path: root/drivers/net/Makefile
2011-08-29net: Fix duplicate CONFIG_SLIP entry in driver/net/MakefileDavid S. Miller
Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-29net: fix Makefile typos & build errorsRandy Dunlap
Fix many (randconfig) PPP build errors by fixing typos in drivers/net/Makefile. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-27drivers/net: Kconfig & Makefile cleanupJeff Kirsher
The is does a general cleanup of the drivers/net/ Kconfig and Makefile. This patch create a "core" option and places all the networking core drivers into this option (default is yes for this option). In addition, it alphabitizes the Kconfig driver options. As a side cleanup, found that the arcnet, token ring, and PHY Kconfig options were a tri-state option and should have been a bool option. Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-27com20020_cs: Move the PCMCIA Arcnet driverJeff Kirsher
Move the COM20020 PCMICA Arcnet driver into drivers/net/arcnet/ with the other Arcnet drivers. Made the necessary Kconfig and Makefile changes as well. Since this was the "last" PCMCIA driver in drivers/net/pcmcia/, this patch also cleans up the references to drivers/net/pcmcia. CC: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-27slip: Move the SLIP driversJeff Kirsher
Move the Serial Line Internet Protocol (SLIP) drivers into drivers/net/slip/ and make the necessary Kconfig and Makefile changes. Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: Alan Cox <alan@linux.intel.com>
2011-08-27plip: Move the PLIP driverJeff Kirsher
Move the Parallel Line Internet Protocol (PLIP) driver into drivers/net/plip/ and make the necessary Kconfig and Makefile changes. CC: Niibe Yutaka <gniibe@mri.co.jp> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: Alan Cox <alan@linux.intel.com>
2011-08-27hippi: Move the HIPPI driverJeff Kirsher
Move the HIPPI driver into drivers/net/hippi/ and make the necessary Kconfig and Makefile changes. CC: Jes Sorensen <jes@wildopensource.com> CC: Jes Sorensen <jes@trained-monkey.org> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-27ppp: Move the PPP driversJeff Kirsher
Move the PPP drivers into drivers/net/ppp/ and make the necessary Kconfig and Makefile changes. CC: Paul Mackerras <paulus@samba.org> CC: Frank Cusack <fcusack@fcusack.com> CC: Michal Ostrowski <mostrows@speakeasy.net> CC: Michal Ostrowski <mostrows@earthlink.net> CC: Dmitry Kozlov <xeb@mail.ru> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-27fddi: Move the FDDI driversJeff Kirsher
Move the FDDI drivers into drivers/net/fddi/ and make the necessary Kconfig and Makefile changes. CC: "Maciej W. Rozycki" <macro@linux-mips.org> CC: Christoph Goos <cgoos@syskonnect.de> CC: <linux@syskonnect.de> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-16net: Fix sungem_phy sharing.David S. Miller
Since sungem_phy is used by multiple, unrelated, drivers make it build as a real module under drivers/net. depmod will pick up the symbol dependency and make sure sungem_phy.ko gets loaded any time sungem.ko or spider_net.ko is loaded. Tested-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-13drivers/net: Kconfig and Makefile cleanupJeff Kirsher
After the move of the Ethernet drivers into drivers/net/ethernet/ there was some leftover cleanup to do in the Kconfig and Makefile. Removed the 10/100, 1000, and 10GbE Kconfig menus. Removed the out-dated pci-skeleton.c file which was used an example driver. With the current networking features and structure, the file is no longer a good example to use for driver creation. CC: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12tile: Move the Tilera driverJeff Kirsher
Move the Tilera driver into drivers/net/ethernet/tile and make the necessary Kconfig and Makefile changes. Updated the Kconfig so that the options defualt to y if TILE kernel. CC: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12sh_eth: Move the Renesas SuperH driverJeff Kirsher
Move the Renesas driver into drivers/net/ethernet/renesas/ and make the necessary Kconfig and Makefile changes. CC: Yoshihiro Shimoda <yoshihiro.shirmoda.uh@renesas.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12netx: Move the netx driverJeff Kirsher
Move the netx driver into drivers/net/ethernet/ and make the necessary Kconfig and Makefile changes. CC: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-08-12dm9000: Move the Davicom driverJeff Kirsher
Move the Davicom driver into drivers/net/ethernet/davicom/ and make the necessary Kconfig and Makefile changes. CC: Ben Dooks <ben@simtec.co.uk> CC: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-08-12enc28j60: Move the Microchip driverJeff Kirsher
Move the Microchip driver into drivers/net/ethernet/microchip/ and make the necessary Kconfig and Makefile changes. CC: Claudio Lanconelli <lanconelli.claudio@eptar.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12greth: Move the Aeroflex Gaisler driverJeff Kirsher
