path: root/drivers/net/Kconfig
2012-01-09Merge branch 'staging-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging * 'staging-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (466 commits) net/hyperv: Add support for jumbo frame up to 64KB net/hyperv: Add NETVSP protocol version negotiation net/hyperv: Remove unnecessary kmap_atomic in netvsc driver staging/rtl8192e: Register against lib80211 staging/rtl8192e: Convert to lib80211_crypt_info staging/rtl8192e: Convert to lib80211_crypt_data and lib80211_crypt_ops staging/rtl8192e: Add lib80211.h to rtllib.h staging/mei: add watchdog device registration wrappers drm/omap: GEM, deal with cache staging: vt6656: int.c, int.h: Change return of function to void staging: usbip: removed unused definitions from header staging: usbip: removed dead code from receive function staging:iio: Drop {mark,unmark}_in_use callbacks staging:iio: Drop buffer mark_param_change callback staging:iio: Drop the unused buffer enable() and is_enabled() callbacks staging:iio: Drop buffer busy flag staging:iio: Make sure a device is only opened once at a time staging:iio: Disallow modifying buffer size when buffer is enabled staging:iio: Disallow changing scan elements in all buffered modes staging:iio: Use iio_buffer_enabled instead of open coding it ... Fix up conflict in drivers/staging/iio/adc/ad799x_core.c (removal of module_init due to using module_i2c_driver() helper, next to removal of MODULE_ALIAS due to using MODULE_DEVICE_TABLE instead).
2011-11-29staging: hv: move hv_netvsc out of staging areaHaiyang Zhang
hv_netvsc has been reviewed on netdev mailing list on 6/09/2011. All recommended changes have been made. We are requesting to move it out of staging area. Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: KY Srinivasan <kys@microsoft.com> Signed-off-by: Mike Sterling <Mike.Sterling@microsoft.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-29dsa: Move switch drivers to new directory drivers/net/dsaBen Hutchings
Support for specific hardware belongs under drivers/net/ not net/. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
The forcedeth changes had a conflict with the conversion over to atomic u64 statistics in net-next. The libertas cfg.c code had a conflict with the bss reference counting fix by John Linville in net-next. Conflicts: drivers/net/ethernet/nvidia/forcedeth.c drivers/net/wireless/libertas/cfg.c
2011-11-13net: introduce ethernet teaming deviceJiri Pirko
This patch introduces new network device called team. It supposes to be very fast, simple, userspace-driven alternative to existing bonding driver. Userspace library called libteam with couple of demo apps is available here: https://github.com/jpirko/libteam Note it's still in its dipers atm. team<->libteam use generic netlink for communication. That and rtnl suppose to be the only way to configure team device, no sysfs etc. Python binding of libteam was recently introduced. Daemon providing arpmon/miimon active-backup functionality will be introduced shortly. All what's necessary is already implemented in kernel team driver. v7->v8: - check ndo_ndo_vlan_rx_[add/kill]_vid functions before calling them. - use dev_kfree_skb_any() instead of dev_kfree_skb() v6->v7: - transmit and receive functions are not checked in hot paths. That also resolves memory leak on transmit when no port is present v5->v6: - changed couple of _rcu calls to non _rcu ones in non-readers v4->v5: - team_change_mtu() uses team->lock while travesing though port list - mac address changes are moved completely to jurisdiction of userspace daemon. This way the daemon can do FOM1, FOM2 and possibly other weird things with mac addresses. Only round-robin mode sets up all ports to bond's address then enslaved. - Extended Kconfig text v3->v4: - remove redundant synchronize_rcu from __team_change_mode() - revert "set and clear of mode_ops happens per pointer, not per byte" - extend comment of function __team_change_mode() v2->v3: - team_change_mtu() uses rcu version of list traversal to unwind - set and clear of mode_ops happens per pointer, not per byte - port hashlist changed to be embedded into team structure - error branch in team_port_enter() does cleanup now - fixed rtln->rtnl v1->v2: - modes are made as modules. Makes team more modular and extendable. - several commenters' nitpicks found on v1 were fixed - several other bugs were fixed. - note I ignored Eric's comment about roundrobin port selector as Eric's way may be easily implemented as another mode (mode "random") in future. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-09net: drivers/net/hippi/Kconfig should be sourcedPaul Bolle
