Since we have a struct that defines the sizes of the registers, we don't
need to explicitly use the 16bit read/write helpers. Let the code figure
out which size access to make based on the size of the C type.
There should be no functional changes here.
Acked-by: Wolfgang Grandegger <wg@grandegger.com>
If we look closely, the 4 writes to TRANSMIT_CHL.id1 can be collapsed
down into much simpler code. So do just that.
This also fixes a build failure due to the I/O macros no longer
getting pulled in. Their minor (and accidental) usage here gets
dropped as part of the unification.
Acked-by: Kurt Van Dijck <kurt.van.dijck@eia.be>
Now that core network takes care of trans_start updates, dont do it
in drivers themselves, if possible. Drivers can avoid one cache miss
(on dev->trans_start) in their start_xmit() handler.
Exceptions are NETIF_F_LLTX drivers
In the current implementation, CAN drivers need to #include <linux/can.h>
_before_ they #include <linux/can/dev.h>, which is both ugly and
unnecessary.
Fix this by including <linux/can.h> in <linux/can/dev.h> and remove the
#include <linux/can.h> lines from drivers.
Signed-off-by: Hans J. Koch <hjk@linutronix.de>
The MMR bits are being moved to this header, so include it.
Looks like commit a6e4bc530403 didn't include updates to drivers so the
Blackfin CAN driver fails to build now.
Signed-off-by: Barry Song <barry.song@analog.com>
This patch adds error checking of ctrlmode values for CAN devices. As
an example all availabe bits are implemented in the mcp251x driver.
Signed-off-by: Christian Pellegrin <chripell@fsfe.org>
To prevent the CAN drivers to operate on invalid socketbuffers the skbs are
now checked and silently dropped at the xmit-function consistently.
Also the netdev stats are consistently using the CAN data length code (dlc)
for [rx|tx]_bytes now.
Signed-off-by: Oliver Hartkopp <oliver@hartkopp.net>
A valid CAN dataframe can have a data length code (DLC) of 0 .. 8 data bytes.
When reading the CAN controllers register the 4-bit value may contain values
from 0 .. 15 which may exceed the reserved space in the socket buffer!
The ISO 11898-1 Chapter 8.4.2.3 (DLC field) says that register values > 8
should be reduced to 8 without any error reporting or frame drop.
This patch introduces a new helper macro to cast a given 4-bit data length
code (dlc) to __u8 and ensure the DLC value to be max. 8 bytes.
The different handlings in the rx path of the CAN netdevice drivers are fixed.
Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
Signed-off-by: Barry Song <21cnbao@gmail.com>
Signed-off-by: H.J. Oertel <oe@port.de>
Signed-off-by: Wolfgang Grandegger <wg@grandegger.de>