Move the Aeroflex Gaisler driver into drivers/net/ethernet/aeroflex/ and make the necessary Kconfig and Makefile changes. CC: Kristoffer Glembo <kristoffer@gaisler.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12ethoc: Move the Avionic driverJeff Kirsher
Move the Avionic driver into drivers/net/ethernet/ and make the necessary Kconfig and Makefile changes. CC: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12dnet: Move the Dave Ethernet driverJeff Kirsher
Move the Dave Ethernet driver into drivers/net/ethernet/ and make the necessary Kconfig and Makefile changes. CC: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12hp100: Move the HP driverJeff Kirsher
Move the HP driver into drivers/net/ethernet/hp/ and made the necessary Kconfig and Makefile changes. CC: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12starfire: Move the Adaptec driverJeff Kirsher
Move the Adaptec driver into drivers/net/ethernet/adaptec/ and make the necessary Kconfig and Makefile changes. CC: Ion Badulescu <ionut@badula.org> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12forcedeth: Move the NVIDIA nForce driverJeff Kirsher
Move the nForce driver into drivers/net/ethernet/nvidia/ and make the necessary Kconfig and Makefile changes. Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12fealnx: Move the Myson driverJeff Kirsher
Move the Myson driver into drivers/net/ethernet/ and make the necessary Kconfig and Makefile changes. CC: Donald Becker <becker@scyld.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12r6040: Move the RDC driverJeff Kirsher
Move the RDC driver into drivers/net/ethernet/rdc/ and make the necessary Kconfig and Makefile changes. CC: Florian Fainelli <florian@openwrt.org> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12macb: Move the Atmel driverJeff Kirsher
Move the Atmel driver into drivers/net/ethernet/cadence/ and make the necessary Kconfig and Makefile changes. CC: Nicolas Ferre <nicolas.ferre@atmel.com> CC: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2011-08-12bfin_mac: Move the Analog Devices Inc driverJeff Kirsher
Move the Analog Devices Inc driver into drivers/net/ethernet/adi/ and make the necessary Kconfig and Makefile changes. CC: <uclinux-dist-devel@blackfin.uclinux.org> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: Bob Liu <bob.liu@analog.com>
2011-08-12lantiq: Move the Lantiq SoC driverJeff Kirsher
Move the Lantiq driver into drivers/net/ethernet/ and the necessary Kconfig and Makefile changes. CC: John Crispin <blogic@openwrt.org> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: John Crispin <blogic@openwrt.org>
2011-08-12mipsnet: Move the MIPS driverJeff Kirsher
Move the MIPS drivers into drivers/net/ethernet/ and make the necessary Kconfig and Makefile changes. Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12korina: Move the IDT driverJeff Kirsher
Move the IDT driver into drivers/net/ethernet/ and make the necessary Kconfig and Makefile changes CC: "IDT Inc." <rischelp@idt.com> CC: Felix Fietkau <nbd@openwrt.org> CC: Florian Fainelli <florian@openwrt.org> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12ipg: Move the IC Plus driverJeff Kirsher
Move the IC Plus driver into drivers/net/ethernet/icplus/ and make the necessary Kconfig and Makefile changes. CC: <craig_rich@sundanceti.com> CC: <sorbica@icplus.com.tw> CC: <jesse@icplus.com.tw> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12xilinx/ll_temac: Move the Xilinx driversJeff Kirsher
Move the Xilinx drivers into drivers/net/ethernet/xilinx/ and make the necessary Kconfig and Makefile changes. CC: John Williams <john.williams@petalogix.com> CC: "David H. Lynch Jr." <dhlii@dlasys.net> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12jme: Move the JME driverJeff Kirsher
Move the JME driver into drivers/net/ethernet/ and make the necessary Kconfig and Makefile changes. CC: Guo-Fu Tseng <cooldavid@cooldavid.org> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12octeon: Move the Cavium driverJeff Kirsher
Move the Cavium driver to drivers/net/ethernet/octeon/ and make the necessary Kconfig and Makefile changes. CC: David Daney <david.daney@cavium.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: David Daney <david.daney@cavium.com>
2011-08-12hamachi/yellowfin: Move the packet engine driversJeff Kirsher
Move the packet engine drivers to drivers/net/ethernet/packetengines/ and the necessary Kconfig and Makefile changes. CC: Donald Becker <becker@scyld.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12davinci*/tlan/cpmac: Move the Texas Instruments (TI) driversJeff Kirsher
Move the Texas Instruments drivers to drivers/net/ethernet/ti/ and make the necessary Kconfig and Makefile changes. CC: Sriram <srk@ti.com> CC: Vinay Hegde <vinay.hegde@ti.com> CC: Cyril Chemparathy <cyril@ti.com> CC: Samuel Chessman <chessman@tux.org> CC: <torben.mathiasen@compaq.com> CC: Eugene Konev <ejka@imfi.kspu.ru> CC: Florian Fainelli <florian@openwrt.org> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12s6gmac: Move the s6gmac driversJeff Kirsher