Commit ff5a3b509e ("hippi: Move the HIPPI driver") moved the HIPPI driver into drivers/net/hippi. It didn't source drivers/net/hippi/Kconfig though, so it didn't make all necessary Kconfig changes. So let drivers/net/kconfig source HIPPI's Kconfig file. [ Fix syntax error at the end of HIPP's Kconfig file. -DaveM ] Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-27drivers/net: Kconfig & Makefile cleanupJeff Kirsher
The is does a general cleanup of the drivers/net/ Kconfig and Makefile. This patch create a "core" option and places all the networking core drivers into this option (default is yes for this option). In addition, it alphabitizes the Kconfig driver options. As a side cleanup, found that the arcnet, token ring, and PHY Kconfig options were a tri-state option and should have been a bool option. Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-27com20020_cs: Move the PCMCIA Arcnet driverJeff Kirsher
Move the COM20020 PCMICA Arcnet driver into drivers/net/arcnet/ with the other Arcnet drivers. Made the necessary Kconfig and Makefile changes as well. Since this was the "last" PCMCIA driver in drivers/net/pcmcia/, this patch also cleans up the references to drivers/net/pcmcia. CC: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-27slip: Move the SLIP driversJeff Kirsher
Move the Serial Line Internet Protocol (SLIP) drivers into drivers/net/slip/ and make the necessary Kconfig and Makefile changes. Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: Alan Cox <alan@linux.intel.com>
2011-08-27plip: Move the PLIP driverJeff Kirsher
Move the Parallel Line Internet Protocol (PLIP) driver into drivers/net/plip/ and make the necessary Kconfig and Makefile changes. CC: Niibe Yutaka <gniibe@mri.co.jp> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: Alan Cox <alan@linux.intel.com>
2011-08-27hippi: Move the HIPPI driverJeff Kirsher
Move the HIPPI driver into drivers/net/hippi/ and make the necessary Kconfig and Makefile changes. CC: Jes Sorensen <jes@wildopensource.com> CC: Jes Sorensen <jes@trained-monkey.org> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-27ppp: Move the PPP driversJeff Kirsher
Move the PPP drivers into drivers/net/ppp/ and make the necessary Kconfig and Makefile changes. CC: Paul Mackerras <paulus@samba.org> CC: Frank Cusack <fcusack@fcusack.com> CC: Michal Ostrowski <mostrows@speakeasy.net> CC: Michal Ostrowski <mostrows@earthlink.net> CC: Dmitry Kozlov <xeb@mail.ru> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-27fddi: Move the FDDI driversJeff Kirsher
Move the FDDI drivers into drivers/net/fddi/ and make the necessary Kconfig and Makefile changes. CC: "Maciej W. Rozycki" <macro@linux-mips.org> CC: Christoph Goos <cgoos@syskonnect.de> CC: <linux@syskonnect.de> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-16net: Fix sungem_phy sharing.David S. Miller
Since sungem_phy is used by multiple, unrelated, drivers make it build as a real module under drivers/net. depmod will pick up the symbol dependency and make sure sungem_phy.ko gets loaded any time sungem.ko or spider_net.ko is loaded. Tested-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-13drivers/net: Kconfig and Makefile cleanupJeff Kirsher
After the move of the Ethernet drivers into drivers/net/ethernet/ there was some leftover cleanup to do in the Kconfig and Makefile. Removed the 10/100, 1000, and 10GbE Kconfig menus. Removed the out-dated pci-skeleton.c file which was used an example driver. With the current networking features and structure, the file is no longer a good example to use for driver creation. CC: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12tile: Move the Tilera driverJeff Kirsher
Move the Tilera driver into drivers/net/ethernet/tile and make the necessary Kconfig and Makefile changes. Updated the Kconfig so that the options defualt to y if TILE kernel. CC: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12sh_eth: Move the Renesas SuperH driverJeff Kirsher
Move the Renesas driver into drivers/net/ethernet/renesas/ and make the necessary Kconfig and Makefile changes. CC: Yoshihiro Shimoda <yoshihiro.shirmoda.uh@renesas.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12netx: Move the netx driverJeff Kirsher
Move the netx driver into drivers/net/ethernet/ and make the necessary Kconfig and Makefile changes. CC: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-08-12dm9000: Move the Davicom driverJeff Kirsher
