Once the CAN-bus is open and a packet is sent, the controller switches
into the PASSIVE state. Once the BUS is closed again it goes the back
err-warning. The TX error counter goes 0 -> 0x80 -> 0x7f.
This patch makes sure that the user learns about this state chang
(CAN_STATE_ERROR_WARNING => CAN_STATE_ERROR_PASSIVE)
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Signed-off-by: Matthias Klein <matthias.klein@optimeas.de>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
In case we don't have FLEXCAN_HAS_BROKEN_ERR_STATE and the user set
CAN_CTRLMODE_BERR_REPORTING once it can not be unset again until reboot.
So in case neither hardware nor user wants the error interrupt disable
the bit.
Signed-off-by: Alexander Stein <alexander.stein@systec-electronic.com>
CAN interfaces only support MTU values of 16 (CAN 2.0) and 72 (CAN FD).
Setting the MTU to other values is pointless but it does not really hurt.
With the introduction of the CAN FD support in drivers/net/can a new
function to switch the MTU for CAN FD has been introduced.
This patch makes use of this can_change_mtu() function to check for correct
MTU settings also in legacy CAN (2.0) devices.
Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net>
This patch replaces an open coded pdev->id_entry by platform_get_device_id().
This patch removes #ifdef CONFIG_PM_SLEEP to improve compile coverage.
This patch moves the soft reset into a seperate function.
This patch adds the missing netif_napi_del() to the flexcan_remove() function.
Cc: linux-stable <stable@vger.kernel.org>
This patch factors out freeze and unfreeze of the CAN core into seperate
functions. Experiments have shown that the transition from and to freeze mode
may take several microseconds, especially the time entering the freeze mode
depends on the current bitrate.
This patch adds a while loop which polls the Freeze Mode ACK bit (FRZ_ACK) that
indicates a successfull mode change. If the function runs into a timeout a
error value is returned.
This patch moves the transceiver enable and disable into seperate functions,
where the NULL pointer check is hidden.
In flexcan_chip_enable() and flexcan_chip_disable() fixed delays are used.
Experiments have shown that the transition from and to low power mode may take
several microseconds.
This patch adds a while loop which polls the Low Power Mode ACK bit (LPM_ACK)
that indicates a successfull mode change. If the function runs into a timeout a
If flexcan_chip_start() in flexcan_open() fails, the interrupt is not freed,
this patch adds the missing cleanup.
When shutting down the CAN interface (ifconfig canX down) during high CAN bus
loads, the CAN core might hang and freeze the whole CPU.
This patch fixes the shutdown sequence by first disabling the CAN core then
disabling all interrupts.
endian on PowerPc
There is no reason to disallow building the driver on big-endian ARM kernels.
Furthermore, the current behavior is actually broken on little-endian PowerPC
as well.
The choice of register accessor functions must purely depend on the CPU
architecture, not which endianess the CPU is running on. Note that we nowadays
allow both big-endian ARM and little-endian PowerPC kernels.
With this patch applied, we will do the right thing in all four combinations.
Cc: Lothar Waßmann <LW@KARO-electronics.de>
The flexcan IP core uses the peripheral clock ("per") as basic clock for the
bit timing calculation. However the driver uses the the wrong clock ("ipg").
This leads to wrong bit rates if the rates on both clock are different.
This patch fixes the problem by using the correct clock for the bit rate
calculation.
drivers/net/usb/qmi_wwan.c
include/net/dst.h
Trivial merge conflicts, both were overlapping changes.
The current implemetation of of_match_device() relies that the of_device_id
table in the driver is sorted from most specific to least specific compatible.
Without this patch the mx28 is detected as the less specific p1010. This leads
to a p1010 specific workaround is activated on the mx28, which is not needed.
abort pending TX
In patch
0d1862e can: flexcan: fix flexcan_chip_start() on imx6
the loop in flexcan_chip_start() that iterates over all mailboxes after the
soft reset of the CAN core was removed. This loop put all mailboxes (even the
ones marked as reserved 1...7) into EMPTY/INACTIVE mode. On mailboxes 8...63,
this aborts any pending TX messages.
