commit 7625eb2f2fff7bfae41d3119b472c20b48874895 upstream.
Based on earlier patch from Neil Horman <nhorman@tuxdriver.com>
If iSCSI is not supported on a bnx2 device, bnx2_cnic_probe() will
return NULL and the cnic device will not be visible to bnx2i. This
will prevent bnx2i from registering and then unregistering during
cnic_start() and cause the warning message:
bnx2 0003:01:00.1: eth1: Failed waiting for ULP up call to complete
Signed-off-by: Michael Chan <mchan@broadcom.com>
Cc: Neil Horman <nhorman@tuxdriver.com>
drivers/net/tg3.c
This updates the network drivers so that they don't access the
ethtool_cmd::speed field directly, but use ethtool_cmd_speed()
instead.
For most of the drivers, these changes are purely cosmetic and don't
fix any problem, such as for those 1GbE/10GbE drivers that indirectly
call their own ethtool get_settings()/mii_ethtool_gset(). The changes
are meant to enforce code consistency and provide robustness with
future larger throughputs, at the expense of a few CPU cycles for each
ethtool operation.
All drivers compiled with make allyesconfig ion x86_64 have been
updated.
Tested: make allyesconfig on x86_64 + e1000e/bnx2x work
Signed-off-by: David Decotigny <decot@google.com>
This makes sure the ethtool's set_settings() callback of network
drivers don't ignore the 16 most significant bits when ethtool calls
their set_settings().
All drivers compiled with make allyesconfig on x86_64 have been
updated.
This oops was recently reported to me:
invalid opcode: 0000 [#1] SMP
last sysfs file:
/sys/devices/pci0000:00/0000:00:01.0/0000:01:0d.0/0000:02:05.0/device
CPU 1
Modules linked in: bnx2(+) sunrpc ipv6 dm_mirror dm_region_hash dm_log sg
microcode serio_raw amd64_edac_mod edac_core edac_mce_amd k8temp i2c_piix4
shpchp ext4 mbcache jbd2 sd_mod crc_t10dif mptsas mptscsih mptbase
scsi_transport_sas radeon ttm drm_kms_helper drm hwmon i2c_algo_bit i2c_core
dm_mod [last unloaded: bnx2]
Pid: 23900, comm: pidof Not tainted 2.6.32-130.el6.x86_64 #1 BladeCenter LS21
-[797251Z]-
RIP: 0010:[<ffffffffa058b270>] [<ffffffffa058b270>] 0xffffffffa058b270
RSP: 0018:ffff880002083e48 EFLAGS: 00010246
RAX: ffff880002083e90 RBX: ffff88007ccd4000 RCX: 0000000000000000
RDX: 0000000000000100 RSI: dead000000200200 RDI: ffff8800007b8700
RBP: ffff880002083ed0 R08: ffff88000208db40 R09: 0000022d191d27c8
R10: 0000000000000000 R11: 0000000000000000 R12: ffff8800007b9bc8
R13: ffff880002083e90 R14: ffff8800007b8700 R15: ffffffffa058b270
FS: 00007fbb3bcf7700(0000) GS:ffff880002080000(0000) knlGS:0000000000000000
CR2: 0000000001664a98 CR3: 0000000060395000 CR4: 00000000000006e0
Process pidof (pid: 23900, threadinfo ffff8800007e8000, task ffff8800091c0040)
Stack:
ffffffff81079f77 ffffffff8109e010 ffff88007ccd5c20 ffff88007ccd5820
<0> ffff88007ccd5420 ffff8800007e9fd8 ffff8800007e9fd8 0000010000000000
<0> ffff88007ccd5020 ffff880002083e90 ffff880002083e90 ffffffff8102a00d
Call Trace:
<IRQ>
[<ffffffff81079f77>] ? run_timer_softirq+0x197/0x340
[<ffffffff8109e010>] ? tick_sched_timer+0x0/0xc0
[<ffffffff8102a00d>] ? lapic_next_event+0x1d/0x30
[<ffffffff8106f737>] __do_softirq+0xb7/0x1e0
[<ffffffff81092cc0>] ? hrtimer_interrupt+0x140/0x250
[<ffffffff81185f90>] ? filldir+0x0/0xe0
[<ffffffff8100c2cc>] call_softirq+0x1c/0x30
[<ffffffff8100df05>] do_softirq+0x65/0xa0
[<ffffffff8106f525>] irq_exit+0x85/0x90
[<ffffffff814e3340>] smp_apic_timer_interrupt+0x70/0x9b
[<ffffffff8100bc93>] apic_timer_interrupt+0x13/0x20
<EOI>
[<ffffffff81211ba5>] ? selinux_file_permission+0x45/0x150
[<ffffffff81262a75>] ? _atomic_dec_and_lock+0x55/0x80
[<ffffffff812050c6>] security_file_permission+0x16/0x20
[<ffffffff811861c1>] vfs_readdir+0x71/0xe0
[<ffffffff81186399>] sys_getdents+0x89/0xf0
[<ffffffff8100b172>] system_call_fastpath+0x16/0x1b
It occured during some stress testing, in which the reporter was repeatedly
removing and modprobing the bnx2 module while doing various other random
operations on the bnx2 registered net device. Noting that this error occured on
a serdes based device, we noted that there were a few ethtool operations (most
notably self_test and set_phys_id) that have execution paths that lead into
bnx2_setup_serdes_phy. This function is notable because it executes a mod_timer
call, which starts the bp->timer running. Currently bnx2 is setup to assume
that this timer only nees to be stopped when bnx2_close or bnx2_suspend is
called. Since the above ethtool operations are not gated on the net device
having been opened however, that assumption is incorrect, and can lead to the
timer still running after the module has been removed, leading to the oops above
(as well as other simmilar oopses).
