-mips@linux-mips.org> Cc: linux-watchdog@vger.kernel.org Cc: Wim Van Sebroeck <wim@iguana.be> Patchwork: https://patchwork.linux-mips.org/patch/2381/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org
2011-05-19MIPS: Lantiq: Add NOR flash supportJohn Crispin
This patch adds the driver/map for NOR devices attached to the SoC via the External Bus Unit (EBU). Signed-off-by: John Crispin <blogic@openwrt.org> Signed-off-by: Ralph Hempel <ralph.hempel@lantiq.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Cc: linux-mips@linux-mips.org Cc: linux-mtd@lists.infradead.org Acked-by: Artem Bityutskiy <dedekind1@gmail.com> Patchwork: https://patchwork.linux-mips.org/patch/2285/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-18drivercore: revert addition of of_match to struct deviceGrant Likely
Commit b826291c, "drivercore/dt: add a match table pointer to struct device" added an of_match pointer to struct device to cache the of_match_table entry discovered at driver match time. This was unsafe because matching is not an atomic operation with probing a driver. If two or more drivers are attempted to be matched to a driver at the same time, then the cached matching entry pointer could get overwritten. This patch reverts the of_match cache pointer and reworks all users to call of_match_device() directly instead. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-04-26Revert wrong fixes for common misspellingsLucas De Marchi
These changes were incorrectly fixed by codespell. They were now manually corrected. Signed-off-by: Lucas De Marchi <lucas.demarchi@profusion.mobi>
2011-04-09Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: mtd: atmel_nand: use CPU I/O when buffer is in vmalloc(ed) region mtd: atmel_nand: modify test case for using DMA operations mtd: atmel_nand: fix support for CPUs that do not support DMA access mtd: atmel_nand: trivial: change DMA usage information trace mtd: mtdswap: fix printk format warning
2011-04-07Merge branch 'for-linus' of git://git.infradead.org/ubifs-2.6Linus Torvalds
* 'for-linus' of git://git.infradead.org/ubifs-2.6: UBI: do not select KALLSYMS_ALL UBI: do not compare array with NULL UBI: check if we are in RO mode in the erase routine UBIFS: fix debugging failure in dbg_check_space_info UBIFS: fix error path in dbg_debugfs_init_fs UBIFS: unify error path dbg_debugfs_init_fs UBIFS: do not select KALLSYMS_ALL UBIFS: fix assertion warnings UBIFS: fix oops on error path in read_pnode UBIFS: do not read flash unnecessarily
2011-04-05UBI: do not select KALLSYMS_ALLArtem Bityutskiy
All UBI needs is to make sure we stacktraces when UBI debugging is enabled. It is enough to select KALLSYMS for this, KALLSYMS_ALL is not necessary. And the current Kconfig line we have: select KALLSYMS_ALL if KALLSYMS && DEBUG_KERNEL is just too complex to be sane and right. But this "if" part there is needed to prevent "unmet direct dependency" warnings, because KALLSYMS_ALL depends on KALLSYMS and DEBUG_KERNEL, so we cannot just select KALLSYMS_ALL. Anyway, this feels messy, and we do not seem to really need KALLSYMS_ALL, so select KALLSYMS instead. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com>
2011-04-05UBI: do not compare array with NULLArtem Bityutskiy
Coverity spotted that UBI debugging code tries to compare an array and NULL, which obviously makes little sense. Kill this check. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-04-05UBI: check if we are in RO mode in the erase routineArtem Bityutskiy
'do_sync_erase()' has to check whether we are in R/O mode before erasing the PEB. This patch adds the check and while on it, adds an assertion which validates the 'pnum' argument, as well as removes a check which is always true because it has already been done few lines before. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-04-01mtd: atmel_nand: use CPU I/O when buffer is in vmalloc(ed) regionHong Xu
The previous way of dealing with vmalloc(ed) region by walking though the pages can not work well actually. We just fall back to CPU I/O when the buffer address is higher than `high_memory'. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Hong Xu <hong.xu@atmel.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-04-01mtd: atmel_nand: modify test case for using DMA operationsNicolas Ferre
We have better performances not using DMA for oob operations. Modify size test so that it is using DMA for size greater than oobsize. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-04-01mtd: atmel_nand: fix support for CPUs that do not support DMA accessHong Xu
use_dma was always "1" even if the CPU does not support DMA Tested on AT91SAM9261EK by Jean-Christophe PLAGNIOL-VILLARD Reported-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Hong Xu <hong.xu@atmel.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-04-01mtd: atmel_nand: trivial: change DMA usage information traceNicolas Ferre
2011-04-01mtd: mtdswap: fix printk format warningRandy Dunlap
The number is actually a sizeof(), so using %zu for it builds cleanly on 32-bit or 64-bit. drivers/mtd/mtdswap.c:1456: warning: format '%lu' expects type 'long unsigned int', but argument 4 has type 'unsigned int' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-03-25Merge branch 'master' of ↵Artem Bityutskiy
