path: root/drivers/net/bcm63xx_enet.c
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
2011-06-11net: fix MIPS fallout from "net: remove interrupt.h inclusion from netdevice.h"Alexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-10treewide: Convert uses of struct resource to resource_size(ptr)Joe Perches
Several fixes as well where the +1 was missing. Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-04-29ethtool: cosmetic: Use ethtool ethtool_cmd_speed APIDavid Decotigny
This updates the network drivers so that they don't access the ethtool_cmd::speed field directly, but use ethtool_cmd_speed() instead. For most of the drivers, these changes are purely cosmetic and don't fix any problem, such as for those 1GbE/10GbE drivers that indirectly call their own ethtool get_settings()/mii_ethtool_gset(). The changes are meant to enforce code consistency and provide robustness with future larger throughputs, at the expense of a few CPU cycles for each ethtool operation. All drivers compiled with make allyesconfig ion x86_64 have been updated. Tested: make allyesconfig on x86_64 + e1000e/bnx2x work Signed-off-by: David Decotigny <decot@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/smsc911x.c
2011-03-30drivers/net: Remove IRQF_SAMPLE_RANDOM flag from network driversJavier Martinez Canillas
The IRQF_SAMPLE_RANDOM flag is marked as deprecated and will be removed. Every input point to the kernel's entropy pool have to better document the type of entropy source it is. drivers/char/random.c now implements a set of interfaces that can be used for devices to collect enviromental noise. IRQF_SAMPLE_RANDOM will be replaced with these add_*_randomness exported functions. Network drivers are not a good source of entropy. They use as a source of entropy essentially a remote host. Which means that the source of entropy can be potentially controlled by an attacker. Also, with heavy workloads the entropy decreases due to less hardware interrupts happening thanks to irq mitigation and NAPI. If a system relies in its network interface as a entropy source it has a false sense of security. Systems that don't have devices whose drivers are good sources of entropy, should either use a hardware random number generator or feed the kernel's entropy pool from userspace using other sources of entropy such as EGD, video_entropyd, timer_entropyd and audio-entropyd. Signed-off-by: Javier Martinez Canillas <martinez.javier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-12drivers/net: don't use flush_scheduled_work()Tejun Heo
flush_scheduled_work() is on its way out. This patch contains simple conversions to replace flush_scheduled_work() usage with direct cancels and flushes. Directly cancel the used works on driver detach and flush them in other cases. The conversions are mostly straight forward and the only dangers are, * Forgetting to cancel/flush one or more used works. * Cancelling when a work should be flushed (ie. the work must be executed once scheduled whether the driver is detaching or not). I've gone over the changes multiple times but it would be much appreciated if you can review with the above points in mind. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jay Cliburn <jcliburn@gmail.com> Cc: Michael Chan <mchan@broadcom.com> Cc: Divy Le Ray <divy@chelsio.com> Cc: e1000-devel@lists.sourceforge.net Cc: Vasanthy Kolluri <vkolluri@cisco.com> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: Lennert Buytenhek <buytenh@wantstofly.org> Cc: Andrew Gallatin <gallatin@myri.com> Cc: Francois Romieu <romieu@fr.zoreil.com> Cc: Ramkrishna Vepa <ramkrishna.vepa@exar.com> Cc: Matt Carlson <mcarlson@broadcom.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Shreyas Bhatewara <sbhatewara@vmware.com> Cc: netdev@vger.kernel.org
2010-08-25drivers/net: Remove address use from assignments of function pointersJoe Perches
"foo = &function" is more commonly written "foo = function" Done with coccinelle script: // <smpl> @r@ identifier f; @@ f(...) { ... } @@ identifier r.f; @@ - &f + f // </smpl> drivers/net/tehuti.c used a function and struct with the same name, the function was renamed. Compile tested x86 only. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-24bcm63xx_enet: use netdev statsEric Dumazet
Use integrated net_device stats instead of a private one Get rid of bcm_enet_get_stats() Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-18net: preserve ifreq parameter when calling generic phy_mii_ioctl().Richard Cochran
The phy_mii_ioctl() function unnecessarily throws away the original ifreq. We need access to the ifreq in order to support PHYs that can perform hardware time stamping. Two maverick drivers filter the ioctl commands passed to phy_mii_ioctl(). This is unnecessary since phylib will check the command in any case. Signed-off-by: Richard Cochran <richard.cochran@omicron.at> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-10net: trans_start cleanupsEric Dumazet
Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-06bcm63xx_enet: Remove unnecessary memset of netdev private dataTobias Klauser
The memory for the private data is allocated using kzalloc in alloc_etherdev (or alloc_netdev_mq respectively) so there is no need to set it to 0 again. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-13drivers: net: last_rx eliminationEric Dumazet
Network drivers do not have to update last_rx, unless they need it for their private use. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-13bcm63xx_enet: do not overwrite ENET_CTL_REG valueFlorian Fainelli
bcm_enet_hw_preinit will correctly set values in ENET_CTL_REG for internal or external MII operations, however, bcm_enet_open will blindly overwrite the ENET_CTL_REG register value and thus we will loose any changes to it that were made in bcm_enet_hw_preinit, rendering external MII operations non-working. This would lead to the driver not being able to check for link availability on external PHY setups, and thus we would never get to sending packets because link was down from the driver side. This was completely un-noticed because all boards out there but BCM6338-based ones use internal phy on their enet0 interface. Signed-off-by: Florian Fainelli <ffainelli@freebox.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-03net: convert multicast list to list_headJiri Pirko
Converts the list and the core manipulating with it to be the same as uc_list. +uses two functions for adding/removing mc address (normal and "global" variant) instead of a function parameter. +removes dev_mcast.c completely. +exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for manipulation with lists on a sandbox (used in bonding and 80211 drivers) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-30net: remove redundant codeEric Dumazet
eth_type_trans(skb, netdev) does the "skb->dev = netdev;" initialization, we can remove it from various network drivers. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-22net: convert multiple drivers to use netdev_for_each_mc_addr, part3Jiri Pirko
2010-02-12net: use netdev_mc_count and netdev_mc_empty when appropriateJiri Pirko
This patch replaces dev->mc_count in all drivers (hopefully I didn't miss anything). Used spatch and did small tweaks and conding style changes when it was suitable. Jirka Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-15bcm63xx_enet: fix compilation failure after get_stats_count removalFlorian Fainelli
This patch converts bcm63xx_enet to uset get_sset_count like the other drivers do. Signed-off-by: Florian Fainelli <ffainelli@freebox.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-13net: Use netdev_alloc_skb_ip_align()Eric Dumazet
2009-09-30bcm63xx_enet: timeout off by one in do_mdio_op()roel kluin
`while (limit-- >= 0)' reaches -2 after the loop upon timeout. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Acked-by: Maxime Bizon <mbizon@freebox.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-17MIPS: BCM63xx: Add integrated ethernet mac support.Maxime Bizon
Signed-off-by: Maxime Bizon <mbizon@freebox.fr> Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