Fix the problem by ensuring that the timer is stopped when pci_device_unregister
is called.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Reported-by: Hushan Jia <hjia@redhat.com>
CC: Michael Chan <mchan@broadcom.com>
CC: "David S. Miller" <davem@davemloft.net>
Acked-by: Michael Chan <mchan@broadcom.com>
When physical identification of an adapter is done by toggling the
mechanism on and off through software utilizing the set_phys_id operation,
it is done with a fixed duration for both on and off states. Some drivers
may want to set a custom duration for the on/off intervals. This patch
changes the API so the return code from the driver's entry point when it
is called with ETHTOOL_ID_ACTIVE can specify the frequency at which to
cycle the on/off states, and updates the drivers that have already been
converted to use the new set_phys_id and use the synchronous method for
identifying an adapter.
The physical identification frequency set in the updated drivers is based
on how it was done prior to the introduction of set_phys_id.
Compile tested only. Also fixes a compiler warning in sfc.
v2: drivers do not return -EINVAL for ETHOOL_ID_ACTIVE
v3: fold patchset into single patch and cleanup per Ben's feedback
Signed-off-by: Bruce Allan <bruce.w.allan@intel.com>
Cc: Ben Hutchings <bhutchings@solarflare.com>
Cc: Sathya Perla <sathya.perla@emulex.com>
Cc: Subbu Seetharaman <subbu.seetharaman@emulex.com>
Cc: Ajit Khaparde <ajit.khaparde@emulex.com>
Cc: Michael Chan <mchan@broadcom.com>
Cc: Eilon Greenstein <eilong@broadcom.com>
Cc: Divy Le Ray <divy@chelsio.com>
Cc: Don Fry <pcnet32@frontier.com>
Cc: Jon Mason <jdmason@kudzu.us>
Cc: Solarflare linux maintainers <linux-net-drivers@solarflare.com>
Cc: Steve Hodgson <shodgson@solarflare.com>
Cc: Stephen Hemminger <shemminger@linux-foundation.org>
Cc: Matt Carlson <mcarlson@broadcom.com>
Acked-by: Jon Mason <jdmason@kudzu.us>
Acked-by: Ben Hutchings <bhutchings@solarflare.com>
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
In this case, need to add element to device private to hold
original led state.
The correct usage should be "static inline void" instead of "static void inline"
Signed-off-by: G.Balaji <balajig81@gmail.com>
Update 5709 mips firmware to 6.2.1a to fix iSCSI performance
regression. There was an unnecessary context read in the fast path
affecting performance.
Update bnx2 to 2.1.6.
Add missing __rcu annotations and helpers.
minor : Fix some rcu_dereference() calls in macvtap
On PPC for example, AER is not supported and we see unnecessary AER
error message without this patch:
bnx2 0003:01:00.1: pci_cleanup_aer_uncorrect_error_status failed 0xfffffffb
Reported-by: Breno Leitao <leitao@linux.vnet.ibm.com>
TSO does not work if the VLAN tag is in the packet (non-accelerated).
We may be able to remove this restriction in future firmware.
Reported-by: Eric Dumazet <eric.dumazet@gmail.com>
Quoting Ben Hutchings: we presumably won't be defining features that
can only be enabled on 64-bit architectures.
