Fix the parity errors recovery flow for 578xx:
- Add a separate column for the 578xx in the parity mask
registers DB.
- Fix the bnx2x_process_kill_chip_reset() to handle the blocks
newly introduced in the 578xx.
Cover ATC and PGLUE_B blocks for 57712 and 578xx.
Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com>
Signed-off-by: Eilon Greenstein <eilong@broadcom.com>
Overview:
Support mapping of priorities to traffic classes and
traffic classes to transmission queues ranges in the net device.
The queue ranges are (count, offset) pairs relating to the txq
array.
This can be done via DCBX negotiation or by kernel.
As a result Enhanced Transmission Selection (ETS) and Priority Flow
Control (PFC) are supported between L2 network traffic classes.
Mapping:
This patch uses the netdev_set_num_tc, netdev_set_prio_tc_map and
netdev_set_tc_queue functions to map priorities to traffic classes
and traffic classes to transmission queue ranges.
This mapping is performed by bnx2x_setup_tc function which is
connected to the ndo_setup_tc.
This function is always called at nic load where by default it
maps all priorities to tc 0, and it may also be called by the
kernel or by the bnx2x upon DCBX negotiation to modify the mapping.
rtnl lock:
When the ndo_setup_tc is called at nic load or by kernel the rtnl
lock is already taken. However, when DCBX negotiation takes place
the lock is not taken. The work is therefore scheduled to be
handled by the sp_rtnl task.
Fastpath:
The fastpath structure of the bnx2x which was previously used
to hold the information of one tx queue and one rx queue was
redesigned to represent multiple tx queues, one for each traffic
class.
The transmission queue supplied in the skb by the kernel can no
longer be interpreted as a straightforward index into the fastpath
structure array, but it must rather be decoded to the appropriate
fastpath index and the tc within that fastpath.
Slowpath:
The bnx2x's queue object was redesigned to accommodate multiple
transmission queues. The queue object's state machine was enhanced
to allow opening multiple transmission-only connections on top of
the regular tx-rx connection.
Firmware:
This feature relies on the tx-only queue feature introduced in the
bnx2x 7.0.23 firmware and the FW likewise must have the bnx2x multi
cos support.
Signed-off-by: Ariel Elior <ariele@broadcom.com>
- Added support for a parity error handling for a 57712 chip.
- Changed the parity recovery scheme from per-chip to per-engine.
Signed-off-by: David S. Miller <davem@conan.davemloft.net>
New FW/HSI (7.0):
- Added support to 578xx chips
- Improved HSI - much less driver's direct access to the FW internal
memory needed.
New implementation of the HSI handling layer in the bnx2x (bnx2x_sp.c):
- Introduced chip dependent objects that have chip independent interfaces
for configuration of MACs, multicast addresses, Rx mode, indirection table,
fast path queues and function initialization/cleanup.
- Objects functionality is based on the private function pointers, which
allows not only a per-chip but also PF/VF differentiation while still
preserving the same interface towards the driver.
- Objects interface is not influenced by the HSI changes which do not require
providing new parameters keeping the code outside the bnx2x_sp.c invariant
with regard to such HSI chnages.
Changes in a CNIC, bnx2fc and bnx2i modules due to the new HSI.
Signed-off-by: Michael Chan <mchan@broadcom.com>
Signed-off-by: Bhanu Prakash Gollapudi <bprakash@broadcom.com>
Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com>
Fixes in registers dump:
- Properly calculate dump length for 57712.
- Prevent HW blocks parity attentions when dumping registers in order to
prevent false parity errors handling.
- Update the bnx2x_dump.h file: old one had a few bugs that could cause
fatal HW error as a result of a registers dump.
57712 HW supported with same set of features as for 57710/57711
This is the new FW HSI blob and the relevant definitions without logic changes.
It also included code adaptation for new HSI. New features are not enabled.
New FW/HSI includes:
- Support for 57712 HW
- Future support for VF (not used)
- Improvements in FW interrupts scheme
- FW FCoE hooks (stubs for future usage)
This commit includes files movement to newly created folder
using git-mv command and fixes references in cnic and bnx2x code
to each other.
files moved using following:
#!/bin/bash
mkdir drivers/net/bnx2x/
list=$(cd drivers/net/ && ls bnx2x*.[ch])
for f in $list; do
git mv -f drivers/net/$f drivers/net/bnx2x/$f
done