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into for-linus-1 * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6: (9356 commits) [media] rc: update for bitop name changes fs: simplify iget & friends fs: pull inode->i_lock up out of writeback_single_inode fs: rename inode_lock to inode_hash_lock fs: move i_wb_list out from under inode_lock fs: move i_sb_list out from under inode_lock fs: remove inode_lock from iput_final and prune_icache fs: Lock the inode LRU list separately fs: factor inode disposal fs: protect inode->i_state with inode->i_lock lib, arch: add filter argument to show_mem and fix private implementations SLUB: Write to per cpu data when allocating it slub: Fix debugobjects with lockless fastpath autofs4: Do not potentially dereference NULL pointer returned by fget() in autofs_dev_ioctl_setpipefd() autofs4 - remove autofs4_lock autofs4 - fix d_manage() return on rcu-walk autofs4 - fix autofs4_expire_indirect() traversal autofs4 - fix dentry leak in autofs4_expire_direct() autofs4 - reinstate last used update on access vfs - check non-mountpoint dentry might block in __follow_mount_rcu() ... NOTE! This merge commit was created to fix compilation error. The block tree was merged upstream and removed the 'elv_queue_empty()' function which the new 'mtdswap' driver is using. So a simple merge of the mtd tree with upstream does not compile. And the mtd tree has already be published, so re-basing it is not an option. To fix this unfortunate situation, I had to merge upstream into the mtd-2.6.git tree without committing, put the fixup patch on top of this, and then commit this. The result is that we do not have commits which do not compile. In other words, this merge commit "merges" 3 things: the MTD tree, the upstream tree, and the fixup patch.
2011-03-25mtd: mtdswap: fix compilation warningArtem Bityutskiy
Fix the following compilation warning: drivers/mtd/mtdswap.c: In function ‘mtdswap_pick_gc_eblk’: drivers/mtd/mtdswap.c:859: warning: ‘idx’ may be used uninitialized in this function drivers/mtd/mtdswap.c:859: note: ‘idx’ was declared here Initialize idx to -1 because this value means "no tree choosen". Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-03-25mtdswap: kill strict error handling optionYang Ruirui
As Artem Bityutskiy suggested: this option is controversial, as we do not really have any prove it is useful. And it is too much to have it as a config parameter. So, better kill it and let the real mtdswap users decide whether it is needed or not. Signed-off-by: Yang Ruirui<ruirui.r.yang@tieto.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-03-24Merge branch 'for-linus' of git://git.infradead.org/ubi-2.6Linus Torvalds
* 'for-linus' of git://git.infradead.org/ubi-2.6: UBIFS: fix assertion warning and refine comments UBIFS: kill CONFIG_UBIFS_FS_DEBUG_CHKS UBIFS: use GFP_NOFS properly UBI: use GFP_NOFS properly
2011-03-24UBI: use GFP_NOFS properlyArtem Bityutskiy
This patch fixes a brown-paperbag bug which was introduced by me: I used incorrect "GFP_KERNEL | GFP_NOFS" allocation flags to make sure my allocations do not cause write-back. But the correct form is "GFP_NOFS". Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-03-23tmio: Silence warnings introduced by mfd changesAndres Salomon
This silences warnings such as drivers/video/tmiofb.c: In function 'tmiofb_hw_init': drivers/video/tmiofb.c:270: warning: initialization discards qualifiers from pointer target type These were added by me in commit 2a79bb1d. Signed-off-by: Andres Salomon <dilinger@queued.net> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-03-23mtd: Use mfd_data instead of driver_data for tmio_nandAndres Salomon
Use mfd_data for passing information from mfd drivers to mfd clients. The mfd_cell's driver_data field is being phased out. Clients that were using driver_data now access .mfd_data via mfd_get_data(). This changes tmio-nand only; mfd drivers with other cells are not modified. Signed-off-by: Andres Salomon <dilinger@queued.net> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-03-23mfd: mfd_cell is now implicitly available to t7166xb driversAndres Salomon
No need to explicitly set the cell's platform_data/data_size. Modify clients to use mfd_get_cell helper function instead of accessing platform_data directly. Signed-off-by: Andres Salomon <dilinger@queued.net> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-03-18Merge branch 'linux-next' of git://git.infradead.org/ubifs-2.6Linus Torvalds
* 'linux-next' of git://git.infradead.org/ubifs-2.6: (25 commits) UBIFS: clean-up commentaries UBIFS: save 128KiB or more RAM UBIFS: allocate orphans scan buffer on demand UBIFS: allocate lpt dump buffer on demand UBIFS: allocate ltab checking buffer on demand UBIFS: allocate scanning buffer on demand UBIFS: allocate dump buffer on demand UBIFS: do not check data crc by default UBIFS: simplify UBIFS Kconfig menu UBIFS: print max. index node size UBIFS: handle allocation failures in UBIFS write path UBIFS: use max_write_size during recovery UBIFS: use max_write_size for write-buffers UBIFS: introduce write-buffer size field UBI: incorporate LEB offset information UBIFS: incorporate maximum write size UBI: provide LEB offset information UBI: incorporate maximum write size UBIFS: fix LEB number in printk UBIFS: restrict world-writable debugfs files ...