Move the Davicom driver into drivers/net/ethernet/davicom/ and make the necessary Kconfig and Makefile changes. CC: Ben Dooks <ben@simtec.co.uk> CC: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-08-12enc28j60: Move the Microchip driverJeff Kirsher
Move the Microchip driver into drivers/net/ethernet/microchip/ and make the necessary Kconfig and Makefile changes. CC: Claudio Lanconelli <lanconelli.claudio@eptar.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12greth: Move the Aeroflex Gaisler driverJeff Kirsher
Move the Aeroflex Gaisler driver into drivers/net/ethernet/aeroflex/ and make the necessary Kconfig and Makefile changes. CC: Kristoffer Glembo <kristoffer@gaisler.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12ethoc: Move the Avionic driverJeff Kirsher
Move the Avionic driver into drivers/net/ethernet/ and make the necessary Kconfig and Makefile changes. CC: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12dnet: Move the Dave Ethernet driverJeff Kirsher
Move the Dave Ethernet driver into drivers/net/ethernet/ and make the necessary Kconfig and Makefile changes. CC: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12hp100: Move the HP driverJeff Kirsher
Move the HP driver into drivers/net/ethernet/hp/ and made the necessary Kconfig and Makefile changes. CC: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12starfire: Move the Adaptec driverJeff Kirsher
Move the Adaptec driver into drivers/net/ethernet/adaptec/ and make the necessary Kconfig and Makefile changes. CC: Ion Badulescu <ionut@badula.org> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12forcedeth: Move the NVIDIA nForce driverJeff Kirsher
Move the nForce driver into drivers/net/ethernet/nvidia/ and make the necessary Kconfig and Makefile changes. Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12fealnx: Move the Myson driverJeff Kirsher
Move the Myson driver into drivers/net/ethernet/ and make the necessary Kconfig and Makefile changes. CC: Donald Becker <becker@scyld.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12r6040: Move the RDC driverJeff Kirsher
Move the RDC driver into drivers/net/ethernet/rdc/ and make the necessary Kconfig and Makefile changes. CC: Florian Fainelli <florian@openwrt.org> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12macb: Move the Atmel driverJeff Kirsher
Move the Atmel driver into drivers/net/ethernet/cadence/ and make the necessary Kconfig and Makefile changes. CC: Nicolas Ferre <nicolas.ferre@atmel.com> CC: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2011-08-12bfin_mac: Move the Analog Devices Inc driverJeff Kirsher
Move the Analog Devices Inc driver into drivers/net/ethernet/adi/ and make the necessary Kconfig and Makefile changes. CC: <uclinux-dist-devel@blackfin.uclinux.org> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: Bob Liu <bob.liu@analog.com>
2011-08-12lantiq: Move the Lantiq SoC driverJeff Kirsher
Move the Lantiq driver into drivers/net/ethernet/ and the necessary Kconfig and Makefile changes. CC: John Crispin <blogic@openwrt.org> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: John Crispin <blogic@openwrt.org>
2011-08-12mipsnet: Move the MIPS driverJeff Kirsher
Move the MIPS drivers into drivers/net/ethernet/ and make the necessary Kconfig and Makefile changes. Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12korina: Move the IDT driverJeff Kirsher
Move the IDT driver into drivers/net/ethernet/ and make the necessary Kconfig and Makefile changes CC: "IDT Inc." <rischelp@idt.com> CC: Felix Fietkau <nbd@openwrt.org> CC: Florian Fainelli <florian@openwrt.org> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12ipg: Move the IC Plus driverJeff Kirsher
Move the IC Plus driver into drivers/net/ethernet/icplus/ and make the necessary Kconfig and Makefile changes. CC: <craig_rich@sundanceti.com> CC: <sorbica@icplus.com.tw> CC: <jesse@icplus.com.tw> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12xilinx/ll_temac: Move the Xilinx driversJeff Kirsher
Move the Xilinx drivers into drivers/net/ethernet/xilinx/ and make the necessary Kconfig and Makefile changes. CC: John Williams <john.williams@petalogix.com> CC: "David H. Lynch Jr." <dhlii@dlasys.net> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12jme: Move the JME driverJeff Kirsher
Move the JME driver into drivers/net/ethernet/ and make the necessary Kconfig and Makefile changes. CC: Guo-Fu Tseng <cooldavid@cooldavid.org> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12octeon: Move the Cavium driverJeff Kirsher
Move the Cavium driver to drivers/net/ethernet/octeon/ and make the necessary Kconfig and Makefile changes. CC: David Daney <david.daney@cavium.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: David Daney <david.daney@cavium.com>