After a cold boot there is random garbage in the mailboxes, which leads to
spontaneous transmit of CAN frames during first activation. Further if the
interface was disabled with a pending message (usually due to an error
condition on the CAN bus), this message is retransmitted after enabling the
interface again.
This patch fixes the regression by:
1) Limiting the maximum number of used mailboxes to 8, 0...7 are used by the RX
FIFO, 8 is used by TX.
2) Marking the TX mailbox as EMPTY/INACTIVE, so that any pending TX of that
mailbox is aborted.
drivers/net/ethernet/emulex/benet/be.h
drivers/net/wireless/brcm80211/brcmfmac/dhd_bus.h
include/net/netfilter/nf_conntrack_synproxy.h
include/net/secure_seq.h
The conflicts are of two varieties:
1) Conflicts with Joe Perches's 'extern' removal from header file
function declarations. Usually it's an argument signature change
or a function being added/removed. The resolutions are trivial.
2) Some overlapping changes in qmi_wwan.c and be.h, one commit adds
a new value, another changes an existing value. That sort of
thing.
In the flexcan_chip_start() function first the flexcan core is going through
the soft reset sequence, then the RX FIFO is enabled.
With the hardware is put into FIFO mode, message buffers 1...7 are reserved by
the FIFO engine. The remaining message buffers are in reset default values.
This patch removes the bogus initialization of the message buffers, as it
causes an imprecise external abort on imx6.
Reported-by: Lothar Waßmann <LW@KARO-electronics.de>
Tested-by: Lothar Waßmann <LW@KARO-electronics.de>
Use the wrapper function for retrieving the platform data instead of
accessing dev->platform_data directly. This is a cosmetic change
to make the code simpler and enhance the readability.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Use the wrapper functions for getting and setting the driver data using
platform_device instead of using dev_set_drvdata() with &pdev->dev,
so we can directly pass a struct platform_device.
Signed-off-by: Libo Chen <libo.chen@huawei.com>
clk_prepare_enable() may fail, so let's check its return value and propagate it
in the case of error.
Using devm_ioremap_resource() can make the code simpler and smaller.
Also, place alloc_candev() after of_match_device() to make error handling
easier.
Instead of using a GPIO to turn on/off the CAN transceiver, it is better to
use a regulator as some systems may use a PMIC to power the CAN transceiver.
Acked-by: Shawn Guo <shawn.guo@linaro.org>
Using SIMPLE_DEV_PM_OPS can make the code smaller and simpler.
Also change CONFIG_PM to CONFIG_PM_SLEEP.
Since commit ab78029 (drivers/pinctrl: grab default handles from device core)
we can rely on device core for handling pinctrl, so remove
devm_pinctrl_get_select_default() from the driver.
Cc: Marc Kleine-Budde <mkl@pengutronix.de>
Cc: <linux-can@vger.kernel.org>
The driver core clears the driver data to NULL after device_release
or on probe failure, since commit 0998d0631001288a5974afc0b2a5f568bcdecb4d
(device-core: Ensure drvdata = NULL when no driver is bound).
Thus, it is not needed to manually clear the device driver data to NULL.
Add support for canbus activity led indicators on flexcan devices by
calling appropriate can_led_* functions.
These are only enabled when CONFIG_CAN_LEDS is Y, becomes no-op
otherwise.
Cc: Oliver Hartkopp <socketcan@hartkopp.net>
Cc: Wolfgang Grandegger <wg@grandegger.com>
Signed-off-by: Fabio Baltieri <fabio.baltieri@gmail.com>
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Cc: linux-can@vger.kernel.org
This patch adds a MODULE_DEVICE_TABLE for the of and platform bindings, so that
the module can be loaded automatically by udev.
This patch adds some Flexcan version info and removes the feature flag
FLEXCAN_HAS_BROKEN_ERR_STATE for the i.MX6Q. It also has the line [TR]WRN_INT
properly connected.