2011-03-18Merge branch 'linux-next' of git://git.infradead.org/ubi-2.6Linus Torvalds
* 'linux-next' of git://git.infradead.org/ubi-2.6: UBI: make tests modes dynamic UBI: make self-checks dynamic UBI: make debugging messages dynamic UBI: remove UBI_IO_DEBUG macro UBI: kill debugging buffer UBI: allocate erase checking buffer on demand UBI: allocate write checking buffer on demand UBI: always re-read in case of read failures UBI: cleanup comments about corrupted PEBs UBI: add slab cache for ubi_scan_leb objects UBI: use raw mtd read function in debugging code UBI: try to reveal buggy MTD drivers UBI: add a commentary about allocating VID header buffer on stack UBI: cleanup LEB start calculations UBI: fix NOR erase preparation quirk
2011-03-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits) doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore Update cpuset info & webiste for cgroups dcdbas: force SMI to happen when expected arch/arm/Kconfig: remove one to many l's in the word. asm-generic/user.h: Fix spelling in comment drm: fix printk typo 'sracth' Remove one to many n's in a word Documentation/filesystems/romfs.txt: fixing link to genromfs drivers:scsi Change printk typo initate -> initiate serial, pch uart: Remove duplicate inclusion of linux/pci.h header fs/eventpoll.c: fix spelling mm: Fix out-of-date comments which refers non-existent functions drm: Fix printk typo 'failled' coh901318.c: Change initate to initiate. mbox-db5500.c Change initate to initiate. edac: correct i82975x error-info reported edac: correct i82975x mci initialisation edac: correct commented info fs: update comments to point correct document target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c ... Trivial conflict in fs/eventpoll.c (spelling vs addition)
2011-03-17Merge branch 'omap-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (258 commits) omap: zoom: host should not pull up wl1271's irq line arm: plat-omap: iommu: fix request_mem_region() error path OMAP2+: Common CPU DIE ID reading code reads wrong registers for OMAP4430 omap4: mux: Remove duplicate mux modes omap: iovmm: don't check 'da' to set IOVMF_DA_FIXED flag omap: iovmm: disallow mapping NULL address when IOVMF_DA_ANON is set omap2+: mux: Fix compile when CONFIG_OMAP_MUX is not selected omap4: board-omap4panda: Initialise the serial pads omap3: board-3430sdp: Initialise the serial pads omap4: board-4430sdp: Initialise the serial pads omap2+: mux: Add macro for configuring static with omap_hwmod_mux_init omap2+: mux: Remove the use of IDLE flag omap2+: Add separate list for dynamic pads to mux perf: add OMAP support for the new power events OMAP4: Add IVA OPP enteries. OMAP4: Update Voltage Rail Values for MPU, IVA and CORE OMAP4: Enable 800 MHz and 1 GHz MPU-OPP OMAP3+: OPP: Replace voltage values with Macros OMAP3: wdtimer: Fix CORE idle transition Watchdog: omap_wdt: add fine grain runtime-pm ... Fix up various conflicts in - arch/arm/mach-omap2/board-omap3evm.c - arch/arm/mach-omap2/clock3xxx_data.c - arch/arm/mach-omap2/usb-musb.c - arch/arm/plat-omap/include/plat/usb.h - drivers/usb/musb/musb_core.h
2011-03-17Merge branch 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-arm: (289 commits) davinci: DM644x EVM: register MUSB device earlier davinci: add spi devices on tnetv107x evm davinci: add ssp config for tnetv107x evm board davinci: add tnetv107x ssp platform device spi: add ti-ssp spi master driver mfd: add driver for sequencer serial port ARM: EXYNOS4: Implement Clock gating for System MMU ARM: EXYNOS4: Enhancement of System MMU driver ARM: EXYNOS4: Add support for gpio interrupts ARM: S5P: Add function to register gpio interrupt bank data ARM: S5P: Cleanup S5P gpio interrupt code ARM: EXYNOS4: Add missing GPYx banks ARM: S3C64XX: Fix section mismatch from cpufreq init ARM: EXYNOS4: Add keypad device to the SMDKV310 ARM: EXYNOS4: Update clocks for keypad ARM: EXYNOS4: Update keypad base address ARM: EXYNOS4: Add keypad device helpers ARM: EXYNOS4: Add support for SATA on ARMLEX4210 plat-nomadik: make GPIO interrupts work with cpuidle ApSleep mach-u300: define a dummy filter function for coh901318 ... Fix up various conflicts in - arch/arm/mach-exynos4/cpufreq.c - arch/arm/mach-mxs/gpio.c - drivers/net/Kconfig - drivers/tty/serial/Kconfig - drivers/tty/serial/Makefile - drivers/usb/gadget/fsl_mxc_udc.c - drivers/video/Kconfig
