path: root/drivers/mux
2018-01-17mux: core: fix double get_device()Hans de Goede
commit aa1f10e85b0ab53dee85d8e293c8159d18d293a8 upstream. class_find_device already does a get_device on the returned device. So the device returned by of_find_mux_chip_by_node is already referenced and we should not reference it again (and unref it on error). Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Peter Rosin <peda@axentia.se> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-29mux: make device_type constBhumika Goyal
Make this const as it is only stored in the type field of a device structure, which is const. Done using Coccinelle. Signed-off-by: Bhumika Goyal <bhumirks@gmail.com> Signed-off-by: Peter Rosin <peda@axentia.se> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-28mux: zap mux- prefix from the source filesPeter Rosin
Preserve the module names with Makefile additions. Signed-off-by: Peter Rosin <peda@axentia.se> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-28mux: convert to using %pOF instead of full_nameRob Herring
Now that we have a custom printf format specifier, convert users of full_name to use %pOF instead. This is preparation to remove storing of the full path string for each node. Signed-off-by: Rob Herring <robh@kernel.org> Signed-off-by: Peter Rosin <peda@axentia.se> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-17mux: mux-core: unregister mux_class in mux_exit()Kuppuswamy Sathyanarayanan
Fixes an obvious and nasty typo. Fixes: a3b02a9c6591 ("mux: minimal mux subsystem") Signed-off-by: Kuppuswamy Sathyanarayanan <sathyanarayanan.kuppuswamy@linux.intel.com> Signed-off-by: Peter Rosin <peda@axentia.se> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-17mux: remove the Kconfig question for the subsystemPeter Rosin
The MULTIPLEXER question in the Kconfig might be confusing and is of dubious value. Remove it. This makes consumers responsible for selecting MULTIPLEXER, which they already do. Signed-off-by: Peter Rosin <peda@axentia.se> Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-09mux: adg792a: always require I2C supportArnd Bergmann
COMPILE_TEST makes no sense when I2C is disabled, as the driver cannot compile in that configuration: drivers/mux/mux-adg792a.c: In function 'adg792a_write_cmd': drivers/mux/mux-adg792a.c:34:9: error: implicit declaration of function 'i2c_smbus_write_byte_data'; did you mean 'i2c_set_clientdata'? [-Werror=implicit-function-declaration] drivers/mux/mux-adg792a.o: In function `adg792a_driver_init': mux-adg792a.c:(.init.text+0x14): undefined reference to `i2c_register_driver' drivers/mux/mux-adg792a.o: In function `adg792a_probe': mux-adg792a.c:(.text.adg792a_probe+0x94): undefined reference to `i2c_smbus_write_byte_data' drivers/mux/mux-adg792a.o: In function `adg792a_set': mux-adg792a.c:(.text.adg792a_set+0x80): undefined reference to `i2c_smbus_write_byte_data' Fixes: afda08c4caa9 ("mux: adg792a: add mux controller driver for ADG792A/G") Signed-off-by: Arnd Bergmann <arnd@arndb.de> Reviewed-by: Peter Rosin <peda@axentia.se> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-03mux: mmio-based syscon mux controllerPhilipp Zabel
This adds a driver for mmio-based syscon multiplexers controlled by bitfields in a syscon register range. Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de> Signed-off-by: Peter Rosin <peda@axentia.se> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-03mux: adg792a: add mux controller driver for ADG792A/GPeter Rosin
Analog Devices ADG792A/G is a triple 4:1 mux. Reviewed-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Peter Rosin <peda@axentia.se> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-03mux: gpio: add mux controller driver for gpio based multiplexersPeter Rosin
The driver builds a single multiplexer controller using a number of gpio pins. For N pins, there will be 2^N possible multiplexer states. The GPIO pins can be connected (by the hardware) to several multiplexers, which in that case will be operated in parallel. Reviewed-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Peter Rosin <peda@axentia.se> Reviewed-by: Philipp Zabel <p.zabel@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-03mux: minimal mux subsystemPeter Rosin
Add a new minimalistic subsystem that handles multiplexer controllers. When multiplexers are used in various places in the kernel, and the same multiplexer controller can be used for several independent things, there should be one place to implement support for said multiplexer controller. A single multiplexer controller can also be used to control several parallel multiplexers, that are in turn used by different subsystems in the kernel, leading to a need to coordinate multiplexer accesses. The multiplexer subsystem handles this coordination. Thanks go out to Lars-Peter Clausen, Jonathan Cameron, Rob Herring, Wolfram Sang, Paul Gortmaker, Dan Carpenter, Colin Ian King, Greg Kroah-Hartman and last but certainly not least to Philipp Zabel for helpful comments, reviews, patches and general encouragement! Reviewed-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Peter Rosin <peda@axentia.se> Reviewed-by: Philipp Zabel <p.zabel@pengutronix.de> Tested-by: Philipp Zabel <p.zabel@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