2011-08-12hamachi/yellowfin: Move the packet engine driversJeff Kirsher
Move the packet engine drivers to drivers/net/ethernet/packetengines/ and the necessary Kconfig and Makefile changes. CC: Donald Becker <becker@scyld.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12davinci*/tlan/cpmac: Move the Texas Instruments (TI) driversJeff Kirsher
Move the Texas Instruments drivers to drivers/net/ethernet/ti/ and make the necessary Kconfig and Makefile changes. CC: Sriram <srk@ti.com> CC: Vinay Hegde <vinay.hegde@ti.com> CC: Cyril Chemparathy <cyril@ti.com> CC: Samuel Chessman <chessman@tux.org> CC: <torben.mathiasen@compaq.com> CC: Eugene Konev <ejka@imfi.kspu.ru> CC: Florian Fainelli <florian@openwrt.org> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12s6gmac: Move the s6gmac driversJeff Kirsher
Move the s6gmac driver to drivers/net/ethernet/ and make the necessary Kconfig and Makefile changes. CC: Oskar Schirmer <os@emlix.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12tsi108*: Move the Tundra driverJeff Kirsher
Move the Tundra driver to drivers/net/ethernet/tundra/ and make the necessary Kocnfig and Makefile changes. CC: Kong Lai <kong.lai@tundra.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12sis*: Move the Silicon Integrated Systems (SiS) driversJeff Kirsher
Move the SiS drivers into drivers/net/ethernet/sis/ and make the necessary Kconfig and Makefile changes CC: Daniele Venzano <venza@brownhat.org> CC: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12toshiba: Move the Toshiba driversJeff Kirsher
Move the Toshiba ethernet drivers into drivers/net/ethernet/toshiba and make the necessary Kconfig and Makefile changes. CC: Geoff Levand <geoff@infradead.org> CC: Jens Osterkamp <Jens.Osterkamp@de.ibm.com> CC: Ishizaki Kou <kou.ishizaki@toshiba.co.jp> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12ks8*/ksz8*: Move the Micrel driversJeff Kirsher
Move the Micrel drivers into drivers/net/ethernet/micrel/ and make the necessary Kconfig and Makefile changes. CC: Ben Dooks <ben@simtec.co.uk> CC: Tristram Ha <Tristram.Ha@micrel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12freescale: Move the Freescale driversJeff Kirsher
Move the Freescale drivers into drivers/net/ethernet/freescale/ and make the necessary Kconfig and Makefile changes. CC: Sandeep Gopalpet <sandeep.kumar@freescale.com> CC: Andy Fleming <afleming@freescale.com> CC: Shlomi Gridish <gridish@freescale.com> CC: Li Yang <leoli@freescale.com> CC: Pantelis Antoniou <pantelis.antoniou@gmail.com> CC: Vitaly Bordug <vbordug@ru.mvista.com> CC: Dan Malek <dmalek@jlc.net> CC: Sylvain Munaut <tnt@246tNt.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12eth16i: Move the Allied Telesis/Fujitsu driversJeff Kirsher
Move the Allied Telesis/Fujitsu drivers into drivers/net/ethernet/fujitsu/ and make the necessary Kconfig and Makefile changes. CC: Shingo Fujimoto <shingo@flab.fujitsu.co.jp> CC: Yutaka Tamiya <tamy@flab.fujitsu.co.jp> CC: Rene Schmit <rene@bss.lu> CC: Mika Kuoppala <miku@iki.fi> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12via-*: Move the VIA driversJeff Kirsher
Move the VIA drivers into drivers/net/ethernet/via/ and make the necessary Kconfig and Makefile changes. CC: Roger Luethi <rl@hellgate.ch> CC: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12skge/sky2/mv643xx/pxa168: Move the Marvell Ethernet driversJeff Kirsher
Move the Marvell Ethernet drivers into drivers/net/ethernet/marvell/ and make the necessary Kconfig and Makefile changes. CC: Sachin Sanap <ssanap@marvell.com> CC: Zhangfei Gao <zgao6@marvell.com> CC: Philip Rakity <prakity@marvell.com> CC: Mark Brown <markb@marvell.com> CC: Lennert Buytenhek <buytenh@marvell.com> CC: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12pch_gbe: Move the OKI Semiconductor driverJeff Kirsher
Move the OKI Semiconductor driver into driver/net/ethernet/oki-semi/ and make the necessary Kconfig and Makefile changes. Note: there is no documented maintainer for this driver, so I CC'd the last 2 major contributors. CC: Tomoya <tomoya-linux@dsn.okisemi.com> CC: Toshiharu Okada <toshiharu-linux@dsn.okisemi.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12seeq: Move the SEEQ driversJeff Kirsher
Move the drivers that use SEEQ chipset into drivers/net/ethernet/seeq and make the necessary Kconfig and Makefile changes. CC: Russell King <linux@arm.linux.org.uk> CC: Hamish Coleman <hamish@zot.apana.org.au> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
