path: root/drivers/net/au1000_eth.c
2005-11-18[PATCH] au1000_eth: Include <linux/config.h>Ralf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> The Au1000 ethernet driver references plenty of CONFIG_* symbols. Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-28drivers/net: Remove pointless checks for NULL prior to calling kfree()Jesper Juhl
2005-10-18[PATCH] au1000_eth: Misc Au1000 net driver fixes.Ralf Baechle
o Add support for DP83847 MII. o remove unused variable. o Add some initialisations so even an unknown MII won't result in a crash. o Correct error message to "no known MIIs found". Signed-off-by: Ralf Baechle <ralf@linux-mips.org> drivers/net/au1000_eth.c | 13 +++++-------- 1 files changed, 5 insertions(+), 8 deletions(-) Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-05-12[netdrvrs] Use netif_carrier_* instead of IFF_RUNNING
