path: root/drivers/net/amd8111e.h
2011-07-21amd8111e: do vlan cleanupJiri Pirko
- unify vlan and nonvlan rx path - kill lp->vlgrp and amd8111e_vlan_rx_register Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-21amd8111e: use net_device_stats from struct net_deviceEric Dumazet
struct net_device has its own struct net_device_stats member, so use this one instead of a private copy in the amd8111e_priv struct. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-22net: convert multiple drivers to use netdev_for_each_mc_addr, part3Jiri Pirko
2007-10-10amd8111e: trivial endianness annotations, NULL noise removalAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[NET]: Make NAPI polling independent of struct net_device objects.Stephen Hemminger
Several devices have multiple independant RX queues per net device, and some have a single interrupt doorbell for several queues. In either case, it's easier to support layouts like that if the structure representing the poll is independant from the net device itself. The signature of the ->poll() call back goes from: int foo_poll(struct net_device *dev, int *budget) to int foo_poll(struct napi_struct *napi, int budget) The caller is returned the number of RX packets processed (or the number of "NAPI credits" consumed if you want to get abstract). The callee no longer messes around bumping dev->quota, *budget, etc. because that is all handled in the caller upon return. The napi_struct is to be embedded in the device driver private data structures. Furthermore, it is the driver's responsibility to disable all NAPI instances in it's ->stop() device close handler. Since the napi_struct is privatized into the driver's private data structures, only the driver knows how to get at all of the napi_struct instances it may have per-device. With lots of help and suggestions from Rusty Russell, Roland Dreier, Michael Chan, Jeff Garzik, and Jamal Hadi Salim. Bug fixes from Thomas Graf, Roland Dreier, Peter Zijlstra, Joseph Fannin, Scott Wood, Hans J. Koch, and Michael Chan. [ Ported to current tree and all drivers converted. Integrated Stephen's follow-on kerneldoc additions, and restored poll_list handling to the old style to fix mutual exclusion issues. -DaveM ] Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-01potential parse error in ifdefYoann Padioleau
I have made a tool to parse the kernel that does not pre-process the source. That means that my parser tries to parse all the code, including code in the #else branch or code that is not often compiled because the driver is not very used (or not used at all). So, my parser sometimes reports parse error not originally detected by gcc. Here is my (first) patch. [akpm@linux-foundation.org: fix amd8111e.c] Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Acked-by: Matthew Wilcox <matthew@wil.cx> Acked-by: Wim Van Sebroeck <wim@iguana.be> Acked-by: David Woodhouse <dwmw2@infradead.org> Acked-by: Jeff Garzik <jeff@garzik.org> Acked-by: James Bottomley <James.Bottomley@steeleye.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-02[PATCH] amd8111e use standard CRC libStephen Hemminger
I noticed this driver (and several others) reinvent their own copy of the existing CRC library. Don't have the hardware, but tested by extracting code and comparing result. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
2005-10-28[git] change permissions on drivers/net/amd8111e.[ch] to 0644,Jeff Garzik
removing executable bits.