2011-03-16Merge branch 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6: (21 commits) tty: serial: altera_jtaguart: Add device tree support tty: serial: altera_uart: Add devicetree support dt: eliminate of_platform_driver shim code dt: Eliminate of_platform_{,un}register_driver dt/serial: Eliminate users of of_platform_{,un}register_driver dt/usb: Eliminate users of of_platform_{,un}register_driver dt/video: Eliminate users of of_platform_{,un}register_driver dt/net: Eliminate users of of_platform_{,un}register_driver dt/sound: Eliminate users of of_platform_{,un}register_driver dt/spi: Eliminate users of of_platform_{,un}register_driver dt: uartlite: merge platform and of_platform driver bindings dt: xilinx_hwicap: merge platform and of_platform driver bindings ipmi: convert OF driver to platform driver leds/leds-gpio: merge platform_driver with of_platform_driver dt/sparc: Eliminate users of of_platform_{,un}register_driver dt/powerpc: Eliminate users of of_platform_{,un}register_driver dt/powerpc: move of_bus_type infrastructure to ibmebus drivercore/dt: add a match table pointer to struct device dt: Typo fix. altera_ps2: Add devicetree support ...
2011-03-16UBI: make tests modes dynamicArtem Bityutskiy
Similarly to the debugging checks and message, make the test modes be dynamically selected via the "debug_tsts" module parameter or via the "/sys/module/ubi/parameters/debug_tsts" sysfs file. This is consistent with UBIFS as well. And now, since all the Kconfig knobs became dynamic, we can remove the Kconfig.debug file completely. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-03-16UBI: make self-checks dynamicArtem Bityutskiy
This patch adds a possibility to dynamically switch UBI self-checks on and off, instead of toggling them compile-time from the configuration menu. This is much more flexible, and consistent with UBIFS, and this also simplifies UBI Kconfig menu and the code. This patch introduces two levels of self-checks - general, which includes all self-checks which are relatively fast, and I/O, which includes write-verify checks and erase-verify checks, which are relatively slow and involve flash I/O. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-03-16UBI: make debugging messages dynamicArtem Bityutskiy
This patch adds a possibility to dynamically select UBI debugging messages, instead of selecting them compile-time from the configuration menu. This is much more flexible, and consistent with UBIFS, and this also simplifies UBI Kconfig menu and the code. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-03-16UBI: remove UBI_IO_DEBUG macroArtem Bityutskiy
This additional little macro is used to print a bit more messages while scanning the media. However, we have the 'dbg_bld()' macro for this, so we better us 'dbg_bld()' and kill UBI_IO_DEBUG. This simplifies the code a tiny bit. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-03-16UBI: kill debugging bufferArtem Bityutskiy
This patch kills the 'ubi->dbg_peb_buf' debugging buffer and the associated mutex, because all users of this buffer are now gone. We are killing this buffer because we are going to switch to dynamic debugging control, just like in UBIFS, which means that CONFIG_MTD_UBI_DEBUG_PARANOID will be removed. In this case we'd end up always allocating 'ubi->dbg_peb_buf', which is rather large (128KiB or more), and this would be wasteful. Thus, we are just killing it. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-03-16UBI: allocate erase checking buffer on demandArtem Bityutskiy
Instead of using pre-allocated 'ubi->dbg_peb_buf' buffer in 'ubi_dbg_check_all_ff()', dynamically allocate it when needed. The intend is to get rid of the pre-allocated 'ubi->dbg_peb_buf' buffer completely. And the need for this arises because we want to change to dynamic debugging control instead of compile-time control, i.e., we are going to kill the CONFIG_MTD_UBI_DEBUG_PARANOID Kconfig option, which would mean that 'ubi->dbg_peb_buf' is always allocated, which would be wasteful. Thus, we are getting rid of 'ubi->dbg_peb_buf', and this is a preparation for that. signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-03-16UBI: allocate write checking buffer on demandArtem Bityutskiy
