- unify vlan and nonvlan rx path
- kill adapter->vlgrp and atlx_vlan_rx_register
- allow to turn on/off rx/tx vlan accel via ethtool (set_features)
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
Converts the list and the core manipulating with it to be the same as uc_list.
+uses two functions for adding/removing mc address (normal and "global"
variant) instead of a function parameter.
+removes dev_mcast.c completely.
+exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for
manipulation with lists on a sandbox (used in bonding and 80211 drivers)
There is now a net_device_stats structure inside net_device that should
be used if possible by devices. Compile tested only.
See http://marc.info/?l=linux-netdev&m=121931988219314&w=2
Stop the queue and turn off carrier to prevent transmit timeouts
when the cable is unplugged/replugged.
Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
atl1-2.1.3.
Move some code from atlx.c to atl1.c to prevent build conflict with
the upcoming atl2 code. No changes, just movement.
Signed-off-by: Chris Snook <csnook@redhat.com>
There's no good reason to manually set the flash vendor in a module
parameter, outside of an Atheros hardware lab. Remove it, so nobody
accidentally bricks their board using it incorrectly.
The future atl2 driver and the existing atl1 driver can share certain
functions and definitions. Move these shareable functions and definitions
out of atl1-specific files and into atlx.c and atlx.h. Some transitory
hackery will be present until atl2 is merged.
Reduce the number of source files by moving ethtool, hw, and param
functions from separate files into atl1_main.c, then rename it to just
atl1.c.
Move all atl1-specific definitions from atl1_hw.h to atl1.h.
Finally, clean up to make checkpatch.pl happy.
Signed-off-by: Jeff Garzik <jeff@garzik.org>
