path: root/drivers/net/7990.c
2011-08-10amd: Move AMD (Lance) chipset driversJeff Kirsher
Moves the drivers for the AMD chipsets into drivers/net/ethernet/amd/ and the necessary Kconfig and Makfile changes. The au1000 (Alchemy) driver was also moved into the same directory even though it is not a "Lance" driver. CC: Peter Maydell <pmaydell@chiark.greenend.org.uk> CC: Roman Hodek <Roman.Hodek@informatik.uni-erlangen.de> CC: "Maciej W. Rozycki" <macro@linux-mips.org> CC: Donald Becker <becker@scyld.com> CC: Sam Creasey <sammy@users.qual.net> CC: Miguel de Icaza <miguel@nuclecu.unam.mx> CC: Thomas Bogendoerfer <tsbogend@alpha.franken.de> CC: Don Fry <pcnet32@frontier.com> CC: Geert Uytterhoeven <geert@linux-m68k.org> CC: Russell King <linux@arm.linux.org.uk> CC: David Davies <davies@maniac.ultranet.com> CC: "M.Hipp" <hippm@informatik.uni-tuebingen.de> CC: Pete Popov <ppopov@embeddedalley.com> CC: David Hinds <dahinds@users.sourceforge.net> CC: "Roger C. Pao" <rpao@paonet.org> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-07-08drivers/net: Omit check for multicast bit in netdev_for_each_mc_addrTobias Klauser
There is no need to check for the address being a multicast address in the netdev_for_each_mc_addr loop, so remove it. This patch covers all remaining network drivers still containing such a check. Cc: Joe Perches <joe@perches.com> Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-14drivers/net: Remove unnecessary returns from void function()sJoe Perches
This patch removes from drivers/net/ all the unnecessary return; statements that precede the last closing brace of void functions. It does not remove the returns that are immediately preceded by a label as gcc doesn't like that. It also does not remove null void functions with return. Done via: $ grep -rP --include=*.[ch] -l "return;\n}" net/ | \ xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }' with some cleanups by hand. Compile tested x86 allmodconfig only. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-10net: trans_start cleanupsEric Dumazet
Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-03net: convert multicast list to list_headJiri Pirko
Converts the list and the core manipulating with it to be the same as uc_list. +uses two functions for adding/removing mc address (normal and "global" variant) instead of a function parameter. +removes dev_mcast.c completely. +exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for manipulation with lists on a sandbox (used in bonding and 80211 drivers) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-22net: convert multiple drivers to use netdev_for_each_mc_addr, part3Jiri Pirko
2010-02-12net: use netdev_mc_count and netdev_mc_empty when appropriateJiri Pirko
This patch replaces dev->mc_count in all drivers (hopefully I didn't miss anything). Used spatch and did small tweaks and conding style changes when it was suitable. Jirka Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-05net: convert remaining non-symbolic return values in ndo_start_xmit() functionsPatrick McHardy
This patch converts the remaining occurences of raw return values to their symbolic counterparts in ndo_start_xmit() functions that were missed by the previous automatic conversion. Additionally code that assumed the symbolic value of NETDEV_TX_OK to be zero is changed to explicitly use NETDEV_TX_OK. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-13net: use symbolic values for ndo_start_xmit() return codesPatrick McHardy
Convert magic values 1 and -1 to NETDEV_TX_BUSY and NETDEV_TX_LOCKED respectively. 0 (NETDEV_TX_OK) is not changed to keep the noise down, except in very few cases where its in direct proximity to one of the other values. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-10add missing lance_* exportsAdrian Bunk
This patch fixes the following build error: <-- snip --> ... Building modules, stage 2. MODPOST 1203 modules ERROR: "lance_open" [drivers/net/mvme147.ko] undefined! ERROR: "lance_close" [drivers/net/mvme147.ko] undefined! ERROR: "lance_tx_timeout" [drivers/net/mvme147.ko] undefined! ERROR: "lance_set_multicast" [drivers/net/mvme147.ko] undefined! ERROR: "lance_start_xmit" [drivers/net/mvme147.ko] undefined! ... make[2]: *** [__modpost] Error 1 <-- snip --> Reported-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-01-28NULL noise in drivers/netAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET] drivers/net: statistics cleanup #1 -- save memory and shrink codeJeff Garzik
We now have struct net_device_stats embedded in struct net_device, and the default ->get_stats() hook does the obvious thing for us. Run through drivers/net/* and remove the driver-local storage of statistics, and driver-local ->get_stats() hook where applicable. This was just the low-hanging fruit in drivers/net; plenty more drivers remain to be updated. [ Resolved conflicts with napi_struct changes and fix sunqe build regression... -DaveM ] Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NET]: Kill eth_copy_and_sum().David S. Miller
It hasn't "summed" anything in over 7 years, and it's just a straight mempcy ala skb_copy_to_linear_data() so just get rid of it. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-04m68k: kill skb_copy_from_linear_data compiler warningsGeert Uytterhoeven
The recent conversion from `memcpy' to `skb_copy_from_linear_data' removed a few casts, which were needed to silence compiler warnings. Re-add them. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-25[SK_BUFF]: Introduce skb_copy_from_linear_data{_offset}Arnaldo Carvalho de Melo
To clearly state the intent of copying from linear sk_buffs, _offset being a overly long variant but interesting for the sake of saving some bytes. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2007-04-25[ETH]: Make eth_type_trans set skb->dev like the other *_type_transArnaldo Carvalho de Melo
One less thing for drivers writers to worry about. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-14[PATCH] Scheduled removal of SA_xxx interrupt flags fixupsThomas Gleixner
The obsolete SA_xxx interrupt flags have been used despite the scheduled removal. Fixup the remaining users. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: Roland Dreier <rolandd@cisco.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Cc: Dave Airlie <airlied@linux.ie> Cc: James Simmons <jsimmons@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-09[PATCH] m68k/HP300: HP LANCE updatesKars de Jong
- 7990: request_irq() should have SA_SHIRQ flag set - hplance_init() printed dev->name before register_netdev() had filled it in Signed-off-by: Kars de Jong <jongk@linux-m68k.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-07[PATCH] m68k pt_regs fixesAl Viro
m68k_handle_int() split in two functions: __m68k_handle_int() takes pt_regs * and does set_irq_regs(); m68k_handle_int() doesn't get pt_regs *. Places where we used to call m68k_handle_int() recursively with the same pt_regs have simply lost the second argument, the rest is switched to __m68k_handle_int(). The rest of patch is just dropping pt_regs * where needed. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
2006-01-28[PATCH] bogus include of linux/irq.h in 7990.cAl Viro