Move the s6gmac driver to drivers/net/ethernet/ and make the necessary Kconfig and Makefile changes. CC: Oskar Schirmer <os@emlix.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12tsi108*: Move the Tundra driverJeff Kirsher
Move the Tundra driver to drivers/net/ethernet/tundra/ and make the necessary Kocnfig and Makefile changes. CC: Kong Lai <kong.lai@tundra.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12sis*: Move the Silicon Integrated Systems (SiS) driversJeff Kirsher
Move the SiS drivers into drivers/net/ethernet/sis/ and make the necessary Kconfig and Makefile changes CC: Daniele Venzano <venza@brownhat.org> CC: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12toshiba: Move the Toshiba driversJeff Kirsher
Move the Toshiba ethernet drivers into drivers/net/ethernet/toshiba and make the necessary Kconfig and Makefile changes. CC: Geoff Levand <geoff@infradead.org> CC: Jens Osterkamp <Jens.Osterkamp@de.ibm.com> CC: Ishizaki Kou <kou.ishizaki@toshiba.co.jp> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12ks8*/ksz8*: Move the Micrel driversJeff Kirsher
Move the Micrel drivers into drivers/net/ethernet/micrel/ and make the necessary Kconfig and Makefile changes. CC: Ben Dooks <ben@simtec.co.uk> CC: Tristram Ha <Tristram.Ha@micrel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12freescale: Move the Freescale driversJeff Kirsher
Move the Freescale drivers into drivers/net/ethernet/freescale/ and make the necessary Kconfig and Makefile changes. CC: Sandeep Gopalpet <sandeep.kumar@freescale.com> CC: Andy Fleming <afleming@freescale.com> CC: Shlomi Gridish <gridish@freescale.com> CC: Li Yang <leoli@freescale.com> CC: Pantelis Antoniou <pantelis.antoniou@gmail.com> CC: Vitaly Bordug <vbordug@ru.mvista.com> CC: Dan Malek <dmalek@jlc.net> CC: Sylvain Munaut <tnt@246tNt.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12eth16i: Move the Allied Telesis/Fujitsu driversJeff Kirsher
Move the Allied Telesis/Fujitsu drivers into drivers/net/ethernet/fujitsu/ and make the necessary Kconfig and Makefile changes. CC: Shingo Fujimoto <shingo@flab.fujitsu.co.jp> CC: Yutaka Tamiya <tamy@flab.fujitsu.co.jp> CC: Rene Schmit <rene@bss.lu> CC: Mika Kuoppala <miku@iki.fi> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12via-*: Move the VIA driversJeff Kirsher
Move the VIA drivers into drivers/net/ethernet/via/ and make the necessary Kconfig and Makefile changes. CC: Roger Luethi <rl@hellgate.ch> CC: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12skge/sky2/mv643xx/pxa168: Move the Marvell Ethernet driversJeff Kirsher
Move the Marvell Ethernet drivers into drivers/net/ethernet/marvell/ and make the necessary Kconfig and Makefile changes. CC: Sachin Sanap <ssanap@marvell.com> CC: Zhangfei Gao <zgao6@marvell.com> CC: Philip Rakity <prakity@marvell.com> CC: Mark Brown <markb@marvell.com> CC: Lennert Buytenhek <buytenh@marvell.com> CC: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12pch_gbe: Move the OKI Semiconductor driverJeff Kirsher
Move the OKI Semiconductor driver into driver/net/ethernet/oki-semi/ and make the necessary Kconfig and Makefile changes. Note: there is no documented maintainer for this driver, so I CC'd the last 2 major contributors. CC: Tomoya <tomoya-linux@dsn.okisemi.com> CC: Toshiharu Okada <toshiharu-linux@dsn.okisemi.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12seeq: Move the SEEQ driversJeff Kirsher
Move the drivers that use SEEQ chipset into drivers/net/ethernet/seeq and make the necessary Kconfig and Makefile changes. CC: Russell King <linux@arm.linux.org.uk> CC: Hamish Coleman <hamish@zot.apana.org.au> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12ioc3-eth/meth: Move the SGI driversJeff Kirsher
Move the SGI drivers into drivers/net/ethernet/sgi/ and make the necessary Kconfig and Makefile changes. CC: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-12ewrk3/tulip: Move the DEC - Tulip driversJeff Kirsher
Move the DEC - Tulip driver into drivers/net/ethernet/dec/tulip/ and make the necessary Kconfig and Makefile changes. The Digital Equioment (DEC) driver ewrk3 was moved into drivers/net/ethernet/dec/ and the remaining drivers (Tulip) were moved into drivers/net/ethernet/dec/tulip/ CC: Tobias Ringstrom <tori@unhappy.mine.nu> CC: Grant Grundler <grundler@parisc-linux.org> CC: David Davies <davies@maniac.ultranet.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: Grant Grundler <grundler@parisc-linux.org>
2011-08-11spider_net: fix compile issue introduced by driver moveJeff Kirsher
Both Spider net driver and Sun GEM driver use the sungem_phy.o object. This fix creates a Kconfig object for sungem_phy (like MDIO) so that both drivers require the SUNGEM_PHY object. This has been compile tested for the Sun GEM driver. Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-11atl*: Move the Atheros driversJeff Kirsher
Move the Atheros drivers into drivers/net/ethernet/atheros/ and make the necessary Kconfig and Makefile changes. CC: Jay Cliburn <jcliburn@gmail.com> CC: Chris Snook <chris.snook@gmail.com> CC: Jie Yang <jie.yang@atheros.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