Cc: Hui Wang <jason77.wang@gmail.com>
Cc: Shawn Guo <shawn.guo@linaro.org>
Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
[mkl: convert to incremental patch]
Due to a bug in most Flexcan cores, the bus error interrupt needs
to be enabled. Otherwise we don't get any error warning or passive
interrupts. This is _not_ necessary for the i.MX28 and this patch
disables bus error interrupts if "berr-reporting" is not requested.
This avoids bus error flooding, which might harm, especially on
low-end systems.
To handle such quirks of the Flexcan cores, a hardware feature flag
has been introduced, also replacing the "hw_ver" variable. So far
nobody could tell what Flexcan core version is available on what
Freescale SOC, apart from the i.MX6Q and P1010, and which bugs or
features are present on the various "hw_rev".
CC: Hui Wang <jason77.wang@gmail.com>
CC: Shawn Guo <shawn.guo@linaro.org>
This patch adds support for a second clock to the flexcan driver. On
modern freescale ARM cores like the imx53 and imx6q two clocks ("ipg"
and "per") must be enabled in order to access the CAN core.
In the original driver, the clock was requested without specifying the
connection id, further all mainline ARM archs with flexcan support
(imx28, imx25, imx35) register their flexcan clock without a
connection id, too.
This patch first renames the existing clk variable to clk_ipg and
converts it to devm for easier error handling. The connection id "ipg"
is added to the devm_clk_get() call. Then a second clock "per" is
requested. As all archs don't specify a connection id, both clk_get
return the same clock. This ensures compatibility to existing flexcan
support and adds support for imx53 at the same time.
After this patch hits mainline, the archs may give their existing
flexcan clock the "ipg" connection id and implement a dummy "per"
clock.
This patch has been tested on imx28 (unmodified clk tree) and on imx53
with a seperate "ipg" and "per" clock.
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Signed-off-by: Steffen Trumtrar <s.trumtrar@pengutronix.de>
Acked-by: Hui Wang <jason77.wang@gmail.com>
This patch marks the bittiming_const pointer as in the struct can_pric as
"const". This allows us to mark the struct can_bittiming_const in the CAN
drivers as "const", too.
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
At least in the i.MX series, the flexcan contrller divides into ver_3
and ver_10, current driver is for ver_3 controller.
i.MX6 has ver_10 controller, it has more reigsters than ver_3 has.
The rxfgmask (Rx FIFO Global Mask) register is one of the new added.
Its reset value is 0xffffffff, this means ID Filter Table must be
checked when receive a packet, but the driver is designed to accept
everything during the chip start, we need to clear this register to
follow this design.
Use the data entry of the struct of_device_id to point chip specific
info, we can set hardware version for each platform.
Signed-off-by: Hui Wang <jason77.wang@gmail.com>
[mkl: add id_table support]
Tested-by: Hui Wang <jason77.wang@gmail.com>
of_property_read_u32() can auto handle endian problems, use this
function can make code clean and simple.
No need to check return value here since the following got value
check will handle this.
drivers/net/caif/caif_hsi.c
The qmi_wwan merge was trivial.
The caif_hsi.c, on the other hand, was not. It's a conflict between
1c385f1fdf6f9c66d982802cd74349c040980b50 ("caif-hsi: Replace platform
device with ops structure.") in the net-next tree and commit
39abbaef19cd0a30be93794aa4773c779c3eb1f3 ("caif-hsi: Postpone init of
HIS until open()") in the net tree.
I did my best with that one and will ask Sjur to check it out.
The freescale arm i.MX series platform can support this driver, and
usually the arm cpu works in the little endian mode by default, while
device tree entry value is stored in big endian format, we should use
be32_to_cpup() to handle them, after modification, it can work well
both on the le cpu and be cpu.
Cc: stable <stable@vger.kernel.org> # v3.2+
tested on an i.MX257
Signed-off-by: Eric Bénard <eric@eukrea.com>
Acked-by: Marc Kleine-Budde <mkl@pengutronix.de>
Acked-by: Dong Aisheng <dong.aisheng@linaro.org>
drivers/net/can/usb/ems_usb.c
Minor dev_warn --> netdev_warn conversion conflicts.