Occurences found by `grep -r` on net/, drivers/net, include/
[ Move features and vlan_features next to each other in
struct netdev, as per Eric Dumazet's suggestion -DaveM ]
Update MIPS firmware to 6.2.1, with improved small packet performance
in RSS mode, and iSCSI CID allocation bug fix on 5708.
Update driver version to 2.0.21.
When changing ring size, we free all memory including status block
memory. If we're in INTA mode and sharing IRQ, the IRQ handler can
be called and it will reference the NULL status block pointer.
Because of the lockless design of the IRQ handler, there is no simple
way to synchronize and prevent this. So we avoid this problem by
freeing the IRQ handler before freeing the status block memory.
Michael pointed out that bnx2_close() already cancels bp->reset_task
and thus it is guaranteed to be idle when bnx2_remove_one() is called.
Remove the unnecessary cancel_work_sync() in remove_one.
Using static const generally increases object text and decreases data size.
It also generally decreases overall object size.
flush_scheduled_work() is on its way out. This patch contains simple
conversions to replace flush_scheduled_work() usage with direct
cancels and flushes.
Directly cancel the used works on driver detach and flush them in
other cases.
The conversions are mostly straight forward and the only dangers are,
* Forgetting to cancel/flush one or more used works.
* Cancelling when a work should be flushed (ie. the work must be
executed once scheduled whether the driver is detaching or not).
I've gone over the changes multiple times but it would be much
appreciated if you can review with the above points in mind.
Cc: Jay Cliburn <jcliburn@gmail.com>
Cc: e1000-devel@lists.sourceforge.net
Cc: Vasanthy Kolluri <vkolluri@cisco.com>
Cc: Samuel Ortiz <samuel@sortiz.org>
Cc: Lennert Buytenhek <buytenh@wantstofly.org>
Cc: Andrew Gallatin <gallatin@myri.com>
Cc: Francois Romieu <romieu@fr.zoreil.com>
Cc: Ramkrishna Vepa <ramkrishna.vepa@exar.com>
Cc: David Brownell <dbrownell@users.sourceforge.net>
Cc: Shreyas Bhatewara <sbhatewara@vmware.com>
Cc: netdev@vger.kernel.org
In KVM passthrough mode, the driver may not have config access to
non-standard registers. The BNX2_PCICFG_MISC_CONFIG config register
access to setup mailbox swapping can be done using MMIO.
Update version to 2.0.20.
The 5709 chip requires the BNX2_MISC_NEW_CORE_CTL_DMA_ENABLE bit to be
cleared and polling for pending DMAs to complete before chip reset.
Without this step, we've seen NMIs during repeated resets of the chip.
Signed-off-by: Eddie Wai <waie@broadcom.com>
Use vzalloc() and vzalloc_node() in net drivers
Acked-by: Jon Mason <jon.mason@exar.com>
Some cards don't support changing vlan offloading settings. Make
Ethtool set_flags return -EINVAL in those cases.
Reported-by: Ben Hutchings <bhutchings@solarflare.com>
Signed-off-by: Jesse Gross <jesse@nicira.com>
Make the bnx2 driver use the new vlan accleration model.
Many (but not all) drivers check to see whether there is a vlan
group configured before using a tag stored in the skb. There's
not much point in this check since it just throws away data that
should only be present in the expected circumstances. However,
it will soon be legal and expected to get a vlan tag when no
vlan group is configured, so remove this check from all drivers
to avoid dropping the tags.
To prevent unnecessary error message. pci_save_state() is also moved to
the end of ->probe() so that all PCI config, including AER state, will be
saved.
Update version to 2.0.18.
Reviewed-by: Benjamin Li <mchan@broadcom.com>
- Improved flow control and simplified interface
- Use hardware RSS indirection table instead of the slower firmware-
based table
- Lower latency interrupt on 5709
Reviewed-by: Benjamin Li <benli@broadcom.com>
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
Change "return (EXPR);" to "return EXPR;"
return is not a function, parentheses are not required.
fresh skbs have ip_summed set to CHECKSUM_NONE (0)
We can avoid setting again skb->ip_summed to CHECKSUM_NONE in drivers.
Introduce skb_checksum_none_assert() helper so that we keep this
assertion documented in driver sources.
Change most occurrences of :
skb->ip_summed = CHECKSUM_NONE;
by :
skb_checksum_none_assert(skb);
Signed-off-by: John Feeney <jfeeney@redhat.com>
Signed-off-by: Benjamin Li <benli@broadcom.com>
smp_mb() inside bnx2_tx_avail() is used twice in the normal
bnx2_start_xmit() path (see illustration below). The full memory
barrier is only necessary during race conditions with tx completion.