Instead of using pre-allocated 'ubi->dbg_peb_buf' buffer in 'ubi_dbg_check_write()', dynamically allocate it when needed. The intend is to get rid of the pre-allocated 'ubi->dbg_peb_buf' buffer completely. And the need for this arises because we want to change to dynamic debugging control instead of compile-time control, i.e., we are going to kill the CONFIG_MTD_UBI_DEBUG_PARANOID Kconfig option, which would mean that 'ubi->dbg_peb_buf' is always allocated, which would be wasteful. Thus, we are getting rid of 'ubi->dbg_peb_buf', and this is a preparation for that. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-03-15Merge branch 'for-rmk' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into devel-stable Conflicts: arch/arm/mm/Kconfig
2011-03-13Merge git://git.infradead.org/users/dwmw2/mtd-2.6.38Linus Torvalds
* git://git.infradead.org/users/dwmw2/mtd-2.6.38: mtd: add "platform:" prefix for platform modalias mtd: mtd_blkdevs: fix double free on error path mtd: amd76xrom: fix oops at boot when resources are not available mtd: fix race in cfi_cmdset_0001 driver mtd: jedec_probe: initialise make sector erase command variable mtd: jedec_probe: Change variable name from cfi_p to cfi
2011-03-11mtd: nand: enable software BCH ECC in nand simulatorIvan Djelic
This patch adds option 'bch' to nandsim, which can be used to enable software BCH ECC (introduced in previous patches) and select BCH error correction capability. Signed-off-by: Ivan Djelic <ivan.djelic@parrot.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-03-11mtd: nand: add software BCH ECC supportIvan Djelic
This patch adds software BCH ECC support to mtd, in order to handle recent NAND device ecc requirements (4 bits or more). It does so by adding a new ecc mode (NAND_ECC_SOFT_BCH) for use by board drivers, and a new Kconfig option to enable BCH support. It relies on the generic BCH library introduced in a previous patch. When a board driver uses mode NAND_ECC_SOFT_BCH, it should also set fields chip->ecc.size and chip->ecc.bytes to select BCH ecc data size and required error correction capability. See nand_bch_init() documentation for details. It has been tested on the following platforms using mtd-utils, UBI and UBIFS: x86 (with nandsim), arm926ejs. Signed-off-by: Ivan Djelic <ivan.djelic@parrot.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-03-11mtd: fix printf format warnings, mostly lack of %zd for size_t, in mtdswapDavid Woodhouse
2011-03-11mtd: sm_rtl: check kmalloc return valueXiaochen Wang
Because malloc/kzalloc may fail, we should check kmalloc/kzalloc return value in sm_create_sysfs_attributes(), mtd/sm_rtl.c and do error handling. Meanwhile, we should check sm_create_sysfs_attributes return value. Signed-off-by: Xiaochen Wang <wangxiaochen0@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-03-11mtd: cfi: add support for AMIC flashes (e.g. A29L160AT)Steffen Sledz
Signed-off-by: Steffen Sledz <sledz@dresearch.de> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-03-11mtd: mxc_nand: fix OOB corruption when page size > 2KiBBaruch Siach
When page size is 4KiB, ecc.total is set to 8*9, and this causes nand_write_page_hwecc() to read past the initialized part of the eccpos array, which corrupts chip->oob_poi with bogus values from ecc_calc. Fix this by creating a proper nand_ecclayout for 4KiB flashes. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-03-11mtd: DaVinci: Removed header file that is not requiredSandeep Paulraj
The DaVinci NAND driver was including the mach-types.h header file. This prevented the DaVinci NAND driver from getting used in a DSP only device. The linux port on c6x devices can make use of the same driver and does not define a corresponding header file. This header file was required in the driver because earlier there was code dependent on a machine_* check. This piece of code has now been factored out and is in arch/arm/mach-davinci/aemif.c Thus removing the header file is harmless Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-03-11mtd: pxa3xx_nand: clean the keep configure codeLei Wen
Use nand_scan_ident to unify the need of mtd member initilization for both normal detection and keep configuration method. Signed-off-by: Lei Wen <leiwen@marvell.com> Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