Cc: uclinux-dist-devel@blackfin.uclinux.org
Cc: Anant Gole <anantgole@ti.com>
Cc: Chris Elston <celston@katalix.com>
Cc: Sebastian Haas <haas@ems-wuensche.com>
Cc: Matthias Fuchs <matthias.fuchs@esd.eu>
Acked-by: Sebastian Haas <dev@sebastianhaas.info>
Currently the flexcan driver uses hardware local echo. This blindly
echos all transmitted frames to all receiving sockets, regardless what
CAN_RAW_RECV_OWN_MSGS and CAN_RAW_LOOPBACK are set to.
This patch now submits transmitted frames to be echoed in the transmit
complete interrupt, preserving the reference to the sending
socket. This allows the can protocol to correctly handle the local
echo.
Further this patch moves tx_bytes statistic accounting into the tx_complete
handler.
Signed-off-by: Reuben Dowle <reuben.dowle@navico.com>
[mkl: move tx_bytes accounting into tx_complete handler; cleanups]
As pointed out by Reuben Dowle and Lothar Waßmann, the TWRN_INT,
RWRN_INT, BOFF_INT interrupt sources need to be cleared as well
to avoid interrupt flooding, at least for the Flexcan on i.MX28
SOCs. Furthermore, the interrupts are only cleared, if really one
of those interrupt sources are pending (which is not the case for
rx and tx done).
Cc: Reuben Dowle <Reuben.Dowle@navico.com>
clock management changes for i.MX
Another simple series related to clock management, this time only for
imx.
* tag 'clk' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: mxs: select HAVE_CLK_PREPARE for clock
clk: add config option HAVE_CLK_PREPARE into Kconfig
ASoC: mxs-saif: convert to clk_prepare/clk_unprepare
video: mxsfb: convert to clk_prepare/clk_unprepare
serial: mxs-auart: convert to clk_prepare/clk_unprepare
net: flexcan: convert to clk_prepare/clk_unprepare
mtd: gpmi-lib: convert to clk_prepare/clk_unprepare
mmc: mxs-mmc: convert to clk_prepare/clk_unprepare
dma: mxs-dma: convert to clk_prepare/clk_unprepare
net: fec: add clk_prepare/clk_unprepare
ARM: mxs: convert platform code to clk_prepare/clk_unprepare
clk: add helper functions clk_prepare_enable and clk_disable_unprepare
Fix up trivial conflicts in drivers/net/ethernet/freescale/fec.c due to
commit 0ebafefcaa7a ("net: fec: add clk_prepare/clk_unprepare") clashing
trivially with commit e163cc97f9ac ("net/fec: fix the .remove code").
The patch converts flexcan driver to clk_prepare/clk_unprepare by
using helper functions clk_prepare_enable/clk_disable_unprepare.
This patch converts the drivers in drivers/net/can/* to use the
module_platform_driver() macro which makes the code smaller and a bit
simpler.
Cc: Bhupesh Sharma <bhupesh.sharma@st.com>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Paul Bolle <pebolle@tiscali.nl>
Cc: Kurt Van Dijck <kurt.van.dijck@eia.be>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
If our CAN device's device tree node has a clock-frequency property,
then use that value for the can devices clock frequency. If not, fall
back to asking the platform/mach code for the clock frequency associated
with the flexcan device.
Signed-off-by: Robin Holt <holt@sgi.com>
Acked-by: Wolfgang Grandegger <wg@grandegger.com>,
Cc: Kumar Gala <galak@kernel.crashing.org>
Cc: Marc Kleine-Budde <mkl@pengutronix.de>,
Cc: U Bhaskar-B22300 <B22300@freescale.com>
Cc: Scott Wood <scottwood@freescale.com>
Cc: socketcan-core@lists.berlios.de,
Cc: netdev@vger.kernel.org,
Cc: PPC list <linuxppc-dev@lists.ozlabs.org>
Cc: devicetree-discuss@lists.ozlabs.org