We can speed up the tx path by replacing smp_mb() in bnx2_tx_avail()
with a compiler barrier. The compiler barrier is to force the
compiler to fetch the tx_prod and tx_cons from memory.
In the race condition between bnx2_start_xmit() and bnx2_tx_int(),
we have the following situation:
bnx2_start_xmit() bnx2_tx_int()
if (!bnx2_tx_avail())
BUG();
netif_tx_stop_queue(); update_tx_index();
smp_mb(); smp_mb();
if (bnx2_tx_avail()) if (netif_tx_queue_stopped() &&
netif_tx_wake_queue(); bnx2_tx_avail())
With smp_mb() removed from bnx2_tx_avail(), we need to add smp_mb() to
bnx2_start_xmit() as shown above to properly order netif_tx_stop_queue()
and bnx2_tx_avail() to check the ring index. If it is not strictly
ordered, the tx queue can be stopped forever.
This improves performance by about 5% with 2 ports running bi-directional
64-byte packets.
Reviewed-by: Matt Carlson <mcarlson@broadcom.com>
Based on original patch by Breno Leitão <leitao@linux.vnet.ibm.com>.
Allocate the actual number of vectors and make use of fewer vectors
if pci_enable_msix() returns > 0. We must allocate one additional
vector for the cnic driver.
Cc: Breno Leitão <leitao@linux.vnet.ibm.com>
We were using the wrong tx multicast counter instead of the rx multicast
counter.
Reported-by: Peter Snellman <peter.snellman@cinnober.com>
Use DMA API as PCI equivalents will be deprecated. This change also allow
to allocate with GFP_KERNEL in some places.
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
Now core network is able to handle 64 bit netdevice stats on 32 bit
arches, we can provide them for bnx2, since hardware maintains some 64
bit counters.
These config register values will be useful when the memory registers
are returning 0xffffffff which has been reported.
Add skb->rxhash support for TCP packets only because the bnx2 RSS hash
does not hash UDP ports.
Minor change to use MSI-X even if there is only one CPU. This allows
the CNIC driver to always have a dedicated MSI-X vector to handle
iSCSI events, instead of sharing the MSI vector.
net/ipv4/ip_output.c
This removes dma_get_ops() prefetch optimization in bnx2.
bnx2 uses dma_get_ops() to see if dma_sync_single_for_cpu() is
noop. bnx2 does prefetch if it's noop.
But dma_get_ops() isn't available on all the architectures (only the
architectures that uses dma_map_ops struct have it). Using
dma_get_ops() in drivers leads to compilation breakage on many
architectures.
This patch removes dma_get_ops() and changes bnx2 to do prefetch on
all the architectures. This adds useless prefetch on non-coherent
architectures but this is harmless. It is also unlikely to cause the
performance drop.
[ Remove now unused local variable 'pdev' -DaveM ]
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
drivers/net/bnx2.c: In function 'bnx2_disable_forced_2g5':
drivers/net/bnx2.c:1489: warning: 'bmcr' may be used uninitialized in this function
We fix it by checking return values from all bnx2_read_phy() and proceeding
to do read-modify-write only if the read operation is successful.
The related bnx2_enable_forced_2g5() is also fixed the same way.
Reported-by: Prarit Bhargava <prarit@redhat.com>
The regression is caused by:
commit 4327ba435a56ada13eedf3eb332e583c7a0586a9
bnx2: Fix netpoll crash.
If ->open() and ->close() are called multiple times, the same napi structs
will be added to dev->napi_list multiple times, corrupting the dev->napi_list.
This causes free_netdev() to hang during rmmod.
We fix this by calling netif_napi_del() during ->close().
Also, bnx2_init_napi() must not be in the __devinit section since it is
called by ->open().
Based on original patch from Stanislaw Gruszka <sgruszka@redhat.com>.
Using netif_carrier_off() is better than updating all the ->trans_start
on all the tx queues.
netif_carrier_off() needs to be called after bnx2_disable_int_sync()
to guarantee no race conditions with the serdes timers that can
modify the carrier state.
If the chip or phy is reset, carrier will turn back on when we get the
link interrupt. If there is no reset, we need to turn carrier back on
in bnx2_netif_start(). Again, the phy_lock prevents race conditions with
the serdes timers.
Signed-off-by: Matt Carlson <mcarlson@broadcom.com>
