Fix 1G link LED for the BCM578xx-SFI/KR.
Signed-off-by: Yaniv Rosner <yanivr@broadcom.com>
Signed-off-by: Eilon Greenstein <eilong@broadcom.com>
Change XMAC loopback type from CORE LOCAL to LINE LOCAL for the BCM578xx due to intermittent problem with the loopback with this configuration.
Remove remote fault detection as a tactic retreat due to link issues involved with it.
Once issue is resolved, this feature will be restored again.
Enable FEC(Forward Error Correction) for 57810-KR to reduce link errors.
ETS bandwidth of 0% is not allowed by driver, so provide alternative HW configuration for this case.
After resetting BCM54618se, link partner would still see link since the PHY wasn't put into low-power state.
BCM84833 fail to link due to incorrect auto-negotiation setting.
Fix no-link issue on BCM578xx when direct attached cable is connected since Warpcore microcode restart was missing to re-read the new mode.
This fix resolve two problems seen regarding LED:
1. LED doesn't flash during port identification.
2. Traffic LED sometimes do not blink.
Fix MDIO access to Warpcore on new chip version of 578xx.
Fix couple of issues of remote fault detection and handling:
Link may go down due to remote fault indications during link establishment.
Possible link down after primary function migration.
Remote fault was not detected on 578xx.
Fix a problem in which the 578xx chip hangs after running traffic, and then pulling the network cable.
This occurs since TX pipe is stalled due to missing XON indication towards the NIG.
When link speed is 1G and below, pause weren't sent due to missing pause setting in the UMAC.
Clear warning message "MDC/MDIO access timeout" during first driver load by setting MDIO clock.
This warning has no significant meaning, since it occurs prior to the first PHY initialization.
Add autogrEEEn support on BCM84833 and 54618se, which allows to reduce power consumption.
When driver is unloaded, disable PMD in addition to TX laser, provided that the management firmware will be able to enable it back.
Add hardware PHY reset action for BCM578xx when fan failure occur.
The new bnx2x_warpcore_hw_reset warps bnx2x_warpcore_power_module to fit the .hw_reset function template of the phy structure.
Add CL37 BAM support according to configuration.
Change 1G copper PHY BCM54616S to BCM54618SE since we only have HW with latter one of the two.
Set the source MAC address for PFC packets and update its status during PMF migration.
Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com>
Signed-off-by: David S. Miller <davem@conan.davemloft.net>
New FW/HSI (7.0):
- Added support to 578xx chips
- Improved HSI - much less driver's direct access to the FW internal
memory needed.
New implementation of the HSI handling layer in the bnx2x (bnx2x_sp.c):
- Introduced chip dependent objects that have chip independent interfaces
for configuration of MACs, multicast addresses, Rx mode, indirection table,
fast path queues and function initialization/cleanup.
- Objects functionality is based on the private function pointers, which
allows not only a per-chip but also PF/VF differentiation while still
preserving the same interface towards the driver.
- Objects interface is not influenced by the HSI changes which do not require
providing new parameters keeping the code outside the bnx2x_sp.c invariant
with regard to such HSI chnages.
Changes in a CNIC, bnx2fc and bnx2i modules due to the new HSI.
Signed-off-by: Michael Chan <mchan@broadcom.com>
Signed-off-by: Bhanu Prakash Gollapudi <bprakash@broadcom.com>
Instead of setting CL45 mode for every CL45 access, apply it once during initialization.
Modify XGXS functions to follow rest of PHY scheme.
Fix link status synchronization between the primary function, and rest functions.
Move BCM8726 module detection code into a separate function to be called only once during initialization.
This patch relocates some functions as a preparation for next patches, and also fixes some grammar mistakes.
Fix BCM84833 register settings.
On 57712 chip, port number is enumerated per engine, so it requires adjustment in port display to the user.
In case TX fault is detected on Fiber PHYs, declare the link as down until TX fault is gone.
Change return status from u8 to int.
Display the current media type connected to the port in ethtool.
Add support for new phy BCM8722.
Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com>
Remove unneeded support for emulation/FPGA from the code
Add CMS(Common Mode Sense) functionality for 848x3 as this reduces power consumption and allows a better 10G link stability
Add support for new PHY BCM84833. This PHY is very similar to the BCM84823, only it has different register offset compared to the BCM84823, which needs to be handled correctly.
Add flexible support to control various SFP+ module features either throughout MDIO registers or GPIO pins according to NVRAM configuration
Add and modify some net dev prints to improve error control
Fix annoying compilation warning, mainly related to static declarations
